InDesign CC crashing on launch on macOS
Contributor ,
Jun 17, 2013 Jun 17, 2013
I've just downloaded the CC version of InDesign to my MacBook Pro but every time I launch it it crashes.
I'm running OSX 10.8.3, 8GB of ram, 8GB of disc space and I've tried trashing the prefs but it doesn't even make it to that dialog window. The UI appears and that's it boom! I've sent the crash log to Adobe but I'm wondering if anyone has any suggestions or things to try to get it up and running?
{Renamed By MOD}
Bug
63.1K
Community Beginner , Jun 18, 2013 Jun 18, 2013
I had the exact same problem today. It was a font in my case. Just open fontbook and disable all of the user fonts. Restart Indesign... if it opens without crashing... bingo you've found the problem. Re-enable the fonts until you find the culprit.
Adobe Indesign CC - Version 9.0
Model Name:Mac Pro
  Model Identifier:MacPro1,1
  Processor Name:Dual-Core Intel Xeon
  Processor Speed:3 GHz
  Number of Processors:2
  Total Number of Cores:4
  L2 Cache (per Processor):4 MB
  Memory:4 GB
  Bus Speed:1.33 GHz
  B
Engaged ,
Uh oh! Sorry to hear that, Tony!
Could you also share your crash log here? Please post it to http://pastebin.com and link us the url.
Contributor ,
Yes it was very disappointing. Here's the pastebin link http://pastebin.com/aEGsKukJ
Jun 25, 2013 Jun 25, 2013
Same problem. Crashes after launch. Already deleted 3 fonts that may be causing the problem, and yet the crash persists.
Heres the crash log:
http://pastebin.com/viubK6ty
Looks like you only pasted part of the log, and we need to see it all.
That aside, just because you removed three fonts doesn't mean you got all of them that might be a problem. You need to remove ALL of your user fonts, then add them back in groups to test and isolate bad fonts.
Same issue here. Running OSX 10.8.4, 12GB of ram. Crashes on startup for me, can't even create a document or anything.
Engaged ,
Same thing as Tony, could you share your crash log as well? Here's how you can obtain it: http://bit.ly/idcrashlog
A few standard troubleshooting steps we'd like you to test out:
1. Recreate preferences: http://forums.adobe.com/thread/526990
2. Disable any third party plug-ins
3. Starting your computer in Safe boot mode: http://support.apple.com/kb/HT1455
4. Creating a new user account and see if the issue persists
Please let us know how it goes. Thanks!
http://pastebin.com/Q1szSB7y
I've tried recreating my preferences already, I have no plug-ins running. I'll try the others in the morning.
edit:
my curiosity got to me, logged in as a guest on my computer and it works just fine. Log back in on my user account and it crashes instantly still. Also in safe mode it's the same result, works on the guest account but not my main user account.
Contributor ,
I can second JHammel60 on that. I have the same experience works in Guest login but not Admin.
Engaged ,
Again, our apologies for your frustrating experience everyone!
JHAmmel60:
If it's a user account specific issues, please take a look at this help artcile:
http://helpx.adobe.com/x-productkb/global/troubleshoot-unexpected-behavior-user-account.html
Please refer to Step 4 on how to repair user permissions and Step 5 for repair disk utility.
Let us know if this helps!
And thanks for everyone helping troubleshooting
Well I did step 4 and that didn't work. Did step 5, it loaded up fine and I was able to open a document. Then it crashed as usual.
When I go to load up InDesign now I get an error message saying "Unable to launch Adobe InDesign as you do not have sufficient permissions to access the preferences folders. Ensure that you have appropriate permissions and then restart Adobe InDesign'
Ugh.
I'm having the same issue only on Windows...both InDesign CC and InCopy are crashing and in the error report it says the ObjectModel.dll file is corrupted or incomplete....uninstalled programs multiple times and restarted the machine, but nothing seems to work.
all other CC programs seem to run smoothly though....
I also just tried installing InCopy to see if it crashed for me also and the result...yep, same exact thing as InDesign. Photoshop, Illustrator, Dreamweaver, Flash, After Effects all work perfectly for me.
None of the steps on the thread above worked. Still crashes. So the last step is saying oh if none of these worked for you then you have to create a new user account if you want to use this product basically? Yet InDesign CS6 works fine on my main user account.
I'm having the same problem as everyone else. Going back to CS6 until a fix gets pushed.
Nov 27, 2013 Nov 27, 2013
I had months of frustration with Illustrator CS6 and InDesign CC.
Repairing permissions as indicated by amxyz did the trick!!
I can't thank you enough.
JHAmmel60:
http://helpx.adobe.com/x-productkb/global/troubleshoot-unexpected-beha vior-user-account.html
Dec 03, 2013 Dec 03, 2013
I'm at the end of my tether with this issue, so eventually have to add to this post. I have tried absolutely everything listed in this thread, and others - fonts, permissions, disk repair, preferences, uninstall, log out cc etc... all with no improvement for indesign cc and illustrator cc.
amxyz, the item no.5. Reset the access settings on the user account's Library folder, has templates for 10.4.x and 10.5.x but nothing for newer osx versions. I've tried the 10.5.x commands with no apparent effect. Certainly didn't fix my cc issues.
A new user account does fix it for me, but I'm buggered if I'm going to go through changing my user account over for two badly programmed apps. Adobe, we're paying for these apps, and not charging you for our time trying to resolve your faults.
As you can see from the crash report I'm running 10.7.5. I'm reluctant to update OS as that will have many other flow-on effects of other things that then wont work.
I'm an Adobe user since 1980, tech savvy, but this one is really annoying me - worst issue I've had with adobe products that I can remember.
So here's my crash report for indesign:
Process:         Adobe InDesign CC [9590]
Path:            /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Adobe InDesign CC
Identifier:      com.adobe.InDesign
Version:         9.1.0.33 (9100)
Code Type:       X86-64 (Native)
Parent Process:  launchd [159]
Date/Time:       2013-12-04 11:09:11.074 +1300
OS Version:      Mac OS X 10.7.5 (11G63)
Report Version:  9
Sleep/Wake UUID: 2137B958-FE7A-4403-A9FE-ED898D6DA5CC
Interval Since Last Report:          36455 sec
Per-App Interval Since Last Report:  121 sec
Per-App Crashes Since Last Report:   4
Anonymous UUID:                      B7E773C4-CE08-43BC-8068-748BE30022EA
Crashed Thread:  0  Dispatch queue: com.apple.main-thread
Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
VM Regions Near 0:
    __TEXT                 0000000100000000-0000000100006000 [   24K] r-x/rwx SM=COW  /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Adobe InDesign CC
Application Specific Information:
objc[9590]: garbage collection is OFF
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   com.adobe.InDesign.SettingsInCloud          0x00000001125c821b DBManager::GetMetadataTableEntryByRelativePathLowerCase(FilePath_LowerCase const&, DBItem&) + 235
1   com.adobe.InDesign.SettingsInCloud          0x00000001125a29a7 PreferenceFolderHandler::HandlePreferencesCollectionCreate(boost::shared_ptr<uxtech::c4::Task> const&, boost::shared_ptr<uxtech::c4::Collection> const&) + 247
2   com.adobe.InDesign.SettingsInCloud          0x000000011256d3d7 0x112497000 + 877527
3   com.adobe.InDesign.SettingsInCloud          0x0000000112592b49 uxtech::c4::NetworkTask::InvokeMainThreadFinalize() + 185
4   com.adobe.InDesign.SettingsInCloud          0x000000011259bc20 0x112497000 + 1068064
5   com.adobe.InDesign.SettingsInCloud          0x000000011255ae1e uxtech::ThreadTaskDispatcher::Flush() + 350
6   com.adobe.InDesign.SettingsInCloud          0x000000011255b19c 0x112497000 + 803228
7   com.apple.CoreFoundation                0x00007fff8a3e670d -[NSObject performSelector:withObject:] + 61
8   com.apple.Foundation                    0x00007fff8ad7ad70 __NSThreadPerformPerform + 214
9   com.apple.CoreFoundation                0x00007fff8a3654f1 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
10  com.apple.CoreFoundation                0x00007fff8a364d5d __CFRunLoopDoSources0 + 253
11  com.apple.CoreFoundation                0x00007fff8a38bb49 __CFRunLoopRun + 905
12  com.apple.CoreFoundation                0x00007fff8a38b486 CFRunLoopRunSpecific + 230
13  com.apple.HIToolbox                     0x00007fff8b31e2bf RunCurrentEventLoopInMode + 277
14  com.apple.HIToolbox                     0x00007fff8b32556d ReceiveNextEventCommon + 355
15  com.apple.HIToolbox                     0x00007fff8b3253fa BlockUntilNextEventMatchingListInMode + 62
16  com.apple.AppKit                        0x00007fff887c5779 _DPSNextEvent + 659
17  com.apple.AppKit                        0x00007fff887c507d -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 135
18  com.apple.AppKit                        0x00007fff887c19b9 -[NSApplication run] + 470
19  com.adobe.exo.framework                 0x00000001028ace88 exo::app::OS_AppBase::RunEventLoop() + 56
20  com.adobe.InDesign.AppFramework          0x000000011372ce53 0x11361f000 + 1105491
21  com.adobe.InDesign.AppFramework          0x000000011372bfe2 0x11361f000 + 1101794
22  com.adobe.InDesign                      0x0000000100001dbc main + 412
23  com.adobe.InDesign                      0x0000000100001bb4 start + 52
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0   libsystem_kernel.dylib                  0x00007fff8a24a7e6 kevent + 10
1   libdispatch.dylib                       0x00007fff8ba53786 _dispatch_mgr_invoke + 923
2   libdispatch.dylib                       0x00007fff8ba52316 _dispatch_mgr_thread + 54
Thread 2:
0   libsystem_kernel.dylib                  0x00007fff8a249bca __psynch_cvwait + 10
1   libsystem_c.dylib                       0x00007fff885ac2a6 _pthread_cond_wait + 890
2   com.apple.CoreServices.CarbonCore          0x00007fff8cb0eec4 TSWaitOnConditionTimedRelative + 157
3   com.apple.CoreServices.CarbonCore          0x00007fff8cb53e81 MPWaitOnQueue + 181
4   PMRuntime.dylib                         0x0000000101661be1 0x101660000 + 7137
5   com.apple.CoreServices.CarbonCore          0x00007fff8cb54ce6 PrivateMPEntryPoint + 58
6   libsystem_c.dylib                       0x00007fff885a88bf _pthread_start + 335
7   libsystem_c.dylib                       0x00007fff885abb75 thread_start + 13
Thread 3:
0   libsystem_kernel.dylib                  0x00007fff8a24a192 __workq_kernreturn + 10
1   libsystem_c.dylib                       0x00007fff885aa594 _pthread_wqthread + 758
2   libsystem_c.dylib                       0x00007fff885abb85 start_wqthread + 13
Thread 4:
Thread 5:: com.apple.CFSocket.private
0   libsystem_kernel.dylib                  0x00007fff8a249df2 __select + 10
1   com.apple.CoreFoundation                0x00007fff8a3d4c8b __CFSocketManager + 1355
2   libsystem_c.dylib                       0x00007fff885a88bf _pthread_start + 335
3   libsystem_c.dylib                       0x00007fff885abb75 thread_start + 13
Thread 6:
1   libsystem_c.dylib                       0x00007fff885ac274 _pthread_cond_wait + 840
2   com.adobe.InDesign.AppFramework          0x0000000113717d82 0x11361f000 + 1019266
3   com.adobe.InDesign.AppFramework          0x00000001137171ed 0x11361f000 + 1016301
4   com.adobe.InDesign.AppFramework          0x00000001137148f7 0x11361f000 + 1005815
5   com.adobe.InDesign.AppFramework          0x000000011371891d 0x11361f000 + 1022237
6   com.adobe.InDesign.AppFramework          0x00000001137188a3 0x11361f000 + 1022115
7   com.adobe.InDesign.AppFramework          0x0000000113718862 0x11361f000 + 1022050
8   com.adobe.boost_threads.framework          0x00000001010766d4 boost::thread::start_thread() + 436
9   libsystem_c.dylib                       0x00007fff885a88bf _pthread_start + 335
10  libsystem_c.dylib                       0x00007fff885abb75 thread_start + 13
Thread 7:
Thread 8:
0   libsystem_kernel.dylib                  0x00007fff8a249e42 __semwait_signal + 10
1   libsystem_c.dylib                       0x00007fff8855edea nanosleep + 164
2   com.adobe.InDesign.Support for JavaScript          0x0000000119433818 0x1193e0000 + 342040
3   com.adobe.InDesign.Support for JavaScript          0x000000011941aa3e 0x1193e0000 + 240190
4   com.adobe.InDesign.Support for JavaScript          0x00000001194333d5 0x1193e0000 + 340949
5   libsystem_c.dylib                       0x00007fff885a88bf _pthread_start + 335
6   libsystem_c.dylib                       0x00007fff885abb75 thread_start + 13
Thread 9:
0   libsystem_kernel.dylib                  0x00007fff8a249d7a __recvfrom + 10
1   ServiceManager-Launcher.dylib           0x000000011d250231 0x11d238000 + 98865
2   ServiceManager-Launcher.dylib           0x000000011d24f5d6 0x11d238000 + 95702
3   ServiceManager-Launcher.dylib           0x000000011d24e678 0x11d238000 + 91768
4   ServiceManager-Launcher.dylib           0x000000011d24e6e6 0x11d238000 + 91878
5   ServiceManager-Launcher.dylib           0x000000011d2492e4 0x11d238000 + 70372
6   ServiceManager-Launcher.dylib           0x000000011d249cfe 0x11d238000 + 72958
7   ServiceManager-Launcher.dylib           0x000000011d249c0b 0x11d238000 + 72715
8   ServiceManager-Launcher.dylib           0x000000011d24d36e 0x11d238000 + 86894
9   ServiceManager-Launcher.dylib           0x000000011d24d4b2 0x11d238000 + 87218
10  ServiceManager-Launcher.dylib           0x000000011d24d26d 0x11d238000 + 86637
11  ServiceManager-Launcher.dylib           0x000000011d24d1e6 0x11d238000 + 86502
12  ServiceManager-Launcher.dylib           0x000000011d23b916 0x11d238000 + 14614
13  ServiceManager-Launcher.dylib           0x000000011d23fb05 0x11d238000 + 31493
14  ServiceManager-Launcher.dylib           0x000000011d24de46 0x11d238000 + 89670
15  ServiceManager-Launcher.dylib           0x000000011d24fef3 0x11d238000 + 98035
16  libsystem_c.dylib                       0x00007fff885a88bf _pthread_start + 335
17  libsystem_c.dylib                       0x00007fff885abb75 thread_start + 13
Thread 10:: C4 ThreadController
