1
Illustrator CC crashes on creating new document, or opening existing file
Guest
Jul 02, 2013 Jul 02, 2013
Just like the problem in Illustrator CS6 ( http://forums.adobe.com/message/5288811#5288811 )
Launching Illustator CC and then creating a new file (pressing command > N) causes the application to not respond and gives me a beachball. No new document dialog appears, it just freezes right away.
Force quitting, and then trying to launch illustrator by opening an already-created file causes an immediate freeze.
If I manually delete
/Users/<username>/Library/Preferences/Adobe Illustrator 17 Settings/en_US/plugincache.bin
my next launch is fine, but all subsequent launches will have the same issues - so I'll have to manually delete it bin file every time.
I've run the cleaner tool, i've installed a fresh copy of CC.
It seems reasonable to infer that there may be an issue with a particular plugin, but as it's a fresh install there aren't any 3rd party plugins that I'm aware of. Any help would be tremendously appreaciated!
I'm on an Early 2008 Mac Pro running OSX 10.8.4 (12E55)
Processor:  2 x 2.8 GHz Quad-Core Intel Xeon
Memory:  14 GB 800 MHz DDR2 FB-DIMM
Graphics:  NVIDIA GeForce 8800 GT 512 MB
21.5K
Adobe
Are you using a Wacom tablet?
Guest
I do have a Wacom tablet, and I did see the thread about the inkling plugin causing an issue.
However I have the Wacom Intuos5 Touch Medium Pen Tablet (PTH650), and I wasn't able to find a 'wacexportfile.aip' plugin file mentionedin that thread. Think there's another wacom-associated plugin I should look for?
I also have verdana enabled
Did you update your Wacom drivers? Have you made the hidden Users/<yourname>/Library visible and looked there?
Guest
Thanks for that suggestion - it's been awhile.
So, I just updated Wacom drivers to the latest available (jun 18) and, alas, am still having the same issues.
I noticed this thread: http://forums.adobe.com/message/5447001#5447001
I've got my setup similar to the original poster (see his last post) where my home folder is on a separate HD and my applications are on my startup disk which is a much faster SSD. Not sure if that's helpful to anybody.
Well then have you tried the solution posted in the other thread: to move your home folder to where Illustrator is?
Guest
Thanks, Monika -
Unfortunately, moving around a home directory isn't exactly trivial on a non-fresh install of the OS, as I have numerous symlinks and paths set to its current location - so that'll have to be my last ditch effort...
I'd love to understand why a home directory located on a hd separate from the one where the app is located would cause this problem.
Guest
i'm attaching the crash report in case it might help someone:
Date/Time:       2013-07-02 19:22:30 -0400
OS Version:      10.8.4 (Build 12E55)
Architecture:    x86_64
Report Version:  11
Command:         Illustrator
Path:            /Applications/Adobe Illustrator CC/Adobe Illustrator.app/Contents/MacOS/Adobe Illustrator
Version:         256 (17.0.0)
Parent:          launchd [144]
PID:             9459
Event:           hang
Duration:        2.34s
Steps:           24 (100ms sampling interval)
Hardware model:  MacPro3,1
Active cpus:     8
Free pages:      1752416 pages (-173)
Pageins:         1 pages
Pageouts:        0 pages
Process:         Adobe Illustrator [9459]
UID:             501
Task size:       75217 pages
CPU Time:        0.001s
  Thread 0x5c148    DispatchQueue 1          priority 47
  24 start + 52 (Adobe Illustrator) [0x100002c94]
    24 main + 135 (Adobe Illustrator) [0x100419a57]
      24 CAIApplication::RunApp() + 396 (Adobe Illustrator) [0x10042e74c]
        24 CAIExoAppImpl::RunEventLoop() + 21 (Adobe Illustrator) [0x100488195]
          24 exo::app::OS_AppBase::RunEventLoop() + 56 (exo) [0x1097efeb8]
            24 -[NSApplication run] + 636 (AppKit) [0x7fff8de3621a]
              24 -[ExoMacApplication sendEvent:] + 359 (exo) [0x1097f03c7]
                24 bool dvacore::config::ExecuteTopLevelFunction(boost::function0, bool*) + 125 (Adobe Illustrator) [0x100400c9d]
                  24 bool dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0, bool*) + 140 (Adobe Illustrator) [0x1004010bc]
                    24 DroverErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0) + 66 (Adobe Illustrator) [0x100489a52]
                      24 int dvacore::config::ErrorManager::ExecuteFunction(boost::function0*, bool*) + 71 (Adobe Illustrator) [0x100401207]
                        24 boost::detail::function::function_obj_invoker0, boost::_bi::list2, boost::_bi::value > >, bool>::invoke(boost::detail::function::function_buffer&) + 36 (exo) [0x1097f41a4]
                          24 exo::app::AppBase::PreEventProcessing(dvaui::ui::OS_Event const&) + 13 (exo) [0x1097eb98d]
                            24 CAIExoAppImpl::DoPreEventProcessing(dvaui::ui::OS_Event const&) + 47 (Adobe Illustrator) [0x1004895ff]
                              24 CAIExoAppMacEventHandler::PreProcessEvent(dvaui::ui::OS_Event const&) + 448 (Adobe Illustrator) [0x1003f6a10]
                                24 CAIExoAppMacEventHandler::HandleForwardedEvent(dvaui::ui::OS_Event const&) + 293 (Adobe Illustrator) [0x1003f6d35]
                                  24 CAIExoAppMacEventHandler::DispatchKeyEvent(unsigned short const&, unsigned short const&, unsigned long const&) + 197 (Adobe Illustrator) [0x1003f6e85]
                                    24 CAIExoAppMacEventHandler::DispatchKeyEvent(CAIEvent&) + 223 (Adobe Illustrator) [0x1003f6f9f]
                                      24 CAIExoAppEventHandler::DispatchKeyEvent(CAIEvent&) + 1284 (Adobe Illustrator) [0x100486e34]
                                        24 CAIExoAppEventHandler::HandleAIEvent(CAIEvent&) + 42 (Adobe Illustrator) [0x1004863ba]
                                          24 CAIExoAppEventHandler::DispatchMenuEvent(CAIEvent&) + 376 (Adobe Illustrator) [0x100486598]
                                            24 CommandDoInternal(CAIEvent*, int, int) + 196 (Adobe Illustrator) [0x1001fa914]
                                              24 CommandNewCommon(bool) + 896 (Adobe Illustrator) [0x1001d93e0]
                                                24 CommandNewEx(NewDlgData&, unsigned char) + 224 (Adobe Illustrator) [0x1001d95d0]
                                                  24 ArtworkNewDialog(NewDlgData&) + 341 (Adobe Illustrator) [0x100179375]
                                                    24 ??? (IllustratorUI + 261513) [0x11cd98d89]
                                                      24 ??? (IllustratorUI + 437933) [0x11cdc3ead]
                                                        24 ??? (IllustratorUI + 439374) [0x11cdc444e]
                                                          24 ??? (IllustratorUI + 446273) [0x11cdc5f41]
                                                            24 CAIStartupProfileMgr::GetProfileData(ai::FilePath const&, NewDlgData*) + 1191 (Adobe Illustrator) [0x1001d4387]
                                                              24 CAIStartupProfileMgr::OpenArtwork(ai::FilePath const&, Artwork**, ViewDesc*) + 461 (Adobe Illustrator) [0x1001d47bd]
        24 ArtOpenGeneral(Artwork**, bool, MiFile*, bool, ViewDesc*, ActionParamValue*, ActionParamValue*, bool) + 369 (Adobe Illustrator) [0x100159a11]
        24 FileFormatOpen(ai::FilePath&, Artwork**, unsigned char, ActionParamValue*, ActionParamValue*) + 825 (Adobe Illustrator) [0x1007f3409]
        24 readFile(ai::FilePath const&, Artwork*, CAIDocumentView*, PluginFileFormat*, int, int, PlaceRequestMgr*, unsigned char, ActionParamValue*, ActionParamValue*, unsigned char) + 1492 (Adobe Illustrator) [0x1007f4b54]
        24 CAPIContext::~CAPIContext() + 14 (Adobe Illustrator) [0x1006e06ae]
        24 CAPIContext::Pop() + 73 (Adobe Illustrator) [0x1006e0489]
        24 Pillows(int) + 322 (Adobe Illustrator) [0x1006b49c2]
        24 APIArt(int) + 154 (Adobe Illustrator) [0x10077324a]
        24 ArtworkSync::Synchronize(ArtworkSyncWhy, bool) + 172 (Adobe Illustrator) [0x1001b24ac]
        24 ArtworkSync::SynchronizeMetaPatterns(int, bool) + 394 (Adobe Illustrator) [0x1001b287a]
        24 CAIArtStyle::CleanupDirtyDescendants(ArtObject* const&) + 556 (Adobe Illustrator) [0x1002825cc]
        24 CAIArtStyle::CleanupDirtyDescendants(ArtObject* const&) + 233 (Adobe Illustrator) [0x100282489]
        24 CAIArtStyle::GetStyledArt(ArtObject*, bool) + 722 (Adobe Illustrator) [0x100282972]
        24 CAIArtStyle::Execute(ArtObject*) + 1341 (Adobe Illustrator) [0x10028341d]
        24 CAIArtStyle::ExecActiveStyle(ArtObject*) + 571 (Adobe Illustrator) [0x10028487b]
        24 CAICompoundFilterExecution::Execute(ArtObject*, Ref) + 127 (Adobe Illustrator) [0x1002a8bef]
        24 CAIChainStyleFilter::Execute(Ref, ArtObject*, Ref) const + 129 (Adobe Illustrator) [0x1002a7791]
        24 CAIChainStyleFilter::Execute(Ref, ArtObject*, Ref, ArtObject*) const + 2467 (Adobe Illustrator) [0x1002a71e3]
        24 CAIFilterExecution::Execute(ArtObject*, Ref) + 484 (Adobe Illustrator) [0x1002b9ce4]
        24 _t_AILiveEffectOpaque::Execute(Ref, ArtObject*, Ref) const + 5297 (Adobe Illustrator) [0x100856261]
        24 fxCallPlugin(SPPlugin*, char const*, void*) + 1573 (Adobe Illustrator) [0x1006b6605]
        24 SPSendMessage + 646 (Adobe Illustrator) [0x100ab8066]
        24 SPCallPlugin + 99 (Adobe Illustrator) [0x100ab5423]
        24 spEdgeCallPlugin(SPAccess*, char const*, char const*, void*, int*) + 152 (Adobe Illustrator) [0x100aba158]
        24 CCachedUIElements::NewCachePluginMain(char const*, char const*, void*) + 1400 (Adobe Illustrator) [0x1006c94b8]
        24 LiveEffectProxyManager::HandleProxyMessage(void*, char const*, char const*) + 372 (Adobe Illustrator) [0x100700944]
        24 LiveEffectProxyManager::SendMessageToPlugin(SPPlugin*, char const*, char const*, void*) + 75 (Adobe Illustrator) [0x1007006cb]
        24 PluginMain + 301 (FuzzyEffect) [0x1214e547d]
        24 ??? (FuzzyEffect + 15076) [0x1214e7ae4]
        24 ??? (FuzzyEffect + 15687) [0x1214e7d47]
        24 ??? (FuzzyEffect + 17883) [0x1214e85db]
        24 ??? (FuzzyEffect + 21669) [0x1214e94a5]
        24 ??? (DiffusionRasterSuite + 26568) [0x11f4987c8]
        24 ??? (Rasterize + 28178) [0x1148b6e12]
        24 ??? (Rasterize + 43026) [0x1148ba812]
        24 unsigned char ai::proxy::Wrapper::f() + 37 (Adobe Illustrator) [0x10072df25]
        24 ai::proxy::FindAndLoadSuite(char const*, int, void const**) + 125 (Adobe Illustrator) [0x10073b74d]
        24 CAIAspectBase::Notify(void const*) + 108 (Adobe Illustrator) [0x10057cd5c]
        24 CAIAspectBase::Impl::Notify(CAIAspectBase&, void const*) + 81 (Adobe Illustrator) [0x10057d1e1]
        24 CAIAspectType::NotifyObserver(void*, CAIAspectBase::ObserverData&, void const*) + 54 (Adobe Illustrator) [0x10073e616]
        24 SuiteProxyManager::HandleProxyMessage(void*, char const*, char const*) + 199 (Adobe Illustrator) [0x10073c947]
        24 IProxyManager::StartupPlugin(SPPlugin*) + 30 (Adobe Illustrator) [0x1007108de]
        24 fxReloadCachedPlugin(SPPlugin*) + 112 (Adobe Illustrator) [0x1007ccc60]
        24 startupSweetPeaPlugin(SPPlugin*) + 94 (Adobe Illustrator) [0x100ab830e]
        24 PluginMain + 120 (BNPlugin) [0x1218e19a8]
        24 ??? (BNPlugin + 18814) [0x1218e497e]
        24 ??? (BNPlugin + 19130) [0x1218e4aba]
        24 ??? (BNPlugin + 35270) [0x1218e89c6]
        24 ??? (AdobePSL + 6011253) [0x104d2b975]
        24 ??? (AdobePSL + 6018063) [0x104d2d40f]
        24 ??? (AdobePSL + 6595618) [0x104dba422]
        24 ??? (AdobePSL + 6601033) [0x104dbb949]
        24 ??? (AdobePSL + 7758510) [0x104ed62ae]
        24 ??? (AdobePSL + 3287385) [0x104a92959]
        24 ??? (AdobePSL + 3286623) [0x104a9265f]
        24 ??? (AdobePSL + 3284853) [0x104a91f75]
        24 ??? (AdobePSL + 3263867) [0x104a8cd7b]
