1. Re: Which File Format works best in Premiere?
Steve Grisetti Sep 18, 2012 10:23 AM (in response to ohwell1234)You can load the DVD files as is into a project, if, when you start your project, you set the project up for Hard Disk Camcorder Standard Definition video.
You'll need to render often as you work. (Press Enter whenever your see red lines above your clips on the timeline.) But your results should be virtually as good as the original.
If you know what you're doing, you can try converting the VOBs to DV files -- but they MUST be true DV files. Not any AVI or MOV files will do. Then you can use the standard DV project set-up and you won't need to render your work so often.
2. Re: Which File Format works best in Premiere?
John T Smith Sep 18, 2012 10:55 AM (in response to ohwell1234)Since you are new, I will ask... do you know that a VOB has had "about" 2/3 (give or take) of the original information removed?
DV AVI is about 13Gig per hour of video... for that 13gig (or more) of video to fit on a 4+Gig DVD, the original video is HIGHLY compressed, which means much of the original information is gone forever
Converting back to a more easily edited format is a compromise... do as Steve says, and edit your VOB
More on editing a compressed file http://tangentsoft.net/video/mpeg/edit.html
And specific to VOB
Read Bill Hunt on editing a VOB/MPG file http://forums.adobe.com/thread/464549
Edit Vob http://premierepro.wikia.com/wiki/FAQ:How_do_I_import_VOB_files_/_edit_a_DVD%3F
3. Re: Which File Format works best in Premiere?
Bill Hunt Sep 18, 2012 12:35 PM (in response to ohwell1234)As has been mentioned, the MPEG-2 DVD files, wrapped into the VOB "containers, have already been highly-compressed. That is the nature of a DVD-Video. Nothing can be done to undo that compression, and return any of the quality.
PrE will let you Import the VOB files,* and edit them natively. However, if you are then going to Export/Share to a compressed format, say out to an edited DVD-Video, then there WILL be additional compression, and a loss in data.
Good luck,
Hunt
* PrE will Import and edit VOB's, that are 100% DVD-compatible. However, if they are NOT 100% DVD-compatible, then the only recourse is to rip/convert the MPEG-2 DVD files in the VOB's, to Import and edit. In that case, I would recommend DV-AVI Type II files w/ 48KHz 16-bit PCM/WAV Audio, using the MS DV/DVC CODEC.
Unfortunately, most DVR machines, and a lot of DVD-Video authoring software, do NOT produce 100% DVD-compliant files, and usually the first VOB (contains Menus and navigation, plus the first part of the MPEG-2 DVD file, that can span several VOB's) will NOT Import properly, while the second, plus any more, will usually work fine. It might be that you will only have to rip/convert the first VOB, but some software just does a bad job of authoring, so one would have to rip/convert all VOB's.
4. Re: Which File Format works best in Premiere?
ohwell1234 Sep 18, 2012 1:49 PM (in response to Bill Hunt)Many thankseveryone - A great help. But going back a step, I initially copied from tapes to my old DVD hard-drive and then created DVDs from them. The only output option was VOB. Is there maybe a better way to digfitalise the original tapes?
5. Re: Which File Format works best in Premiere?
John T Smith Sep 18, 2012 2:08 PM (in response to ohwell1234)>copied from tapes to my old DVD hard-drive
A hard drive and a DVD are not at all the same... so please provide details about what you did
The best way to be able to edit is by using a product from http://www.grassvalley.com/products/converters
The ADVC55 is one way from tape to computer, the model 110 (more $) is two way so you may write back to tape
Both the 55 and 110 will convert your analog tapes to digital format... DV AVI type 2 which is at good as it gets for editing SD video
Added
By "DVD hard-drive" do you mean a non-computer DVD recorder?
If you played your tapes into a "box" with a hard drive and a DVD writer, go back and read what Hunt had to say... your VOB files may not be 100% editable
6. Re: Which File Format works best in Premiere?
Bill Hunt Sep 18, 2012 3:13 PM (in response to ohwell1234)For digitizing an analog source, this article might be useful: http://forums.adobe.com/thread/615047?tstart=60
7. Re: Which File Format works best in Premiere?
ohwell1234 Sep 19, 2012 10:03 AM (in response to John T Smith)Thanks John.
I used a DVD player's harddrive to convert initially.
Not sure how much the ADVC-55 costs in the US but it is ca $300 in Europe and $200 in the UK.! And nothing second hand available.