2   com.adobe.boost_threads.framework          0x000000010107906b boost::condition_variable::wait(boost::unique_lock<boost::mutex>&) + 155
3   com.adobe.InDesign.SettingsInCloud          0x000000011259aff3 0x112497000 + 1064947
4   com.adobe.InDesign.SettingsInCloud          0x00000001125990ba 0x112497000 + 1056954
5   com.adobe.boost_threads.framework          0x00000001010766d4 boost::thread::start_thread() + 436
Thread 11:: C4 ThreadController
Thread 12:: C4: CollectionCreate
2   com.apple.Foundation                    0x00007fff8ad874c0 -[NSCondition wait] + 261
3   com.apple.Foundation                    0x00007fff8ad7a854 -[NSObject(NSThreadPerformAdditions) performSelector:onThread:withObject:waitUntilDone:modes:] + 975
4   com.apple.Foundation                    0x00007fff8adb9b16 -[NSObject(NSThreadPerformAdditions) performSelector:onThread:withObject:waitUntilDone:] + 119
5   com.adobe.InDesign.SettingsInCloud          0x000000011255abe2 uxtech::ThreadTaskDispatcher::ScheduleTask(boost::shared_ptr<uxtech::ThreadTask> const&, uxtech::ThreadTaskDispatcher::ScheduleMode) + 578
6   com.adobe.InDesign.SettingsInCloud          0x000000011259b314 0x112497000 + 1065748
7   com.adobe.InDesign.SettingsInCloud          0x00000001125990ba 0x112497000 + 1056954
Thread 13:: C4 ThreadController
Thread 14:: C4 ThreadController
Thread 15:: C4 ThreadController
Thread 16:: C4 ThreadController
Thread 17:: C4 ThreadController
Thread 18:: com.apple.NSURLConnectionLoader
0   libsystem_kernel.dylib                  0x00007fff8a24867a mach_msg_trap + 10
1   libsystem_kernel.dylib                  0x00007fff8a247d71 mach_msg + 73
2   com.apple.CoreFoundation                0x00007fff8a38350c __CFRunLoopServiceMachPort + 188
3   com.apple.CoreFoundation                0x00007fff8a38bc74 __CFRunLoopRun + 1204
4   com.apple.CoreFoundation                0x00007fff8a38b486 CFRunLoopRunSpecific + 230
5   com.apple.Foundation                    0x00007fff8ad90fd7 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 335
6   com.apple.Foundation                    0x00007fff8ad8572a -[NSThread main] + 68
7   com.apple.Foundation                    0x00007fff8ad856a2 __NSThread__main__ + 1575
8   libsystem_c.dylib                       0x00007fff885a88bf _pthread_start + 335
9   libsystem_c.dylib                       0x00007fff885abb75 thread_start + 13
Thread 19:
Thread 20:
Thread 21:: MPSupport Worker
2   MultiProcessor Support                  0x0000000128e1f44b 0x128dda000 + 283723
3   MultiProcessor Support                  0x0000000128e1f303 0x128dda000 + 283395
4   MultiProcessor Support                  0x0000000128e3f394 0x128dda000 + 414612
Thread 22:: MPSupport Worker
Thread 23:: MPSupport Worker
Thread 24:: MPSupport Worker
Thread 25:: MPSupport Worker
Thread 26:: MPSupport Worker
Thread 27:: MPSupport Worker
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x00007fff5fbfe1d8  rbx: 0x00007fff5fbfe280  rcx: 0x3fffffffffffffb9  rdx: 0x0000000000000001
  rdi: 0x00007fff5fbfe1d8  rsi: 0x00000001125f22ea  rbp: 0x00007fff5fbfe240  rsp: 0x00007fff5fbfe1c0
   r8: 0x0000000000000011   r9: 0x0000000000000d1c  r10: 0x0000000000000000  r11: 0x0000000007a15db4
  r12: 0x000000012252b110  r13: 0x0000000127e3be10  r14: 0x00007fff5fbfe290  r15: 0x0000000000000000
  rip: 0x00000001125c821b  rfl: 0x0000000000010206  cr2: 0x0000000000000000
Logical CPU: 6
Binary Images:
       0x100000000 -        0x100005fff +com.adobe.InDesign (9.1.0.33 - 9100) <B7C09BD6-74AF-323E-8D22-D5E1F7965643> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Adobe InDesign CC
       0x10000c000 -        0x10000eff7 +com.adobe.InDesign.InDesignModelAndUI (9.0 - ???) <612870BE-869E-3165-9714-55F900A66BCC> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/InDesignModelAndUI.framework/Versions/A/InDesignModelAndUI
       0x100014000 -        0x10001cfff +com.adobe.coretech.adobesplashkit (AdobeSplashKit Version 1.0 - 1.0) <65BFDA83-4121-3D12-9BBE-9F4FF1DB3D6A> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeSplashKit.framework/Versions/A/AdobeSplashKit
       0x100025000 -        0x10002ffff +ASLSupportLib.dylib (??? - ???) <1039F962-C495-36E4-B868-3DA5C43E3EBF> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/ASLSupportLib.dylib
       0x100037000 -        0x10012cfff +DV_WidgetBinLib.dylib (??? - ???) <E9E8E0B7-A59C-30F0-9E3A-6E096AA18C48> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/DV_WidgetBinLib.dylib
       0x1001c1000 -        0x100206ff7 +TextPanelLib.dylib (??? - ???) <D57C5ADC-53A7-347C-8F44-30ABBE243FB2> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/TextPanelLib.dylib
       0x100223000 -        0x100384fff +WidgetBinLib.dylib (??? - ???) <AB920F70-D419-3EB0-99E3-CA007895128B> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/WidgetBinLib.dylib
       0x100436000 -        0x1005ffff7 +com.adobe.owl (AdobeOwl version 5.0.13 - 5.0.13) <E9BEFE93-8AB5-3EF9-B59E-69208015C7FA> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
       0x100642000 -        0x100886ff7 +com.adobe.dvacore.framework (7.0.853914 - 7.0.853914.0) <75BA2F95-1D2C-3844-AE13-35ADD4B3F3CC> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
       0x10094d000 -        0x100ddaff7 +com.adobe.dvaui.framework (7.0.853914 - 7.0.853914.0) <DF5970A5-A55D-3CBB-84D2-51582F22D5F4> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
       0x101070000 -        0x101070fff +com.adobe.InDesign.InDesignModel (9.0 - ???) <7DCCCD9E-8ECB-330B-84AF-4F090F82BBBA> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/InDesignModel.framework/Versions/A/InDesignModel
       0x101075000 -        0x101083fff +com.adobe.boost_threads.framework (7.0.847203 - 7.0.847203.0) <A0AE19A9-2B8E-310A-8AC1-0E2E026E7A40> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
       0x101099000 -        0x10109fff7 +com.adobe.boost_date_time.framework (7.0.847203 - 7.0.847203.0) <F30F59C3-41C0-3DB1-899A-E2491EA25263> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
       0x1010ae000 -        0x101516fff +PublicLib.dylib (??? - ???) <84561314-CC42-3485-9219-1977F0F39804> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/PublicLib.dylib
       0x101660000 -        0x10166afff +PMRuntime.dylib (??? - ???) <0164EA5E-E56E-332F-901A-5E514833C38F> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/PMRuntime.dylib
       0x101673000 -        0x10168aff7 +com.adobe.AFL (AdobeAFL 1.5.0 - 1.5) <1C46F2BE-2E4D-3E25-ACDF-85E2962B92DF> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeAFL.framework/Versions/A/AdobeAFL
       0x101699000 -        0x1019a9ff7 +com.adobe.CoolType (AdobeCoolType 5.13.00.30830 - 5.13.00.30830) <BBF1FCF6-523A-3E24-967A-10EA909DF89B> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
       0x1019f1000 -        0x101a0efff +com.adobe.BIB (AdobeBIB 1.2.03.30830 - 1.2.03.30830) <A69D3AA0-9248-3B77-991B-89B2B7FE46BB> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
       0x101a16000 -        0x101b5afff +com.adobe.ACE (AdobeACE 2.20.02.30830 - 2.20.02.30830) <73C9699B-5EDC-3FDC-82FF-738C99AA840F> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
       0x101b6d000 -        0x10213efff +com.adobe.AGM (AdobeAGM 4.30.19.30830 - 4.30.19.30830) <9062D763-4040-3F8C-8FF3-23876F112FB8> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
       0x1021db000 -        0x102218fff +com.adobe.ARE (AdobeARE 1.5.02.30830 - 1.5.02.30830) <73174C59-1DDC-3416-A0AD-4D70930ABA60> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
       0x102220000 -        0x102246fff +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <FA20BCA0-05BF-35ED-95B7-5775B8310D12> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
       0x10224e000 -        0x1027e7fff +com.adobe.MPS (AdobeMPS 5.8.1.30604 - 5.8.1.30604) <70CBC6A8-2740-37AB-964E-484096A1BF8A> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
       0x102864000 -        0x102882fff +com.adobe.dvaflashview.framework (7.0.853914 - 7.0.853914.0) <4A6FE7D8-835A-3B0D-959B-8CA0E9A1C758> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
       0x10289a000 -        0x10289eff7 +com.adobe.ape.shim (3.4.0.29366 - 3.4.0.29366) <B9447EE8-6F91-9E85-C163-96600BF70764> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
       0x1028a5000 -        0x102967fff +com.adobe.exo.framework (7.0.853914 - 7.0.853914.0) <B6CCEBE6-6179-3611-B700-C6EEF9EA757E> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/exo.framework/Versions/A/exo
       0x102a04000 -        0x102ab2fff +com.adobe.dvaworkspace.framework (7.0.853914 - 7.0.853914.0) <E80A9533-786D-3063-9695-D40BE50BDCAC> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
       0x102b35000 -        0x1031cbff7 +com.adobe.PlugPlugOwl (4.0.2.35 - 4.0.2.35) <395AA523-BA82-3577-BB56-BC9949DB3EA6> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
       0x1034bd000 -        0x1034e9ff7 +libtbb.dylib (??? - ???) <64B7013E-D548-3F7B-A2FB-28B7B932275C> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/libtbb.dylib
       0x103504000 -        0x103523fe7 +libtbbmalloc.dylib (??? - ???) <6887ED68-67ED-3748-82DA-B39A3EB210BB> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/libtbbmalloc.dylib
       0x103548000 -        0x10428dfff +com.adobe.ICUData (4.0 - 3.61) <01D90725-4B10-312C-9546-9C0CCCA1B7BB> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/ICUData.framework/Versions/4.0/libicudata.40.0.dylib
       0x1042a1000 -        0x1043d2ff7 +com.adobe.ICUInternationalization (4.0 - 3.61) <CD4AD967-00CD-3979-8F82-1166E2058FA6> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/ICUInternationalization.framework/Versions/4.0/libicui18n.40.0.dylib
       0x104426000 -        0x10451cff7 +com.adobe.ICUUnicode (4.0 - 3.61) <2352E6C8-3431-3A99-92B9-382E85A018AC> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/libicuuc.40.0.dylib
       0x104554000 -        0x104682fff +com.winsoft.wrservices (WRServices 7.0.0 - 7.0.0) <0853A41B-A14A-37B7-B27F-457F87865EAD> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
       0x1046dd000 -        0x1047ccfff +com.adobe.amtlib (7.0.0.169 - 7.0.0.169) <A9A9F814-FF1F-3182-992C-395E5BC52481> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
       0x1047df000 -        0x1047e1fff +com.adobe.AdobeCrashReporter (7.0 - 7.0.1) <B68D0D42-8DEB-3F22-BD17-981AC060E9D7> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
       0x1047e7000 -        0x10489eff7 +com.adobe.boost_regex.framework (7.0.847203 - 7.0.847203.0) <F1C659D9-D3E8-3ACE-8368-9161529A6A66> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
       0x104908000 -        0x104977ff7 +com.adobe.adobe_caps (adobe_caps 7.0.0.21 - 7.0.0.21) <CE3C6356-9EE2-3B88-8261-8612A0743F56> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
       0x104982000 -        0x10498dfff +com.adobe.boost_signals.framework (7.0.847203 - 7.0.847203.0) <E0B3BB47-4294-3D65-8979-29B2D6C5DD2E> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
       0x10499c000 -        0x1049a0fff +com.adobe.boost_system.framework (7.0.847203 - 7.0.847203.0) <70F73B9F-8416-37BF-9294-086AE475B743> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
       0x1049a6000 -        0x104a47fff +com.adobe.ICUConverter (4.0 - 3.61) <46764474-111C-3B13-AF62-002B71877405> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/libicucnv.40.0.dylib
       0x104a67000 -        0x104ac9ff7 +DataBaseLib.dylib (??? - ???) <E83A89F6-EA79-37FD-9A25-69FEF8FD92B2> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/DataBaseLib.dylib
       0x104add000 -        0x104b49fff +ObjectModelLib.dylib (??? - ???) <DACE1F3B-0BB0-3F81-99CB-1ECBB73F50A4> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/ObjectModelLib.dylib
       0x104b66000 -        0x104b8afff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.30807 - 3.8.0.30807) <16FF5E16-19E0-3CE1-A68E-27567234429F> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
       0x106542000 -        0x106545fff +com.adobe.InDesign.Global Preferences Panel (9.1.0.33 - ???) <3B261D67-E6B5-32E3-AC7E-AFCCDC9B75CB> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Global Preferences Panel.InDesignPlugin/Global Preferences Panel
       0x10654b000 -        0x106557ff7 +com.adobe.InDesign.Group (9.1.0.33 - ???) <8DF66586-0FC5-3EA5-8F0D-6083387F0697> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Group.InDesignPlugin/Group
       0x106564000 -        0x106585ff7 +com.adobe.InDesign.Guides (9.1.0.33 - ???) <0431FB5F-AA6B-33A6-BDFE-7ABEC7445572> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Guides.InDesignPlugin/Guides
       0x106597000 -        0x1065b1ff7 +com.adobe.InDesign.IME (9.1.0.33 - ???) <905334C5-8BF8-3958-8216-720BDB4D3A1F> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/IME.InDesignPlugin/IME
       0x106700000 -        0x106753ff7 +com.adobe.InDesign.Image Filters (9.1.0.33 - ???) <F3DF9DCA-6073-3DF8-89EB-18F8D1DB8902> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Image Filters.InDesignPlugin/Image Filters
       0x10675f000 -        0x106760ff7 +com.adobe.InDesign.Metadata Database Filter (9.1.0.33 - ???) <3BE1DF86-81E8-359D-A40E-84EC7A016E16> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Metadata Database Filter.InDesignPlugin/Metadata Database Filter
       0x106765000 -        0x10676bfff  com.apple.agl (3.2.0 - AGL-3.2.0) <AB0B5D3F-BA2A-3366-830A-EF9258C18276> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
       0x106772000 -        0x106774fff  com.apple.textencoding.unicode (2.4 - 2.4) <FD4695F4-6110-36C6-AC06-86453E30FF6E> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
       0x109d5c000 -        0x109d64fff +com.adobe.InDesign.Data Services UI (9.1.0.33 - ???) <EF01EA1E-61C9-3B9E-A166-0A425537E310> /Applications/Adobe InDesign CC/*/Data Services UI
       0x109d6e000 -        0x109d76fff +com.adobe.InDesign.Data Services (9.1.0.33 - ???) <48C1DEF8-D77A-3717-AD51-02E641D9EF8F> /Applications/Adobe InDesign CC/*/Data Services
       0x109f83000 -        0x109fc1fff +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 7.0.1.102 - 7.0.1.102) <75ADE364-1107-3DA7-84A2-26C6874EB881> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
       0x10c21b000 -        0x10c238fff +com.adobe.InDesign.InCopySharedUI (9.1.0.33 - ???) <0A19AFFD-DB77-334D-B8D3-60CB775F517D> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/InCopySharedUI.InDesignPlugin/InCopySharedUI