        24 ??? (AdobePSL + 3261904) [0x104a8c5d0]
        24 ??? (AdobePSL + 3291660) [0x104a93a0c]
        24 ??? (AdobePSL + 5377930) [0x104c90f8a]
        24 ??? (AdobePSL + 5366093) [0x104c8e14d]
        24 ??? (AdobePSL + 5367901) [0x104c8e85d]
        24 ??? (AdobePSL + 5367368) [0x104c8e648]
        24 ??? (AdobePSL + 5543570) [0x104cb9692]
        24 ??? (AdobePSL + 5536409) [0x104cb7a99]
        24 ??? (AdobePSL + 5525057) [0x104cb4e41]
        24 ??? (AdobePSL + 5527807) [0x104cb58ff]
        24 ??? (AdobePSL + 5525993) [0x104cb51e9]
        24 ??? (AdobePSL + 465240) [0x1047e1958]
        24 ??? (AdobePSL + 466627) [0x1047e1ec3]
        24 ??? (AdobePSL + 5537874) [0x104cb8052]
        24 ??? (AdobePSL + 468936) [0x1047e27c8]
        24 __psynch_mutexwait + 10 (libsystem_kernel.dylib) [0x7fff98c15122]
        *24 psynch_mtxcontinue + 0 (mach_kernel) [0xffffff80005b4550]
  Thread 0x5c15e    DispatchQueue 2          priority 49
  24 _dispatch_mgr_thread + 54 (libdispatch.dylib) [0x7fff9089b9ee]
    24 kevent + 10 (libsystem_kernel.dylib) [0x7fff98c15d16]
     *24 ??? (mach_kernel + 3471808) [0xffffff800054f9c0]
  Thread 0x5c16c    priority 47
  24 thread_start + 13 (libsystem_c.dylib) [0x7fff8fb691e1]
    24 _pthread_start + 327 (libsystem_c.dylib) [0x7fff8fb7c7a2]
      24 ??? (AdobeAGM + 3512488) [0x1038ab8a8]
        24 ??? (AdobeAGM + 3422333) [0x10389587d]
          24 ??? (AdobeAGM + 3419595) [0x103894dcb]
            24 __psynch_cvwait + 10 (libsystem_kernel.dylib) [0x7fff98c150fa]
             *24 psynch_cvcontinue + 0 (mach_kernel) [0xffffff80005b5bb0]
  Thread 0x5c171    priority 63
      24 __NSThread__main__ + 1345 (Foundation) [0x7fff9619f562]
        24 +[NSURLConnection(Loader) _resourceLoadLoop:] + 356 (Foundation) [0x7fff96141546]
          24 CFRunLoopRunSpecific + 290 (CoreFoundation) [0x7fff922c30e2]
            24 __CFRunLoopRun + 1078 (CoreFoundation) [0x7fff922c3916]
              24 __CFRunLoopServiceMachPort + 195 (CoreFoundation) [0x7fff922be233]
                24 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff98c13686]
                 *24 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
  Thread 0x5c175    priority 47
      24 __select + 10 (libsystem_kernel.dylib) [0x7fff98c15322]
       *24 ??? (mach_kernel + 3580832) [0xffffff800056a3a0]
  Thread 0x5c191    priority 48
      24 ??? (dBrushTool + 362275) [0x115d9e723]
        24 usleep + 54 (libsystem_c.dylib) [0x7fff8fc06717]
          24 __semwait_signal + 10 (libsystem_kernel.dylib) [0x7fff98c15386]
           *22 semaphore_wait_continue + 0 (mach_kernel) [0xffffff8000234040]
           *2  hndl_unix_scall64 + 19 (mach_kernel) [0xffffff80002ce9c3]
             *2  unix_syscall64 + 522 (mach_kernel) [0xffffff80005e16aa]
               *2  __semwait_signal_nocancel + 170 (mach_kernel) [0xffffff800056675a]
                 *2  semaphore_timedwait_trap_internal + 130 (mach_kernel) [0xffffff8000234582]
                   *2  ??? (mach_kernel + 213735) [0xffffff80002342e7]
                     *2  thread_block_reason + 275 (mach_kernel) [0xffffff800022db73]
                       *2  ??? (mach_kernel + 187905) [0xffffff800022de01]
                         *2  processor_idle + 237 (mach_kernel) [0xffffff800022f34d]
                           *2  machine_idle + 443 (mach_kernel) [0xffffff80002b9c9b]
  Thread 0x5c192    priority 47
  24 semaphore_wait_trap + 10 (libsystem_kernel.dylib) [0x7fff98c136c2]
   *24 semaphore_wait_continue + 0 (mach_kernel) [0xffffff8000234040]
  Thread 0x5c193    priority 47
  Thread 0x5c194    priority 47
  Thread 0x5c195    priority 47
  Thread 0x5c196    priority 47
  Thread 0x5c197    priority 47
  Thread 0x5c198    priority 47
  Thread 0x5c199    priority 47
  Thread 0x5c1aa    priority 47         cpu time   0.001s
      24 ScObjects::Thread::go(void*) + 165 (ScriptingSupport) [0x114e758f5]
        24 ScObjects::BridgeTalkThread::run() + 174 (ScriptingSupport) [0x114e5e10e]
          24 ScObjects::Thread::wait(unsigned int) + 56 (ScriptingSupport) [0x114e75d38]
             *18 semaphore_wait_continue + 0 (mach_kernel) [0xffffff8000234040]
             *6  hndl_unix_scall64 + 19 (mach_kernel) [0xffffff80002ce9c3]
               *6  unix_syscall64 + 522 (mach_kernel) [0xffffff80005e16aa]
                 *6  __semwait_signal_nocancel + 170 (mach_kernel) [0xffffff800056675a]
                   *6  semaphore_timedwait_trap_internal + 130 (mach_kernel) [0xffffff8000234582]
                     *6  ??? (mach_kernel + 213735) [0xffffff80002342e7]
                       *6  thread_block_reason + 275 (mach_kernel) [0xffffff800022db73]
                         *6  ??? (mach_kernel + 187905) [0xffffff800022de01]
                           *6  processor_idle + 237 (mach_kernel) [0xffffff800022f34d]
                             *6  machine_idle + 443 (mach_kernel) [0xffffff80002b9c9b]
  Thread 0x5c1b0    priority 47
      24 thread_proxy + 164 (boost_threads) [0x107a9a6d4]
        24 (anonymous namespace)::ThreadController::operator()() + 266 (Adobe Illustrator) [0x100a6ecda]
          24 (anonymous namespace)::ThreadControllerContinous::Run() + 1267 (Adobe Illustrator) [0x100a70bc3]
            24 boost::condition_variable::wait(boost::unique_lock&) + 155 (Adobe Illustrator) [0x100a71edb]
  Thread 0x5c1b1    priority 47
  Thread 0x5c1b2    priority 47
  Thread 0x5c1b3    priority 47
  Thread 0x5c1b4    priority 47
  Thread 0x5c1b5    priority 47
  Thread 0x5c1b6    priority 47
  Thread 0x5c1b7    priority 47
  Thread 0x5c1ba    priority 47
      24 ??? (ServiceManager-Launcher.dylib + 98035) [0x12229aef3]
        24 ??? (ServiceManager-Launcher.dylib + 89670) [0x122298e46]
          24 ??? (ServiceManager-Launcher.dylib + 31493) [0x12228ab05]
            24 ??? (ServiceManager-Launcher.dylib + 14614) [0x122286916]
              24 ??? (ServiceManager-Launcher.dylib + 86502) [0x1222981e6]
                24 ??? (ServiceManager-Launcher.dylib + 86637) [0x12229826d]
                  24 ??? (ServiceManager-Launcher.dylib + 87218) [0x1222984b2]
                    24 ??? (ServiceManager-Launcher.dylib + 86894) [0x12229836e]
                      24 ??? (ServiceManager-Launcher.dylib + 72715) [0x122294c0b]
                        24 ??? (ServiceManager-Launcher.dylib + 72958) [0x122294cfe]
                          24 ??? (ServiceManager-Launcher.dylib + 70372) [0x1222942e4]
                            24 ??? (ServiceManager-Launcher.dylib + 91878) [0x1222996e6]
                              24 ??? (ServiceManager-Launcher.dylib + 91768) [0x122299678]
                                24 ??? (ServiceManager-Launcher.dylib + 95702) [0x12229a5d6]
                                  24 __recvfrom + 10 (libsystem_kernel.dylib) [0x7fff98c152aa]
                                   *24 hndl_unix_scall64 + 19 (mach_kernel) [0xffffff80002ce9c3]
                                     *24 unix_syscall64 + 522 (mach_kernel) [0xffffff80005e16aa]
                                       *24 recvfrom_nocancel + 255 (mach_kernel) [0xffffff80005a0b8f]
                                         *24 ??? (mach_kernel + 3804654) [0xffffff80005a0dee]
                                           *24 soreceive + 5579 (mach_kernel) [0xffffff80005999cb]
                                             *24 sbwait + 175 (mach_kernel) [0xffffff800059cbdf]
                                               *24 msleep + 116 (mach_kernel) [0xffffff800056a1c4]
                                                 *24 ??? (mach_kernel + 3579350) [0xffffff8000569dd6]
                                                   *24 lck_mtx_sleep + 78 (mach_kernel) [0xffffff800022664e]
                                                     *24 thread_block_reason + 300 (mach_kernel) [0xffffff800022db8c]
                                                       *24 ??? (mach_kernel + 190657) [0xffffff800022e8c1]
                                                         *24 machine_switch_context + 366 (mach_kernel) [0xffffff80002b47fe]
  Thread 0x5c1ce    priority 47
  Thread 0x5c1cf    priority 47
  Thread 0x5c1d0    priority 47
  Thread 0x5c1d1    priority 47
  Thread 0x5c1d2    priority 47
  Thread 0x5c1d3    priority 47
  Thread 0x5c1d4    priority 47
  Thread 0x5c1d5    priority 47
  Thread 0x5c23e    priority 54
      24 AsyncFileThread(void*) + 180 (CarbonCore) [0x7fff8f348b46]
        24 ??? (AdobePSL + 475052) [0x1047e3fac]
          24 ??? (AdobePSL + 5528236) [0x104cb5aac]
            24 __cxa_guard_acquire + 33 (libc++abi.dylib) [0x7fff8d93f261]
  Binary Images:
         0x100000000 -        0x101430fff  com.adobe.illustrator 256 (17.0.0)  /Applications/Adobe Illustrator CC/Adobe Illustrator.app/Contents/MacOS/Adobe Illustrator
         0x103552000 -        0x103b23fff  com.adobe.AGM AdobeAGM 4.30.20.30929 (4.30.20.30929) <7D9DF39D-A7FA-3284-84B2-5BA83794981A> /Applications/Adobe Illustrator CC/Adobe Illustrator.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
         0x104770000 -        0x1056f3fef  com.adobe.psl AdobePSL 14.0.0.30830 (14.0.0.30830) <7BDC4AF7-B14F-3DE0-B47A-E69B37529A6B> /Applications/Adobe Illustrator CC/Adobe Illustrator.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
         0x107a99000 -        0x107aa7fff  com.adobe.boost_threads.framework 7.0.0 (7.0.0.0)  /Applications/Adobe Illustrator CC/Adobe Illustrator.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
         0x1097e8000 -        0x1098aaff7  com.adobe.exo.framework 7.0.0 (7.0.0.0)  /Applications/Adobe Illustrator CC/Adobe Illustrator.app/Contents/Frameworks/exo.framework/Versions/A/exo
         0x1148b0000 -        0x1148d1fff  com.adobe.illustrator.plugins.Rasterize Rasterize version 17.0.0 (17.0.0)  /Applications/Adobe Illustrator CC/Adobe Illustrator.app/Required/Plug-ins/Rasterize.aip/Contents/MacOS/Rasterize
         0x114d02000 -        0x114f96fff  com.adobe.illustrator.plugins.ScriptingSupport Scripting Support version 17.0.0 (17.0.0) <4BC4ED1F-E783-3054-88E2-ACA13096C2AC> /Applications/Adobe Illustrator CC/*/ScriptingSupport
         0x115d46000 -        0x115dcbfef  com.adobe.illustrator.plugins.dBrushTool Bristle Brush Tool version 17.0.0 (17.0.0)  /Applications/Adobe Illustrator CC/*/dBrushTool
         0x11cd59000 -        0x11cee8fff  com.adobe.illustrator.plugins.IllustratorUI IllustratorUI version 17.0.0 (17.0.0) <97E9FC4A-A729-3B79-B654-319AB41B6D09> /Applications/Adobe Illustrator CC/*/IllustratorUI
         0x11f492000 -        0x11f49dfff  com.adobe.illustrator.plugins.DiffusionRasterSuite DiffusionRaster version 17.0.0 (17.0.0) <06E833AE-5B32-3582-A4FE-C9FCBC61AAD6> /Applications/Adobe Illustrator CC/*/DiffusionRasterSuite
         0x1214e4000 -        0x1214f8fff  com.adobe.illustrator.plugins.FuzzyEffect FuzzyEffect version 17.0.0 (17.0.0) <6A4B35A2-C221-328C-AA02-43A98F269DBC> /Applications/Adobe Illustrator CC/*/FuzzyEffect
         0x1218e0000 -        0x1218eeff7  com.adobe.illustrator.plugins.BNPlugin BNPlugin version 17.0.0 (17.0.0) <30811E3C-EE38-31E6-9BE4-46A945946F90> /Applications/Adobe Illustrator CC/*/BNPlugin
         0x122283000 -        0x1222affff  ServiceManager-Launcher.dylib  /Library/Application Support/Adobe/*/ServiceManager-Launcher.dylib
      0x7fff8d93e000 -     0x7fff8d963ff7  libc++abi.dylib  /usr/lib/libc++abi.dylib
      0x7fff8dcea000 -     0x7fff8e917fff  com.apple.AppKit 6.8 (1187.39) <199962F0-B06B-3666-8FD5-5C90374BA16A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
      0x7fff8f2d8000 -     0x7fff8f5efff7  com.apple.CoreServices.CarbonCore 1037.6 (1037.6) <1E567A52-677F-3168-979F-5FBB0818D52B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
      0x7fff8fb68000 -     0x7fff8fc34ff7  libsystem_c.dylib <4C9EB006-FE1F-3F8F-8074-DFD94CF2CE7B> /usr/lib/system/libsystem_c.dylib
      0x7fff90897000 -     0x7fff908acff7  libdispatch.dylib  /usr/lib/system/libdispatch.dylib
