The XDP version of a form displays correctly but when the generate PDF step in a process is done one of the images is not included. In designer the display as PFD tab works fine. I've recreated the PDF from the XPD, I've removed the image fragment, and even included the images not as a fragement but nothing.Any ideas?
Solved! Go to Solution.
Total Likes
I worked around this problem by finding a form that the image was working on adn copied it to the one that was not working. NOt a real fix but it is workign now.
Total Likes
Is the image included in the PDF template?
When you use the Image Field you can set the relative path to an image: ../Images/logo.png
Total Likes
