1. Re: Audio mixing different sources
joe bloe premiere Jun 14, 2013 8:41 AM (in response to owiseone61755)You might be able to EQ / filter some of the crowd noise out,
but basically you are using a mix and are stuck with what's there.
I don't know your context, but I would be initially inclined
to not try and hide the crowd noise... just use it.
Maybe sneak in a bit of 'crowd noise only' right before the dialog,
then mix it out after the line to keep it from being a jarring audio cut.
note:
Audition has more refined audio tools than Premiere.
2. Re: Audio mixing different sources
Bill Hunt Jun 14, 2013 9:22 AM (in response to owiseone61755)I agree with Joe. Audition has a full compliment of EQ and Gating Filters, and more can be added via VST's.
It will be a bit of work, and I would post to the Audition Forum for some good starting Effects and settings - then critical listening and adjusting might get you very close.
Good luck,
Hunt
3. Re: Audio mixing different sources
Richard M Knight Jun 14, 2013 9:29 AM (in response to Bill Hunt)If the audio is in 5.1 you might find the dialogue cleaner on the centre channel