       0x10c248000 -        0x10c275fff +com.adobe.InDesign.Layer (9.1.0.33 - ???) <94604B73-0E52-30CB-9CC0-805F5B138FE4> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Layer.InDesignPlugin/Layer
       0x10c288000 -        0x10c292fff +com.adobe.InDesign.Workgroup Client UI (9.1.0.33 - ???) <5025F9EC-7C4C-377B-92F0-EC208F75B671> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Workgroup Client UI.InDesignPlugin/Workgroup Client UI
       0x10c2cf000 -        0x10c2deff7 +com.adobe.InDesign.DTTransform (9.1.0.33 - ???) <417A914C-BEA9-3AF6-94BC-158C93DCDC56> /Applications/Adobe InDesign CC/*/DTTransform
       0x10c2e7000 -        0x10c2f0ff7 +com.adobe.InDesign.PNG Import Filter UI (9.1.0.33 - ???) <C566B5E1-9945-3673-A6E0-12FDBE39B7D2> /Applications/Adobe InDesign CC/*/PNG Import Filter UI
       0x10c5e2000 -        0x10c5e4fff +com.adobe.InDesign.SimpleTextImportFilter (9.1.0.33 - ???) <B409D770-A106-3EFE-9925-DE295432C918> /Applications/Adobe InDesign CC/*/SimpleTextImportFilter
       0x10ca93000 -        0x10cad1fff +com.adobe.InDesign.Dictionary Editor Dialog (9.1.0.33 - ???) <C95A4466-2E6E-371D-A983-C8C1A2923FB6> /Applications/Adobe InDesign CC/*/Dictionary Editor Dialog
       0x10caf2000 -        0x10caf9fff +com.adobe.InDesign.InCopyImport (9.1.0.33 - ???) <6C4D93D1-26B1-3A78-AEC4-08BE97A6F15A> /Applications/Adobe InDesign CC/*/InCopyImport
       0x10d4eb000 -        0x10d4f3ff7 +com.adobe.InDesign.JPEG Export UI (9.1.0.33 - ???) <2EAEC64B-5E6D-3E13-80AC-2DED9C3F0A28> /Applications/Adobe InDesign CC/*/JPEG Export UI
       0x10d4fc000 -        0x10d4fcfff  com.apple.applescript.component (2.2.1 - 2.2.1) <C1B5F02E-C2AE-3BAD-9411-BF252FC88022> /System/Library/Components/AppleScript.component/Contents/MacOS/AppleScript
       0x10d720000 -        0x10d746ff7 +com.adobe.InDesign.LILO (9.1.0.33 - ???) <30921CBA-EDDD-3146-AAFC-57C738B06CD7> /Applications/Adobe InDesign CC/*/LILO
       0x10d754000 -        0x10d82ffff +com.adobe.linguistic.LinguisticManager (7.0.0 - 19061) <FDBCF369-5EFE-33BB-893A-2136EF8D0D6E> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
       0x10d84b000 -        0x10d8a8fff +com.adobe.InDesign.Media Import Filter (9.1.0.33 - ???) <E612697E-17AF-3305-B5CF-F7BCA68C4777> /Applications/Adobe InDesign CC/*/Media Import Filter
       0x10d8bb000 -        0x10d8c2ff7 +com.adobe.InDesign.InCopyExportUI (9.1.0.33 - ???) <F0EB0F82-C96B-3B9D-92C5-66E2DCC416DF> /Applications/Adobe InDesign CC/*/InCopyExportUI
       0x10db14000 -        0x10db3eff7 +com.adobe.InDesign.Sangam Preferences UI (9.1.0.33 - ???) <BCFBDD3B-9562-3F7A-AFE7-052DE0E3620E> /Applications/Adobe InDesign CC/*/Sangam Preferences UI
       0x10db51000 -        0x10dba2fff +com.adobe.InDesign.SangamExport (9.1.0.33 - ???) <F8CCDC32-FBFF-38FA-95BE-EB388F00556C> /Applications/Adobe InDesign CC/*/SangamExport
       0x10dbb9000 -        0x10dbcfff7 +com.adobe.InDesign.SaveBack (9.1.0.33 - ???) <546099DF-3333-3037-8591-FA07773367B5> /Applications/Adobe InDesign CC/*/SaveBack
       0x10dbdd000 -        0x10dbe9fff +com.adobe.InDesign.Tagged Text Filters UI (9.1.0.33 - ???) <83C996D8-4E24-3511-A666-70DE47F3DE39> /Applications/Adobe InDesign CC/*/Tagged Text Filters UI
       0x10dbf4000 -        0x10dbf8fff +com.adobe.InDesign.Help (9.1.0.33 - ???) <09CFAB79-828F-39A9-8E6C-634999CF4EC8> /Applications/Adobe InDesign CC/*/Help
       0x10de00000 -        0x10df15fff +com.adobe.InDesign.EBookExport (9.1.0.33 - ???) <C10A49CB-2581-33F9-A50F-766E6345F843> /Applications/Adobe InDesign CC/*/EBookExport
       0x10df3d000 -        0x10dfa6fff +com.adobe.AdobeSangam (AdobeSangam 5.65.0.30369 - 5.65.0.30369) <BCD8B3F6-970F-3DEA-A583-7473FDDCA067> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeSangam.framework/Versions/A/AdobeSangam
       0x10dff4000 -        0x10e135ff7 +com.adobe.InDesign.SangamServicer-Mapper (9.1.0.33 - ???) <F1BCCC8E-BDE9-3299-A144-B70F607763F5> /Applications/Adobe InDesign CC/*/SangamServicer-Mapper
       0x10e159000 -        0x10e22cff7 +com.adobe.InDesign.Tagged Text Attributes (9.1.0.33 - ???) <63FB581D-0334-3755-8697-6051DBBA1716> /Applications/Adobe InDesign CC/*/Tagged Text Attributes
       0x10e25b000 -        0x10e300fff +com.adobe.InDesign.Tagged Text Filters (9.1.0.33 - ???) <36C8468C-1362-31F8-87C6-D8FA7EB933BC> /Applications/Adobe InDesign CC/*/Tagged Text Filters
       0x10e315000 -        0x10e322fff +com.adobe.InDesign.Clipping Path Dialog (9.1.0.33 - ???) <93D2E8FF-D77F-3DBA-96AF-116B460D22C3> /Applications/Adobe InDesign CC/*/Clipping Path Dialog
       0x10e334000 -        0x10e378ff7 +com.adobe.InDesign.Color Management UI (9.1.0.33 - ???) <E1F74CF9-8EF7-3EDE-9A4B-D8588C99A23F> /Applications/Adobe InDesign CC/*/Color Management UI
       0x10e388000 -        0x10e404fff +com.adobe.InDesign.Color Picker Panel (9.1.0.33 - ???) <A2B35463-46D7-3033-AC02-DE4A307F8864> /Applications/Adobe InDesign CC/*/Color Picker Panel
       0x10e42c000 -        0x10e641ff7 +com.adobe.InDesign.Digital Publishing (9.0.10.28 - ???) <3DEACF5D-7856-3674-925E-95058D4CBBFE> /Applications/Adobe InDesign CC/*/Digital Publishing
       0x10e7c0000 -        0x10e7d2fff +com.adobe.boost_filesystem.framework (7.0.847203 - 7.0.847203.0) <B0F56E9F-BAAB-34C5-93C4-C713203AB0DF> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
       0x10e7e3000 -        0x10e81bfef +libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <FA1D87DC-8CBC-3645-8ADA-D974B6EDED53> /Applications/Adobe InDesign CC/*/libcurl.4.dylib
       0x10e826000 -        0x10e84dfff  libssl.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <B0925A5D-5355-3ECE-BF2F-E576FF105F5A> /usr/lib/libssl.0.9.7.dylib
       0x10e85e000 -        0x10e941fff  libcrypto.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <358B5B40-43B2-3F92-9FD3-DAA68806E1FF> /usr/lib/libcrypto.0.9.7.dylib
       0x10e997000 -        0x10ea17ff7 +com.adobe.InDesign.DynamicDocumentsUI (9.1.0.33 - ???) <3DF5B8E9-480D-3634-B410-8186F88A5489> /Applications/Adobe InDesign CC/*/DynamicDocumentsUI
       0x10ea3e000 -        0x10ea5afff +com.adobe.InDesign.EPS UI (9.1.0.33 - ???) <CB5EB4C4-04F6-36B0-8CC1-82C59C2FD56B> /Applications/Adobe InDesign CC/*/EPS UI
       0x10ea6b000 -        0x10ea77ff7 +com.adobe.InDesign.Generic Style Editor (9.1.0.33 - ???) <6DD52448-3D93-3D78-AEE4-BB5B78D2B018> /Applications/Adobe InDesign CC/*/Generic Style Editor
       0x10ea86000 -        0x10eabcfff +com.adobe.InDesign.Gradient Panel (9.1.0.33 - ???) <A0B7F034-768A-3725-8F03-7302B1014374> /Applications/Adobe InDesign CC/*/Gradient Panel
       0x10ead3000 -        0x10eb75fff +com.adobe.InDesign.Graphic Panels (9.1.0.33 - ???) <23239156-9058-3019-8ECD-88DA24122B99> /Applications/Adobe InDesign CC/*/Graphic Panels
       0x10eb9e000 -        0x10ebb9fff +com.adobe.InDesign.JPEG Export (9.1.0.33 - ???) <DB2C27D2-B1A9-37BF-BFB4-484E28CFC2E5> /Applications/Adobe InDesign CC/*/JPEG Export
       0x10ebcb000 -        0x10ec1cff7 +com.adobe.InDesign.Output Preview (9.1.0.33 - ???) <BF8EA07F-798D-3D9F-872B-F75E35376CCE> /Applications/Adobe InDesign CC/*/Output Preview
       0x10ec36000 -        0x10ec4dff7 +com.adobe.InDesign.OutputMiscUI (9.1.0.33 - ???) <BACF73C7-0ABA-361D-8F85-840CF055968A> /Applications/Adobe InDesign CC/*/OutputMiscUI
       0x10ec60000 -        0x10ece1fff +com.adobe.InDesign.PDF UI (9.1.0.33 - ???) <2ABDFC92-F233-3DD2-9F41-6EA7F34B2E1E> /Applications/Adobe InDesign CC/*/PDF UI
       0x10ed05000 -        0x10ed72fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.5 -c 14 - 79.151481) <BCDB9366-EDB3-3FEA-854D-3D2C72D48781> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
       0x10ed7d000 -        0x10ed94ff7 +com.adobe.InDesign.Printer Styles (9.1.0.33 - ???) <ACDF3B96-030B-3A7A-B552-661D4EF28F6D> /Applications/Adobe InDesign CC/*/Printer Styles
       0x10eda3000 -        0x10ee85fff +com.adobe.InDesign.PrintUI (9.1.0.33 - ???) <8CF1D4F4-85B0-3B0E-ABB8-DF70DA17609C> /Applications/Adobe InDesign CC/*/PrintUI
       0x10eeb1000 -        0x10eec3ff7 +com.adobe.InDesign.PS Import UI (9.1.0.33 - ???) <6F36235F-8819-3C30-8DCE-2771243875BE> /Applications/Adobe InDesign CC/*/PS Import UI
       0x10eed2000 -        0x10eef5fff +com.adobe.InDesign.Swatch Library Panel (9.1.0.33 - ???) <DE2CA80F-CE46-3CD9-9FD4-EA8E9E672B1E> /Applications/Adobe InDesign CC/*/Swatch Library Panel
       0x10ef04000 -        0x10efc1ff7 +com.adobe.InDesign.Swatches Panel (9.1.0.33 - ???) <E9F1F194-99D8-35E5-8685-5C8DC4508EE6> /Applications/Adobe InDesign CC/*/Swatches Panel
       0x10eff8000 -        0x10f0a7ff7 +com.adobe.InDesign.Transparency UI (9.1.0.33 - ???) <469B9D94-8BA5-3F4C-98BE-AD7BE885BFC7> /Applications/Adobe InDesign CC/*/Transparency UI
       0x10f0da000 -        0x10f13efff +com.adobe.InDesign.Assignment UI (9.1.0.33 - ???) <63DC234B-5418-3FEF-961C-04E65E8F376D> /Applications/Adobe InDesign CC/*/Assignment UI
       0x10f160000 -        0x10f183fff +com.adobe.InDesign.InCopy Bridge UI (9.1.0.33 - ???) <7923E03C-96CB-3369-8CEC-1EA4E369DE70> /Applications/Adobe InDesign CC/*/InCopy Bridge UI
       0x10f191000 -        0x10f1d0ff7 +com.adobe.InDesign.InCopy Bridge (9.1.0.33 - ???) <F476293E-F020-3CDB-9A0C-660B91A71281> /Applications/Adobe InDesign CC/*/InCopy Bridge
       0x10f1e0000 -        0x10f1e8fff +com.adobe.InDesign.InCopyExport (9.1.0.33 - ???) <9ACE4231-FCB8-3995-BE0E-ED6DBEAA58B7> /Applications/Adobe InDesign CC/*/InCopyExport
       0x10f1f2000 -        0x10f1fafff +com.adobe.InDesign.InCopyWorkflow UI (9.1.0.33 - ???) <F7524889-E7AC-3177-AFF7-B487FD6BF7D6> /Applications/Adobe InDesign CC/*/InCopyWorkflow UI
       0x10f205000 -        0x10f25cff7 +com.adobe.InDesign.Note (9.1.0.33 - ???) <07808666-F165-34C1-9E46-D4403EC7C6A6> /Applications/Adobe InDesign CC/*/Note
       0x10f27c000 -        0x10f287ff7 +com.adobe.InDesign.NotePref (9.1.0.33 - ???) <D1FA4217-A5A8-31D2-9178-D94F2F048790> /Applications/Adobe InDesign CC/*/NotePref
       0x10f295000 -        0x10f29aff7 +com.adobe.InDesign.Username UI (9.1.0.33 - ???) <D3009947-D338-3EAB-9690-722AB9C10FB3> /Applications/Adobe InDesign CC/*/Username UI
       0x10f2a4000 -        0x10f345ff7 +com.adobe.InDesign.ButtonUI (9.1.0.33 - ???) <80905FB7-290E-3CBF-9544-4B3ADF9EA03F> /Applications/Adobe InDesign CC/*/ButtonUI
       0x10f374000 -        0x10f39cff7 +com.adobe.InDesign.MediaUI (9.1.0.33 - ???) <7ECB27BD-1D9D-3AF9-B649-97A711719520> /Applications/Adobe InDesign CC/*/MediaUI
       0x10f3b1000 -        0x10f3c1fff +com.adobe.InDesign.Alignment Panel (9.1.0.33 - ???) <54940D94-3BB6-38D7-B45B-14906B94A6C3> /Applications/Adobe InDesign CC/*/Alignment Panel
       0x10f3ca000 -        0x10f411fff +com.adobe.InDesign.Asset Library Panel (9.1.0.33 - ???) <C43845BE-9F2F-31A4-AB1E-2E031415722F> /Applications/Adobe InDesign CC/*/Asset Library Panel
       0x10f435000 -        0x10f4a2ff7 +com.adobe.InDesign.Asset PubLibrary (9.1.0.33 - ???) <DCD77415-2134-3E42-9CD6-FA9E47BCD4BF> /Applications/Adobe InDesign CC/*/Asset PubLibrary
       0x10f4c0000 -        0x10f50dff7 +com.adobe.InDesign.Book Panel (9.1.0.33 - ???) <8114886F-3760-31DF-A429-078084FA7AA7> /Applications/Adobe InDesign CC/*/Book Panel
       0x10f530000 -        0x10f54cfff +com.adobe.InDesign.Bookmark Panel (9.1.0.33 - ???) <2D72245E-E8B5-3958-8B1E-A47CFC64D8BB> /Applications/Adobe InDesign CC/*/Bookmark Panel
       0x10f563000 -        0x10f59cfff +com.adobe.InDesign.ContentDropper Tool (9.1.0.33 - ???) <99A68583-FDFD-38B8-A727-86CA230F62EF> /Applications/Adobe InDesign CC/*/ContentDropper Tool
       0x10f5bb000 -        0x10f601ff7 +com.adobe.InDesign.Control Panel (9.1.0.33 - ???) <15528F16-3629-3E3B-90A8-E5CBD8E31B45> /Applications/Adobe InDesign CC/*/Control Panel
       0x10f61e000 -        0x10f628fff +com.adobe.InDesign.Create Guides Dialog (9.1.0.33 - ???) <59B37FF3-166C-3BA0-88F9-B48121D455FA> /Applications/Adobe InDesign CC/*/Create Guides Dialog
       0x10f633000 -        0x10f66dfff +com.adobe.InDesign.Eyedropper Tool (9.1.0.33 - ???) <6EB8BC12-7868-3B4C-BAD1-851801E0A42E> /Applications/Adobe InDesign CC/*/Eyedropper Tool
       0x10f682000 -        0x10f70ffff +com.adobe.InDesign.Hyperlinks Panel (9.1.0.33 - ???) <0AB14BC3-AC1D-3DDC-B451-449644AF37D2> /Applications/Adobe InDesign CC/*/Hyperlinks Panel
       0x10f734000 -        0x10f7c4fff +com.adobe.InDesign.Index Panel (9.1.0.33 - ???) <3B1558CE-A272-35B4-A8A3-FFD880B3630B> /Applications/Adobe InDesign CC/*/Index Panel
       0x10f7e4000 -        0x10f7f0ff7  com.apple.carbonframeworktemplate (1.0 - 1.0) <E859A35E-8EC1-3CA9-9758-95EC69D4EC5D> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/unihan.framework/Versions/A/unihan
       0x10f7fb000 -        0x10f864fff +com.adobe.InDesign.Info Panel (9.1.0.33 - ???) <1C0402F5-4C5E-3D10-88BA-7407A40E3965> /Applications/Adobe InDesign CC/*/Info Panel
       0x10f87c000 -        0x10f940fff +com.adobe.InDesign.Knowledge Base (9.1.0.33 - ???) <E650B6BD-690B-37A0-9371-970563634B38> /Applications/Adobe InDesign CC/*/Knowledge Base
       0x10f94a000 -        0x10f99dff7 +com.adobe.InDesign.Layers Panel (9.1.0.33 - ???) <52C05DD0-6A95-3032-B41C-2B480A5EED88> /Applications/Adobe InDesign CC/*/Layers Panel
       0x10f9bf000 -        0x10f9c4fff +com.adobe.InDesign.Layout Adjustment Panel (9.1.0.33 - ???) <098313B3-96FB-3AF9-BC24-2F3CA93AFB4C> /Applications/Adobe InDesign CC/*/Layout Adjustment Panel
       0x10f9cd000 -        0x10f9ecfff +com.adobe.InDesign.Layout Adjustment (9.1.0.33 - ???) <DB9C45CC-3A38-3875-BBDF-399DCB593A14> /Applications/Adobe InDesign CC/*/Layout Adjustment
       0x10f9fb000 -        0x10fa47ff7 +com.adobe.InDesign.Links UI (9.1.0.33 - ???) <C4F379A7-7AC3-3504-BADC-ABCCFE5100A0> /Applications/Adobe InDesign CC/*/Links UI
       0x10fa69000 -        0x10fb0eff7 +com.adobe.InDesign.ObjectStylesUI (9.1.0.33 - ???) <58E9476C-6716-3CA3-BDCD-E1AA5DF42624> /Applications/Adobe InDesign CC/*/ObjectStylesUI
       0x10fb3e000 -        0x10fb64fff +com.adobe.InDesign.Page Setup Dialog (9.1.0.33 - ???) <F138A322-9F60-3A17-B2C7-9F05A7E8BD98> /Applications/Adobe InDesign CC/*/Page Setup Dialog
