quote:...
Originally posted by: Newsgroup User
> Error Executing Database Query.
> [Macromedia][SequeLink JDBC Driver][ODBC Socket][Microsoft][ODBC Microsoft
> Access Driver] Syntax error (missing operator) in query expression ''{d
> '2007-04-13'}''.
it seems the error is with your eventDate. in MS Access, dates should be
entered as ###date### (where date is an actual date, in m/d/yyyy format,
or d/m/yyyy, depending on locale settings in the database). but there
should be 3 # on both sides of t
> '2007-04-13'}''.
should be 3 # on both sides of the date and no '.
so try changing your SEEevents.eventDate='#form.eventDate#' to
SEEevents.eventDate=###form.eventDate###.
if that still throws an error, you will have to parse your date form
field and make a date in MS Access format from it first, i.e. before
your <cfquery> add <cfset eDate = DateFormat(form.eventDate,
"mm/dd/yyyy")> and then use that in your query:
SEEevents.eventDate=###eDate###
