Coldfusion Service will not start after reboot
Guest
Jun 18, 2013 Jun 18, 2013
I am having trouble getting the coldfusion service to start after a server reboot.  The service was working prior to the reboot and the only thing that changed was an update to the application hosted on the server.
The server setup:
  • Windows Server 2008 R2
  • Coldfusion 9.0.1 (multiserver)
  • Java 7 update 13
  • Jrun 4
The error message I am seeing in all the log files is 'Error loading: C:/Program Files/Java/jre7\bin\server\jvm.dll'.
Nothing has changed with Java or Jrun since the reboot, so I can't quite put my finger on the actual issue.
We have tried rebooting the server, updating Java with no success.
Any thoughts on what it might be?
2.8K
Adobe Employee ,
Hello HiTop,
Can you share your jvm.config file?
Anit Kumar
Guest
# VM configuration
# Where to find JVM, if {java.home}/jre exists then that JVM is used
# if not then it must be the path to the JRE itself
#java.home=C:/JRun4/jre
java.home=C:/Program Files/Java/jre7
# If no java.home is specified a VM is located by looking in these places in this
# order:
#  1) bin directory for java.dll (windows) or lib/<ARCH>/libjava.so (unix)
#  2) ../jre
#  3) registry (windows only)
#  4) JAVA_HOME env var plus jre (ie $JAVA_HOME/jre)
# Arguments to VM
java.args=-server -Xmx2048m -Dsun.io.useCanonCaches=false -XX:MaxPermSize=192m -XX:+UseParallelGC -Xbatch -Dcoldfusion.rootDir={application.home}/ -Djava.security.policy={application.home}/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfusion/lib/coldfusion.policy -Djava.security.auth.policy={application.home}/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfusion/lib/neo_jaas.policy
# commas will be converted to platform specific separator and the result will be passed
# as -Djava.ext.dirs= to the VM
java.ext.dirs={jre.home}/lib/ext
# where to find shared libraries
java.library.path={application.home}/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfusion/lib,{application.home}/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfusion/jintegra/bin,{application.home}/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfusion/jintegra/bin/international,{application.home}/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfusion/lib/oosdk/classes/win
system.path.first=false
# set the current working directory - useful for Windows to control
# the default search path used when loading DLLs since it comes
# before system directory, windows directory and PATH
java.user.dir={application.home}/../lib
# JVM classpath
java.class.path={application.home}/servers/lib,{application.home}/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfusion/lib/oosdk/classes,{application.home}/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfusion/lib/oosdk/lib,{application.home}/lib,c:/inetpub/v4/javalib
This does point to an existing jvm.
Adobe Employee ,
Hello HiTop,
Please try the following:-
  1. Launch Command prompt as Administrator
  2. Browse to C:\JRun4\bin and run the following command jrun.exe -start cfusion
  3. Try to access the CF admin, once the services are started.
In case it gives an error message, please share the same.
Anit Kumar
Guest
Upon attempting #2, I receive the following error:
     The program can't start because MSVCR100.dll is missing from your computer.  Try reinstalling the program to fix this problem.
I did see posts about this, but they related to cumulative hotfix 4 for Coldfusion.  Do you believe this missing .dll file to be the culprit?
Adobe Employee ,
Yes, that seems to be the issue.
Please copy the msvcr100.dll from C:\Program Files\Java\jre7\bin\ to C:\JRun4\bin\ and then try to start the service.
Anit Kumar
Guest
Copying the msvcr100.dll to c:/jrun4/bin/ seemed to work.  However, I am wondering why coldfusion isn't looking to the first location for that file.  Do you know why I had to copy the file to the other directory?  I was hoping to keep that .dll in one spot so that future updates occur on the same Java.
Guest
Jun 24, 2013 Jun 24, 2013
@Anit_Kumar,
Would you happen to know why this is a desired solution?  Why did I have to copy that file?  Why did the JVM not see it in the original directory?
Documentation
