The web site you are accessing has experienced an unexpected error.
Please contact the website administrator.
The following information is meant for the website developer for debugging purposes. | ||||||||||||||||||
Error Occurred While Processing Request | ||||||||||||||||||
what should i do.,
am i missing anything or did i do something wrong .,
Hard to tell, it would probably be useful to see exactly what query you were trying to execute at the time, and the surrounding ColdFusion code.
Well, judging from the error message, you are doing in INSERT that has move items in the VALUES list than in the fields list. It appears that the Oracle driver isn't as friendly as the MS SQL driver in showing the actual SQL statement being processed. Try taking the advice of the error message and turn on robust error handling, to see if that causes the Oracle driver to give you more info. Personally, I'd look real close at the SQL statement for a missing comma in the VALUES clause.
If you most the query here, maybe someone will spot the error.
-reed
