quote:
WHY is this not possible?
quote:
Sorry, I'm reading these via the NNTP feed: it does not receive the edits.
quote:
I've been able to use UNC paths with CFFILE to upload files successfully. One thing I found that you need to do is to upload to the primary server so that the file is then replicated to the other servers. If you're having problems, it is probably related to the permission ColdFusion has on the network. Although if you're getting an error that the directory is not found, perhaps your UNC reference is incorrect. Are you working with a server administrator who can help you troubleshoot this?
