Hi, I am having trouble with the whcshdata.js file coming up empty when generating context-sensitive WebHelp from RoboHelp 10. Is there a setting in RoboHelp that I can change to fix this? We successfully generated the same CS WebHelp a couple of months ago where the whcshdata.js file included all the map IDs, etc. as it should. However, this time around, it is not working. We are building on the same RH 10 project file as before and added a few new map IDs. The FrameMaker source file has been updated as well, but nothing else changed that I know of. What could be causing this problem? Thanks for helping.
I will answer my own question. Apparently, the option for linking the map file unchecked itself between the last time I generated the WebHelp and now. I assume it does this when you import a new map file into the project, so now I know to check this every time. The solution was right in front of me in the WebHelp settings window under Content Categories. Such a simple answer!