      0x7fff9228e000 -     0x7fff92478ff7  com.apple.CoreFoundation 6.8 (744.19) <0F7403CA-2CB8-3D0A-992B-679701DF27CA> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
      0x7fff96109000 -     0x7fff96468fff  com.apple.Foundation 6.8 (945.18) <1D7E58E6-FA3A-3CE8-AC85-B9D06B8C0AA0> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
      0x7fff98c03000 -     0x7fff98c1eff7  libsystem_kernel.dylib  /usr/lib/system/libsystem_kernel.dylib
 *0xffffff8000200000 - 0xffffff8000736dbc  mach_kernel <896CB1E3-AB79-3DF1-B595-549DFFDF3D36> /mach_kernel
Process:         accountsd [9346]
Path:            /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
UID:             501
Sudden Term:     Clean (allows idle exit)
Task size:       1440 pages
  Thread 0x5b58c    DispatchQueue 1          priority 24
  24 start + 1 (libdyld.dylib) [0x7fff975d97e1]
    24 ??? (accountsd + 3048) [0x106d3cbe8]
  Thread 0x5b5bb    DispatchQueue 2          priority 33
  Binary Images:
         0x106d3c000 -        0x106d3cfff  accountsd <0982A50A-159D-3E63-A2EC-6447F3706436> /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
      0x7fff975d7000 -     0x7fff975daff7  libdyld.dylib  /usr/lib/system/libdyld.dylib
Process:         AdobeCrashDaemon [9461]
Path:            /Applications/Adobe Illustrator CC/Adobe Illustrator.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.app/Contents/MacOS/AdobeCrashDaemon
Parent:          Adobe Illustrator [9459]
UID:             501
Task size:       1054 pages
CPU Time:        0.004s
Process:         AirPort Base Station Agent [9357]
Path:            /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
UID:             501
Sudden Term:     Clean
Task size:       571 pages
  Thread 0x5b65a    DispatchQueue 1          priority 29
  24 ??? (AirPort Base Station Agent + 3064) [0x101213bf8]
    24 ??? (AirPort Base Station Agent + 70465) [0x101224341]
      24 CFRunLoopRun + 97 (CoreFoundation) [0x7fff922d1dd1]
  Thread 0x5b65d    DispatchQueue 2          priority 33
  Thread 0x5b668    priority 31
  Thread 0x5b669    priority 31
      24 ??? (AirPort Base Station Agent + 71512) [0x101224758]
        24 ??? (AirPort Base Station Agent + 10842) [0x101215a5a]
          24 ??? (AirPort Base Station Agent + 72265) [0x101224a49]
  Binary Images:
         0x101213000 -        0x101229ff7  com.apple.AirPortBaseStationAgent 2.2 (220.2) <2CA1AE53-7CA0-30CF-99A9-5D2585BDFEF7> /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
Process:         Alfred 2 [9344]
Path:            /Applications/Alfred 2.app/Contents/MacOS/Alfred 2
UID:             501
Task size:       3358 pages
Process:         appleeventsd [93]
Path:            /System/Library/CoreServices/appleeventsd
Parent:          launchd [1]
UID:             71
Sudden Term:     Dirty (allows idle exit)
Task size:       897 pages
  Thread 0x2cf      DispatchQueue 2          priority 33
  Thread 0x2d0      DispatchQueue 7          priority 31
  24 _dispatch_sig_thread + 45 (libdispatch.dylib) [0x7fff90898d85]
    24 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib) [0x7fff98c15566]
  Binary Images:
         0x10625b000 -        0x10625bfff  appleeventsd <33899092-67A8-3A39-A63C-27BAC6C22174> /System/Library/CoreServices/appleeventsd
Process:         AppleIDAuthAgent [9310]
Path:            /System/Library/CoreServices/AppleIDAuthAgent
UID:             501
Task size:       540 pages
  Thread 0x5b507    DispatchQueue 2          priority 33
  Thread 0x5b509    DispatchQueue 7          priority 31
  Thread 0x5b88f    DispatchQueue 16         priority 31
  24 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8fb691d1]
    24 _pthread_wqthread + 404 (libsystem_c.dylib) [0x7fff8fb7ed0b]
      24 _dispatch_worker_thread2 + 249 (libdispatch.dylib) [0x7fff9089a1c3]
        24 _dispatch_queue_invoke + 52 (libdispatch.dylib) [0x7fff9089a2f1]
          24 _dispatch_queue_drain + 180 (libdispatch.dylib) [0x7fff9089a448]
            24 _dispatch_queue_invoke + 72 (libdispatch.dylib) [0x7fff9089a305]
              24 _dispatch_source_invoke + 691 (libdispatch.dylib) [0x7fff9089b29b]
                24 _dispatch_client_callout + 8 (libdispatch.dylib) [0x7fff908990b6]
                  24 _dispatch_after_timer_callback + 22 (libdispatch.dylib) [0x7fff9089d96f]
                      24 _dispatch_call_block_and_release + 15 (libdispatch.dylib) [0x7fff9089cf01]
                        24 ??? (AppleIDAuthAgent + 9227) [0x10376b40b]
                          24 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib) [0x7fff98c136da]
  Binary Images:
         0x103769000 -        0x103799fff  AppleIDAuthAgent <91A3B8DC-AD42-399C-9A44-413CF8DF2CA4> /System/Library/CoreServices/AppleIDAuthAgent
Process:         AppleSpell [9471]
Path:            /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
UID:             501
Sudden Term:     Clean
Task size:       650 pages
  Thread 0x5c26d    DispatchQueue 1          priority 46
    24 ??? (AppleSpell + 7271) [0x10237ec67]
      24 -[NSSpellServer run] + 73 (Foundation) [0x7fff9628bee6]
  Thread 0x5c276    DispatchQueue 2          priority 48
  Binary Images:
         0x10237d000 -        0x102432ff7  com.apple.AppleSpell 1.9 (173.1) <6ED0981A-B081-3345-8EBB-E4AB821B077A> /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
Process:         apsd [99]
Path:            /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
Parent:          launchd [1]
UID:             0
Task size:       2545 pages
  Thread 0x266      DispatchQueue 1          priority 31
    24 ??? (apsd + 21686) [0x101ad94b6]
      24 -[NSRunLoop(NSRunLoop) run] + 74 (Foundation) [0x7fff9613d1aa]
        24 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 268 (Foundation) [0x7fff961a47ee]
  Thread 0x2bf      DispatchQueue 2          priority 33
  Thread 0x707      priority 63
  Thread 0x70b      priority 31
  Binary Images:
         0x101ad4000 -        0x101b52ff7  apsd <79FEFFFF-D855-3F06-BF98-C24F741AB4E7> /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
Process:         autofsd [98]
Path:            /usr/libexec/autofsd
Parent:          launchd [1]
UID:             0
Sudden Term:     Clean
Task size:       538 pages
  Thread 0x29e      DispatchQueue 2          priority 33
  Thread 0x2a1      DispatchQueue 7          priority 31
  Binary Images:
         0x10c9cb000 -        0x10c9ccfff  autofsd  /usr/libexec/autofsd
Process:         CalendarAgent [9311]
Path:            /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
UID:             501
Task size:       5501 pages (+3)
  Thread 0x5b4d3    DispatchQueue 1          priority 31
    24 ??? (CalendarAgent + 2739) [0x100723ab3]
  Thread 0x5b592    DispatchQueue 2          priority 33
  Thread 0x5b6ae    priority 63
  Thread 0x5b6b7    priority 31
        24 -[CalAgentAPSConnectionManager _calAPSMain] + 731 (CalendarAgent) [0x1007340fc]
  Thread 0x5b6e1    priority 31
  Thread 0x5c9cb    priority 33
  19 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8fb691d1]
    19 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8fb7ed13]
      19 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff98c156d6]
       *19 ??? (mach_kernel + 3910896) [0xffffff80005bacf0]
  Binary Images:
         0x100723000 -        0x100723fff  CalendarAgent  /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
         0x10072f000 -        0x100745ff7  com.apple.CalendarAgent 1.0 (57) <762A246C-65FC-339D-A0F2-8ED9C907A9C2> /System/Library/PrivateFrameworks/CalendarAgent.framework/Versions/A/CalendarAgent
Process:         CEPServiceManager [9338]
Path:            /Library/Application Support/Adobe/*/CEPServiceManager.app/Contents/MacOS/CEPServiceManager
Architecture:    i386
Parent:          launchd [1]
UID:             501
Task size:       2103 pages
Process:         cfprefsd [23]
Path:            /usr/sbin/cfprefsd
Parent:          launchd [1]
UID:             0
Task size:       652 pages (+6)
  Thread 0x134      DispatchQueue 2          priority 33
  Thread 0x136      DispatchQueue 7          priority 31
  Thread 0x5c994    priority 31
    24 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8fb7ed13]
      24 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff98c156d6]
       *24 ??? (mach_kernel + 3910896) [0xffffff80005bacf0]
  Thread 0x5c998    priority 31
  Binary Images:
         0x10ac17000 -        0x10ac17ff7  cfprefsd  /usr/sbin/cfprefsd
Process:         cfprefsd [120]
Parent:          launchd [116]
UID:             88
Task size:       319 pages
  Thread 0x33b      DispatchQueue 2          priority 33
  Thread 0x33d      DispatchQueue 7          priority 31
  Binary Images:
         0x10a724000 -        0x10a724ff7  cfprefsd  /usr/sbin/cfprefsd
Process:         cfprefsd [195]
UID:             501
Task size:       3476 pages (+5)
  Thread 0x47e      DispatchQueue 2          priority 33
  Thread 0x480      DispatchQueue 7          priority 31
  Thread 0x5c993    priority 31
  Thread 0x5c996    priority 31
  Binary Images:
         0x102667000 -        0x102667ff7  cfprefsd  /usr/sbin/cfprefsd
Process:         cfprefsd [307]
Parent:          launchd [305]
UID:             -2
Task size:       318 pages
  Thread 0x832      DispatchQueue 2          priority 33
  Thread 0x834      DispatchQueue 7          priority 31
  Binary Images:
         0x10d388000 -        0x10d388ff7  cfprefsd  /usr/sbin/cfprefsd
Process:         cfprefsd [321]
Parent:          launchd [317]
UID:             89
Task size:       353 pages
  Thread 0x91e      DispatchQueue 2          priority 33
  Thread 0x920      DispatchQueue 7          priority 31
  Binary Images:
         0x1091ba000 -        0x1091baff7  cfprefsd  /usr/sbin/cfprefsd
Process:         cfprefsd [7400]
Parent:          launchd [7395]
UID:             502
Task size:       335 pages
  Thread 0x4b603    DispatchQueue 2          priority 33
  Thread 0x4b605    DispatchQueue 7          priority 31
  Binary Images:
         0x10d415000 -        0x10d415ff7  cfprefsd  /usr/sbin/cfprefsd
Process:         cfprefsd [8674]
Parent:          launchd [8671]
UID:             504
Task size:       617 pages
  Thread 0x5818b    DispatchQueue 2          priority 33
  Thread 0x5818d    DispatchQueue 7          priority 31
  Binary Images:
         0x10d449000 -        0x10d449ff7  cfprefsd  /usr/sbin/cfprefsd
Process:         CIJScannerRegister [9389]
Path:            /Library/Image Capture/Support/*/CIJScannerRegister.app/Contents/MacOS/CIJScannerRegister
UID:             501
Task size:       1884 pages (+3)
Process:         Cloud [9340]
Path:            /Applications/Cloud.app/Contents/MacOS/Cloud
UID:             501
Task size:       4443 pages
Note:            Throttled by external source
Process:         CloudRaindropHelper [9364]
Path:            /Applications/Cloud.app/Contents/Resources/CloudRaindropHelper
Parent:          Cloud [9340]
UID:             501
Task size:       1260 pages
Process:         CloudRaindropHelper [9365]
UID:             501
Task size:       1286 pages
Process:         CloudRaindropHelper [9399]
UID:             501
Task size:       1250 pages
Process:         com.apple.audio.SandboxHelper [312]
Path:            /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Parent:          launchd [1]
UID:             202
Task size:       1148 pages
  Thread 0x8ba      DispatchQueue 7          priority 31
  Thread 0x8bc      DispatchQueue 2          priority 33
  Binary Images:
         0x106905000 -        0x10690dfff  com.apple.audio.SandboxHelper 1.0 (1) <07B534A6-6AD1-37B6-93DF-C7E6088C10C7> /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
Process:         com.apple.dock.extra [9353]
Path:            /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
Parent:          launchd [1]
UID:             501
Task size:       4381 pages
  Thread 0x5b607    DispatchQueue 1          priority 47
  24 ??? (com.apple.dock.extra + 5956) [0x101717744]