       0x10fb71000 -        0x10fc35fff +com.adobe.InDesign.Pages Panel (9.1.0.33 - ???) <C072BBAE-E49A-307E-A115-C5CDC298C9C7> /Applications/Adobe InDesign CC/*/Pages Panel
       0x10fc66000 -        0x10fc75fff +com.adobe.InDesign.Sections UI (9.1.0.33 - ???) <3FD8D737-8DA8-3707-9031-FB97E05D9FB9> /Applications/Adobe InDesign CC/*/Sections UI
       0x10fc80000 -        0x10fc8afff +com.adobe.InDesign.StepRepeat (9.1.0.33 - ???) <0F3A3EC5-6BF6-3D92-B2A9-A8D571E51B54> /Applications/Adobe InDesign CC/*/StepRepeat
       0x10fc96000 -        0x10fcd5ff7 +com.adobe.InDesign.Text Wrap Panel (9.1.0.33 - ???) <0767C906-FE80-30D5-89E1-78D3F7AC8A5A> /Applications/Adobe InDesign CC/*/Text Wrap Panel
       0x10fcee000 -        0x10fd30fff +com.adobe.InDesign.TOC UI Dialog (9.1.0.33 - ???) <942CA8F6-F094-3F26-97BE-4B7B59AE80C7> /Applications/Adobe InDesign CC/*/TOC UI Dialog
       0x10fd4a000 -        0x10fd86ff7 +com.adobe.InDesign.Transform Panel (9.1.0.33 - ???) <597F9458-996D-3C22-A150-BEF828D5634D> /Applications/Adobe InDesign CC/*/Transform Panel
       0x10fd9c000 -        0x10fdb7fff +com.adobe.InDesign.Image Import UI (9.1.0.33 - ???) <BBC09119-A690-340C-93A7-E27B238004B6> /Applications/Adobe InDesign CC/*/Image Import UI
       0x10fdc9000 -        0x10fddffff +com.adobe.InDesign.Scotch Rules (9.1.0.33 - ???) <7BB10CB0-31B7-3B31-B2A5-97B8792273C3> /Applications/Adobe InDesign CC/*/Scotch Rules
       0x10fdea000 -        0x10fe4eff7 +com.adobe.InDesign.BNUI (9.1.0.33 - ???) <A687AB81-E289-3AFD-BDC5-3350B0C1122D> /Applications/Adobe InDesign CC/*/BNUI
       0x10fe6e000 -        0x10ff0fff7 +com.adobe.InDesign.DataMerge (9.1.0.33 - ???) <B879F1CA-45D4-31BE-A831-68226DBFE3C9> /Applications/Adobe InDesign CC/*/DataMerge
       0x10ff2f000 -        0x10ff63fff +com.adobe.InDesign.DataMergeUI (9.1.0.33 - ???) <A3FE421A-366E-3C90-B1C3-F7CD52F87B5D> /Applications/Adobe InDesign CC/*/DataMergeUI
       0x10ff7e000 -        0x110086fff +com.adobe.InDesign.Package and Preflight UI (9.1.0.33 - ???) <7FDC6527-29B8-3307-BE94-CBDA2B5C4B4E> /Applications/Adobe InDesign CC/*/Package and Preflight UI
       0x1100c5000 -        0x110328fff +com.adobe.InDesign.Package and Preflight (9.1.0.33 - ???) <C93636A7-6DFF-3976-93BA-3753C7961356> /Applications/Adobe InDesign CC/*/Package and Preflight
       0x11036e000 -        0x11045cfff +com.adobe.InDesign.JBX (9.1.0.33 - ???) <F9C75EA9-28AF-31BF-9A6E-6EE1E6010591> /Applications/Adobe InDesign CC/*/JBX
       0x110486000 -        0x11048cfff +com.adobe.InDesign.Script Label Panel (9.1.0.33 - ???) <CF90BDAA-5B8E-33EB-B580-972C71104678> /Applications/Adobe InDesign CC/*/Script Label Panel
       0x110498000 -        0x1104a6ff7 +com.adobe.InDesign.Scripts Panel (9.1.0.33 - ???) <AF5E85D2-EBFB-33C2-966C-FEE87EE8211D> /Applications/Adobe InDesign CC/*/Scripts Panel
       0x1104b5000 -        0x1104e7fff +com.adobe.InDesign.Conditional Text UI (9.1.0.33 - ???) <30D77E16-CF41-3627-B3E3-E449847F7AA5> /Applications/Adobe InDesign CC/*/Conditional Text UI
       0x11050a000 -        0x11050afff +DTraceSupport.dylib (??? - ???) <E54DF20B-C169-68CF-A3F5-0470DEFF1C8A> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/DTraceSupport.dylib
       0x112497000 -        0x112623ff7 +com.adobe.InDesign.SettingsInCloud (9.1.0.33 - ???) <6B6F6595-0020-3775-85EB-F315636F8BDC> /Applications/Adobe InDesign CC/*/SettingsInCloud
       0x1126b1000 -        0x112796fff +com.adobe.InDesign.Tables UI (9.1.0.33 - ???) <DE20E47C-580C-30A0-847B-E4F07122331D> /Applications/Adobe InDesign CC/*/Tables UI
       0x1127c5000 -        0x112869ff7 +com.adobe.InDesign.TableStylesUI (9.1.0.33 - ???) <2CE8F674-586E-3EB9-88B3-A4ECBDF0187F> /Applications/Adobe InDesign CC/*/TableStylesUI
       0x112895000 -        0x112921fff +com.adobe.InDesign.Character Panel (9.1.0.33 - ???) <A91DF108-9F28-36E4-A4B8-1A525F98C503> /Applications/Adobe InDesign CC/*/Character Panel
       0x11295d000 -        0x11297aff7 +com.adobe.InDesign.Create Outlines (9.1.0.33 - ???) <67E01895-4459-3227-97EE-05C08FAF12A7> /Applications/Adobe InDesign CC/*/Create Outlines
       0x112987000 -        0x112aacff7 +com.adobe.InDesign.Find and Change Panel (9.1.0.33 - ???) <DD6F373A-18D1-34B1-BD0C-330DD07603F9> /Applications/Adobe InDesign CC/*/Find and Change Panel
       0x112ae9000 -        0x112b15ff7 +com.adobe.InDesign.Find Change Format Panel (9.1.0.33 - ???) <59B463B6-6D3B-3D25-B353-4A99C6301B2A> /Applications/Adobe InDesign CC/*/Find Change Format Panel
       0x112b29000 -        0x112b53fff +com.adobe.InDesign.Font Usage Dialog (9.1.0.33 - ???) <872B9689-D8D1-3237-87E4-1D820ABD3402> /Applications/Adobe InDesign CC/*/Font Usage Dialog
       0x112b63000 -        0x112c33fff +com.adobe.InDesign.Glyphs Panel (9.1.0.33 - ???) <4137222E-0361-3589-A8CF-6C1529BC73E0> /Applications/Adobe InDesign CC/*/Glyphs Panel
       0x112c57000 -        0x112c61fff +com.adobe.InDesign.Hyphenation Panel (9.1.0.33 - ???) <CE3045F4-F009-33E4-904D-557A76A05216> /Applications/Adobe InDesign CC/*/Hyphenation Panel
       0x112c6e000 -        0x112c81ff7 +com.adobe.InDesign.Indents and Tabs (9.1.0.33 - ???) <DE29B198-9C8D-3BF5-AA17-D96ACBA00E43> /Applications/Adobe InDesign CC/*/Indents and Tabs
       0x112c90000 -        0x112c9afff +com.adobe.InDesign.Justification Panel (9.1.0.33 - ???) <4F940073-AAF8-3FDF-87FA-04A8DC87679D> /Applications/Adobe InDesign CC/*/Justification Panel
       0x112ca5000 -        0x112cadff7 +com.adobe.InDesign.Keeps Panel (9.1.0.33 - ???) <B93BD9B2-6C80-39E6-8A20-C37883A904E4> /Applications/Adobe InDesign CC/*/Keeps Panel
       0x112cb5000 -        0x112cd5ff7 +com.adobe.InDesign.Optical Kerning (9.1.0.33 - ???) <24369EBE-1766-35EC-9A39-DE5167F0A8AE> /Applications/Adobe InDesign CC/*/Optical Kerning
       0x112ce0000 -        0x112d14ff7 +com.adobe.InDesign.Paragraph Panel (9.1.0.33 - ???) <AF14E0F9-4234-355B-816F-A19A7BCE8676> /Applications/Adobe InDesign CC/*/Paragraph Panel
       0x112d27000 -        0x112d39ff7 +com.adobe.InDesign.Paragraph Rules Panel (9.1.0.33 - ???) <505B0CE0-4873-3DA9-97BC-1CE80B8A81E4> /Applications/Adobe InDesign CC/*/Paragraph Rules Panel
       0x112d43000 -        0x112d5afff +com.adobe.InDesign.Path Type UI (9.1.0.33 - ???) <5FBB48B2-8E60-3BFA-82EA-A52467B9831A> /Applications/Adobe InDesign CC/*/Path Type UI
       0x112d6a000 -        0x112d74ff7 +PathTypeLib.dylib (??? - ???) <A6E44FB4-61D6-3729-B3DD-A4D22EEC73B3> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/PathTypeLib.dylib
       0x112d7d000 -        0x112daafff +com.adobe.InDesign.RunIn Styles Panel (9.1.0.33 - ???) <EE33D598-7F48-3DCE-A596-B619BE63F8EE> /Applications/Adobe InDesign CC/*/RunIn Styles Panel
       0x112dbc000 -        0x112dcdfff +com.adobe.InDesign.SING (9.1.0.33 - ???) <78835D9D-56FB-39EB-A216-F3494451AC42> /Applications/Adobe InDesign CC/*/SING
       0x112dd7000 -        0x112de1ff7 +com.adobe.InDesign.Span Columns Panel (9.1.0.33 - ???) <15F063E0-7874-30AE-841C-C10A12CF8B5E> /Applications/Adobe InDesign CC/*/Span Columns Panel
       0x112dea000 -        0x112e36ff7 +com.adobe.InDesign.Spelling Panel (9.1.0.33 - ???) <B208BBCC-1AAB-354C-9CA6-44C6B5D35946> /Applications/Adobe InDesign CC/*/Spelling Panel
       0x112e50000 -        0x112e64ff7 +com.adobe.InDesign.Story Panel (9.1.0.33 - ???) <989D8312-C513-36B9-9A2A-A161EC806905> /Applications/Adobe InDesign CC/*/Story Panel
       0x112e73000 -        0x112eeeff7 +com.adobe.InDesign.Style Panel (9.1.0.33 - ???) <60EEDE2C-6BBC-3E5F-9F69-C5A001DAE984> /Applications/Adobe InDesign CC/*/Style Panel
       0x112f17000 -        0x112f24ff7 +com.adobe.InDesign.Text Color Panel (9.1.0.33 - ???) <B9722BDD-B3B2-3B6B-90EC-D7B52D54C678> /Applications/Adobe InDesign CC/*/Text Color Panel
       0x112f2d000 -        0x112f59ff7 +com.adobe.InDesign.Text Frame Options (9.1.0.33 - ???) <24DF4463-54CA-3FC3-95E3-E8C791B12169> /Applications/Adobe InDesign CC/*/Text Frame Options
       0x112f6a000 -        0x112fcffff +com.adobe.InDesign.Text Panel (9.1.0.33 - ???) <C10930A1-FDA7-36B6-B79D-6E6F73BA4EEC> /Applications/Adobe InDesign CC/*/Text Panel
       0x112ff2000 -        0x113014fff +com.adobe.InDesign.Text Preferences (9.1.0.33 - ???) <8C47BE3B-1091-32A2-9059-386030EC9C49> /Applications/Adobe InDesign CC/*/Text Preferences
       0x113024000 -        0x113047ff7 +com.adobe.InDesign.Text Ruler (9.1.0.33 - ???) <7B9A2B91-60B5-32FD-8244-6372495C16BF> /Applications/Adobe InDesign CC/*/Text Ruler
       0x113058000 -        0x11307dff7 +com.adobe.InDesign.Text Style Panel (9.1.0.33 - ???) <8313AC57-723E-3409-97C3-4E33665F8396> /Applications/Adobe InDesign CC/*/Text Style Panel
       0x11308e000 -        0x1130bafff +com.adobe.InDesign.Article Panel (9.1.0.33 - ???) <8D03DC8F-4D9F-34F3-9046-25CDE3D4FE03> /Applications/Adobe InDesign CC/*/Article Panel
       0x1130d3000 -        0x113104ff7 +com.adobe.InDesign.CSXS (9.1.0.33 - ???) <96685203-48A3-39BD-B0A9-90FE7AF33B87> /Applications/Adobe InDesign CC/*/CSXS
       0x11311c000 -        0x113154ff7 +com.adobe.InDesign.Galley Preferences (9.1.0.33 - ???) <F96A6961-E3CD-36DC-9C6F-CACBC0B74579> /Applications/Adobe InDesign CC/*/Galley Preferences
       0x11316f000 -        0x113190fff +com.adobe.InDesign.GapTool (9.1.0.33 - ???) <21C1069C-5783-3940-92A6-A345FCC317AA> /Applications/Adobe InDesign CC/*/GapTool
       0x1131a0000 -        0x1131abff7 +com.adobe.InDesign.General Preferences Panel (9.1.0.33 - ???) <EDF87C7F-BF1E-36D1-8E71-55B4D8DD1C4A> /Applications/Adobe InDesign CC/*/General Preferences Panel
       0x1131b6000 -        0x1131c9ff7 +com.adobe.ahclientframework (1.8.0.31 - 1.8.0.31) <58BB943C-98EC-3812-AAAB-74F66630D1D4> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
       0x1131d0000 -        0x1131ecff7 +com.adobe.InDesign.Performance UI (9.1.0.33 - ???) <F2E0971B-A70C-39CF-91CF-3F4F25B176B5> /Applications/Adobe InDesign CC/*/Performance UI
       0x113201000 -        0x113225ff7 +com.adobe.InDesign.SharedContentUI (9.1.0.33 - ???) <F933D1D2-262B-373D-9C38-9A95EF456410> /Applications/Adobe InDesign CC/*/SharedContentUI
       0x113234000 -        0x11325afff +com.adobe.InDesign.Shortcut Editor Dialog (9.1.0.33 - ???) <C4A827C6-AA10-3628-8967-01B9CD5EF71E> /Applications/Adobe InDesign CC/*/Shortcut Editor Dialog
       0x11326e000 -        0x11328eff7 +com.adobe.InDesign.Tool Box (9.1.0.33 - ???) <D5B0587D-3C0B-3A05-8153-6CEAD7953792> /Applications/Adobe InDesign CC/*/Tool Box
       0x1132b2000 -        0x1132bafff +com.adobe.InDesign.Tool Tips (9.1.0.33 - ???) <2A39F9CA-AD4D-31DE-A547-150997D5731D> /Applications/Adobe InDesign CC/*/Tool Tips
       0x1132c3000 -        0x1132cbfff +com.adobe.InDesign.Track Changes Preferences (9.1.0.33 - ???) <5A658631-2249-3036-A041-EE8CB387BF8B> /Applications/Adobe InDesign CC/*/Track Changes Preferences
       0x1132d5000 -        0x1132ecff7 +com.adobe.InDesign.Track Changes UI (9.1.0.33 - ???) <01C328F8-3440-3866-B596-D03D78FA5BF3> /Applications/Adobe InDesign CC/*/Track Changes UI
       0x1132f7000 -        0x113303ff7 +com.adobe.InDesign.PerformanceMetrics (9.1.0.33 - ???) <67E7E2B5-61E3-3F40-B440-5FE1EDE59E77> /Applications/Adobe InDesign CC/*/PerformanceMetrics
       0x11330e000 -        0x11331dff7 +com.adobe.InDesign.Metadata UI (9.1.0.33 - ???) <442F11B4-4698-3BED-BADD-F1E858A7DCB7> /Applications/Adobe InDesign CC/*/Metadata UI
       0x113327000 -        0x113398fe7 +com.adobe.FileInfo.framework (Adobe XMP FileInfo 5 . 3 . 0 . 0 -i 3 - 79.151561) <380981FE-6528-37CC-9159-AB1892803BD4> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
       0x1133ab000 -        0x1133b5fff +com.adobe.InDesign.Workgroup UI (9.1.0.33 - ???) <F8322558-0D2F-396E-B517-C55212DAB68B> /Applications/Adobe InDesign CC/*/Workgroup UI
       0x1133be000 -        0x11340fff7 +com.adobe.InDesign.Snippet (9.1.0.33 - ???) <5CC75DF2-5697-3E17-920D-1536AED78A9A> /Applications/Adobe InDesign CC/*/Snippet
       0x113428000 -        0x113557ff7 +com.adobe.InDesign.XMedia UI (9.1.0.33 - ???) <B37B0973-4F9F-37F5-B7FC-FA2E9602F1EA> /Applications/Adobe InDesign CC/*/XMedia UI
       0x1135a1000 -        0x113604ff7 +com.adobe.InDesign.Actions (9.1.0.33 - ???) <5673AFC0-08B8-3B67-8447-7C64C1B58E27> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Actions.InDesignPlugin/Actions
       0x11361f000 -        0x1137e3ff7 +com.adobe.InDesign.AppFramework (9.1.0.33 - ???) <BF1B290E-456C-3D0F-8157-283614AF4235> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/AppFramework.InDesignPlugin/AppFramework
       0x113877000 -        0x113a8bff7 +com.adobe.InDesign.Application UI (9.1.0.33 - ???) <E3C17BFD-316C-3537-BB02-0DD33E63C7DC> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Application UI.InDesignPlugin/Application UI
       0x113b22000 -        0x113e40ff7 +com.adobe.dvaadameve.framework (7.0.853914 - 7.0.853914.0) <F3B6585F-C6E9-3BB2-B4A8-2730B6CEEAB4> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
       0x114116000 -        0x114165fff +com.adobe.headlights.LogSessionFramework (??? - 2.1.2.1756) <BD518257-970F-344A-92B8-B8BE1A8EB4D8> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
       0x11418b000 -        0x114249ff7 +com.adobe.AdobeExtendScript (ExtendScript 4.5.5 - 4.5.5.30772) <4FC0039A-A770-3A51-9D7A-D24167344540> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
       0x114271000 -        0x11431cff7 +com.adobe.AdobeScCore (ScCore 4.5.5 - 4.5.5.30772) <5DE0B54D-CDAE-3146-904F-72CBC5C89FA7> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
       0x114346000 -        0x114490fff +com.adobe.dvascriptui.framework (7.0.6 - 7.0.6.0) <9A133FD8-BE29-3AD1-B3A7-ED1C7466C159> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/dvascriptui.framework/Versions/A/dvascriptui
       0x1145aa000 -        0x1145d0ff7 +com.adobe.InDesign.Article (9.1.0.33 - ???) <5594CD9B-844A-3C9F-949A-93F520ACCD63> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Article.InDesignPlugin/Article
       0x1145e0000 -        0x11467dfff +com.adobe.InDesign.Assignments (9.1.0.33 - ???) <EAD2FFCF-B8E5-3530-B58E-474904578138> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Assignments.InDesignPlugin/Assignments
       0x11469e000 -        0x1147aaff7 +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.6 -f 45 - 79.151481) <7B2C5F12-A861-3EA3-A5E1-A0ABF705EB5D> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
