1. Re: Light leaking through edges of black bars..
Steven L. Gotz Jun 12, 2013 10:41 PM (in response to NickBoston)Scale up the title by 1% or 2%?
Or, better yet, fix the template and save it back under a new name.
2. Re: Light leaking through edges of black bars..
NickBoston Jun 13, 2013 8:00 AM (in response to Steven L. Gotz)I tried scaling it but it showed white in a different area. I'll try and edit it myself. Shouldn't this be correct in the first place with no issues?
3. Re: Light leaking through edges of black bars..
Ann Bens Jun 13, 2013 8:02 AM (in response to NickBoston)Post a screenshot.
4. Re: Light leaking through edges of black bars..
NickBoston Jun 13, 2013 8:11 AM (in response to Ann Bens) -
5. Re: Light leaking through edges of black bars..
NickBoston Jun 13, 2013 9:29 AM (in response to NickBoston)What's the best way to fix the template?
6. Re: Light leaking through edges of black bars..
JSS1138 Jun 13, 2013 9:34 AM (in response to NickBoston) -
7. Re: Light leaking through edges of black bars..
NickBoston Jun 13, 2013 9:40 AM (in response to JSS1138)Thanks Jim, read that from top to bottom. Pardon my slowness, but i cant understand how this helps me. I see the preset files and I'll definitely download them but are you saying to use these ones instead?
8. Re: Light leaking through edges of black bars..
JSS1138 Jun 13, 2013 9:41 AM (in response to NickBoston)Yeah, the Letterbox presets.
9. Re: Light leaking through edges of black bars..
Ann Bens Jun 13, 2013 10:10 AM (in response to NickBoston)Select the top bar in the Titler and hit the up arrow key ones or twices.
Do the same for the lower bar and down arrow key.
10. Re: Light leaking through edges of black bars..
NickBoston Jun 13, 2013 10:16 AM (in response to JSS1138)Okay, I can't get them to show up in my template browser. The folder, "Film Presets" is there but Premiere is not seeing the .prfpset files.
Any suggestions?
11. Re: Light leaking through edges of black bars..
JSS1138 Jun 13, 2013 10:20 AM (in response to NickBoston)"Unzip the file, and from the Presets bin do a Right Click>Import Presets..."
12. Re: Light leaking through edges of black bars..
NickBoston Jun 13, 2013 11:03 AM (in response to JSS1138)Okay got it. One question though, are these presets adjustable in anyway? Meaning can I change width of the letterbox? I notice 2.39 is different in HD than it is in SD and was looking for something in between those sizes. Closer to the matte preset size in Premiere.
13. Re: Light leaking through edges of black bars..
Bill Hunt Jun 13, 2013 11:49 AM (in response to NickBoston)Perhaps rather than adjusting a Preset Template, if you are having issues, would be to apply the Crop Effect, or the Garbage Matte, or creating the exact black Filled Shapes in Titler, to suit your needs?
Good luck,
Hunt
14. Re: Light leaking through edges of black bars..
JSS1138 Jun 13, 2013 2:13 PM (in response to NickBoston)I notice 2.39 is different in HD than it is in SD and was looking for something in between those sizes.
It's only different because of the original frame size. The end result is the same.
But yes, they're just simple Crop effects. You can change them as desired.
15. Re: Light leaking through edges of black bars..
NickBoston Jun 15, 2013 9:48 AM (in response to JSS1138)The presets worked! Thanks! Still not sure why the original Adobe matte templates show light leakage....