    24 xpc_service_main + 433 (XPCService) [0x7fff8fdbdd15]
      24 NSApplicationMain + 869 (AppKit) [0x7fff8dddabd6]
        24 -[NSApplication run] + 517 (AppKit) [0x7fff8de361a3]
          24 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128 (AppKit) [0x7fff8de3edf2]
            24 _DPSNextEvent + 685 (AppKit) [0x7fff8de3f533]
              24 BlockUntilNextEventMatchingListInMode + 62 (HIToolbox) [0x7fff95cd4ae3]
                24 ReceiveNextEventCommon + 356 (HIToolbox) [0x7fff95cd4c52]
                  24 RunCurrentEventLoopInMode + 209 (HIToolbox) [0x7fff95cd4eb4]
  Thread 0x5b612    DispatchQueue 2          priority 49
  Binary Images:
         0x101716000 -        0x10171afff  com.apple.dock.extra 1.0 (1)  /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
      0x7fff8fdbc000 -     0x7fff8fdc3fff  com.apple.XPCService 2.0 (1) <4B83D804-9CE3-359D-A5FA-C81CB5B09544> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
      0x7fff95c75000 -     0x7fff95fa5fff  com.apple.HIToolbox 2.0 <656D08C2-9068-3532-ABDD-32EC5057CCB2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
Process:         com.apple.iCloudHelper [8652]
Path:            /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iCloudHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
Parent:          launchd [1]
UID:             501
Task size:       1582 pages (+3)
  Thread 0x57fca    DispatchQueue 1          priority 31
    24 main + 176 (com.apple.iCloudHelper) [0x10bcea900]
      24 xpc_main + 260 (libxpc.dylib) [0x7fff93c8f950]
        24 _xpc_main + 452 (XPCService) [0x7fff8fdbe23b]
  Thread 0x57fcc    DispatchQueue 2          priority 33
     *23 ??? (mach_kernel + 3471808) [0xffffff800054f9c0]
     *1  hndl_unix_scall64 + 19 (mach_kernel) [0xffffff80002ce9c3]
       *1  unix_syscall64 + 522 (mach_kernel) [0xffffff80005e16aa]
         *1  kevent + 52 (mach_kernel) [0xffffff800054e414]
           *1  ??? (mach_kernel + 3467355) [0xffffff800054e85b]
             *1  kqueue_scan + 187 (mach_kernel) [0xffffff800054f22b]
               *1  thread_block_reason + 275 (mach_kernel) [0xffffff800022db73]
                 *1  ??? (mach_kernel + 187905) [0xffffff800022de01]
                   *1  processor_idle + 237 (mach_kernel) [0xffffff800022f34d]
                     *1  machine_idle + 443 (mach_kernel) [0xffffff80002b9c9b]
  Thread 0x57fd4    priority 31
        24 -[AOSPushManager _AOSPushListener] + 317 (AOSKit) [0x7fff91fb4b88]
  Thread 0x5c9c8    priority   21 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8fb691d1]
    21 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8fb7ed13]
      21 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff98c156d6]
       *20 ??? (mach_kernel + 3910896) [0xffffff80005bacf0]
           *1  workq_kernreturn + 478 (mach_kernel) [0xffffff80005ba62e]
             *1  ??? (mach_kernel + 3907044) [0xffffff80005b9de4]
  Binary Images:
         0x10bce9000 -        0x10bceeff7  com.apple.iCloudHelper 1.051 (152.4) <5443C071-0EA5-33F2-99C0-35ADE733CAA1> /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iCloudHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
      0x7fff91f97000 -     0x7fff92218fff  com.apple.AOSKit 1.051 (152.4) <01C09924-2603-3C1E-97F7-9484CBA35BC9> /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/AOSKit
      0x7fff93c7d000 -     0x7fff93c9fff7  libxpc.dylib <70BC645B-6952-3264-930C-C835010CCEF9> /usr/lib/system/libxpc.dylib
Process:         configd [20]
Path:            /usr/libexec/configd
Parent:          launchd [1]
UID:             0
Sudden Term:     Clean
Task size:       1238 pages
CPU Time:        0.001s
  Thread 0x11f      DispatchQueue 1          priority 31         cpu time   0.001s
    24 ??? (configd + 7263) [0x10d41fc5f]
      24 ??? (configd + 10127) [0x10d42078f]
               *22 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
               *2  hndl_mach_scall64 + 19 (mach_kernel) [0xffffff80002ce9e3]
                 *2  ??? (mach_kernel + 681270) [0xffffff80002a6536]
                   *2  mach_msg_overwrite_trap + 427 (mach_kernel) [0xffffff800021970b]
                     *2  ipc_mqueue_receive + 59 (mach_kernel) [0xffffff800021310b]
  Thread 0x123      DispatchQueue 2          priority 33
  Thread 0x125      priority 31
      24 ??? (configd + 12444) [0x10d42109c]
  Thread 0x14f      priority 31
      24 ??? (configd + 54376) [0x10d42b468]
  Thread 0x151      priority 31
  Thread 0x16b      priority 31
      24 pppcntl_run_thread + 2390 (PPPController) [0x10d855982]
  Thread 0x5c99d    priority 31
  Binary Images:
         0x10d41e000 -        0x10d44cff7  configd <66DE8AD9-5CCC-395C-91DB-465897FADFF9> /usr/libexec/configd
         0x10d84a000 -        0x10d88bff7  com.apple.SystemConfiguration.PPPController 1.8 (1.8)  /System/Library/SystemConfiguration/PPPController.bundle/Contents/MacOS/PPPController
Process:         cookied [9360]
Path:            /System/Library/Frameworks/CFNetwork.framework/Versions/A/Support/cookied
UID:             501
Sudden Term:     Clean
Task size:       978 pages
  Thread 0x5b674    DispatchQueue 1          priority 31
    24 _cookied_main + 1190 (CFNetwork) [0x7fff99d9deb6]
  Thread 0x5b675    DispatchQueue 2          priority 33
  Binary Images:
         0x10a713000 -        0x10a713fff  cookied <69D61D52-AF42-381A-8B59-804F0F22250A> /System/Library/Frameworks/CFNetwork.framework/Versions/A/Support/cookied
      0x7fff99ca2000 -     0x7fff99e17ff7  com.apple.CFNetwork 596.4.3 (596.4.3)  /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
Process:         coreaudiod [142]
Path:            /usr/sbin/coreaudiod
Parent:          launchd [1]
UID:             202
Sudden Term:     Clean
Task size:       2927 pages
  Thread 0x3be      DispatchQueue 1          priority 63
    24 ??? (coreaudiod + 422293) [0x108ba4195]
  Thread 0x3c1      DispatchQueue 2          priority 33
  Thread 0x3c9      priority 61
      24 ??? (coreaudiod + 468639) [0x108baf69f]
        24 ??? (coreaudiod + 435005) [0x108ba733d]
  Binary Images:
         0x108b3d000 -        0x108c16fff  coreaudiod <63E9E901-5880-3D0A-B04A-9AB867DF242A> /usr/sbin/coreaudiod
Process:         coreservicesd [42]
Path:            /System/Library/CoreServices/coreservicesd
Parent:          launchd [1]
UID:             0
Sudden Term:     Clean
Task size:       69282 pages (+3)
  Thread 0x1c7      DispatchQueue 1          priority 31
    24 _CoreServicesServerMain + 691 (CarbonCore) [0x7fff8f2d8ff5]
  Thread 0x1c9      DispatchQueue 2          priority 33
  Thread 0x1cd      priority 31
      24 fmodWatchConsumer + 581 (CarbonCore) [0x7fff8f2debf7]
  Thread 0x1ce      priority 31
      24 read + 10 (libsystem_kernel.dylib) [0x7fff98c15ffa]
           *24 read_nocancel + 130 (mach_kernel) [0xffffff8000576762]
             *24 ??? (mach_kernel + 3631422) [0xffffff800057693e]
               *24 ??? (mach_kernel + 1168567) [0xffffff800031d4b7]
                 *24 tsleep + 88 (mach_kernel) [0xffffff800056a258]
                   *24 ??? (mach_kernel + 3579744) [0xffffff8000569f60]
  Thread 0x5c9cd    priority 31
  14 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8fb691d1]
    14 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8fb7ed13]
      14 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff98c156d6]
       *14 ??? (mach_kernel + 3910896) [0xffffff80005bacf0]
  Binary Images:
         0x1096b5000 -        0x1096b5fff  coreservicesd <46E63883-6EEA-31B9-8D9F-D8B607D36974> /System/Library/CoreServices/coreservicesd
Process:         coresymbolicationd [186]
Path:            /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
Parent:          launchd [1]
UID:             0
Task size:       4117 pages
  Thread 0x440      DispatchQueue 7          priority 31
  Thread 0x441      DispatchQueue 2          priority 33
  Binary Images:
         0x1011e9000 -        0x1011f4fff  coresymbolicationd  /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
Process:         cupsd [9470]
Path:            /usr/sbin/cupsd
Parent:          launchd [1]
UID:             0
Sudden Term:     Clean
Task size:       800 pages
  Thread 0x5c234    DispatchQueue 1          priority 31
    24 ??? (cupsd + 88877) [0x10c6ceb2d]
  Thread 0x5c236    DispatchQueue 2          priority 33
  Thread 0x5c238    priority 31
      24 ??? (cupsd + 248179) [0x10c6f5973]
  Binary Images:
         0x10c6b9000 -        0x10c70bfff  cupsd <0C9A2A58-CFD4-3582-8E83-3AC290F10464> /usr/sbin/cupsd
Process:         CVMServer [115]
Path:            /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
Parent:          launchd [1]
UID:             0
Sudden Term:     Dirty
Task size:       535 pages
  Thread 0x32e      DispatchQueue 7          priority 31
  Thread 0x330      DispatchQueue 2          priority 33
  Binary Images:
         0x103ea3000 -        0x103eacfff  CVMServer <249C0BD0-4057-31B3-87B8-3A85F5F7AD41> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
Process:         dbfseventsd [9380]
Path:            /Library/DropboxHelperTools/*/dbfseventsd
Architecture:    i386
Parent:          Dropbox [9343]
UID:             0
Task size:       94 pages
Process:         dbfseventsd [9381]
Architecture:    i386
Parent:          dbfseventsd [9380]
UID:             0
Task size:       346 pages (+1)
Process:         dbfseventsd [9382]
Architecture:    i386
Parent:          dbfseventsd [9381]
UID:             501
Task size:       42 pages
Process:         diskarbitrationd [19]
Path:            /usr/sbin/diskarbitrationd
Parent:          launchd [1]
UID:             0
Sudden Term:     Dirty
Task size:       638 pages
  Thread 0x11e      DispatchQueue 1          priority 31
    24 ??? (diskarbitrationd + 33766) [0x105d103e6]
  Thread 0x126      DispatchQueue 2          priority 33
  Thread 0x5c99e    priority   24 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8fb691d1]
  Binary Images:
         0x105d08000 -        0x105d22fff  diskarbitrationd <173CBBB5-300F-33F6-A669-2ADBE1EB95B0> /usr/sbin/diskarbitrationd
Process:         diskmanagementd [9514]
Path:            /usr/sbin/diskmanagementd
Architecture:    unknown
Parent:          launchd [1]
UID:             0
Task size:       595 pages
Note:            Exited before symbolication
  Thread 0x5c945    DispatchQueue 1          priority 31
  20 ??? [0x7fff975d97e1]
    20 ??? [0x1036d36e2]
      20 ??? [0x7fff922c30e2]
        20 ??? [0x7fff922c3916]
          20 ??? [0x7fff922be233]
            20 ??? [0x7fff98c13686]
             *20 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
  Thread 0x5c949    DispatchQueue 2          priority 33
  20 ??? [0x7fff9089b9ee]
    20 ??? [0x7fff98c15d16]
     *20 ??? (mach_kernel + 3471808) [0xffffff800054f9c0]
  Thread 0x5c94b    priority 33
  20 ??? [0x7fff8fb691d1]
    20 ??? [0x7fff8fb7ed13]
      20 ??? [0x7fff98c156d6]
  Thread 0x5c99a    priority 33
  Binary Images:
Process:         distnoted [22]
Path:            /usr/sbin/distnoted
Parent:          launchd [1]
UID:             0
Task size:       705 pages (+10)
  Thread 0x129      DispatchQueue 1          priority 31
    24 ??? (distnoted + 14743) [0x10d703997]
  Thread 0x12a      DispatchQueue 2          priority 33
  Thread 0x5c9d1    priority 31
  13 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8fb691d1]
    13 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8fb7ed13]
      13 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff98c156d6]
       *13 ??? (mach_kernel + 3910896) [0xffffff80005bacf0]
  Thread 0x5c9d2    priority 31
  Thread 0x5c9d6    priority 31
       *4 ??? (mach_kernel + 3910896) [0xffffff80005bacf0]
  Binary Images:
         0x10d700000 -        0x10d705ff7  distnoted <1AD693FE-8ACE-3EF5-B496-2FBFEB9F463D> /usr/sbin/distnoted
Process:         distnoted [192]
UID:             501
Task size:       2171 pages
  Thread 0x470      DispatchQueue 1          priority 31
    24 ??? (distnoted + 14743) [0x100e36997]