       0x1147df000 -        0x11481ffff +com.adobe.InDesign.AWS (9.1.0.33 - ???) <4503E027-C352-3E36-B97F-053F163815B3> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/AWS.InDesignPlugin/AWS
       0x114838000 -        0x114863ff7 +com.adobe.InDesign.AWSUI (9.1.0.33 - ???) <6CDDCDEE-176D-3E7E-A666-3CE5045EA3CB> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/AWSUI.InDesignPlugin/AWSUI
       0x114878000 -        0x1148b2ff7 +com.adobe.InDesign.Basic Tools (9.1.0.33 - ???) <67E340EB-CE3F-334F-B1FB-7B0FBCE2AB75> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Basic Tools.InDesignPlugin/Basic Tools
       0x1148cd000 -        0x114936fff +com.adobe.InDesign.Behavior (9.1.0.33 - ???) <9224EBBE-1184-30AC-9C0B-7776AC77A582> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Behavior.InDesignPlugin/Behavior
       0x114954000 -        0x1149f6ff7 +com.adobe.InDesign.BNCore (9.1.0.33 - ???) <7370C6DC-E42A-3AE4-9E2B-AE876B3A625F> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/BNCore.InDesignPlugin/BNCore
       0x114a14000 -        0x114a7afff +com.adobe.InDesign.Book (9.1.0.33 - ???) <04687BA9-AAB6-3DEF-A1CB-387134C9C01C> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Book.InDesignPlugin/Book
       0x114a91000 -        0x114acafff +com.adobe.InDesign.CellStyles (9.1.0.33 - ???) <99BB7B71-EDF0-361B-B168-A9AB3025E24D> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/CellStyles.InDesignPlugin/CellStyles
       0x114add000 -        0x114b6dff7 +com.adobe.InDesign.CJK Text Attributes (9.1.0.33 - ???) <81D0AE00-2265-39ED-900F-C55FF6B383A7> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/CJK Text Attributes.InDesignPlugin/CJK Text Attributes
       0x114b90000 -        0x114c16fff +com.adobe.InDesign.CJKGrid (9.1.0.33 - ???) <C2AE712A-12DC-3666-A8F6-CE4572E22B87> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/CJKGrid.InDesignPlugin/CJKGrid
       0x114c32000 -        0x114d2ffff +com.adobe.InDesign.Color Management (9.1.0.33 - ???) <33023C59-D4C5-3BF2-8C42-54BD6E50E651> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Color Management.InDesignPlugin/Color Management
       0x114d5c000 -        0x114dc3fff +com.adobe.InDesign.CompFontMgr (9.1.0.33 - ???) <3058E746-133A-343A-8ED2-6AC33635DDDE> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/CompFontMgr.InDesignPlugin/CompFontMgr
       0x114ddb000 -        0x114e32fff +com.adobe.InDesign.Conditional Text (9.1.0.33 - ???) <0F92B4B6-9877-38A5-AE21-77558C13513F> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Conditional Text.InDesignPlugin/Conditional Text
       0x114e4b000 -        0x114e7fff7 +com.adobe.InDesign.ContentDropper (9.1.0.33 - ???) <770161E3-FD66-3F7E-9590-8081A26EBF87> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/ContentDropper.InDesignPlugin/ContentDropper
       0x114e93000 -        0x114eb9fff +com.adobe.InDesign.Dialog Layout (9.1.0.33 - ???) <A707ECDB-55B2-3E5F-8AB7-41AF8B5E88A9> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Dialog Layout.InDesignPlugin/Dialog Layout
       0x114ecb000 -        0x114ef1fff +com.adobe.InDesign.Document Actions (9.1.0.33 - ???) <49E39D70-73A7-34AB-9A85-6CB1E72E296C> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Document Actions.InDesignPlugin/Document Actions
       0x114efe000 -        0x1150d9fff +com.adobe.InDesign.Document Framework (9.1.0.33 - ???) <C3CE0E63-77DE-3E9E-993D-9F67D2936C47> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Document Framework.InDesignPlugin/Document Framework
       0x115116000 -        0x115120ff7 +com.adobe.InDesign.Document UI (9.1.0.33 - ???) <55DDF1E6-E82B-3200-9290-83A58959DB28> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Document UI.InDesignPlugin/Document UI
       0x11512a000 -        0x115179ff7 +com.adobe.InDesign.DV_Widgets (9.1.0.33 - ???) <A68057AD-EC2D-374C-8141-0C6D614192FD> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/DV_Widgets.InDesignPlugin/DV_Widgets
       0x1151ae000 -        0x11550bfff +com.adobe.InDesign.Dynamic Documents (9.1.0.33 - ???) <010593B4-AEE5-3454-AF7B-FBFE8A6A907E> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Dynamic Documents.InDesignPlugin/Dynamic Documents
       0x115553000 -        0x11564afff +com.adobe.AGMFL (AdobeAGMFL 2.1.0.30848 - 2.1.0.30848) <DBCCE05E-9069-3496-8154-38965BECDC31> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/ADBE_AGMFL.framework/Versions/A/ADBE_AGMFL
       0x115667000 -        0x11583efff +com.adobe.AFlamingo (AFlamingo 2.4.104.30551 - 2.4.104.30551) <0CFE6F29-B675-3D00-8A19-D204AE5B5AE4> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
       0x115862000 -        0x1159a1fe7 +com.adobe.InDesign.EPS Page Item (9.1.0.33 - ???) <D36AF79C-7FC0-3708-8AD6-E16287BA01AB> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/EPS Page Item.InDesignPlugin/EPS Page Item
       0x1159e0000 -        0x115aebfff +com.adobe.InDesign.Font Manager (9.1.0.33 - ???) <438EFE25-CC8A-35F5-8E60-84EE6DBDDFB6> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Font Manager.InDesignPlugin/Font Manager
       0x115b0a000 -        0x115be1ff7 +com.adobe.InDesign.FormField (9.1.0.33 - ???) <8D813A0F-DBD0-31EA-93DA-102D366DF99C> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/FormField.InDesignPlugin/FormField
       0x115c06000 -        0x115c67ff7 +com.adobe.InDesign.Galley (9.1.0.33 - ???) <335A35BE-36E8-361C-A94B-531476E1C1D5> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Galley.InDesignPlugin/Galley
       0x115c7c000 -        0x115dc7fff +com.adobe.InDesign.GalleyUI (9.1.0.33 - ???) <473804F7-E665-3073-A041-BD04683F20F1> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/GalleyUI.InDesignPlugin/GalleyUI
       0x115df5000 -        0x11605dff7 +com.adobe.InDesign.Generic Page Item (9.1.0.33 - ???) <838AE2F5-74A3-36A6-8F91-9DFF8A906183> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Generic Page Item.InDesignPlugin/Generic Page Item
       0x1160a8000 -        0x1160b6fff +com.adobe.InDesign.GenericSettings (9.1.0.33 - ???) <265C32A6-C9D4-3571-93BB-BF1A64FE3001> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/GenericSettings.InDesignPlugin/GenericSettings
       0x1160c0000 -        0x116130fff +com.adobe.InDesign.Gradient Fill (9.1.0.33 - ???) <FFE95F52-F173-3B84-A96C-3340E06FFE72> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Gradient Fill.InDesignPlugin/Gradient Fill
       0x11614c000 -        0x11624eff7 +com.adobe.InDesign.Graphics (9.1.0.33 - ???) <30631DCC-7478-3808-B59A-F13F67CDA22E> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Graphics.InDesignPlugin/Graphics
       0x116272000 -        0x116344fff +com.adobe.InDesign.HTMLPGT (9.1.0.33 - ???) <7837D27B-DAB6-3725-8385-A204DDABBE09> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/HTMLPGT.InDesignPlugin/HTMLPGT
       0x1163a8000 -        0x1163d0ff7 +com.adobe.InDesign.Layout (9.1.0.33 - ???) <CF27001E-F563-38AB-9FA9-FEBEEB541045> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Layout.InDesignPlugin/Layout
       0x116500000 -        0x116609ff7 +com.adobe.InDesign.Hyperlinks (9.1.0.33 - ???) <F7EE3D54-8FFF-3D3B-B08F-17D0137C2583> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Hyperlinks.InDesignPlugin/Hyperlinks
       0x116634000 -        0x11674aff7 +com.adobe.InDesign.Image (9.1.0.33 - ???) <D2CCFE82-4DF7-343D-99E7-52D5D3EEB31B> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Image.InDesignPlugin/Image
       0x116776000 -        0x1167e6fff +com.adobe.InDesign.Import Export UI (9.1.0.33 - ???) <5197B4CB-1F88-3E23-B7ED-2CE5FA9021E9> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Import Export UI.InDesignPlugin/Import Export UI
       0x11680d000 -        0x116910fff +com.adobe.InDesign.InCopyShared (9.1.0.33 - ???) <8EA9D250-8C61-35CD-A3BF-D0AF39B338A6> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/InCopyShared.InDesignPlugin/InCopyShared
       0x11693c000 -        0x1169d4ff7 +com.adobe.InDesign.InCopyWorkflow (9.1.0.33 - ???) <D6C76680-B980-3D34-A873-C8883C2779F6> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/InCopyWorkflow.InDesignPlugin/InCopyWorkflow
       0x1169fa000 -        0x116b00ff7 +com.adobe.InDesign.Indexing (9.1.0.33 - ???) <9027578A-E271-3152-8C9F-C5DF03C44BAD> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Indexing.InDesignPlugin/Indexing
       0x116b21000 -        0x116bf0fff +com.adobe.InDesign.INXCore (9.1.0.33 - ???) <7DFDC2D1-E2CE-3866-85F8-A319267E859B> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/INXCore.InDesignPlugin/INXCore
       0x116c18000 -        0x116e24ff7 +com.adobe.InDesign.Layout UI (9.1.0.33 - ???) <FF06E6B2-EE74-3EFD-8996-6C483EF8F8AE> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Layout UI.InDesignPlugin/Layout UI
       0x116e84000 -        0x116ed5fff +com.adobe.InDesign.Linguistics (9.1.0.33 - ???) <13A4BC6D-4C68-3884-9059-5837B952EC17> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Linguistics.InDesignPlugin/Linguistics
       0x116eef000 -        0x117029fff +com.adobe.InDesign.Links (9.1.0.33 - ???) <1BCD7856-3DD0-3C58-AF61-0E430CF5EFBC> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Links.InDesignPlugin/Links
       0x11705e000 -        0x117102fff +com.adobe.InDesign.Master Page (9.1.0.33 - ???) <902718A8-8B59-3D14-BD4D-2B70F84DDF24> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Master Page.InDesignPlugin/Master Page
       0x11711c000 -        0x117178ff7 +com.adobe.InDesign.Media (9.1.0.33 - ???) <560CE1DB-99AF-389F-8BC2-37D5F83C110F> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Media.InDesignPlugin/Media
       0x11718e000 -        0x117219fff +com.adobe.InDesign.Metadata (9.1.0.33 - ???) <452BEDA8-D3B2-3522-B985-DB70889E60FB> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Metadata.InDesignPlugin/Metadata
       0x117236000 -        0x11724eff7 +com.adobe.InDesign.Movie (9.1.0.33 - ???) <FD78448B-F572-32C2-9580-4A0681AC69EE> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Movie.InDesignPlugin/Movie
       0x11725d000 -        0x11729efff +com.adobe.InDesign.Open Place (9.1.0.33 - ???) <6CBC4B8F-3B3D-3B14-9512-6808497AC68A> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Open Place.InDesignPlugin/Open Place
       0x1172b2000 -        0x117367fff +com.adobe.InDesign.Paragraph Composer (9.1.0.33 - ???) <2B58802A-7448-3FB0-80EA-88FF597A8773> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Paragraph Composer.InDesignPlugin/Paragraph Composer
       0x117378000 -        0x1173bcfff +com.adobe.InDesign.Path Type (9.1.0.33 - ???) <32D8F2D5-AF06-375A-85ED-C4E42D3B790B> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Path Type.InDesignPlugin/Path Type
       0x1173d5000 -        0x117620ff7 +com.adobe.InDesign.PDF (9.1.0.33 - ???) <FD3A0CC7-2AF5-3DB4-8D0A-1025628937D2> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/PDF.InDesignPlugin/PDF
       0x117662000 -        0x11771bff7 +com.adobe.JP2K (1.2.2 - 1.2.2.29712) <869F46FB-FF39-39CA-B1E3-A13035A48B49> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
       0x117742000 -        0x117846fff +com.adobe.PDFPort (AdobePDFPort 2.1.0.30830 - 2.1.0.30830) <46896FB3-8FDB-3554-B4F6-013BB944D5EB> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
       0x117859000 -        0x117879fff +com.adobe.PDFSettings (AdobePDFSettings 1.04.0 - 1.4) <5CF62F7B-00FB-D2B8-F320-63316043759A> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
       0x117881000 -        0x1178bafff +com.adobe.InDesign.Photoshop Import Filter (9.1.0.33 - ???) <36344F0C-7F5C-3E55-9A53-53A66BBABD83> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Photoshop Import Filter.InDesignPlugin/Photoshop Import Filter
       0x1178ca000 -        0x11884dfef +com.adobe.psl (AdobePSL 14.0.0.30830 - 14.0.0.30830) <7BDC4AF7-B14F-3DE0-B47A-E69B37529A6B> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
       0x118c0e000 -        0x118c4dff7 +com.adobe.InDesign.PNG Import Filter (9.1.0.33 - ???) <3EA87A99-3FBF-38E5-BE00-896001E5AD91> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/PNG Import Filter.InDesignPlugin/PNG Import Filter
       0x118c5d000 -        0x118df2fff +com.adobe.InDesign.Print (9.1.0.33 - ???) <E228F388-FC09-3807-998F-F7C80E22A711> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Print.InDesignPlugin/Print
       0x118e1f000 -        0x118e49fff +com.adobe.InDesign.Rulers (9.1.0.33 - ???) <4158546A-6C92-3AAC-B4DF-C15CAE6288F6> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Rulers.InDesignPlugin/Rulers
       0x118e5c000 -        0x118f0afff +com.adobe.InDesign.Scripting (9.1.0.33 - ???) <01395410-7F18-323A-BF92-4FAC6F3ECCD5> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Scripting.InDesignPlugin/Scripting
       0x118f29000 -        0x118f51fff +com.adobe.InDesign.Sections (9.1.0.33 - ???) <4DB2B4F0-124A-36F1-B1A3-9BFA36BB2FCF> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Sections.InDesignPlugin/Sections
       0x118f62000 -        0x118fecfff +com.adobe.InDesign.SharedContent (9.1.0.33 - ???) <8CE19097-F2DC-366E-A661-725EDB67CD3D> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/SharedContent.InDesignPlugin/SharedContent
       0x11900d000 -        0x11901bfff +com.adobe.InDesign.Sound (9.1.0.33 - ???) <43D68A27-E17F-3E9D-A02D-EB3230178339> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Sound.InDesignPlugin/Sound
       0x119027000 -        0x11903aff7 +com.adobe.InDesign.Spelling Service (9.1.0.33 - ???) <1E6AAFFE-ACCA-3E0B-AA63-37A767CC336E> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Spelling Service.InDesignPlugin/Spelling Service
       0x119049000 -        0x119091fff +com.adobe.InDesign.Spline UI (9.1.0.33 - ???) <F754CDCC-A151-342F-A82B-AB04FC6A7DE7> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Spline UI.InDesignPlugin/Spline UI
       0x1190ad000 -        0x1190f7fff +com.adobe.InDesign.Spline (9.1.0.33 - ???) <0AB8A3E7-0B20-3893-9F14-60353915F2F7> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Spline.InDesignPlugin/Spline
       0x11910f000 -        0x119171fff +com.adobe.InDesign.Spread UI (9.1.0.33 - ???) <6B6773BC-0050-33D4-92D5-4599E731196D> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Spread UI.InDesignPlugin/Spread UI
