1. Re: First render test in CC, Very Slow
Ann Bens Jun 18, 2013 1:20 AM (in response to Jorge Jaramillo Hdz)That is not correct.
Make a new project and try again.
2. Re: First render test in CC, Very Slow
Jorge Jaramillo Hdz Jun 18, 2013 1:21 AM (in response to Ann Bens)Is what I trying right now, my "theory" is that may be is because was a CS6 project, I'm trying to make a new one and see what happen.
3. Re: First render test in CC, Very Slow
Jorge Jaramillo Hdz Jun 18, 2013 1:35 AM (in response to Ann Bens)Made a little test again.. "the problem" seems to be Media Encoder. In Premiere the render is very fast, but in Media Encoder is taking a lot!
4. Re: First render test in CC, Very Slow
Harm Millaard Jun 18, 2013 2:01 AM (in response to Jorge Jaramillo Hdz)AME carries a huge overhead, slowing things down very much. That is the reason we changed our benchmark to only use Direct Export. AME was already crippled in CS6 and still is in CC.
5. Re: First render test in CC, Very Slow
Jorge Jaramillo Hdz Jun 18, 2013 2:03 AM (in response to Harm Millaard)Thanks Harm, is just weird, in CS6 AME works perfectly to me, but in this version seems to be very very slow
6. Re: First render test in CC, Very Slow
Harm Millaard Jun 18, 2013 2:20 AM (in response to Jorge Jaramillo Hdz)Let me give you an example of how AME deteriorated in performance in time.
With CS5.03 the MPEG2-DVD test in our benchmark using AME on my old system took 25 seconds. That system now ranks # 49 in the benchmark and is a lowly i7-920 with 24 GB and a GTX 480, overclocked to 3.7 GHz.
With CS6.03 the same test on my new system using AME takes 44 seconds. That is the system that ranks #1, an i7-3930K with 64 GB and a GTX 680, overclocked to 4.7 GHz. If anything, it should have been much better, not worse by 76%.
I have not seen a noticeable improvement in CC yet.
So, clearly, AME has serious performance problems since CS5 and Adobe is aware of that. It is the internal caching algorithms that cause this behaviour. Unfortunately, the bug has been deferred to somewhere in the future.
7. Re: First render test in CC, Very Slow
Jorge Jaramillo Hdz Jun 18, 2013 4:03 AM (in response to Harm Millaard)Thanks Harm, thats odd, Adobe need to work on it, I use a lot AME, and the CS6 worked "fine", but this version is extremely slow!
8. Re: First render test in CC, Very Slow
Dmart Films Jun 18, 2013 4:05 PM (in response to Jorge Jaramillo Hdz)So...the new AME CC is basically going to make using PP useless for me if I cannot edit while I exportin the background with AME. I just tried to export a 3 min 1920x1080 Canon DSLR footage sequence with AME and it wanted 1 hour to export. I did a direct export through PP and it only took 6 min. I am going to go back and open the project in CS6 and see what I get. I too never had problems with AME CS6, nothing ever seemed crazy long....this is AWFUL!
9. Re: First render test in CC, Very Slow
PaulM-Aus Jun 18, 2013 4:53 PM (in response to Dmart Films)I'm also seeing up to 100% longer render times in AME CC versus AME CS6.
10. Re: First render test in CC, Very Slow
Jorge Jaramillo Hdz Jun 18, 2013 5:05 PM (in response to Dmart Films)So, I'm not the only one.
There is a way that Adobe could read this?, I just sent a Twitt to Premier Pro official account (@AdobePremiere), and report this problem as a "bug" here: https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Would be great if each one do the same to have a quickly update to fix it.
11. Re: First render test in CC, Very Slow
Dmart Films Jun 18, 2013 5:14 PM (in response to Jorge Jaramillo Hdz)Just did same!
12. Re: First render test in CC, Very Slow
Rishaar Jun 18, 2013 6:28 PM (in response to Jorge Jaramillo Hdz)That's a shame...
i use AME a lot as i need to batch render differents projects in different formats.
I have always had great results with my configuration in CS5.5, those poor AME performances are one reason keeping me away from upgrading to CS6 or CC.
How come this keep getting worse?? What's the point of AME then?
13. Re: First render test in CC, Very Slow
lostmile Jun 18, 2013 8:02 PM (in response to Jorge Jaramillo Hdz)this won't be good. It already takes longer than realtime to export my videos
why did I leave apple again?
Can companies please stop "fixing" things that aren't broken and making software for teenagers
14. Re: First render test in CC, Very Slow
JSS1138 Jun 18, 2013 8:07 PM (in response to Jorge Jaramillo Hdz)I ran a short test of the MPEG2 sequence from PPBM5.5 and got a 3:45 export from CS6 and a 4:31 export from CC, identical settings, going through AME.
I haven't tried a Direct Export yet.
