If you've read the title, you know where I'm at. Flash crashes as soon as any page with Flash content is visited. A popular suggestion is to disable Hardware Acceleration, but I cannot do that as the player never loads far enough to let me to do that.
Here's what I've tried so far:
- Uninstalled flash using the Uninstaller tool, verified that both Plugin and ActiveX versions of Flash were gone. Then did a re-install.
- Cleared Flash cache data (from the Control Panel applet)
- Cleared browser caches from both browsers
- Disabled Protected Mode in both system32 and sysWOW64 locations using the mms.cfg file
What HAS worked:
- Downgrading the Plugin version (Firefox) to version 10.3.
NOTE: I cannot install the ActiveX (IE) version to 10.3, as installer quits when it finds that there's a newer version available for download! Additionally, I cannot find a repository for previous versions of Adobe Flash Player ANYWHERE anymore. Adobe's Website, OldApps.com and FileHippo.com... none of them offer previous version of Flash anymore. It was a miracle I was able to find the 10.3 installers. Apparently, it's the latest version or nothing. This does my client precisely zero good.
Unfortunately, this is a client's computer that I'm doing remote support with, so I don't have constant access to it.
Please help!
Please apply the steps mentioned in the below link
http://forums.adobe.com/message/4323109#4323109
Also you can find all archived verion of flash player using this link http://helpx.adobe.com/flash-player/kb/archived-flash-player-versions.html
Unfortunately, that didn't do the trick. I ran the script (as Administrator), rebooted, reinstalled Flash Player. Crash. So then I re-ran the script (as Administrator), rebooted again. Crash!
I have Firefox running FlashPlayer 10.3 and that works. As I mentioned, the ActiveX installer for FlashPlayer 10.3 finds a newer version available and won't install. The only option is to quit. I must say, this frustrates me.
Any more thoughts out there?
try this to uninstall instead of the script, it always worked for me.
http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows.html
Don't have IE or FF running at that time.
