1. Re: Automated assembly edit???
Harm Millaard Jun 10, 2013 11:20 PM (in response to MD Optofonik)Have you tried 'Automate to Sequence'? Select your clips in the project panel and then click on the Automate to Sequence button (leftmost icon at the bottom right of the project panel).
2. Re: Automated assembly edit???
JSS1138 Jun 11, 2013 12:15 PM (in response to MD Optofonik)automatically checkerboarded
Huh?
3. Re: Automated assembly edit???
SAFEHARBOR11 Jun 11, 2013 1:49 PM (in response to JSS1138)"Checkerboarded" likely refers to the old way of arranging clips with V1, V2 and Effects track between. Alternating clips on the timeline is my guess. CS6 uses single-track editing, but same end result, clips with effects between.
Harm's suggestion is correct, and the default transition duration can be set in Prefs.
Jeff Pulera
Safe Harbor
4. Re: Automated assembly edit???
MD Optofonik Jun 11, 2013 1:53 PM (in response to JSS1138)Sorry, film editing term that was still used in the early days of NLE. It's hard for me to put it into words but I'll give it a go. It's when raw clips are placed on a time line using alternating tracks, one above the other with or without a predetermined measure of overlap and transition. In the current NLE world I guess it applies mostly to audio although a few editors I used to know in the early 90's would checkerboard picture as well. Hope that clears it up a bit.
5. Re: Automated assembly edit???
Harm Millaard Jun 11, 2013 3:45 PM (in response to MD Optofonik)Fashion is a form of ugliness so intolerable, we have to change it every 6 months.
That also applies to editing. A/B editing went out ages ago to be replaced by single line editing.
6. Re: Automated assembly edit???
MD Optofonik Jun 11, 2013 5:27 PM (in response to Harm Millaard)Thanks for the reply. I'n going to try Automate to Sequence when I finish a few classes. I clearly need them.
I didn't realize A/B editing was a fashion thing, I thought it was just guys used to cutting on the Steenbeck making the transition to computers and virtualizing their workflow habits. Probably wasn't the best way to go about it but they made it happen. It was all so new; the digital editing workflow paradigm wasn't codified yet. I imagine, "slug" is a term that's fallen out of fashion as well.
Of course us music guys had been getting our heads around working in a non-linear world with MIDI since the early 80's.