  Thread 0x484      DispatchQueue 2          priority 33
  Thread 0x5c92f    priority 31
  Thread 0x5c98b    priority 31
  Binary Images:
         0x100e33000 -        0x100e38ff7  distnoted <1AD693FE-8ACE-3EF5-B496-2FBFEB9F463D> /usr/sbin/distnoted
Process:         distnoted [320]
UID:             89
Task size:       466 pages
  Thread 0x916      DispatchQueue 1          priority 31
    24 ??? (distnoted + 14743) [0x10a86b997]
  Thread 0x917      DispatchQueue 2          priority 33
  Binary Images:
         0x10a868000 -        0x10a86dff7  distnoted <1AD693FE-8ACE-3EF5-B496-2FBFEB9F463D> /usr/sbin/distnoted
Process:         distnoted [7398]
UID:             502
Task size:       446 pages
  Thread 0x4b5f3    DispatchQueue 1          priority 31
    24 ??? (distnoted + 14743) [0x10bc4f997]
  Thread 0x4b5f5    DispatchQueue 2          priority 33
  Binary Images:
         0x10bc4c000 -        0x10bc51ff7  distnoted <1AD693FE-8ACE-3EF5-B496-2FBFEB9F463D> /usr/sbin/distnoted
Process:         distnoted [8702]
UID:             504
Task size:       959 pages
  Thread 0x58408    DispatchQueue 1          priority 31
    24 ??? (distnoted + 14743) [0x10946c997]
  Thread 0x58418    DispatchQueue 2          priority 33
  Binary Images:
         0x109469000 -        0x10946eff7  distnoted <1AD693FE-8ACE-3EF5-B496-2FBFEB9F463D> /usr/sbin/distnoted
Process:         Dock [9289]
Path:            /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
UID:             501
Task size:       12441 pages (+1)
  Thread 0x5b460    DispatchQueue 1          priority 47
    24 ??? (Dock + 843262) [0x102ba8dfe]
  Thread 0x5b46c    DispatchQueue 2          priority 49
  Thread 0x5b578    priority 47
      24 ??? (Dock + 100664) [0x102af3938]
  Thread 0x5c98a    priority 47
  Binary Images:
         0x102adb000 -        0x102d35fff  com.apple.dock 1.8 (1168.8) <126B9757-39DF-318A-8FC6-D7054975CFAC> /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
Process:         Dropbox [9343]
Path:            /Applications/Dropbox.app/Contents/MacOS/Dropbox
Architecture:    i386
UID:             501
Task size:       30024 pages
CPU Time:        0.010s
Process:         dynamic_pager [90]
Path:            /sbin/dynamic_pager
Parent:          launchd [1]
UID:             0
Task size:       202 pages
  Thread 0x25d      priority 63
  24 ??? [0x7fff975d97e1]
    24 ??? [0x10678e4c8]
      24 ??? [0x10678dd8f]
        24 ??? [0x10678db80]
          24 ??? [0x10678d613]
            24 ??? [0x7fff98c13686]
  Binary Images:
Process:         EEventManager [9330]
Path:            /Applications/Epson Software/Event Manager.app/Contents/Resources/Assistants/Event Manager/EEventManager.app/Contents/MacOS/EEventManager
Architecture:    i386
UID:             501
Task size:       1693 pages
CPU Time:        0.001s
Process:         Fantastical [9342]
Path:            /Applications/Fantastical.app/Contents/MacOS/Fantastical
UID:             501
Task size:       9305 pages
Process:         filecoordinationd [214]
Path:            /usr/sbin/filecoordinationd
Parent:          launchd [1]
UID:             0
Sudden Term:     Clean
Task size:       927 pages
  Thread 0x51d      DispatchQueue 7          priority 31
  Thread 0x51f      DispatchQueue 2          priority 33
  Binary Images:
         0x10c835000 -        0x10c835ff7  filecoordinationd <6E46FB95-0458-38CD-84BE-9775D69FF9A8> /usr/sbin/filecoordinationd
Process:         Finder [9291]
Path:            /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
UID:             501
Task size:       25205 pages
CPU Time:        0.002s
  Thread 0x5b465    DispatchQueue 1          priority 46         cpu time   0.001s
    24 ??? (Finder + 23382) [0x107f6eb56]
  Thread 0x5b484    DispatchQueue 2          priority 48
  Thread 0x5b807    priority 62
  Thread 0x5b854    priority 46
  Thread 0x5c2bb    priority 53
      24 startIOThread(void*) + 148 (CoreVideo) [0x7fff8dcb0fd7]
        24 CVDisplayLink::runIOThread() + 689 (CoreVideo) [0x7fff8dcb12a1]
  Thread 0x5c903    priority  cpu time   0.001s
  Thread 0x5c912    priority 46
  Thread 0x5c9a8    priority   24 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8fb691d1]
  Binary Images:
         0x107f69000 -        0x108423ff7  com.apple.finder 10.8.3 (10.8.3) <5AF2416D-6AF0-386F-86D5-A276C74780E6> /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
      0x7fff8dcaf000 -     0x7fff8dcd9ff7  com.apple.CoreVideo 1.8 (99.4)  /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
Process:         Folder Actions Dispatcher [9325]
Path:            /System/Library/CoreServices/Folder Actions Dispatcher.app/Contents/MacOS/Folder Actions Dispatcher
UID:             501
Sudden Term:     Clean
Task size:       1979 pages
  Thread 0x5b4e1    DispatchQueue 1          priority 47
  Thread 0x5b50e    DispatchQueue 2          priority 49
  Binary Images:
         0x101162000 -        0x101173fff  com.apple.FolderActionsDispatcher 1.0.4 (1.0.4) <10F80E2D-7667-3483-ACE5-C86CB45247CA> /System/Library/CoreServices/Folder Actions Dispatcher.app/Contents/MacOS/Folder Actions Dispatcher
Process:         fontd [9296]
Path:            /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/fontd
UID:             501
Sudden Term:     Clean
Task size:       2502 pages
  Thread 0x5b4a1    DispatchQueue 1          priority 31
    24 main_handler + 4757 (libATSServer.dylib) [0x7fff8db69ff7]
  Thread 0x5b4a8    DispatchQueue 2          priority 33
  Thread 0x5c5bc    priority 38
      24 AsyncFileThread(void*) + 257 (CarbonCore) [0x7fff8f348b93]
        24 TSWaitOnSemaphoreCommon + 265 (CarbonCore) [0x7fff8f384f6d]
          24 TSWaitOnConditionTimedRelative + 163 (CarbonCore) [0x7fff8f385406]
  Thread 0x5c959    priority 31
  Binary Images:
         0x103483000 -        0x103486fff  fontd <8EE3DBFC-B8F0-3A32-9ED8-29E195EF9269> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/fontd
      0x7fff8daeb000 -     0x7fff8db92fff  libATSServer.dylib <531C17E4-40BE-3D3D-A0C4-1F895FF3191E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libATSServer.dylib
Process:         fseventsd [43]
Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/Support/fseventsd
Parent:          launchd [1]
UID:             0
Task size:       4588 pages (+3)
  Thread 0x1d8      DispatchQueue 1          priority 31
    24 ??? (fseventsd + 5581) [0x1085805cd]
      24 mach_msg_server + 393 (libsystem_kernel.dylib) [0x7fff98c1346d]
  Thread 0x1df      DispatchQueue 2          priority 33
  Thread 0x1db      priority 49
      24 ??? (fseventsd + 43276) [0x10858990c]
        24 ??? (fseventsd + 42504) [0x108589608]
  Thread 0x1dc      priority 31
      24 ??? (fseventsd + 12957) [0x10858229d]
  Thread 0x1dd      priority 50
  Thread 0x1de      priority 31
      24 ??? (fseventsd + 29434) [0x1085862fa]
  Thread 0x211      priority 31
  Thread 0x212      priority 31
  Thread 0x213      priority 31
  Thread 0x214      priority 31
  Thread 0x215      priority 31
  Thread 0x216      priority 31
  Thread 0x217      priority 31
  Thread 0x218      priority 31
  Thread 0x219      priority 31
  Thread 0x21a      priority 31
  Thread 0x21b      priority 31
  Thread 0x21c      priority 31
  Thread 0x21d      priority 31
  Thread 0x21e      priority 31
  Thread 0x21f      priority 31
  Thread 0x220      priority 31
  Thread 0x221      priority 31
  Thread 0x222      priority 31
  Thread 0x223      priority 31
  Thread 0x224      priority 31
  Thread 0x225      priority 31
  Thread 0x226      priority 31
  Thread 0x227      priority 31
  Thread 0x228      priority 31
  Thread 0x229      priority 31
  Thread 0x22a      priority 31
  Thread 0x22b      priority 31
  Thread 0x5b497    priority 31
  Thread 0x5b4b1    priority 31
  Thread 0x5b4b3    priority 31
  Thread 0x5b4ba    priority 31
  Thread 0x5b59a    priority 31
  Thread 0x5b59f    priority 14
  Thread 0x5b5a2    priority 19
  Thread 0x5b5a7    priority 0
  Thread 0x5b5a8    priority 31
  Thread 0x5b5ac    priority 31
  Thread 0x5b5c4    priority 31
  Thread 0x5b5c5    priority 31
  Thread 0x5b5f4    priority 31
  Thread 0x5b602    priority 31
  Thread 0x5b63e    priority 31
  Thread 0x5b63f    priority 31
  Thread 0x5b640    priority 31
  Thread 0x5b641    priority 31
  Thread 0x5b642    priority 31
  Thread 0x5b643    priority 31
  Thread 0x5b644    priority 31
  Thread 0x5b645    priority 31
  Thread 0x5b646    priority 31
  Thread 0x5b647    priority 31
  Thread 0x5b649    priority 31
  Thread 0x5b64c    priority 31
  Thread 0x5b64d    priority 31
  Thread 0x5b64e    priority 31
  Thread 0x5b64f    priority 31
  Thread 0x5b650    priority 31
  Thread 0x5b651    priority 31
  Thread 0x5b659    priority 31
  Thread 0x5b6c0    priority 31
  Thread 0x5b883    priority 31
  Thread 0x5b8d5    priority 31
  Thread 0x5c2ba    priority 31
  Thread 0x5c9ce    priority 31
  Binary Images:
         0x10857f000 -        0x108594fff  fseventsd  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/Support/fseventsd
Process:         Google Chrome [9397]
Path:            /Applications/Google Chrome.app/Contents/MacOS/Google Chrome
Architecture:    i386
UID:             501
Task size:       67331 pages
Pageins:         1 pages
CPU Time:        0.010s
Process:         Google Chrome Helper [9402]
Path:            /Applications/Google Chrome.app/Contents/Versions/27.0.1453.116/Google Chrome Helper.app/Contents/MacOS/Google Chrome Helper
Architecture:    i386
Parent:          Google Chrome [9397]
UID:             501
Task size:       6974 pages
Process:         Google Chrome Helper [9403]
Architecture:    i386
UID:             501
Task size:       20198 pages
Process:         Google Chrome Helper [9404]
Architecture:    i386
UID:             501
Task size:       24212 pages
CPU Time:        0.035s
Process:         Google Chrome Helper [9405]
Architecture:    i386
UID:             501
Task size:       8187 pages
Process:         Google Chrome Helper [9406]
Architecture:    i386
UID:             501
Task size:       29277 pages
CPU Time:        0.001s
Process:         Google Chrome Helper [9407]
Architecture:    i386
UID:             501
Task size:       6840 pages
Process:         Google Chrome Helper [9408]
Architecture:    i386
UID:             501
Task size:       9344 pages
Process:         Google Chrome Helper [9409]
Architecture:    i386
UID:             501
Task size:       8409 pages
Process:         Google Chrome Helper [9410]
Architecture:    i386
UID:             501
Task size:       25383 pages
Process:         Google Chrome Helper [9412]
Architecture:    i386
UID:             501
Task size:       7463 pages
Process:         Google Chrome Helper [9413]
Architecture:    i386
UID:             501
Task size:       20606 pages
Process:         Google Chrome Helper [9414]
Architecture:    i386
UID:             501
Task size:       6787 pages
Process:         Google Chrome Helper [9415]
Architecture:    i386
UID:             501
Task size:       7768 pages
Process:         Google Chrome Helper [9416]
Architecture:    i386
UID:             501
Task size:       19820 pages
CPU Time:        0.001s
Process:         Google Chrome Helper [9417]
Architecture:    i386
UID:             501
Task size:       20005 pages
Process:         Google Chrome Helper [9418]
Architecture:    i386
UID:             501
Task size:       7790 pages
Process:         Google Chrome Helper [9419]
Architecture:    i386
UID:             501
Task size:       7709 pages
Process:         Google Chrome Helper [9420]
Architecture:    i386
UID:             501
Task size:       14995 pages
CPU Time:        0.001s
Process:         Google Chrome Helper [9423]
Architecture:    i386
UID:             501
Task size:       21807 pages
Process:         Google Chrome Helper [9424]
Architecture:    i386
UID:             501
Task size:       15925 pages
Process:         Google Chrome Helper [9425]
