1. Re: CS6 Project With H.264 Video Wont Open in Premiere CC
JSS1138 Jun 19, 2013 12:06 PM (in response to TheMtyThor)Try starting a new project in CC7, then importing the problem clips. How does that go?
2. Re: CS6 Project With H.264 Video Wont Open in Premiere CC
TheMtyThor Jun 20, 2013 8:10 AM (in response to TheMtyThor)the Error Message from the Footage is "the File Has No Audio or video Streams. the Format is a Photo JPEG 1920x1080 25 fps. it works fine in CS6 i am Using Windows 7 Ultimate 64Bit
3. Re: CS6 Project With H.264 Video Wont Open in Premiere CC
TheMtyThor Jun 19, 2013 1:50 PM (in response to JSS1138)Same Message opening a New Project "the File Has No Audio or Video Streams"
4. Re: CS6 Project With H.264 Video Wont Open in Premiere CC
jstrawn Jun 19, 2013 2:07 PM (in response to TheMtyThor)3 questions:
1. Are you working on widnows?
2. Do you have quicktime installed?
3. Were you trying to re-link?
5. Re: CS6 Project With H.264 Video Wont Open in Premiere CC
TheMtyThor Jun 19, 2013 2:30 PM (in response to jstrawn)i am working in windows 7 Ultimate 64Bit, i do have quicktime 7.7.4 installed. i have tried to re-link, replace, and import the files in question. the files show up fine in After Effects CC. I can See the Clip in Bridge CC, i can see the Clip in CS6
6. Re: CS6 Project With H.264 Video Wont Open in Premiere CC
jstrawn Jun 19, 2013 2:54 PM (in response to TheMtyThor)It failed for relink, but it also failed for regular import, right? If so, do you have a reasonably sized file (<50 mb) that you can send me directly if I give you my email address?
7. Re: CS6 Project With H.264 Video Wont Open in Premiere CC
TheMtyThor Jun 19, 2013 3:36 PM (in response to jstrawn)the file sizes are much bigger than 50mb. this one in particular is 185 mb
8. Re: CS6 Project With H.264 Video Wont Open in Premiere CC
jstrawn Jun 19, 2013 3:40 PM (in response to TheMtyThor)OK, then please use yousendit or dropbox or somethign to send the smallest sample file you have to my email address. Thanks,
-james
9. Re: CS6 Project With H.264 Video Wont Open in Premiere CC
TheMtyThor Jun 19, 2013 4:30 PM (in response to jstrawn)yeah i will find one and upload it and thank you for your help whats your email address?
10. Re: CS6 Project With H.264 Video Wont Open in Premiere CC
TheMtyThor Jun 19, 2013 5:19 PM (in response to jstrawn)Send me a private Message on this board, i will send you a download link. thanks again
11. Re: CS6 Project With H.264 Video Wont Open in Premiere CC
jstrawn Jun 20, 2013 10:07 AM (in response to TheMtyThor)I got your link and am downloading the file now. I've got some other tsks to take care of but I'll take a look at it when I can and then update back here.
12. Re: CS6 Project With H.264 Video Wont Open in Premiere CC
TheMtyThor Jun 20, 2013 10:12 AM (in response to jstrawn)no problem, i wasnt aware of your location or work schedule and thank you very much, i'm anxious to use CC, this is my last problem with it, then i am good! again this is greatly appreciated
13. Re: CS6 Project With H.264 Video Wont Open in Premiere CC
jstrawn Jun 20, 2013 11:16 AM (in response to TheMtyThor)I cannot repro on GM build of CC on mac/win using 'MVI_1982.mov. I do get the 'no video/audio streams error' on win7 but only with no quicktime installed. As soon as I install quicktime 7.7.4 and re-launch then I can import your test file no problem. This is an expected bhavior on win since it needs QT to import third-party mov files. (mov files ecported by ppro don't)'
All I can suggest is to check your quicktime version again on that system, make sure it's updated, re-start, relaunch, all that stuff... and then try again.
14. Re: CS6 Project With H.264 Video Wont Open in Premiere CC
TheMtyThor Jun 20, 2013 12:12 PM (in response to jstrawn)I am On Windows 7 Ultimate with Quicktime 7.7.4 already installed, is this a bad refernce point on Premiere CC? something is awry in the Registry? that it doesnt see the Quicktime Install? All Other CC apps see the video and can play it. so there must be a registry problem of some kind that Premiere doesnt see?
15. Re: CS6 Project With H.264 Video Wont Open in Premiere CC
TheMtyThor Jun 20, 2013 12:14 PM (in response to jstrawn)I also Wonder if Mcafee Might have prevented something from happening, like a script running that linked the Quicktime Modules to teh Premiere Pro Modules? i'll let you knwo what happens later. thanks
16. Re: CS6 Project With H.264 Video Wont Open in Premiere CC
TheMtyThor Jun 20, 2013 1:55 PM (in response to jstrawn)ok this was Odd, but i am happy. I accepted a Camera RAW update but doubt that would have anything to do with it. I decided to reopen the CS6 Premiere Project, i saved it as a CC Project, and BOOM it worked. so go fiure i guess. thanks for all your help
17. Re: CS6 Project With H.264 Video Wont Open in Premiere CC
jstrawn Jun 20, 2013 2:50 PM (in response to TheMtyThor)Glad it worked for you!
-James
