I'm getting the following error when I create an item with the data services:
INFO: [Data Services] [DEBUG] SQL Assembler jdbc exception on operation=create-item error=com.microsoft.sqlserver.jdbc.SQLServerException: The value is not set for the parameter number 1.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(SQLServerException.java:190
Configuration settings are:
<source>flex.data.assemblers.SQLAssembler</source>
<scope>application</scope>
<metadata>
<identity property="TO_ID" undefined-value="0" />
</metadata>
<create-item>
<procedure name="spMob_TakeOff_Details_Header_Insert">
<procedure-param property-value="#ID#" type="OUT"/>
<procedure-param property-value="#Session_ID#" />
<procedure-param property-value="#Notes#" />
</procedure>
</create-item>
ID always has value equal to 0, and this procedure always falls.
Could anyone help or explain to fix this?
Could this be bug of JDBC (https://bugs.eclipse.org/bugs/show_bug.cgi?id=385627)?
Total Likes