       0x11918d000 -        0x1192ceff7 +com.adobe.InDesign.Spread (9.1.0.33 - ???) <B39E935B-BFE8-316B-A313-706D4162A03A> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Spread.InDesignPlugin/Spread
       0x119300000 -        0x11935bff7 +com.adobe.InDesign.Stroke and Fill (9.1.0.33 - ???) <72D3DE23-CFCC-3821-80AE-0908DB5768F5> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Stroke and Fill.InDesignPlugin/Stroke and Fill
       0x119373000 -        0x1193caff7 +com.adobe.InDesign.Support for AppleScript (9.1.0.33 - ???) <7D7706C3-B3C9-3B96-8473-CAD03A053148> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Support for AppleScript.InDesignPlugin/Support for AppleScript
       0x1193e0000 -        0x119484fff +com.adobe.InDesign.Support for JavaScript (9.1.0.33 - ???) <88686CC2-432E-37FF-860D-F953DB1C3EE1> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Support for JavaScript.InDesignPlugin/Support for JavaScript
       0x1194af000 -        0x11953aff7 +com.adobe.InDesign.SVGExport (9.1.0.33 - ???) <9001F868-EFD3-378E-8F90-A3B2D0BA2667> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/SVGExport.InDesignPlugin/SVGExport
       0x119554000 -        0x119612fff +com.adobe.SVGExport (AdobeSVGExport 6.0 - 6.0) <2FAB4B9A-EDB9-0FF9-55B2-52DEC380D2BF> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeSVGExport.framework/Versions/A/AdobeSVGExport
       0x119635000 -        0x119867ff7 +com.adobe.InDesign.Table Model (9.1.0.33 - ???) <B4107211-47BD-311A-A9AE-D6E4C7172C92> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Table Model.InDesignPlugin/Table Model
       0x1198a3000 -        0x119900ff7 +com.adobe.InDesign.TableStyles (9.1.0.33 - ???) <4D83BFF9-CAF4-34EF-BEAE-86E2D8A1D14F> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/TableStyles.InDesignPlugin/TableStyles
       0x119913000 -        0x119969ff7 +com.adobe.InDesign.Text Attributes (9.1.0.33 - ???) <F90E2E25-38B2-3F12-8902-D5A56D6AD919> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Text Attributes.InDesignPlugin/Text Attributes
       0x119984000 -        0x11999aff7 +com.adobe.InDesign.Text Editor Model (9.1.0.33 - ???) <C997B3C0-98C6-34A5-89E0-DBD7FB071AD6> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Text Editor Model.InDesignPlugin/Text Editor Model
       0x1199a5000 -        0x119a77fff +com.adobe.InDesign.Text Editor (9.1.0.33 - ???) <95F0F538-CE40-3E81-813A-CAF911E96921> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Text Editor.InDesignPlugin/Text Editor
       0x119aa7000 -        0x119c65ff7 +com.adobe.InDesign.Text Walker (9.1.0.33 - ???) <1A101D2C-2B6A-3BE1-ABD0-BE6BADAE022D> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Text Walker.InDesignPlugin/Text Walker
       0x119cbd000 -        0x119ce1ff7 +com.adobe.InDesign.Text Wrap Path (9.1.0.33 - ???) <6085531E-D2E8-31F4-B64E-C57AAE45344E> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Text Wrap Path.InDesignPlugin/Text Wrap Path
       0x119cea000 -        0x119d60ff7 +com.adobe.InDesign.Text Wrap (9.1.0.33 - ???) <589CB866-43EC-358C-B3E7-2655867F9A05> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Text Wrap.InDesignPlugin/Text Wrap
       0x119d79000 -        0x11a37bfff +com.adobe.InDesign.Text (9.1.0.33 - ???) <09BB1292-929B-32FC-9D91-0E7CBD42A250> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Text.InDesignPlugin/Text
       0x11a419000 -        0x11a47bfff +com.adobe.InDesign.TOC (9.1.0.33 - ???) <99A6C9FF-2F20-3475-A9CF-24C7B0F63CF3> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/TOC.InDesignPlugin/TOC
       0x11a48f000 -        0x11a5d3ff7 +com.adobe.InDesign.Transparency (9.1.0.33 - ???) <D09FF0A0-ACCE-351F-B52D-A91D13E4A042> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Transparency.InDesignPlugin/Transparency
       0x11a5fe000 -        0x11a62bfff +com.adobe.InDesign.Utilities (9.1.0.33 - ???) <AA91ED5D-2080-31F1-A857-D54D227D9D84> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Utilities.InDesignPlugin/Utilities
       0x11a646000 -        0x11a753fff +com.adobe.InDesign.Widgets (9.1.0.33 - ???) <76777FA5-649D-3467-8DA6-92E76013D57B> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Widgets.InDesignPlugin/Widgets
       0x11a7ba000 -        0x11a7dcfff +com.adobe.InDesign.Workgroup Client (9.1.0.33 - ???) <2447A61F-74CA-38D1-9444-22A25D2DEE98> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Workgroup Client.InDesignPlugin/Workgroup Client
       0x11a7ea000 -        0x11a827ff7 +com.adobe.InDesign.Workgroup (9.1.0.33 - ???) <0606AF6F-40BC-3A30-9165-4DD557469545> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/Workgroup.InDesignPlugin/Workgroup
       0x11a837000 -        0x11a864fff +com.adobe.InDesign.WorldReady (9.1.0.33 - ???) <787871A9-77D2-3095-8930-4F140D091F0A> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/WorldReady.InDesignPlugin/WorldReady
       0x11a874000 -        0x11aa97fff +com.adobe.InDesign.XML (9.1.0.33 - ???) <57AD94DB-04BA-3279-8AB8-A401C25FB805> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/XML.InDesignPlugin/XML
       0x11aae1000 -        0x11abdfff7 +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.30807 - 3.8.0.30807) <DF0EC9F6-D499-39B8-B2F4-CAF4F742D702> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
       0x11abf5000 -        0x11ac64fff +com.adobe.InDesign.XMLParser (9.1.0.33 - ???) <8385725A-5573-34FC-8F35-8BB74EB9FDFC> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Required/XMLParser.InDesignPlugin/XMLParser
       0x11ac7a000 -        0x11ad57fff +com.adobe.AXEXSLT (AdobeAXSLE 3.8.0.30807 - 3.8.0.30807) <6299FB87-471B-3EA2-9E02-6DEA293FA533> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeAXSLE.framework/Versions/A/AdobeAXSLE
       0x11d238000 -        0x11d264fff +ServiceManager-Launcher.dylib (55.0.0 - compatibility 2.5.0) <D5A4D905-A054-3E22-A284-3519895C201B> /Library/Application Support/Adobe/*/ServiceManager-Launcher.dylib
       0x11d293000 -        0x11d294ff7  libCyrillicConverter.dylib (54.0.0 - compatibility 1.0.0) <C8D0607A-A668-36EE-AF03-866BD04B5611> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
       0x11d298000 -        0x11d2c4ff7 +com.adobe.Reader for DOCX (Reader for DOCX 5.65.0.30369 - 5.65.0.30369) <C21B199B-542B-34CD-8F0E-F38D970D88BD> /Applications/Adobe InDesign CC/*/Reader for DOCX
       0x11d2cf000 -        0x11d2e3fff +com.adobe.AdobeSFL (AdobeSFL 1.1.0.30369 - 1.1.0.30369) <E345428A-1893-3428-8DE9-2C61895AC1DA> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
       0x11d2eb000 -        0x11d2efff7  libFontRegistryUI.dylib (??? - ???) <6EFD0158-64F7-3A65-92E3-875AD0382A5C> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
       0x11d500000 -        0x11d56bff7 +com.adobe.AdobeSangamML (AdobeSangamML 5.65.0.30369 - 5.65.0.30369) <BD083684-4F07-3F85-BD5D-729E4C597126> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobeSangamML.framework/Versions/A/AdobeSangamML
       0x11d58f000 -        0x11d5edff7 +com.adobe.Reader for Excel (Reader for Excel 5.65.0.30369 - 5.65.0.30369) <628DA00F-210B-3856-89F3-66393386E801> /Applications/Adobe InDesign CC/*/Reader for Excel
       0x11d600000 -        0x11d6f5fff +com.adobe.Reader for Quark (Reader for Quark 5.65.0.30369 - 5.65.0.30369) <7877BBF5-B31A-3CA9-9E8E-3FDFB174F261> /Applications/Adobe InDesign CC/*/Reader for Quark
       0x11d70f000 -        0x11d76aff7 +com.adobe.Reader for RTF (Reader for RTF 5.65.0.30369 - 5.65.0.30369) <3ACB0F8E-0B51-3E5C-B924-A31D1D6606F6> /Applications/Adobe InDesign CC/*/Reader for RTF
       0x11d783000 -        0x11d7a9ff7 +com.adobe.ape (3.4.0.29366 - 3.4.0.29366) <40A59819-7A57-0E9F-658D-1803B2A461AE> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
       0x11eee1000 -        0x11ef4fff7 +com.adobe.Reader for Word (Reader for Word 5.65.0.30369 - 5.65.0.30369) <27531852-B602-3785-94C0-3B316DBEC69C> /Applications/Adobe InDesign CC/*/Reader for Word
       0x11ef64000 -        0x11efcafff +com.adobe.Reader for XLSX (Reader for XLSX 5.65.0.30369 - 5.65.0.30369) <D896568B-FB6A-3036-91FC-A1DF0FA820DF> /Applications/Adobe InDesign CC/*/Reader for XLSX
       0x11efe4000 -        0x11efecff7 +com.adobe.ZTextReader (ZTextReader 5.65.0.30369 - 5.65.0.30369) <28B268EF-A3AD-3933-B4DC-247428D3A88D> /Applications/Adobe InDesign CC/*/ZTextReader
       0x11f073000 -        0x11f156fff +IMSLib.dylib (7.0.0.116 - 7.0.0.116) <D0E2EA23-B1FA-3809-98B5-E6367D65050D> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/IMSLib.dylib
       0x11f16e000 -        0x11f200ff7  com.apple.xquery (1.3 - 29) <F141557A-93DF-3DD5-9B91-24F0F07D12EF> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
       0x11f9f4000 -        0x11f9f7ff7  libCoreFSCache.dylib (??? - ???) <0D155750-7910-32C5-8327-924FC1089442> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
       0x11fb00000 -        0x11fb95ff7  com.apple.applescript (2.2.1 - 2.2.1) <2289814D-3A6E-3B63-A03C-86FB79556522> /System/Library/PrivateFrameworks/AppleScript.framework/Versions/A/AppleScript
       0x11fbc6000 -        0x11fbe1fff  libJapaneseConverter.dylib (54.0.0 - compatibility 1.0.0) <59FCE9C0-27E6-34CE-89E5-3A83B843B36C> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
       0x11fbe6000 -        0x11fc07fff  libKoreanConverter.dylib (54.0.0 - compatibility 1.0.0) <25FF31F5-9D1E-35EB-8085-F0AC25C38DAC> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
       0x1207c5000 -        0x1207d4ff7  libSimplifiedChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <D30A4333-0953-394D-BB26-739937ED0BD8> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
       0x1207d8000 -        0x1207eaff7  libTraditionalChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <66A3625A-6918-3C14-8DF3-2F4924C389EA> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
       0x1207ee000 -        0x1207f8fef  libcldcpuengine.dylib (2.0.19 - compatibility 1.0.0) <4572AD1E-D1D1-3412-AFCC-D37037B1FAB5> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
       0x1227e2000 -        0x1227f0fff  libGPUSupport.dylib (??? - ???) <9FF8DDA2-7CB1-3888-8AAE-227C7691CB98> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib
       0x123ab0000 -        0x123adeff7  GLRendererFloat (??? - ???) <06CA5D0B-BC5F-3CC7-836D-A02F7DB92BE8> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
       0x123ae7000 -        0x123aeeff7 +FastCore (??? - ???) <550801D3-EA46-34A4-BD38-B9412427C4B4> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobePSL.framework/PlugIns/FastCore.plugin/Contents/MacOS/FastCore
       0x123f83000 -        0x123fc8ff7 +com.adobe.pip (??? - 7.0.0.1768) <F022E031-1429-354F-B718-70F001B342EF> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
       0x128883000 -        0x128a3bfff  GLEngine (??? - ???) <59179FEC-D0E2-38B3-BD49-765506A645AC> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
       0x128a72000 -        0x128bccfff  libGLProgrammability.dylib (??? - ???) <90390984-70BC-365C-AB3E-16C35C4240CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
       0x128d00000 -        0x128d5dfff +MMXCore (??? - ???) <F4FFD11E-5B99-34E3-90DC-6DA133A6C96F> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobePSL.framework/PlugIns/MMXCore.plugin/Contents/MacOS/MMXCore
       0x128dda000 -        0x128e5bff7 +MultiProcessor Support (??? - ???) <24272CF0-F997-3A5E-B941-87ADB8C66409> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/AdobePSL.framework/PlugIns/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
       0x129800000 -        0x129abbff7  com.apple.ATIRadeonX2000GLDriver (7.32.12 - 7.3.2) <C894DE28-1B2F-37BE-88FC-1E66D7828B77> /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLDriver
    0x7fff68a26000 -     0x7fff68a5abaf  dyld (195.6 - ???) <C58DAD8A-4B00-3676-8637-93D6FDE73147> /usr/lib/dyld
    0x7fff86d4f000 -     0x7fff86de5ff7  libvMisc.dylib (325.4.0 - compatibility 1.0.0) <642D8D54-F9F5-3FBB-A96C-EEFE94C6278B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff86de6000 -     0x7fff87213fff  libLAPACK.dylib (??? - ???) <4F2E1055-2207-340B-BB45-E4F16171EE0D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff8728f000 -     0x7fff8736efff  com.apple.ImageIO.framework (3.1.2 - 3.1.2) <047DFE61-500F-3F11-9881-D0844D2FCE5F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff87800000 -     0x7fff878defff  com.apple.DiscRecording (6.0.4 - 6040.4.1) <E6D5835F-EE3C-3814-A2EE-6962B5570EF1> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x7fff878df000 -     0x7fff879a6ff7  ColorSyncDeprecated.dylib (4.6.0 - compatibility 1.0.0) <7E2E109C-A438-3EDC-A6EB-3EF634A1B28B> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
    0x7fff87dc0000 -     0x7fff87dc0fff  com.apple.Accelerate (1.7 - Accelerate 1.7) <82DDF6F5-FBC3-323D-B71D-CF7ABC5CF568> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff87dc1000 -     0x7fff87dc2ff7  libremovefile.dylib (21.1.0 - compatibility 1.0.0) <739E6C83-AA52-3C6C-A680-B37FE2888A04> /usr/lib/system/libremovefile.dylib
    0x7fff881ea000 -     0x7fff88225fff  com.apple.LDAPFramework (3.2 - 120.2) <275D4298-C435-3E98-AA25-95D9D0A56550> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x7fff88250000 -     0x7fff88266ff7  com.apple.ImageCapture (7.1.0 - 7.1.0) <1AD40E02-2126-377B-A0D2-CBB21D932558> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff8837b000 -     0x7fff884d8fff  com.apple.audio.toolbox.AudioToolbox (1.7.3 - 1.7.3) <5F1E4695-BC74-3ADD-8345-627BCD68201A> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff884d9000 -     0x7fff884dcfff  com.apple.help (1.3.2 - 42) <BF14DE49-F7E8-336F-81FB-BBDF2DB3AC09> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff884dd000 -     0x7fff884e2fff  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <D952F17B-200A-3A23-B9B2-7C1F7AC19189> /usr/lib/libpam.2.dylib
    0x7fff884e3000 -     0x7fff88559fff  com.apple.CoreSymbolication (2.2 - 73.2) <126415E3-3A35-315B-B4B7-507CDBED0D58> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff8855a000 -     0x7fff88637fef  libsystem_c.dylib (763.13.0 - compatibility 1.0.0) <41B43515-2806-3FBC-ACF1-A16F35B7E290> /usr/lib/system/libsystem_c.dylib