Architecture:    i386
UID:             501
Task size:       17035 pages
CPU Time:        0.001s
Process:         Google Chrome Helper [9427]
Architecture:    i386
UID:             501
Task size:       18196 pages
Process:         Google Chrome Helper [9428]
Architecture:    i386
UID:             501
Task size:       16336 pages
Process:         Google Chrome Helper [9429]
Architecture:    i386
UID:             501
Task size:       11872 pages
Process:         Google Chrome Helper [9430]
Architecture:    i386
UID:             501
Task size:       4519 pages
Process:         Google Chrome Helper [9431]
Architecture:    i386
UID:             501
Task size:       30698 pages (-466)
CPU Time:        0.042s
Process:         Google Chrome Helper [9511]
Architecture:    i386
UID:             501
Task size:       6899 pages
Process:         GrowlHelperApp [9336]
Path:            /Library/PreferencePanes/Growl.prefPane/Contents/Resources/GrowlHelperApp.app/Contents/MacOS/GrowlHelperApp
UID:             501
Task size:       13607 pages
Process:         helpd [9308]
Path:            /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/Resources/helpd
UID:             501
Sudden Term:     Clean
Task size:       616 pages
  Thread 0x5b4d0    DispatchQueue 1          priority 27
    24 ??? (helpd + 41173) [0x1099580d5]
  Thread 0x5b4e7    DispatchQueue 2          priority 33
  Binary Images:
         0x10994e000 -        0x10995dfff  helpd <18369DE6-2FD3-3D31-8E69-F1CE023B0B8F> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/Resources/helpd
Process:         hidd [88]
Path:            /usr/libexec/hidd
Parent:          launchd [1]
UID:             0
Task size:       379 pages
  Thread 0x25b      DispatchQueue 1          priority 31
    24 ??? (hidd + 3863) [0x10e330f17]
  Thread 0x27e      DispatchQueue 2          priority 33
  Thread 0x280      priority 63
      24 __IOHIDSessionStartOnThread + 402 (IOKit) [0x7fff9590e254]
  Binary Images:
         0x10e330000 -        0x10e330fff  hidd  /usr/libexec/hidd
      0x7fff958de000 -     0x7fff9594cff7  com.apple.framework.IOKit 2.0.1 <04BFB138-8AF4-310A-8E8C-045D8A239654> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
Process:         httpd [63]
Path:            /usr/sbin/httpd
Parent:          launchd [1]
UID:             0
Task size:       2779 pages
  Thread 0x242      DispatchQueue 1          priority 31
    24 main + 3186 (httpd) [0x10115db12]
      24 ap_mpm_run + 1085 (httpd) [0x101192c9d]
        24 ap_wait_or_timeout + 169 (httpd) [0x10116c579]
  Binary Images:
         0x101153000 -        0x1011a7ff7  httpd  /usr/sbin/httpd
Process:         httpd [114]
Parent:          httpd [63]
UID:             70
Task size:       529 pages
  Thread 0x322      DispatchQueue 1          priority 31
      24 ap_mpm_run + 703 (httpd) [0x101192b1f]
        24 startup_children + 128 (httpd) [0x101193a50]
          24 make_child + 414 (httpd) [0x10119399e]
            24 child_main + 1374 (httpd) [0x101194e4e]
              24 unixd_accept + 55 (httpd) [0x101196287]
                24 __accept + 10 (libsystem_kernel.dylib) [0x7fff98c14996]
                     *24 accept_nocancel + 442 (mach_kernel) [0xffffff800059f96a]
  Binary Images:
Process:         httpd [2812]
Parent:          httpd [63]
UID:             70
Task size:       513 pages
  Thread 0x1b1a9    DispatchQueue 1          priority 31
      24 ap_mpm_run + 1460 (httpd) [0x101192e14]
        24 perform_idle_server_maintenance + 621 (httpd) [0x101193cfd]
  Binary Images:
Process:         httpd [2813]
Parent:          httpd [63]
UID:             70
Task size:       506 pages
  Thread 0x1b1b1    DispatchQueue 1          priority 31
  Binary Images:
Process:         httpd [2814]
Parent:          httpd [63]
UID:             70
Task size:       501 pages
  Thread 0x1b1b2    DispatchQueue 1          priority 31
  Binary Images:
Process:         httpd [2898]
Parent:          httpd [63]
UID:             70
  Thread 0x1c322    DispatchQueue 1          priority 31
  Binary Images:
Process:         Image Capture Extension [9388]
Path:            /System/Library/Image Capture/Support/Image Capture Extension.app/Contents/MacOS/Image Capture Extension
UID:             501
Sudden Term:     Clean
Task size:       8167 pages (+3)
  Thread 0x5b87e    DispatchQueue 1          priority 46
  Thread 0x5b880    DispatchQueue 2          priority 48
  Thread 0x5c9d4    priority 46
  10 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8fb691d1]
    10 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8fb7ed13]
      10 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff98c156d6]
       *10 ??? (mach_kernel + 3910896) [0xffffff80005bacf0]
  Binary Images:
         0x10101e000 -        0x101085fff  com.apple.ImageCaptureExtension2 8.0.1 (8.0.1) <4C3765E8-FAB8-3525-8474-EB9767FC75D8> /System/Library/Image Capture/Support/Image Capture Extension.app/Contents/MacOS/Image Capture Extension
Process:         imagent [9307]
Path:            /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
UID:             501
Task size:       1378 pages
  Thread 0x5b4cf    DispatchQueue 1          priority 31
    24 ??? (imagent + 32939) [0x10a75c0ab]
  Thread 0x5b4eb    DispatchQueue 2          priority 33
  Thread 0x5b528    priority 31
        24 ??? (IMDPersistence + 6074) [0x7fff94a7f7ba]
  Binary Images:
         0x10a754000 -        0x10a77bfff  com.apple.imagent 8.0 (900) <0F128A3A-D546-3C5E-8F32-F695DC6EADE3> /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
      0x7fff94a7e000 -     0x7fff94ac4ff7  com.apple.IMDPersistence 8.0 (900) <8F359FC3-BD5E-3269-9A79-80849E9CC2DE> /System/Library/PrivateFrameworks/IMDPersistence.framework/Versions/A/IMDPersistence
Process:         kdc [86]
Path:            /System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kdc
Parent:          launchd [1]
UID:             0
Sudden Term:     Clean
Task size:       837 pages
  Thread 0x2ba      DispatchQueue 2          priority 33
  Thread 0x2c7      DispatchQueue 7          priority 31
  Binary Images:
         0x107340000 -        0x10737bfff  kdc <60951367-D2D3-3C10-872E-05BD43147298> /System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kdc
Process:         KernelEventAgent [85]
Path:            /usr/sbin/KernelEventAgent
Parent:          launchd [1]
UID:             0
Sudden Term:     Clean
Task size:       306 pages
  Thread 0x258      DispatchQueue 1          priority 31
    24 main + 908 (KernelEventAgent) [0x10d7896ec]
  Thread 0x271      DispatchQueue 2          priority 33
  Thread 0x270      priority 31
  Binary Images:
         0x10d788000 -        0x10d78efff  KernelEventAgent  /usr/sbin/KernelEventAgent
Process:         kextd [15]
Path:            /usr/libexec/kextd
Parent:          launchd [1]
UID:             0
Task size:       3919 pages
  Thread 0x114      DispatchQueue 1          priority 27
    24 ??? (kextd + 7152) [0x10028cbf0]
  Thread 0x11c      DispatchQueue 2          priority 33
  Thread 0x5c99b    priority 31
  Binary Images:
         0x10028b000 -        0x1002a9fff  kextd  /usr/libexec/kextd
Process:         launchd [1]
Path:            /sbin/launchd
Parent:          kernel_task [0]
UID:             0
Task size:       820 pages
CPU Time:        0.002s
  Thread 0xcf       DispatchQueue 1          priority 31         cpu time   0.002s
    24 ??? (launchd + 15472) [0x10bf74c70]
      24 ??? (launchd + 24092) [0x10bf76e1c]
        24 xpc_pipe_try_receive + 89 (libxpc.dylib) [0x7fff93c7fbbd]
          24 _xpc_pipe_receive + 116 (libxpc.dylib) [0x7fff93c7fdb0]
             *23 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
             *1  hndl_mach_scall64 + 19 (mach_kernel) [0xffffff80002ce9e3]
               *1  ??? (mach_kernel + 681270) [0xffffff80002a6536]
                 *1  mach_msg_overwrite_trap + 427 (mach_kernel) [0xffffff800021970b]
                   *1  ipc_mqueue_receive + 59 (mach_kernel) [0xffffff800021310b]
  Thread 0xe8       priority 31
       *23 ??? (mach_kernel + 3580832) [0xffffff800056a3a0]
           *1  select_nocancel + 1268 (mach_kernel) [0xffffff8000577f44]
             *1  selprocess + 1035 (mach_kernel) [0xffffff800057836b]
               *1  ??? (mach_kernel + 3579737) [0xffffff8000569f59]
  Thread 0xe9       priority 31
      24 ??? (launchd + 15865) [0x10bf74df9]
        24 sleep + 61 (libsystem_c.dylib) [0x7fff8fc0668a]
  Binary Images:
         0x10bf71000 -        0x10bf97ff7  launchd <7DCC9489-2DF5-3807-83FA-EF5666EE8078> /sbin/launchd
Process:         launchd [116]
Path:            /sbin/launchd
Parent:          launchd [1]
UID:             88
Sudden Term:     Dirty
Task size:       244 pages
  Thread 0x333      DispatchQueue 1          priority 31
    24 ??? (launchd + 15472) [0x10b7fcc70]
      24 ??? (launchd + 24092) [0x10b7fee1c]
  Thread 0x336      priority 31
  Binary Images:
         0x10b7f9000 -        0x10b81fff7  launchd <7DCC9489-2DF5-3807-83FA-EF5666EE8078> /sbin/launchd
Process:         launchd [144]
Path:            /sbin/launchd
Parent:          launchd [1]
UID:             501
Sudden Term:     Dirty
Task size:       1097 pages
  Thread 0x3de      DispatchQueue 1          priority 31
    24 ??? (launchd + 15472) [0x102370c70]
      24 ??? (launchd + 24092) [0x102372e1c]
  Thread 0x3e1      priority 31
  Binary Images:
         0x10236d000 -        0x102393ff7  launchd <7DCC9489-2DF5-3807-83FA-EF5666EE8078> /sbin/launchd
Process:         launchd [305]
Path:            /sbin/launchd
Parent:          launchd [1]
UID:             -2
Sudden Term:     Dirty
  Thread 0x829      DispatchQueue 1          priority 31
    24 ??? (launchd + 15472) [0x10c19fc70]
      24 ??? (launchd + 24092) [0x10c1a1e1c]
  Thread 0x82c      priority 31
  Binary Images:
         0x10c19c000 -        0x10c1c2ff7  launchd <7DCC9489-2DF5-3807-83FA-EF5666EE8078> /sbin/launchd
Process:         launchd [317]
Path:            /sbin/launchd
Parent:          launchd [1]
UID:             89
Sudden Term:     Dirty
Task size:       264 pages
  Thread 0x909      DispatchQueue 1          priority 31
    24 ??? (launchd + 15472) [0x1034afc70]
      24 ??? (launchd + 24092) [0x1034b1e1c]
  Thread 0x90b      priority 31
  Binary Images:
         0x1034ac000 -        0x1034d2ff7  launchd <7DCC9489-2DF5-3807-83FA-EF5666EE8078> /sbin/launchd
Process:         launchd [7395]
Path:            /sbin/launchd
Parent:          launchd [1]
UID:             502
Sudden Term:     Dirty
Task size:       236 pages
  Thread 0x4b5e8    DispatchQueue 1          priority 31
    24 ??? (launchd + 15472) [0x10243ec70]
      24 ??? (launchd + 24092) [0x102440e1c]
  Thread 0x4b5ec    priority 31
  Binary Images:
         0x10243b000 -        0x102461ff7  launchd <7DCC9489-2DF5-3807-83FA-EF5666EE8078> /sbin/launchd
Process:         launchd [8671]
Path:            /sbin/launchd
Parent:          launchd [1]
UID:             504
Sudden Term:     Dirty
Task size:       517 pages
  Thread 0x5817b    DispatchQueue 1          priority 31
    24 ??? (launchd + 15472) [0x10ae04c70]
      24 ??? (launchd + 24092) [0x10ae06e1c]
  Thread 0x5817f    priority 31
  Binary Images:
         0x10ae01000 -        0x10ae27ff7  launchd <7DCC9489-2DF5-3807-83FA-EF5666EE8078> /sbin/launchd
Process:         launchdadd [9515]
Path:            /usr/libexec/launchdadd
Parent:          launchd [1]
UID:             0
Sudden Term:     Clean
Task size:       436 pages (+1)
CPU Time:        0.004s
  Thread 0x5c946    DispatchQueue 1          priority 31         cpu time   0.004s
    24 main + 281 (launchdadd) [0x10fb1a577]
          23 __CFRunLoopRun + 1078 (CoreFoundation) [0x7fff922c3916]
            23 __CFRunLoopServiceMachPort + 195 (CoreFoundation) [0x7fff922be233]
              23 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff98c13686]
          1  __CFRunLoopRun + 1826 (CoreFoundation) [0x7fff922c3c02]
