Download can't find my PowerPoint, tried IE and GC, no luck. This is a purchased Presenter 7 that I never downloaded. Tried IE and GC, also tried download from Adobe site and same error. My machine is running 64bit Windows 2010
Moving this discussion to the Presenter forum.
I bought Presenter 7, but never downloaded it. Now I'm trying to download it and I get an error saying it can't be downloaded because PowerPoint can't be found. I tried different browsers and a Presenter 7 download from the Adobe web site, but no luck. However, I was able to download Presenter 9 as a trial. I plan to get on the phone with Adobe today and hopefully it will be solved. In the meanwhile if you have any suggestions, I'm grateful. Thanks
Please explain the problem in little detail. It is clear what is happening currently.
Jayashree
Adobe Presenter Engg. Team
As you explain , It seems your presenter version is 7 and office version is 2010 which is not compatible.
Presenter 7 does not support office 2010 while presenter 7.0.7 does.
Can you confirm which version of presenter you are installing?
Check which version of presenter is getting downloaded from the download link.
If you are getting presenter 7 then try presenter 7.0.7.
Try saving the download file and then install manually by double clicking on exe file.
Let us know if you stuck anywhere of issue is not resolved.
Sunil
(Adobe Presenter Engg Team)
And if you are running the 64 bit version of PPT 2010, you will need to have Presenter 8, as there is no 64 bit version of Presenter 7, 7.0.7 included.
Presenter 7, 7.0.7 and 8 can be downloaded from here: http://www.adobe.com/support/downloads/product.jsp?product=153&platform=Windows
Ok thanks to all for the info, looks like I'll need to go to Presenter 9. Hopefully they will give me some discount for the money spent on 7 that was incorrect for my machine.
