Ok -- So I've got this SharePoint running under the HTTPS
protocal. It's in my Network Places, but not as a standard
\\computer\share\ as I would expect; no, sharepoints are a little
screwy so it just lists the full
https://www.sharepointserver.com/mywebdirectory -- and I can access
all the subdirectories & everything else from there.
The problem comes when I try to set up RoboHelp to publish to
this mysterious webserver in the sky.
The Choices: FTP, HTTP, Frontpage & Filesystem.
FTP won't work cause -- go figure,
not an FTP server.
Both HTTP and Frontpage don't work
because RH automatically places protocal as "HTTP", without the S
-- connection refused
Filesystem -- oh this one is the one
that really gets me. So I can click the "Browse" button, Navigate
to Network Places and I can see the Sharepoint directory just
sitting there... when I try and click OK on it though, the
Destination Path text box doesn't change... If I select any other
network place it updates it fine... So I try the same format,
\\server\share\, where server is
www.sharepointserver.com, share is
-- oh let's say mywebdirectory -- and I get an access denied error.
Probably the closest I got to get it to work.
So, questions:
Has anyone successfully set up
RoboHelp to publish to a Sharepoint?
How did you do it?
Right now I've taken the long route and just Genreate &
Copy over to the sharepoint whenever I need to -- But ideally I'd
like to set it up to publish as that saves copious amounts of
bandwidth.
Thanks !
-Tyler Waters