15. Re: First render test in CC, Very Slow
JSS1138 Jun 19, 2013 9:07 AM (in response to Harm Millaard)I ran some more tests. Here's what I have so far:
Windows 8 Pro 64 bit
i7 2500
8GB DDR3 1333 RAM
1TB HD (single drive)
GTX 560 Ti 2GB, 320.18 driver
CUDA acceleration turned on in both versions
I imported a 4 minute AVCHD clip with a lot of action. I created a sequence based on that clip. I exported that clip with no edits or effects to BD and DVD settings identical in both versions.
Using AME for Export:
CC7_BD = 5:58
CS6_BD = 5:43 <---Winer CS6
CC7_DVD = 3:07 <---Winner CC7
CS6_DVD = 3:12
Using Direct Export
CC7_BD = 5:49
CS6_BD = 5:40 <---Winner CS6
CC7_DVD = 1:39 <---Winner CC7
CS6_DVD = 2:55
So, it looks like MPEG2 is faster with CC7 and H.264 is faster using CS6. The biggest difference is for DVD using CC7. Look at the times for AME and Direct, nearly cut in half!
Now it should be noted that a brand new project was started in each version. I've seen reports of older projects opened in CC7 behaving slowly, so I wanted to take that into account. And in fact my first test was done opening an older project, Harm's 5.5 benchmark project, in fact. So far, it's looking like where the project was created makes a difference. Of course, Harm's project was full of effects, and this round of tests used none at all. That's the next step, repeating these tests with effects, both accelerated and not.
16. Re: First render test in CC, Very Slow
jasonvp Jun 23, 2013 7:13 AM (in response to Harm Millaard)Harm Millaard wrote:
I did a quick test with AME vs Pr exporting with CC this morning. Harm's right on the money. It took 15 minutes for an export with AME, and less than 8 minutes with Pr. Same project, same footage, same export settings, same everything.
That's just... silly.
17. Re: First render test in CC, Very Slow
Rishaar Jun 23, 2013 7:40 AM (in response to jasonvp)That's not just "silly" but totally unacceptable!
What's going on ?
In my case, not beeing able to use AME efficiently is just a deal breaker...
Just to illustrate my case:
I run a Yoga lesson-videos streaming site. We upload 3 videos a week, about 30min to 90 min each, currently streamin 170 videos and counting.
For every single videos i edit, i batch export in 4 different optimized formats: 1 master for us, 1 for vimeo, 1 for brightcove and 1 teaser for Youtube
So any single project ends up in AME CS 5.5 in 4 different outputs. Of course, i usually render multiple projects in a row, making it a dozen tasks in line.
(Thanks to Harm Millard advices when i rebuild my editing station 2 years ago, everything is just working so smoothly it is outrageous )
In the mean time, i can just keep doing something else, like a shooting or going for dinner, or well you know...Now, imagine me doing direct render in Premiere, waiting for one task to end to manually start another one...just plain impossible.
18. Re: First render test in CC, Very Slow
JSS1138 Jun 23, 2013 9:34 AM (in response to jasonvp)same export settings
What were those export settings?
19. Re: First render test in CC, Very Slow
It shouldn't matter, Jim. But compressing down from 1080p to 720p and converting AVCHD to MP4. Same frame rate (29.97), 1 pass VBR, and 5Mbps bitrate.
I've never been able to use AME with PrP CS6 because I can't edit my AVCHD with it. All I know is that AME 5.5 is considerably faster than AME CC with the same footage. It's a 20 minute video, and 5.5 can do the deed in half real time. (10 minutes or so).
20. Re: First render test in CC, Very Slow
JSS1138 Jun 23, 2013 11:29 AM (in response to jasonvp)I ask because in my tests, the H.264 Blu-ray settings showed AME and Direct export times within seconds of each other. (Post 15) The Direct was barely faster, not enough to cause concern with using AME. It was a very different story with MPEG2, which showed a significant decrease in export time going Direct.
Also, was that project created in CC, as that does seem to make a difference?
21. Re: First render test in CC, Very Slow
Yes, it was created in CC.
22. Re: First render test in CC, Very Slow
JSS1138 Jun 23, 2013 12:20 PM (in response to jasonvp)Thanks.
Any effects? (My test had none.) Were any of them accelerated?
23. Re: First render test in CC, Very Slow
jasonvp Jun 23, 2013 12:26 PM (in response to JSS1138)Jim Simon wrote:
Thanks.
Crop and Horizontal Flip, both of which are accelerated.
24. Re: First render test in CC, Very Slow
JSS1138 Jun 23, 2013 3:43 PM (in response to jasonvp)Thanks. Testing now.
25. Re: First render test in CC, Very Slow
JSS1138 Jun 23, 2013 4:11 PM (in response to jasonvp)Ran another test and I'm seeing the same as you. AME was 16:33 and Direct was 9:14.
I wonder if my earlier test using a 4 minute clip just wasn't long enough for significant differences to manifest.
