3 Replies Latest reply: Jun 11, 2013 9:16 AM by Rafael Aviles RSS
    Cannot print from LR5 to HP printer
    Rafael Aviles Community Member
      I just downloaded and installed LR5 successfully to my iMac (2012) running OS 10.8.4. Everything seems to be working fine (LR4 catalog converted, Import works fine, etc.) EXCEPT printing to the same HP printer I use with LR4. When I press the Print button after setting things up, the bar on the upper left corner proceeds quickly, the message Task Completed appears (and goes away quickly), BUT...nothing happens on the printer. It just does not get the print job sent to it. The iMac reports that the printer is Idle, there is no record of a job being received.
      I checked the printer, it works fine. I can print from Photoshop without a gltch. So, comunication between the computer and the printer does not seem to be the issue.
      Any thoughts/suggestions?
      (I am using the trial version of LR5.)
