Hi All,
I am trying to install either ColdFusion 9 (which is where company is using) or 10 (if I can't have 9) on my Mac 10.8.6. When I click on the dmg file, it shows a running bar and once it's completed, i see a standard installation box (the one you click "agree" "nect" etc...) except there is nothing showing on the box. There is a blue "next" button but I can't click on it. This happens to both ColdFusion 9 and 10 installation. With 9 though, I get a centaur_err file.
This is very urgent as I cannot work without ColdFusion. I would really appreciate your suggestions.
Thank you,
Jennfer
Hello Jennfer,
can you share the installer logs with us? This could be a permission related issue.
Anit Kumar
Hi Anit,,
Attached is everything in the log folder. I am not sure which file you need. Please advice
Jennifer
Hello Jennifer,
Can you search for Adobe_ColdFusion_10_Install_.log file with date and time stamp. This log file would be available at your desktop (or at the location of installer file).
Anit Kumar
Hi Anit,
I don't have that. The program was never installed. It stops at that grey box.
Jennifer
Hello Jennifer,
The name of file vary as per time stamp. For e.g. mine says, Adobe_ColdFusion_10_Install_05_29_2013_02_40_58.log
Can you search only with Adobe_ColdFusion_10_Install. That may work.
Anit Kumar
no...
Hello Jennifer,
I just checked and found this. As per the technical specifications (http://www.adobe.com/in/products/coldfusion-enterprise/tech-specs.html), CF 10 is only supported till Mac OS X v10.6.x, or v10.7 officially.
However, you can try enabling the root user on MAC (http://support.apple.com/kb/ht1528) and then try to install ColdFusion 10.
Anit Kumar
Hi Anit,
I saw that techinical specification too. But there is a different specification when you are on the download page that says
There is another article that mentions Mac 10.8 http://helpx.adobe.com/coldfusion/kb/coldfusion-10-update-8.html
I am not sure which one is correct but I really need to have this installed. Thanks.
Hello Jennifer,
Thank you for pointing this to us. Yes, i just checked the same on Support Matrix and it says that it is supported on MAC 10.8.
Can you try enabling the root user on MAC (http://support.apple.com/kb/ht1528) and then try to install ColdFusion 10.
Anit Kumar
Hi Anit,
I just got to my home computer and tried to install ColdFusion 10 (w/o enbling the root user) and it's working. I also don't have java installed on this computer. What do you think the problem may be with the other computer?
Jennifer
Hello Jennifer,
That is great. Java is not a mandate for installation of ColdFusion. ColdFusion uses their own JRE.
Is the home computer, also a MAC.
Jennifer
Anit Kumar
Yes, they are both the same.
Hello Jennifer,
Please try the root user suggestion for the other MAC. If you still face any issue, please send an email to cfinstal@adobe.com.
Anit Kumar
Can anyone help? I'm getting the same grey screen and I'm not able to install coldFusion 10 in iMac 10.8.3. This is urgent
The only way I am able to proceed is by clicking on the next, then clicking on Adobe ColdFusion 10 on the top left and hovering over "Service." This allows the screen to move to the next step and you have to do that every single time.