8. Re: Which File Format works best in Premiere?
ohwell1234 Sep 19, 2012 10:07 AM (in response to Bill Hunt)Thanks. I followed the link and it ended up recommending WinFF but I cannot establish whether the files created are AVI or DV AVI. Can you help? I found another recommendation for VirtualDubMod which clearly states that the output is the latter.
best regards
9. Re: Which File Format works best in Premiere?
John T Smith Sep 19, 2012 10:10 AM (in response to ohwell1234)>used a DVD player's harddrive to convert
Well, as Hunt said in #3, you may or may not be able to edit those files
If your files do not edit, you will need to convert to a format that will edit
Convert SD (Standard Definition) files to DV-AVI Type II with 48KHz 16-bit Audio
I have NOT used the products below, I only forward due to other mentions... so YMMV and all the usual disclaimers... check the links and read to find out if one of the products listed below will rip or convert the files you have to something you need for editing
http://www.corel.com/servlet/Satellite/us/en/Product/1175714228541#tabview=tab0
http://www.womble.com/products/mvw.html
http://www.magix.com/us/movie-edit-pro/ plus $5 Ship
http://www.nchsoftware.com/prism/index.html
http://www.videoredo.com/en/index.htm
http://www.daniusoft.com/media-converter-ultimate.html
http://www.deskshare.com/media-converter.aspx Digital Media Converter
http://www.any-dvd-ripper.com/any-dvd-ripper-windows.html
http://www.deskshare.com/dvd-ripping-software.aspx
http://www.dvdcopysoftware-reviews.com/dvd-cloner/
http://www.topsoftwareol.com/product/Video/Video_Converter_Standard.html
http://www.erightsoft.com/SUPER.html Multi-Converter <-- supposed to be very good
http://download.cnet.com/FreeStar-Free-Video-Converter/3000-2194_4-10854990.html
http://www.dvddecrypter.org.uk/ or http://www.mrbass.org/dvdrip/
http://www.flaskmpeg.net/download.php Mpeg to AVI Converter
http://www.squared5.com/ MPEG Streamclip Converter
http://www.virtualdub.org/ Mpeg to AVI Converter
10. Re: Which File Format works best in Premiere?
Bill Hunt Sep 19, 2012 10:11 AM (in response to ohwell1234)DV-AVI is a particular version of AVI, and uses the standard MS DV/DVC CODEC. It is perfect for such work. The format, AVI, can have any number of CODEC's, so is virtually meaningless, with the qualifier of CODEC used.
Hope that clears things up a bit.
Hunt
11. Re: Which File Format works best in Premiere?
ohwell1234 Sep 19, 2012 10:37 AM (in response to Bill Hunt)Not quite - Steve refers to "true DV files" not "any" AVI files. I just want to make sure that I convert to the least compressed format possible. This article is quite specific;
http://stray-notes.blogspot.ch/2010/11/convert-vob-to-dv-avi-for-use-in.htmlhttp://
winFF is not at all clear
12. Re: Which File Format works best in Premiere?
Bill Hunt Sep 19, 2012 2:57 PM (in response to ohwell1234)Sorry, that page shows as not available.
What CODEC is used in the files from WinFF?
Like I said, and I stand by it, a DV-AVI files is an AVI file, but it is a very specific sub-set of the AVI, in that it uses the MS DV/DVC CODEC. Other AVI files can have almost any CODEC known to man.
Good luck,
Hunt
13. Re: Which File Format works best in Premiere?
johnjv24 May 19, 2013 12:45 AM (in response to Bill Hunt)Is DV-AVI good with text? Like adding titles? Also is PreE any good with HD footage or would it be better to get Premiere Pro? If it is good with HD footage which one's work best?
Jonathan
14. Re: Which File Format works best in Premiere?
Peru Bob May 19, 2013 10:41 AM (in response to johnjv24)They will "work" equally well. It's just a matter of editing options and workflow.
You will need more robust hardware and multiple hard drives for Pro.
You can download the trial and see if you want Pro.
15. Re: Which File Format works best in Premiere?
johnjv24 May 19, 2013 11:34 AM (in response to Peru Bob)Okay so DV-AVI will be good enough for text with the video. It is the DV format that
Is known to not to be gracious to text correct? Will a i5 with hyperthreading be a good enough processor to work with the HD footage in either PreE or PrePro? Besides the ton of storage space.
16. Re: Which File Format works best in Premiere?
Bill Hunt May 19, 2013 4:52 PM (in response to johnjv24)Actually, it is MPEG-2 DVD, which is not kind to Text - and a few others. That MPEG-2 DVD is the required CODEC for a DVD-Video.
DV-AVI is compressed, but by only about 5%. Generally, it is OK with Text, so long as one does not have a lot of generations. When I do have multi-generational files, I will instead use one of the lossless CODEC's, such as Lagarith Lossless, or UT Lossless. They ARE compressed, BUT they are "visually lossless."