            1  __CFRunLoopDoSource1 + 153 (CoreFoundation) [0x7fff92290a49]
              1  __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 41 (CoreFoundation) [0x7fff92290d09]
                1  __CFMachPortPerform + 288 (CoreFoundation) [0x7fff92290e40]
                  1  __LDToolServerMachPortFire + 80 (launchdadd) [0x10fb19e74]
                    1  launchdadd_msg_server + 106 (launchdadd) [0x10fb14a65]
                      1  _Xlaunchd_request + 305 (launchdadd) [0x10fb148bd]
                        1  ldclient_request_launchd_request + 1554 (launchdadd) [0x10fb194e2]
                          1  _CFPropertyListCreateXMLData + 199 (CoreFoundation) [0x7fff922ee437]
                            1  _CFAppendXML0 + 1977 (CoreFoundation) [0x7fff922eee29]
                              1  _CFAppendXML0 + 3411 (CoreFoundation) [0x7fff922ef3c3]
                                1  _plistAppendFormat + 183 (CoreFoundation) [0x7fff922f5fb7]
                                  1  _plistAppendString + 99 (CoreFoundation) [0x7fff922f6043]
                                    1  CFStringCreateExternalRepresentation + 742 (CoreFoundation) [0x7fff922a4776]
                                      1
  Thread 0x5c947    DispatchQueue 2          priority 33
  Binary Images:
         0x10fb13000 -        0x10fb1ffff  launchdadd <635F6227-0868-3C28-94C5-7BFD7464BC9E> /usr/libexec/launchdadd
Process:         LMIGUIAgent [9316]
Path:            /Library/Application Support/LogMeIn/*/LogMeIn.app/Contents/Resources/LMIGUIAgent.app/Contents/MacOS/LMIGUIAgent
Architecture:    i386
UID:             501
Task size:       1751 pages
Process:         LMILaunchAgentFixer [9339]
Path:            /Library/Application Support/LogMeIn/LMILaunchAgentFixer.app/Contents/MacOS/LMILaunchAgentFixer
Architecture:    i386
UID:             501
Task size:       706 pages
Process:         logind [133]
Path:            /System/Library/CoreServices/logind
Parent:          launchd [1]
UID:             0
Task size:       536 pages
  Thread 0x385      DispatchQueue 1          priority 31
    24 ??? (logind + 3087) [0x102b21c0f]
  Thread 0x386      DispatchQueue 2          priority 33
  Binary Images:
         0x102b21000 -        0x102b23fff  logind  /System/Library/CoreServices/logind
Process:         loginwindow [9259]
Path:            /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
Parent:          launchd [1]
UID:             501
Task size:       8666 pages (+34)
CPU Time:        0.087s
  Thread 0x5b30e    DispatchQueue 1          priority 48         cpu time   0.042s
    24 ??? (loginwindow + 23560) [0x105b07c08]
      15 -[NSApplication run] + 636 (AppKit) [0x7fff8de3621a]
        15 ??? (loginwindow + 40406) [0x105b0bdd6]
          15 -[NSApplication sendEvent:] + 5761 (AppKit) [0x7fff8df20644]
            15 -[NSWindow sendEvent:] + 6853 (AppKit) [0x7fff8df2450e]
              15 -[NSControl mouseDown:] + 820 (AppKit) [0x7fff8df2cb9c]
                15 -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 504 (AppKit) [0x7fff8df2d421]
                  8  -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 1371 (AppKit) [0x7fff8df2d9ef]
                    8  -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128 (AppKit) [0x7fff8de3edf2]
                      8  _DPSNextEvent + 685 (AppKit) [0x7fff8de3f533]
                        8  BlockUntilNextEventMatchingListInMode + 62 (HIToolbox) [0x7fff95cd4ae3]
                          8  ReceiveNextEventCommon + 356 (HIToolbox) [0x7fff95cd4c52]
                            8  RunCurrentEventLoopInMode + 209 (HIToolbox) [0x7fff95cd4eb4]
                              8  CFRunLoopRunSpecific + 290 (CoreFoundation) [0x7fff922c30e2]
                                8  __CFRunLoopRun + 1078 (CoreFoundation) [0x7fff922c3916]
                                  8  __CFRunLoopServiceMachPort + 195 (CoreFoundation) [0x7fff922be233]
                                    8  mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff98c13686]
                                     *8  ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                  7  -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 1855 (AppKit) [0x7fff8df2dbd3]
                    7  -[NSCell _sendActionFrom:] + 138 (AppKit) [0x7fff8df2f6eb]
                      7  -[NSControl sendAction:to:] + 85 (AppKit) [0x7fff8df2f7b7]
                        7  -[NSApplication sendAction:to:from:] + 342 (AppKit) [0x7fff8df2f959]
                          4  ??? (loginwindow + 134105) [0x105b22bd9]
                            4  -[NSApplication _commonBeginModalSessionForWindow:relativeToWindow:modalDelegate:didEndSelector:contextInfo:] + 778 (AppKit) [0x7fff8dd37bff]
                              4  -[NSApplication _orderFrontModalWindow:relativeToWindow:] + 717 (AppKit) [0x7fff8dd38415]
                                4  -[NSWindow _doOrderWindow:relativeTo:findKey:forCounter:force:isModal:] + 940 (AppKit) [0x7fff8deff038]
                                  4  -[NSWindow _reallyDoOrderWindow:relativeTo:findKey:forCounter:force:isModal:] + 1761 (AppKit) [0x7fff8deffb98]
                                    4  -[NSWindow(NSSheets) _orderFrontRelativeToWindow:] + 207 (AppKit) [0x7fff8dd3883d]
                                      4  -[NSMoveHelper(NSSheets) _moveParent:andOpenSheet:] + 1788 (AppKit) [0x7fff8dd38f64]
                                        4  -[NSMoveHelper _doAnimation] + 1373 (AppKit) [0x7fff8dd35bdc]
                                                 *3  ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                                            1  __CFRunLoopRun + 1529 (CoreFoundation) [0x7fff922c3ad9]
                                              1  __CFRunLoopDoTimer + 557 (CoreFoundation) [0x7fff922de31d]
                                                1  __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20 (CoreFoundation) [0x7fff922de804]
                                                  1  __28-[NSMoveHelper _doAnimation]_block_invoke_0 + 1039 (AppKit) [0x7fff8dd361b7]
                                                    1  -[NSMoveHelper _stopAnimation] + 292 (AppKit) [0x7fff8dd36e37]
                                                      1  CGSReenableUpdate + 25 (CoreGraphics) [0x7fff96af2426]
                                                        1  CGSReenableUpdateForConnections + 395 (CoreGraphics) [0x7fff96af25b7]
                                                          1  _CGSReenableUpdateForConnections + 175 (CoreGraphics) [0x7fff96af2700]
                                                            1  mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff98c13686]
                                                             *1  ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                          3  -[NSApplication endSheet:returnCode:] + 267 (AppKit) [0x7fff8dd3cac6]
                            3  ??? (loginwindow + 134517) [0x105b22d75]
                              3  -[NSWindow orderWindow:relativeTo:] + 159 (AppKit) [0x7fff8defec1f]
                                3  -[NSWindow _doOrderWindow:relativeTo:findKey:forCounter:force:isModal:] + 940 (AppKit) [0x7fff8deff038]
                                  3  -[NSWindow _reallyDoOrderWindow:relativeTo:findKey:forCounter:force:isModal:] + 2210 (AppKit) [0x7fff8deffd59]
                                    3  -[NSWindow(NSSheets) _orderOutRelativeToWindow:] + 115 (AppKit) [0x7fff8dd3d13f]
                                      2  -[NSMoveHelper(NSSheets) _closeSheet:andMoveParent:] + 543 (AppKit) [0x7fff8dd3d3be]
                                        2  -[NSMoveHelper _doAnimation] + 1373 (AppKit) [0x7fff8dd35bdc]
                                          2  CFRunLoopRunSpecific + 290 (CoreFoundation) [0x7fff922c30e2]
                                            1  __CFRunLoopRun + 1078 (CoreFoundation) [0x7fff922c3916]
                                              1  __CFRunLoopServiceMachPort + 195 (CoreFoundation) [0x7fff922be233]
                                                  1  __28-[NSMoveHelper _doAnimation]_block_invoke_0 + 425 (AppKit) [0x7fff8dd35f51]
                                                    1  MetalSheetProgress + 7832 (CoreGraphics) [0x7fff96a9d5de]
                                                      1  resizeTopShadow + 621 (CoreGraphics) [0x7fff96a9e79b]
                                                        1  CGContextFillRects + 104 (CoreGraphics) [0x7fff96adcf60]
                                                          1  ripc_DrawRects + 645 (libRIP.A.dylib) [0x7fff9a0c3e3a]
                                                            1  ripc_Render + 135 (libRIP.A.dylib) [0x7fff9a0c7fde]
                                                              1  ripr_Coverage + 1322 (libRIP.A.dylib) [0x7fff9a0c711d]
        1  aa_render_shape + 1124 (CoreGraphics) [0x7fff96b2d835]
        1                                        1  -[NSMoveHelper(NSSheets) _closeSheet:andMoveParent:] + 563 (AppKit) [0x7fff8dd3d3d2]
                                        1  -[NSWindow(NSSheets) _detachSheetWindow] + 333 (AppKit) [0x7fff8dd3dd02]
                                          1  -[NSWindow setHidesOnDeactivate:] + 111 (AppKit) [0x7fff8dfb86e9]
                                            1  -[NSApplication(NSWindowCache) _setHidesOnDeactivateInCache:forWindow:] + 78 (AppKit) [0x7fff8dfb87c1]
                                              1  objc_msgSend + 20 (libobjc.A.dylib) [0x7fff95422254]
                                                1        9  -[NSApplication run] + 517 (AppKit) [0x7fff8de361a3]
        9  -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128 (AppKit) [0x7fff8de3edf2]
          9  _DPSNextEvent + 685 (AppKit) [0x7fff8de3f533]
            9  BlockUntilNextEventMatchingListInMode + 62 (HIToolbox) [0x7fff95cd4ae3]
              9  ReceiveNextEventCommon + 356 (HIToolbox) [0x7fff95cd4c52]
                9  RunCurrentEventLoopInMode + 209 (HIToolbox) [0x7fff95cd4eb4]
                  9  CFRunLoopRunSpecific + 290 (CoreFoundation) [0x7fff922c30e2]
                    9  __CFRunLoopRun + 1078 (CoreFoundation) [0x7fff922c3916]
                      9  __CFRunLoopServiceMachPort + 195 (CoreFoundation) [0x7fff922be233]
                        9  mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff98c13686]
                         *9  ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
  Thread 0x5b313    DispatchQueue 2          priority 50
  Thread 0x5c98e    priority 46
  Thread 0x5c98f    priority   24 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8fb691d1]
  Thread 0x5c990    priority 48
  Thread 0x5c991    priority 48         cpu time   0.045s
        16 -[NSUIHeartBeat _heartBeatThread:] + 543 (AppKit) [0x7fff8e024838]
          16 usleep + 54 (libsystem_c.dylib) [0x7fff8fc06717]
            16 __semwait_signal + 10 (libsystem_kernel.dylib) [0x7fff98c15386]
             *12 semaphore_wait_continue + 0 (mach_kernel) [0xffffff8000234040]
             *4  hndl_unix_scall64 + 19 (mach_kernel) [0xffffff80002ce9c3]
               *4  unix_syscall64 + 522 (mach_kernel) [0xffffff80005e16aa]
                 *4  __semwait_signal_nocancel + 170 (mach_kernel) [0xffffff800056675a]
                   *4  semaphore_timedwait_trap_internal + 130 (mach_kernel) [0xffffff8000234582]
                     *4  ??? (mach_kernel + 213735) [0xffffff80002342e7]
                       *4  thread_block_reason + 275 (mach_kernel) [0xffffff800022db73]
                         *4  ??? (mach_kernel + 187905) [0xffffff800022de01]
                           *4  processor_idle + 237 (mach_kernel) [0xffffff800022f34d]
                             *4  machine_idle + 443 (mach_kernel) [0xffffff80002b9c9b]
        5  -[NSUIHeartBeat _heartBeatThread:] + 493 (AppKit) [0x7fff8e024806]
          5  -[NSLock lock] + 148 (Foundation) [0x7fff9615c61e]