26. Re: First render test in CC, Very Slow
lostmile Jun 24, 2013 7:03 AM (in response to Jorge Jaramillo Hdz)So I don't have a direct to test this and I'm not sure if it helps but;
Intel Core i7 2600K water cooled and clocked at 4Ghz
32GB 1866 DDR3 RAM
SSD - Samsung 840 256gb - WIndows and Adobe install
10,000RPM drive - effects files and scratch/cach
7200RPM 2TB WD red - Raw files storage
Nvidia GTX680
I have a premiere cs6 upgraded to cc (by opening the file in cc) that has a 24minute timeline at 4K using all R3D files that has some AE dynamic link mixed it, some AE edited r3d files, and some text plates.
I exported the project in 4k with 5.1 audio (it was a 5.1 project) using h.264 and queued it in AME CC... Well this export with nothing else open or running on the above PC took 20hours over the weekend. I did it last week in Premiere CS6 exporting to AMECS6 and it took about 10hours. That's at least double the time but these export times are guestimates as I wasn't doing this to post here lol.
27. Re: First render test in CC, Very Slow
jwilliamsrfcu Jun 24, 2013 12:24 PM (in response to Jorge Jaramillo Hdz)Yeah this is insane. I updated to CC on day one and now am seriously regretting it. I cut a weekly 30min television show on my work station. A lot of different clips, titles and graphics, a mix of HDV and DSLR footage, all 1080 at 29.97fps.
The HDV footage is dynamically linked to AE and keyed out with a simple solid BG behind it. So obviously that is a bit of a chore for any system to render it. But in CS6, using AME I could render out the final show in about 2.5 to 3 hours.
But since I upgraded a couple unfinished shows from CS6 to a CC project I'm getting render times of 14+ hours.
That simply can't be right. I've tried making previews of select areas and it's the same insane ammount of time.
Why is there no one from Adboe responding to this forum?
28. Re: First render test in CC, Very Slow
Jorge Jaramillo Hdz Jun 24, 2013 12:32 PM (in response to jwilliamsrfcu)Why is there no one from Adboe responding to this forum?
That is the same thing I'm asking right now, I've reported three bugs
Adobe, What is going on?
29. Re: First render test in CC, Very Slow
tclark513 Jun 24, 2013 1:21 PM (in response to jwilliamsrfcu)No offense but why on earth are you using untested software for such important work?
30. Re: First render test in CC, Very Slow
jwilliamsrfcu Jun 24, 2013 1:35 PM (in response to tclark513)cool man, thanks for being so helpful
31. Re: First render test in CC, Very Slow
jwilliamsrfcu Jun 24, 2013 2:40 PM (in response to Jorge Jaramillo Hdz)It looks like I may have solved my problem, though I'm not sure if it will be any help to the rest of you. I noticed that the render times were only getting seriously clogged because of the AE comps I had dynamically linked into my timeline. These were clips that I had keyed out in AE using a third party plugin. When I went back into AE and used a different effect to get my green screen key (this time I used the buil in Keylight effect) everything seemed back to normal. By which I mean a few hours to render instead of 20.
So maybe check any effects you are using, if they are the CS6 version they may not work to well with CC
32. Re: First render test in CC, Very Slow
jasonvp Jun 24, 2013 2:47 PM (in response to jwilliamsrfcu)jwilliamsrfcu wrote:
Glad you found a solution. On this end, I don't use/own AE, so that's not what's causing any of my slow-downs.
33. Re: First render test in CC, Very Slow
Jorge Jaramillo Hdz Jun 24, 2013 2:49 PM (in response to jasonvp)Jason Van Patten wrote:
Same here, no AE in the sequence, so not what's causing any of the slow render in my CC
34. Re: First render test in CC, Very Slow
jwilliamsrfcu Jun 24, 2013 3:47 PM (in response to Jorge Jaramillo Hdz)Well I guess that didn't totally fix the issue. It still takes quite a bit longer, actually way longer, than CS6 would take to render it.
35. Re: First render test in CC, Very Slow
Actually, i think you've just nailed it (without knowing it?)
CC is, by design, a constantly evolving software suite.
Adobe already proved they are willing to add or scratch features any time, without any real notice from now on.So there we have a software suite in a constant "untested" state, which may be working now but become buggy with the add or removal of something in coming months...
Since this looks a bit like gambling to me, I would propose a new definition for Adobe CC :
For a monthly bet of 30-50 USD, you can now join the Adobe Casino Cloud
36. Re: First render test in CC, Very Slow
Kurrykid Jun 24, 2013 6:31 PM (in response to Rishaar)Hopefully it won't turn into another "Mac CS6 'Serious Error' thread" for PPro which was NEVER resolved by Adobe! It caused quite a bit of problems for a lot of people, including me
37. Re: First render test in CC, Very Slow
It actually was solved by new video card drivers. It took a while for them to release them but it did fix it.
38. Re: First render test in CC, Very Slow
Kurrykid Jun 24, 2013 6:39 PM (in response to tclark513)Hmmm...I followed that thread for a long time and don't remember a posted fix but with 14 pages of threads, I may have missed it
Sorry for getting Off Topic...please resume!
39. Re: First render test in CC, Very Slow
That's great!
I would never use new software for anything important until I tested it on my own. I've read posts from people actually stating that they updated in the middle of a project and having clients in to see their progress the same day. That is business suicide!
