Hi everybody,
I'd like to customize the CM Editors View a little bit - the bullet/numbering-styling - to be exact. When I browse to "ip:port/lc/crx/de/index.jsp#/content/cm/" I found the file called "tbxeditor-config.xml". There I'm able to add/remove fonts, etc. But I couldn't find any hints to change bullet/numbering-styling e.g. changing from 1,2,3 to $1, $2, $3. Any ideas?
Thanks in advance
Total Likes
Have you had a look at the custom numbering in List Module If that suits your requirement ?
You will have to create multiple text modules of each bulleted item and create a list with custom bullet numbering that contains all the text modules.
--Santosh
Total Likes
Hi Santosh,
thank you for your response. I'll tell your solution to my colleague.
Total Likes