    0x7fff88693000 -     0x7fff886afff7  com.apple.GenerationalStorage (1.0 - 126.1) <509F52ED-E54B-3FEF-B3C2-759387B826E6> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fff886b0000 -     0x7fff886befff  com.apple.NetAuth (3.2 - 3.2) <F0D60E34-37A9-308D-B44E-E3450906173A> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff887bd000 -     0x7fff893c3fff  com.apple.AppKit (6.7.5 - 1138.51) <44417D02-6123-3FC3-A119-CE51BB4C3006> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff893c4000 -     0x7fff89437fff  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <6BDD43E4-A4B1-379E-9ED5-8C713653DFF2> /usr/lib/libstdc++.6.dylib
    0x7fff89444000 -     0x7fff894c7fef  com.apple.Metadata (10.7.0 - 627.37) <B9BEB598-B6F2-3BFF-A8F3-C3C87CD076AB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff894c8000 -     0x7fff8957bff7  com.apple.CoreText (220.22.0 - ???) <A7A1096F-A211-3775-BA33-08FE98D27F08> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff8957c000 -     0x7fff8957efff  libCVMSPluginSupport.dylib (??? - ???) <982F1ED4-3CBB-3161-8BEA-8A980C27FCC1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff8957f000 -     0x7fff895a3fff  com.apple.Kerberos (1.0 - 1) <1F826BCE-DA8F-381D-9C4C-A36AA0EA1CB9> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff895b5000 -     0x7fff89617ff7  com.apple.Symbolication (1.3 - 91) <0945ACAF-AA0A-3D01-9960-72B51722EC1F> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fff89618000 -     0x7fff89619fff  libDiagnosticMessagesClient.dylib (??? - ???) <3DCF577B-F126-302B-BCE2-4DB9A95B8598> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff8961a000 -     0x7fff8961bfff  liblangid.dylib (??? - ???) <CACBE3C3-2F7B-3EED-B50E-EDB73F473B77> /usr/lib/liblangid.dylib
    0x7fff89666000 -     0x7fff89760ff7  com.apple.DiskImagesFramework (10.7.4 - 331.7) <BEBA6D78-08E0-3B99-B77B-A5CBF3344834> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x7fff89761000 -     0x7fff8978dff7  com.apple.CoreServicesInternal (113.19 - 113.19) <74532B3B-EDE0-3553-9BED-F02B9CDF1FF7> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff89790000 -     0x7fff898a9fff  com.apple.DesktopServices (1.6.5 - 1.6.5) <5E7DD5F4-B4DA-3F75-A14A-3494E81CFBA0> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff898aa000 -     0x7fff898beff7  com.apple.LangAnalysis (1.7.0 - 1.7.0) <04C31EF0-912A-3004-A08F-CEC27030E0B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff89913000 -     0x7fff8991eff7  libc++abi.dylib (14.0.0 - compatibility 1.0.0) <8FF3D766-D678-36F6-84AC-423C878E6D14> /usr/lib/libc++abi.dylib
    0x7fff89949000 -     0x7fff89971fff  com.apple.PerformanceAnalysis (1.11 - 11) <8D4C6382-DD92-37A2-BCFC-E89951320848> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff899c0000 -     0x7fff89aa4e5f  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <871E688B-CF57-3BC7-80D6-F6476DFF109B> /usr/lib/libobjc.A.dylib
    0x7fff89aa5000 -     0x7fff89aa9fff  libdyld.dylib (195.6.0 - compatibility 1.0.0) <FFC59565-64BD-3B37-90A4-E2C3A422CFC1> /usr/lib/system/libdyld.dylib
    0x7fff89ab2000 -     0x7fff89abafff  libsystem_dnssd.dylib (??? - ???) <584B321E-5159-37CD-B2E7-82E069C70AFB> /usr/lib/system/libsystem_dnssd.dylib
    0x7fff89abb000 -     0x7fff89aceff7  libCRFSuite.dylib (??? - ???) <0B76941F-218E-30C8-B6DE-E15919F8DBEB> /usr/lib/libCRFSuite.dylib
    0x7fff89acf000 -     0x7fff89f96fff  FaceCoreLight (1.4.7 - compatibility 1.0.0) <BDD0E1DE-CF33-3AF8-B33B-4D1574CCC19D> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
    0x7fff89fd6000 -     0x7fff89ff3fff  libxpc.dylib (77.19.0 - compatibility 1.0.0) <9F57891B-D7EF-3050-BEDD-21E7C6668248> /usr/lib/system/libxpc.dylib
    0x7fff8a0c1000 -     0x7fff8a103ff7  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <BB770C22-8C57-365A-8716-4A3C36AE7BFB> /usr/lib/system/libcommonCrypto.dylib
    0x7fff8a104000 -     0x7fff8a11bfff  com.apple.CFOpenDirectory (10.7 - 146) <BBB7C97E-7B46-3286-9128-32B5D16B5CBE> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff8a11c000 -     0x7fff8a200ff7  com.apple.CoreServices.OSServices (478.50 - 478.50) <3D6AA4EF-C601-36C7-8F3A-A00964F01759> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff8a22d000 -     0x7fff8a232fff  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <98ECD5F6-E85C-32A5-98CD-8911230CB66A> /usr/lib/system/libcompiler_rt.dylib
    0x7fff8a233000 -     0x7fff8a253fff  libsystem_kernel.dylib (1699.32.7 - compatibility 1.0.0) <66C9F9BD-C7B3-30D4-B1A0-03C8A6392351> /usr/lib/system/libsystem_kernel.dylib
    0x7fff8a254000 -     0x7fff8a2bcff7  com.apple.coreui (1.2.2 - 165.11) <9316266A-39CA-3EC7-9C9E-726462CEFF4D> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff8a2bd000 -     0x7fff8a2ccff7  libxar-nossl.dylib (??? - ???) <A6ABBFB9-E4ED-38AD-BBBB-F9958B9CEFB5> /usr/lib/libxar-nossl.dylib
    0x7fff8a2cd000 -     0x7fff8a351ff7  com.apple.ApplicationServices.ATS (317.12.0 - ???) <BE3C156D-8326-37AA-BC4E-D3C0D31BF976> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff8a352000 -     0x7fff8a352fff  com.apple.ApplicationServices (41 - 41) <89B6AD5B-5C75-3E83-8C2B-AA7F4C55E400> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff8a353000 -     0x7fff8a527ff7  com.apple.CoreFoundation (6.7.2 - 635.21) <62A3402E-A4E7-391F-AD20-1EF20236CE1B> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff8a528000 -     0x7fff8a529fff  libScreenReader.dylib (??? - ???) <7CC8F990-29A2-3F41-B2C1-A128F2498D8C> /usr/lib/libScreenReader.dylib
    0x7fff8a56a000 -     0x7fff8a571fff  com.apple.NetFS (4.0 - 4.0) <433EEE54-E383-3505-9154-45B909FD3AF0> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fff8a572000 -     0x7fff8a59bfff  libJPEG.dylib (??? - ???) <64D079F9-256A-323B-A837-84628B172F21> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff8a602000 -     0x7fff8a650fff  libauto.dylib (??? - ???) <D8AC8458-DDD0-3939-8B96-B6CED81613EF> /usr/lib/libauto.dylib
    0x7fff8a652000 -     0x7fff8a654fff  com.apple.TrustEvaluationAgent (2.0 - 1) <1F31CAFF-C1C6-33D3-94E9-11B721761DDF> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fff8a663000 -     0x7fff8a668fff  libcache.dylib (47.0.0 - compatibility 1.0.0) <1571C3AB-BCB2-38CD-B3B2-C5FC3F927C6A> /usr/lib/system/libcache.dylib
    0x7fff8a779000 -     0x7fff8a8affff  com.apple.vImage (5.1 - 5.1) <A08B7582-67BC-3EED-813A-4833645964A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff8ac25000 -     0x7fff8ad2afff  libFontParser.dylib (??? - ???) <D2E56B6E-3182-3667-A78C-4172C435523A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fff8ad2b000 -     0x7fff8b044fff  com.apple.Foundation (6.7.2 - 833.25) <22AAC369-B63C-3C55-8AC6-C3ECBA44DA7B> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff8b045000 -     0x7fff8b099ff7  com.apple.ScalableUserInterface (1.0 - 1) <33563775-C662-313D-B7FA-3D575A9F3D41> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
    0x7fff8b31c000 -     0x7fff8b648fff  com.apple.HIToolbox (1.9 - ???) <CCB32DEA-D0CA-35D1-8019-E599C8007AB6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff8b6af000 -     0x7fff8b6d8fff  com.apple.CoreVideo (1.7 - 70.3) <9A9D4058-9935-3B0A-B1A6-27EB78D02249> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff8b6d9000 -     0x7fff8b754ff7  com.apple.print.framework.PrintCore (7.1 - 366.3) <C5F39A82-0E77-3AD6-906A-20DD2EE8D374> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff8b755000 -     0x7fff8b9c9fff  com.apple.CoreImage (7.99.1 - 1.0.1) <4BB09B79-275B-364C-9466-0FF36ABB1218> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff8b9ca000 -     0x7fff8ba4fff7  com.apple.Heimdal (2.2 - 2.0) <52B0F371-D272-3C8E-B42F-04D3FDD8AD0D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff8ba50000 -     0x7fff8ba5efff  libdispatch.dylib (187.10.0 - compatibility 1.0.0) <8E03C652-922A-3399-93DE-9EA0CBFA0039> /usr/lib/system/libdispatch.dylib
    0x7fff8ba5f000 -     0x7fff8ba6cff7  libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <DFAB8CA8-CC9D-3F58-8C12-CE120442AACD> /usr/lib/libbz2.1.0.dylib
    0x7fff8bac4000 -     0x7fff8bac7fff  libCoreVMClient.dylib (??? - ???) <28CB0F3F-A202-391F-8CAC-FC9A1398A962> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff8bc0b000 -     0x7fff8bc4afff  com.apple.AE (527.7 - 527.7) <B82F7ABC-AC8B-3507-B029-969DD5CA813D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff8bc4b000 -     0x7fff8bc51fff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <CEA34337-63DE-302E-81AA-10D717E1F699> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff8bc5e000 -     0x7fff8bc5efff  libOpenScriptingUtil.dylib (??? - ???) <A7847713-F410-39C0-884F-A7188A18E742> /usr/lib/libOpenScriptingUtil.dylib
    0x7fff8bdd7000 -     0x7fff8bdd9ff7  com.apple.print.framework.Print (7.4 - 247.3) <626C58D5-2841-3329-8C32-9F4A8353F3E7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff8bdda000 -     0x7fff8bdecff7  libz.1.dylib (1.2.5 - compatibility 1.0.0) <30CBEF15-4978-3DED-8629-7109880A19D4> /usr/lib/libz.1.dylib
    0x7fff8be3b000 -     0x7fff8beb1ff7  libc++.1.dylib (28.4.0 - compatibility 1.0.0) <A24FC3DA-4FFA-3DD2-9DCC-2B8D1B3BF97C> /usr/lib/libc++.1.dylib
    0x7fff8beb2000 -     0x7fff8beddff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <E71220D3-8015-38EC-B97D-7FDB383C2BDC> /usr/lib/libxslt.1.dylib
    0x7fff8bede000 -     0x7fff8bee7ff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <A4D651E3-D1C6-3934-AD49-7A104FD14596> /usr/lib/system/libsystem_notify.dylib
    0x7fff8bee8000 -     0x7fff8bf40ff7  libTIFF.dylib (??? - ???) <59353B7F-EA9A-32D5-A501-283443B30C60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff8bf41000 -     0x7fff8bf47ff7  libunwind.dylib (30.0.0 - compatibility 1.0.0) <1E9C6C8C-CBE8-3F4B-A5B5-E03E3AB53231> /usr/lib/system/libunwind.dylib
    0x7fff8bf48000 -     0x7fff8bfe9fff  com.apple.LaunchServices (480.40 - 480.40) <C936A07F-0CF8-3F8E-BDB3-76AA7611B4CA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff8bfea000 -     0x7fff8bff1fff  libGFXShared.dylib (??? - ???) <D3598924-B167-372E-8C9F-1BBF68852542> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff8bffa000 -     0x7fff8c062ff7  com.apple.audio.CoreAudio (4.0.3 - 4.0.3) <9987DC46-2A96-3BA0-B88B-04E573C0AD9B> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff8c063000 -     0x7fff8c0afff7  com.apple.SystemConfiguration (1.11.3 - 1.11) <0A7F1982-B4EA-3424-A0C7-FE46C6224F03> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff8c0b0000 -     0x7fff8c0b1ff7  libsystem_sandbox.dylib (??? - ???) <5459F293-E1F2-33B3-B9B2-2ABB7B915B62> /usr/lib/system/libsystem_sandbox.dylib
    0x7fff8c0b2000 -     0x7fff8c0f6ff7  libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <B2A38D2C-7E82-34C5-8896-48C37B0E64A3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x7fff8ca77000 -     0x7fff8ca89ff7  libbsm.0.dylib (??? - ???) <349BB16F-75FA-363F-8D98-7A9C3FA90A0D> /usr/lib/libbsm.0.dylib
    0x7fff8cacb000 -     0x7fff8cde7fff  com.apple.CoreServices.CarbonCore (960.25 - 960.25) <4FC1AB30-022C-3C67-AC46-FDCBFCB7EEDE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff8cfe7000 -     0x7fff8cfe7fff  com.apple.Cocoa (6.6 - ???) <7EC4D759-B2A6-3A99-AC75-809FED1500C6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff8cfe8000 -     0x7fff8d2ddff7  com.apple.security (7.0 - 55148.6) <4535E500-973A-3BA7-AF65-DF5CF0658F02> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff8d30c000 -     0x7fff8d30cfff  com.apple.vecLib (3.7 - vecLib 3.7) <9A58105C-B36E-35B5-812C-4ED693F2618F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff8d5cf000 -     0x7fff8d736fff  com.apple.CFNetwork (520.5.1 - 520.5.1) <08F70E26-5456-3BFB-8192-00D3CE40D3C9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff8da5a000 -     0x7fff8da5afff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <C06A140F-6114-3B8B-B080-E509303145B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff8de06000 -     0x7fff8de0bfff  com.apple.OpenDirectory (10.7 - 146) <7960A302-F9AC-3F72-838E-3A382032DCA6> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff8de0c000 -     0x7fff8e036fe7  com.apple.CoreData (104.1 - 358.14) <6BB64605-8DA7-337D-A2AB-A3346A421CBD> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff8e09e000 -     0x7fff8e1aafef  libcrypto.0.9.8.dylib (49.1.0 - compatibility 0.9.8) <FB999E54-C9BC-3A6D-9FE5-BFCC236775ED> /usr/lib/libcrypto.0.9.8.dylib
    0x7fff8e1ab000 -     0x7fff8e1b6fff  com.apple.CommonAuth (2.2 - 2.0) <4F5302A5-867A-3F2E-9E4B-98FA011678F8> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff8e50b000 -     0x7fff8eaeffff  libBLAS.dylib (??? - ???) <C34F6D88-187F-33DC-8A68-C0C9D1FA36DF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff8eb83000 -     0x7fff8eb83fff  com.apple.CoreServices (53 - 53) <043C8026-8EDD-3241-B090-F589E24062EF> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff8f2ab000 -     0x7fff8f2b6ff7  com.apple.speech.recognition.framework (4.0.21 - 4.0.21) <6540EAF2-E3BF-3D2E-B4C1-F106180D6F20> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff8f2b7000 -     0x7fff8f2eaff7  com.apple.GSS (2.2 - 2.0) <C86012C5-B613-3199-B1B3-A1494EE5E43C> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff8f2eb000 -     0x7fff8f2ecff7  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <8BCA214A-8992-34B2-A8B9-B74DEACA1869> /usr/lib/system/libsystem_blocks.dylib
    0x7fff8f323000 -     0x7fff8f326fff  libRadiance.dylib (??? - ???) <CD89D70D-F177-3BAE-8A26-644EA7D5E28E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff8f327000 -     0x7fff8f429fff  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <AFBB22B7-07AE-3F2E-B88C-70BEEBFB8A86> /usr/lib/libxml2.2.dylib
    0x7fff8f469000 -     0x7fff8f47efff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <C061ECBB-7061-3A43-8A18-90633F943295> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff8f47f000 -     0x7fff8f4bffe7  libGLImage.dylib (??? - ???) <0B7DAB2B-F1C6-39C7-B864-61EF683B6656> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff8f4c0000 -     0x7fff8f4cdfff  libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <72C53E7B-C222-3BE5-9984-FDC328CC4846> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x7fff8f4ce000 -     0x7fff8f6d0fff  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <0176782F-9526-3905-813A-7A5676EC2C86> /usr/lib/libicucore.A.dylib
    0x7fff8f6d1000 -     0x7fff8f6f0fff  libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <0635C52D-DD53-3721-A488-4C6E95607A74> /usr/lib/libresolv.9.dylib
