When I create a new project the Print option is frequently missing from the Toolbar Buttons field in Webhelp Settings. Sometimes I close the dialog, reopen it, and "Print" is miraculously there, so I can select it. Other times I can't make it display. Is there a switch somewhere, where I can indicate that I ALWAYS want the Print button? If not, how do I make it display when it doesn't? Thanks!
Hi there
Whether or not you see a Print button is dependent on whether one was included in the skin you are using. Your example depicts that your skin selection is "Default". In order to see an option to include a Print button, you need to choose a skin that has one defined.
Cheers... Rick
Hi there
Cheers... Rick
Thanks Rick! The "mysterious" appearance probably occurred after I selected another skin.
