Adobe Flash Player 11 does not work in Internet 10. I am running Windows 7 64 bitn a Dell desktop PC. I have maded sure that Flash Player is enabled in IE 10. I have uninstalled and reinstalled Flash Player 11 "numerous" times with reboots. When I open a website that requires Flash Plyer, I get an error message telling me to download the latest version.
What is really confusing is that I have a second Identical Dell desktop running the same software where Flash Player 11 works just fine. I have tried everything that I have found on the Internet reqarding this problem with no look. Can anyone offer a solution.
neoral
Hi neoral,
Since you said that you enabled flash player in IE i'm assuming you're seeing "Shockwave Flash Object" when you go to the Manage Add-ons page, correct?
You may may want to try to fix your permissions - http://forums.adobe.com/thread/987370?tstart=0
Yes.
I downloaded and installed SubInACL Installer from Microsoft but problem still persists...
Hi dandab…
Although, I had installed SubInACL <http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=23510> once without solving my problem, I uninstalled and reinstalled it and Adobe Flash Player 11 is now up and running. Thank you very much.
Do you have ActiveX Filtering enabled, by any chance? Disable it!
ActiveX Filtering is disabled.