    0x7fff8f6f1000 -     0x7fff8f6f2fff  libunc.dylib (24.0.0 - compatibility 1.0.0) <337960EE-0A85-3DD0-A760-7134CF4C0AFF> /usr/lib/system/libunc.dylib
    0x7fff8f6f3000 -     0x7fff8f6fdff7  liblaunch.dylib (392.39.0 - compatibility 1.0.0) <8C235D13-2928-30E5-9E12-2CC3D6324AE2> /usr/lib/system/liblaunch.dylib
    0x7fff8f6fe000 -     0x7fff8f702ff7  com.apple.CommonPanels (1.2.5 - 94) <37C6540B-F8D1-355A-806C-F93D8FB522AB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff8f703000 -     0x7fff8f712fff  com.apple.opengl (1.8.1 - 1.8.1) <51B34133-CEE3-3FC6-82AC-ADF567AE673C> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff8f713000 -     0x7fff8f767fff  libFontRegistry.dylib (??? - ???) <60FF9C2C-5E44-3C49-8A08-F26101898F21> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff8f768000 -     0x7fff8f768fff  com.apple.audio.units.AudioUnit (1.7.3 - 1.7.3) <04C10813-CCE5-3333-8C72-E8E35E417B3B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff8f769000 -     0x7fff8f76efff  libGIF.dylib (??? - ???) <58A4492D-AAE7-3B8F-8B06-62867471A3EE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff904b3000 -     0x7fff904c9fff  libGL.dylib (??? - ???) <A4876AE9-DDFE-3B9A-874E-09BC29D46C39> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff904d8000 -     0x7fff90513fff  libssl.0.9.8.dylib (49.1.0 - compatibility 0.9.8) <B5120F7F-6FD7-3E0B-AAB8-E9A8D72451BC> /usr/lib/libssl.0.9.8.dylib
    0x7fff905c6000 -     0x7fff90600fe7  com.apple.DebugSymbols (2.1 - 87) <ED2B177C-4146-3715-91DF-D99A8ED5449A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff90601000 -     0x7fff906a6fff  com.apple.ink.framework (10.7.5 - 113) <1AE6676D-490A-36C2-B6CC-00F93AEB31DE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff9074f000 -     0x7fff907bffff  com.apple.datadetectorscore (3.0 - 179.4) <9C01D16F-75A9-3BDD-B91A-F0F32261A2E7> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff907c0000 -     0x7fff9115ea27  com.apple.CoreGraphics (1.600.0 - ???) <576777EA-921B-3D94-98C3-40A9CF8EBD18> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff911f0000 -     0x7fff9122bfff  libsystem_info.dylib (??? - ???) <35F90252-2AE1-32C5-8D34-782C614D9639> /usr/lib/system/libsystem_info.dylib
    0x7fff9122c000 -     0x7fff91288ff7  com.apple.HIServices (1.21 - ???) <B012EE97-D1CD-3F4B-812D-9AC7E6852FE6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff912a1000 -     0x7fff912c5fff  com.apple.RemoteViewServices (1.5 - 44.2) <A0417D7F-22E9-3FD8-AC55-67654D8E93EB> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff912c6000 -     0x7fff9138dff7  com.apple.ColorSync (4.7.4 - 4.7.4) <590AFCDA-F10E-31FE-9B01-DA5FFE74C2BB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff9138e000 -     0x7fff91394fff  IOSurface (??? - ???) <77C6757B-D357-3E34-9424-48F962B5CC9C> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff914a9000 -     0x7fff9159efff  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <5C40E880-0706-378F-B864-3C2BD922D926> /usr/lib/libiconv.2.dylib
    0x7fff9159f000 -     0x7fff915e0fff  com.apple.QD (3.40.1 - ???) <13ACC7F4-B004-3370-B575-6D06447EE428> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff915e1000 -     0x7fff915e8fff  libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <0AB51EE2-E914-358C-AC19-47BC024BDAE7> /usr/lib/system/libcopyfile.dylib
    0x7fff915ed000 -     0x7fff9161dff7  com.apple.DictionaryServices (1.2.1 - 158.3) <5E2EBBFD-D520-3379-A431-11DAA844B8D6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff91668000 -     0x7fff916c8fff  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <3A7521E6-5510-3FA7-AB65-79693A7A5839> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff916c9000 -     0x7fff916d0fff  com.apple.CommerceCore (1.0 - 17.1) <B6BFA182-9DC9-3543-89AE-F82EB9AF1CAB> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
    0x7fff916d1000 -     0x7fff916f2fff  libPng.dylib (??? - ???) <E2B52527-4D0C-3595-BB13-8E8EF364E998> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff9196a000 -     0x7fff9196bfff  libdnsinfo.dylib (395.11.0 - compatibility 1.0.0) <853BAAA5-270F-3FDC-B025-D448DB72E1C3> /usr/lib/system/libdnsinfo.dylib
    0x7fff9196c000 -     0x7fff91983fff  com.apple.MultitouchSupport.framework (231.4 - 231.4) <10A978D1-8781-33F0-BE45-60C9171F7278> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff91af1000 -     0x7fff91b37fff  libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <2C442396-1006-3765-92D2-60869D4641CE> /usr/lib/libcurl.4.dylib
    0x7fff91b38000 -     0x7fff91b55ff7  com.apple.openscripting (1.3.3 - ???) <F5E34F54-CE85-334B-8F25-53581D43960C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff91be7000 -     0x7fff91bedfff  libmacho.dylib (800.0.0 - compatibility 1.0.0) <165514D7-1BFA-38EF-A151-676DCD21FB64> /usr/lib/system/libmacho.dylib
    0x7fff91bee000 -     0x7fff91c2eff7  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <7D2E5016-A960-3ADE-B042-F74063E79550> /usr/lib/libcups.2.dylib
    0x7fff91df1000 -     0x7fff91e35ff7  com.apple.MediaKit (12 - 602) <0C2CBEDA-412F-3DDF-9C74-44114E5E0DB9> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x7fff91e53000 -     0x7fff91e55fff  libquarantine.dylib (36.7.0 - compatibility 1.0.0) <8D9832F9-E4A9-38C3-B880-E5210B2353C7> /usr/lib/system/libquarantine.dylib
    0x7fff91ee7000 -     0x7fff91f89fff  com.apple.securityfoundation (5.0 - 55116) <A9311EF6-B7F7-3DA5-84E8-21BC9B2C3C69> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff91fef000 -     0x7fff91ff4ff7  libsystem_network.dylib (??? - ???) <5DE7024E-1D2D-34A2-80F4-08326331A75B> /usr/lib/system/libsystem_network.dylib
    0x7fff92006000 -     0x7fff92071ff7  com.apple.framework.IOKit (2.0 - ???) <FE838BB6-D42E-3291-A1A0-6F53FC970261> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff92072000 -     0x7fff92084ff7  libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <6245B497-784B-355C-98EF-2DC6B45BF05C> /usr/lib/libsasl2.2.dylib
    0x7fff92085000 -     0x7fff92088ff7  com.apple.securityhi (4.0 - 1) <D0ABB03B-CEF9-39E0-A139-AA9484DBBC07> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff92089000 -     0x7fff920e4ff7  com.apple.opencl (2.0.19 - 2.0.19) <B05BF605-73B8-328F-A228-6FA59E1FC73A> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff920e5000 -     0x7fff920e5fff  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <61EFED6A-A407-301E-B454-CD18314F0075> /usr/lib/system/libkeymgr.dylib
    0x7fff920f5000 -     0x7fff920f5fff  com.apple.Carbon (153 - 153) <16EA5662-5C2C-3267-B419-66669AE536D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff92139000 -     0x7fff92246fff  libJP2.dylib (??? - ???) <6AF1F5FC-34D4-3278-BEBB-0712B81890B4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff92280000 -     0x7fff9228eff7  libkxld.dylib (??? - ???) <01161870-E3B3-3F87-BA4A-0AA7A081F409> /usr/lib/system/libkxld.dylib
    0x7fff9228f000 -     0x7fff92329ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <4E70C394-773E-3A4B-A93C-59A88ABA9509> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff92336000 -     0x7fff9243dfe7  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <EE02BB01-64C9-304D-9719-A35F5CD6D04C> /usr/lib/libsqlite3.dylib
    0x7fff9243e000 -     0x7fff9246bfe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <DA79E5BA-BBA3-3768-AAD8-B34BA877EF03> /usr/lib/libSystem.B.dylib
    0x7fff9246c000 -     0x7fff924beff7  libGLU.dylib (??? - ???) <DB906997-0F70-3469-BA0E-2F1DDBEAD8D5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff925b3000 -     0x7fff92753ff7  com.apple.QuartzCore (1.7 - 270.5) <19E5E0AB-DAA9-3F97-988C-D9A46AFB9C04> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff9307e000 -     0x7fff930a4fff  com.apple.framework.familycontrols (3.0 - 300) <6F0C58C0-22E7-3877-8CFA-1ED0CB3CE38B> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
    0x7fff930a5000 -     0x7fff930a9fff  libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <35D606B1-7AD9-38E3-A2A9-E92B904BDDE8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
    0x7fff93a05000 -     0x7fff93a09fff  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <FF83AFF7-42B2-306E-90AF-D539C51A4542> /usr/lib/system/libmathCommon.A.dylib
    0x7fff93a0a000 -     0x7fff93c85ff7  com.apple.RawCamera.bundle (4.09 - 711) <0040632D-09A9-32DE-98E8-BFA99F9F6526> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 4
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 4944
    thread_create: 1
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=402.1M resident=321.4M(80%) swapped_out_or_unallocated=80.7M(20%)
Writable regions: Total=372.7M written=146.2M(39%) resident=183.5M(49%) swapped_out=0K(0%) unallocated=189.2M(51%)
REGION TYPE                      VIRTUAL
ATS (font support)                 31.8M
ATS (font support) (reserved)         4K        reserved VM address space (unallocated)
CG backing stores                  4228K
CG image                              4K
CG raster data                     2192K
CG shared images                   3480K
CoreGraphics                         16K
CoreServices                       4456K
MALLOC                            252.3M
MALLOC guard page                    64K
MALLOC_LARGE (reserved)             9.8M        reserved VM address space (unallocated)
Memory tag=240                        4K
Memory tag=242                       12K
Memory tag=249                      156K
Memory tag=251                       28K
SQLite page cache                   192K
STACK GUARD                        56.1M
Stack                              20.8M
Stack (reserved)                    520K        reserved VM address space (unallocated)
VM_ALLOCATE                        35.2M
__CI_BITMAP                          80K
__DATA                             29.1M
__IMAGE                             528K
__LINKEDIT                         84.6M
__TEXT                            317.6M
__UNICODE                           544K
mapped file                        67.4M
shared memory                       312K
TOTAL                             920.9M
TOTAL, minus reserved VM space    910.7M
Model: iMac11,1, BootROM IM111.0034.B02, 4 processors, Intel Core i7, 2.8 GHz, 8 GB, SMC 1.54f36
Graphics: ATI Radeon HD 4850, ATI Radeon HD 4850, PCIe, 512 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1067 MHz, 0x80AD, 0x484D54333531533641465238432D47372020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1067 MHz, 0x80AD, 0x484D54333531533641465238432D47372020
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 4.0.67.5-P2P
Bluetooth: Version 4.0.8f17, 2 service, 18 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: Hitachi HDS722020ALA330, 2 TB
Serial ATA Device: OPTIARC DVD RW AD-5680H
USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfa100000 / 2
USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfa140000 / 6
USB Device: Apple Keyboard, apple_vendor_id, 0x0220, 0xfa142000 / 7
USB Device: My Book, 0x1058  (Western Digital Technologies, Inc.), 0x1100, 0xfa130000 / 5
USB Device: Internal Memory Card Reader, apple_vendor_id, 0x8403, 0xfa120000 / 4
USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 3
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0xfa111000 / 9
USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfd100000 / 2
USB Device: hub_device, 0x050d  (Belkin Corporation), 0x0706, 0xfd140000 / 5
USB Device: Mass Storage, 0x058f  (Alcor Micro, Corp.), 0x6387, 0xfd144000 / 6
USB Device: Built-in iSight, apple_vendor_id, 0x8502, 0xfd110000 / 4
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd120000 / 3
Dec 03, 2013 Dec 03, 2013
Further info: my remaining system/library/fonts: Apple Color Emoji.ttf, AppleGothic.ttf, Courier.dfont, Geneva.dfont, Helvetica.dfont, HelveticaNeue.dfont, Keyboard.ttf, LastResort.ttf, LucidaGrande.ttc, MarkerFelt.ttc, Menlo.ttc, Monaco.dfont, Symbol.ttf, Times.dfont
Only one user/library/font: Verdana - as Illustrator requires it to load. Then crashes, of course.
Dec 06, 2013 Dec 06, 2013
The Verdana should be in the System Fonts folder.
Dec 08, 2013 Dec 08, 2013
Thank you for the reply Larry, but unfortunately that has not made any difference.
May 29, 2014 May 29, 2014
I wonder if you've ever solved this issue? I just bought InDesign CC yesterday and am encountering the exact issue. I can use a separate admin account to open successfully but I need to use this product with my main user account, as that's where all my files are, etc. - incredibly frustrated and angry. I held out buying CC until I couldn't anymore because I have been receiving customer files that I can't open due to them being saved in CC. This is BS.
If it works with one user and not another, it's most likely either a permissions issue or bad prefs. You can try trashing the prefs (see Replace Your Preferences ) or delete the two Adobe folders in that link and replace with the ones in the user account that works.
I spent some time with adobe support and they tried changing some of the folder permissions on screenshare, so I watched what they did. But after that didn't fix it, I found some info in an adobe forum that solved my problem:
InDesign CC Start-up Error: "...lack sufficient permissions to access the preferences folders"
This combination of actions:
Mohammed: Please open a Finder window. Choose Go > Go To Folder. Type ~/library/Application support and give full permission to Adobe folder.
Paul: That's completed... I've added all the users and groups, given each 'Read and Write" and extended the permissions to all enclosed items.
Mohammed: Now please open a Finder window. Choose Go > Go To Folder. Type /library/Application support and give full permission to Adobe folder.
^(the above did not fix it)
Mohammed: Click the Gear icon, and select Apply to Enclosed Item
^(this finally solved the problem)
Jul 24, 2014 Jul 24, 2014
FDs fix Did not work for me...
Apr 25, 2016 Apr 25, 2016
In my case the 'invalid plug-in'-error is caused, when adding self build plug-ins to the plug-in-folder of InDesign5.5.
The plug-ins are build with 5.5SDK and VS2008 without error.
My first qiestion is, what are the parameters causing that error?
How to build valid plug-ins for InDesign5.5?
I'll test the the InDesign with another account.
But the plug-in related question seems the relevant one.
Jochen Seliger
Mail: jochen.seliger@flowcontrol.org
