I am running Robohelp 10 and producing Multiscreen HTML 5 output as well as .chm. I am not a web developer but would like to add a topic which allows users to give feedback about the help file. Does anyone have sample HTML code I can use?
I used the code from a previous forum post to add a link at the bottom of each page (see below) but would like a separate form where I can ask specific questions and encourage more feedback.
<!-- .js file code starts here-->
//alert("made it into script");
// Get just the page name
var str = location.href.toString();
//var arr = str.split("::/");
var htm_page = str;
var mailSubject = 'Sage Intelligence Reporting Help File Feedback - ' + htm_page;
var mailBody = '[Type your comments here] \n\n\n\nMy comments apply to this page: ' + location.href;
var mailDisplay = 'Send Feedback on this Topic';
document.write('<a href="#">Back to Top</a> | <a href="mailto:<me@mycompany.com>' + '?subject=' + escape(mailSubject) + '&body=' + escape(mailBody) + '">' + mailDisplay + '</a>');
<!-- .js file code ends here-->
You might want to get in touch with Willam van Weelden (wvanweelden.eu) about doing this.
What do you want the form to do? You can create a separate topic and create a form using RoboHelp. By default the form will simply use the client’s email to send the results to you. (And may inform the user of that with a dialog before sending.)
IF you want a form that submits the results from the server (the user doesn’t have to do anything in this case), you will need a server side script to process the form and send the results.
Greet,
Willam