Another limitation of the DV-AVI CODEC is that it is ONLY for SD, i.e. 720 x 480 for NTSC. If one has HD material, it will down-rez the output file to SD dimensions, and that will NOT be good for Text, and not ideal for Video, though it IS better than up-rezzing from SD to HD dimensions.
For creating Text in Video, the links in this article might be useful: http://forums.adobe.com/message/3349385#3349385
Good luck,
Hunt
17. Re: Which File Format works best in Premiere?
Bill Hunt May 19, 2013 4:55 PM (in response to johnjv24)The i5 will easily handle HDV footage, in either version of Premiere, but if you are editing AVCHD, or any other H.264 CODEC material, it will likely be a bit sluggish in playback, and you will want to Render the Timeline often.
The Titles will not matter one way, or the other, but the source footage certainly will.
Good luck,
Hunt
18. Re: Which File Format works best in Premiere?
johnjv24 May 19, 2013 7:12 PM (in response to Bill Hunt)Alright. I thought I was told before that DV was worse than MPEG2. I could be wrong.
Do you know if the ADVC110 Canopus converter captures analog video to DV-AVI or just simply DV? Are they the same?
Or excuse my ignorance but is DV-AVI for windows and DV is on Macintosh? (FYI I have a Mac) Or am I just confused ha.
"The i5 will easily handle HDV footage, in either version of Premiere,...."
Okay thanks for clearing that up ^
THanks,
Jonathan
19. Re: Which File Format works best in Premiere?
Bill Hunt May 19, 2013 7:59 PM (in response to johnjv24)The Canopus, run through the Capture module in PrE, will result in a DV-AVI, if you set it to do so. Of the other possible Capture formats/CODEC's, the DV-AVI would be the best, and is so very easy to edit.
Good luck,
Hunt
20. Re: Which File Format works best in Premiere?
johnjv24 May 20, 2013 2:25 PM (in response to Bill Hunt)Awesome! I will definitely get the Canopus product!
Finally, since my video editing results in creating a regular DVD for the local tv program for our church, would it
be best to always convert/capture footage to DV-AVI no matter what format be it AVCHD, MPEG4, or MPEG2, or even other HD formats?
21. Re: Which File Format works best in Premiere?
Bill Hunt May 20, 2013 2:38 PM (in response to johnjv24)If you are being handed digitized material already, the Canopus will not figure into the workflow.
With SD, or HDV digital material, recorded to miniDV tape, you would Capture directly from the camera, via an IEEE-1394a/FireWire-400 cable.
With digital material, stored on a camera's HDD, or to a flash media card, one would Copy the files (and full folder structure for AVCHD material) to the computer's HDD, then Get/Add Media (depends on PrE version), to Import that material into the Project.
Good luck,
Hunt
22. Re: Which File Format works best in Premiere?
Filme Online May 26, 2013 8:13 PM (in response to Bill Hunt) -
23. Re: Which File Format works best in Premiere?
Ann Bens May 27, 2013 8:47 AM (in response to johnjv24)If you are on a mac you do not capture to dv-avi but it will be transcoded to .mov (which is the equivalent of dv-avi)
DV-avi is compressed 1:5 compaired to raw dv (digital video): so that will be 20%.
24. Re: Which File Format works best in Premiere?
Bill Hunt May 27, 2013 8:47 AM (in response to Ann Bens)Ann,
Good point about a Mac, and one worth mentioning.
Thank you,
Hunt
25. Re: Which File Format works best in Premiere?
johnjv24 May 27, 2013 5:52 PM (in response to Ann Bens)Oh okay so I will get the same results with mov. video? Like the ease of editing and the kindness to text as the DV format is?
26. Re: Which File Format works best in Premiere?
Bill Hunt May 27, 2013 5:57 PM (in response to johnjv24)That depends entirely on the CODEC used inside your MOV files. Like AVI (primarily for the PC), there can be many, many CODEC's inside. Many work well, where some do not. As a for instance, you could a MOV file with the AIC (Apple Intermediate CODEC), where you would need to have Apple's Final Cut Pro installed, even to use that file on a Mac.
Hunt
27. Re: Which File Format works best in Premiere?
johnjv24 Jun 8, 2013 12:39 AM (in response to Bill Hunt)Alrighty thanks for the info!!!
Does anyone know of a video converting software for windows that is able to import a dvd , avchd & mpeg4 files and convert to dv, dv-avi?
Also any recommendation on a dvd authorizing program that does a better job of burning a dvd then preE 10?
John