            5  __psynch_mutexwait + 10 (libsystem_kernel.dylib) [0x7fff98c15122]
             *5  psynch_mtxcontinue + 0 (mach_kernel) [0xffffff80005b4550]
        3  -[NSUIHeartBeat _heartBeatThread:] + 936 (AppKit) [0x7fff8e0249c1]
          3  -[NSWindow(NSWindow_Theme) heartBeat:] + 397 (AppKit) [0x7fff8e04b568]
            3  -[NSButtonCell(NSDefaultButtonIndicatorPrivate) heartBeat:] + 2219 (AppKit) [0x7fff8e04be55]
              3  -[NSView(NSInternal) _recursive:displayRectIgnoringOpacity:inContext:topView:] + 2158 (AppKit) [0x7fff8dfd43bd]
                  2  -[NSView(NSInternal) _recursive:displayRectIgnoringOpacity:inContext:topView:] + 1354 (AppKit) [0x7fff8dfd4099]
                    2  -[NSControl drawRect:] + 400 (AppKit) [0x7fff8de8d7d6]
                      1  -[NSButtonCell drawWithFrame:inView:] + 540 (AppKit) [0x7fff8deab86c]
                        1  -[NSButtonCell drawInteriorWithFrame:inView:] + 2056 (AppKit) [0x7fff8deac0e7]
                          1  -[NSButtonCell _configureAndDrawTitleWithRect:cellFrame:controlView:] + 388 (AppKit) [0x7fff8df05319]
                            1  -[NSButtonCell titleRectForBounds:] + 213 (AppKit) [0x7fff8df05e95]
                              1  -[NSCell _unformattedAttributedStringValue:] + 265 (AppKit) [0x7fff8de844f7]
                                1  -[NSCell _textAttributes] + 72 (AppKit) [0x7fff8de558f4]
                                  1  -[NSButtonCell interiorBackgroundStyle] + 66 (AppKit) [0x7fff8ddf3bbe]
                                    1  objc_msgSend + 5 (libobjc.A.dylib) [0x7fff95422245]
                                      1                        1  -[NSButtonCell drawWithFrame:inView:] + 489 (AppKit) [0x7fff8deab839]
                        1  -[NSButtonCell drawBezelWithFrame:inView:] + 245 (AppKit) [0x7fff8df51782]
                          1  -[NSButtonCell _coreUIBezelDrawOptionsWithFrame:inView:] + 349 (AppKit) [0x7fff8df56b91]
                            1  -[NSCell(NSCellControlTint) _realControlTint] + 46 (AppKit) [0x7fff8de914de]
                              1  -[NSCell _preferInactiveBezelArtInView:] + 171 (AppKit) [0x7fff8de1a04d]
                                1  objc_msgSend + 37 (libobjc.A.dylib) [0x7fff95422265]
                                  1                    1  -[NSView(NSInternal) _recursive:displayRectIgnoringOpacity:inContext:topView:] + 2264 (AppKit) [0x7fff8dfd4427]
                    1  -[NSFocusStack unfocusView:] + 103 (AppKit) [0x7fff8de8e515]
                      1  _CFDoExceptionOperation + 89 (CoreFoundation) [0x7fff92312b49]
                        1  objc_removeExceptionHandler + 268 (libobjc.A.dylib) [0x7fff95427fe5]
                          1  _objc_internal_zone + 1 (libobjc.A.dylib) [0x7fff9541e436]
                            1
  Thread 0x5c992    priority   24 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8fb691d1]
  Binary Images:
         0x105b02000 -        0x105b94ff7  com.apple.loginwindow 8.2 (8.2) <8DCEF97F-3C6C-39EA-900F-5AAE666DBF8C> /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
      0x7fff9541c000 -     0x7fff9553492f  libobjc.A.dylib <90D31928-F48D-3E37-874F-220A51FD9E37> /usr/lib/libobjc.A.dylib
      0x7fff96a9a000 -     0x7fff9742a4af  com.apple.CoreGraphics 1.600.0 <5AB32E51-9154-3733-B83B-A9A748652847> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
      0x7fff9a0c1000 -     0x7fff9a0edff7  libRIP.A.dylib  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
Process:         LogMeIn [102]
Path:            /Library/Application Support/LogMeIn/*/LogMeIn.app/Contents/MacOS/LogMeIn
Architecture:    i386
Parent:          launchd [1]
UID:             0
Task size:       2659 pages
CPU Time:        0.005s
Process:         LogMeInGUI [9317]
Path:            /Library/Application Support/LogMeIn/*/LogMeInGUI.app/Contents/MacOS/LogMeInGUI
Architecture:    i386
Parent:          launchd [144]
UID:             501
Task size:       2148 pages
Process:         mDNSResponder [44]
Path:            /usr/sbin/mDNSResponder
Architecture:    x86_64
Parent:          launchd [1]
UID:             65
Sudden Term:     Clean
Task size:       1133 pages (+3)
CPU Time:        0.003s
  Thread 0x1d9      DispatchQueue 1          priority 31
  24 start + 52 (mDNSResponder) [0x10af676ac]
    24 main + 3362 (mDNSResponder) [0x10af34ca4]
        24 CFRunLoopRunSpecific + 290 (CoreFoundation) [0x7fff922c30e2]
          24 __CFRunLoopRun + 1078 (CoreFoundation) [0x7fff922c3916]
            24 __CFRunLoopServiceMachPort + 195 (CoreFoundation) [0x7fff922be233]
              24 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff98c13686]
               *24 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
  Thread 0x1e2      DispatchQueue 2          priority 33
  24 _dispatch_mgr_thread + 54 (libdispatch.dylib) [0x7fff9089b9ee]
    24 kevent + 10 (libsystem_kernel.dylib) [0x7fff98c15d16]
     *24 ??? (mach_kernel + 3471808) [0xffffff800054f9c0]
  Thread 0x20b      priority 31         cpu time   0.003s
  24 thread_start + 13 (libsystem_c.dylib) [0x7fff8fb691e1]
    24 _pthread_start + 327 (libsystem_c.dylib) [0x7fff8fb7c7a2]
  Thread 0x5c9d3    priority 31
  Binary Images:
         0x10af33000 -        0x10afc2fff  mDNSResponder <1792F6EF-2D34-3047-89FC-1643D1C5C214> /usr/sbin/mDNSResponder
Process:         mds [80]
Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/mds
Parent:          launchd [1]
UID:             0
Task size:       93439 pages
  Thread 0x253      DispatchQueue 1          priority 31
    24 ??? (mds + 58484) [0x101db8474]
  Thread 0x2bd      DispatchQueue 2          priority 33
  Thread 0x308      priority 50
  Thread 0x5c8ee    priority 31
  Thread 0x5c909    priority 0
  Thread 0x5c942    priority 0
  Thread 0x5c95d    priority 31
  Thread 0x5c961    priority 31
  Binary Images:
         0x101daa000 -        0x101ec9fff  mds <4C9E27F4-ACA4-316F-A6F7-40786AA318CF> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/mds
Process:         mdworker [9437]
Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
UID:             501
Sudden Term:     Clean
Task size:       4645 pages
Note:            Self-throttled
  Thread 0x5bcc3    DispatchQueue 1          priority 0
    24 ??? (mdworker + 35721) [0x10f7f8b89]
  Thread 0x5bcc4    DispatchQueue 2          priority 4
  Thread 0x5bcc9    priority 4
      24 ??? (mdworker + 47938) [0x10f7fbb42]
        24 ??? (mdworker + 50346) [0x10f7fc4aa]
  Thread 0x5bcca    priority 4
      24 ??? (mdworker + 118233) [0x10f80cdd9]
  Binary Images:
         0x10f7f0000 -        0x10f849ff7  mdworker <9334DE10-ACFA-3B85-B904-379D2787D95E> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process:         mdworker [9506]
UID:             89
Sudden Term:     Clean
Task size:       1516 pages
  Thread 0x5c7de    DispatchQueue 1          priority 0
    24 ??? (mdworker + 35721) [0x10d7e9b89]
  Thread 0x5c7e0    DispatchQueue 2          priority 4
  Thread 0x5c7e4    priority 4
      24 ??? (mdworker + 47938) [0x10d7ecb42]
        24 ??? (mdworker + 50346) [0x10d7ed4aa]
  Binary Images:
         0x10d7e1000 -        0x10d83aff7  mdworker <9334DE10-ACFA-3B85-B904-379D2787D95E> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process:         Nalpeirond6 [156]
Path:            /Library/StartupItems/ProTec6/Nalpeirond6
Architecture:    i386
Parent:          launchd [1]
UID:             0
Task size:       106 pages
Process:         netbiosd [143]
Path:            /usr/sbin/netbiosd
Parent:          launchd [1]
UID:             222
Sudden Term:     Clean
Task size:       722 pages
  Thread 0x3d1      DispatchQueue 2          priority 4
  Thread 0x3d3      DispatchQueue 7          priority 4
     *24 ??? (mach_kernel + 3580832) [0xffffff800056a3a0]
  Thread 0x59aaf    priority 4
  Binary Images:
         0x1039fe000 -        0x103a50ff7  netbiosd <4922874C-4FA5-3B80-B887-55240CB9EEFF> /usr/sbin/netbiosd
Process:         netsession_mac_da586ac [9327]
Path:            /Applications/Akamai/netsession_mac_da586ac
Architecture:    i386
UID:             501
Task size:       3972 pages
Process:         NetworkBrowserAgent [9295]
Path:            /System/Library/CoreServices/NetworkBrowserAgent
UID:             501
Sudden Term:     Clean
Task size:       868 pages
  Thread 0x5b49c    DispatchQueue 1          priority 27
    24 main + 120 (NetworkBrowserAgent) [0x10c4d0775]
  Thread 0x5b4a2    DispatchQueue 2          priority 33
  Thread 0x5b4ad    priority 31
      24 __select + 10 (libsystem_kernel.dylib) [0x7fff98c15322]
  Binary Images:
         0x10c4a0000 -        0x10c4e8fff  NetworkBrowserAgent  /System/Library/CoreServices/NetworkBrowserAgent
Process:         networkd [45]
Path:            /usr/libexec/networkd
Parent:          launchd [1]
UID:             24
Task size:       392 pages
  Thread 0x1e6      DispatchQueue 2          priority 33
  Thread 0x1e9      DispatchQueue 7          priority 31
  Binary Images:
         0x105915000 -        0x10591bff7  networkd <5612B489-6A6B-39A2-9AAC-834F5409D9CA> /usr/libexec/networkd
Process:         NotificationCenter [9303]
Path:            /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter
UID:             501
Task size:       5867 pages
  Thread 0x5b4ca    DispatchQueue 1          priority 4
    24 ??? (NotificationCenter + 5072) [0x10c00c3d0]
  Thread 0x5b57f    DispatchQueue 2          priority 4
  Thread 0x5b60a    priority 4
          24 __psynch_cvwait + 10 (libsystem_kernel.dylib) [0x7fff98c150fa]
           *24 psynch_cvcontinue + 0 (mach_kernel) [0xffffff80005b5bb0]
  Binary Images:
         0x10c00b000 -        0x10c04bfff  com.apple.notificationcenterui 1.0 (111.6) <395F21C6-41AF-3C87-A088-BA52C03C8733> /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter
Process:         notifyd [17]
Path:            /usr/sbin/notifyd
Parent:          launchd [1]
UID:             0
Task size:       701 pages
  Thread 0x117      DispatchQueue 2          priority 33
  24 ??? [0x7fff9089b9ee]
    24 ??? [0x7fff98c15d16]
  Thread 0x118      DispatchQueue 7          priority 31
  24 ??? [0x7fff90898d85]
    24 ??? [0x7fff98c15566]
  Thread 0x5c95e    priority 31
  24 ??? [0x7fff8fb691d1]
    24 ??? [0x7fff8fb7ed13]
      24 ??? [0x7fff98c156d6]
  Binary Images:
Process:         ntpd [62]
Path:            /usr/sbin/ntpd
Parent:          launchd [1]
UID:             0
Sudden Term:     Clean
Task size:       413 pages
  Thread 0x241      DispatchQueue 1          priority 31
    24 ??? (ntpd + 143653) [0x1018b7125]
      24 ??? (ntpd + 144853) [0x1018b75d5]
        24 __sigsuspend + 10 (libsystem_kernel.dylib) [0x7fff98c15552]
  Thread 0x679      DispatchQueue 2          priority 33
  Binary Images:
         0x101894000 -        0x1018eaff7  ntpd <620BA025-EBF8-3704-8229-A17D4B371F9F> /usr/sbin/ntpd
Process:         ocspd [7824]
Path:            /usr/sbin/ocspd
Parent:          launchd [1]
UID:             0
Sudden Term:     Clean
Task size:       15581 pages
  Thread 0x519a0    DispatchQueue 1          priority 31
    24 ??? (ocspd + 17983) [0x108df563f]
      24 ??? (ocspd + 58188) [0x108dff34c]
        24 ??? (ocspd + 58845) [0x108dff5dd]
          24 mach_msg_overwrite_trap + 10 (libsystem_kernel.dylib) [0x7fff98c13692]
  Thread 0x5317c    DispatchQueue 2          priority 33
  Thread 0x53181    priority 63
      24 __NSThread__main__ + 1345 (Foundation) [0x7fff9619f562]
        24 +[NSURLConnection(Loader) _resourceLoadLoop:] + 356 (Foundation) [0x7fff96141546]
  Thread 0x53188    priority 31
  Thread 0x5c92a    priority 31
      24 ??? (ocspd + 63859) [0x108e00973]
        24 ??? (ocspd + 60287) [0x108dffb7f]
  Binary Images:
         0x108df1000 -        0x108e0eff7  ocspd <29C27AFD-6A43-3AD3-B526-289434CBEBBA> /usr/sbin/ocspd
Process:         opendirectoryd [25]
Path:            /usr/libexec/opendirectoryd
Parent:          launchd [1]
UID:             0
Sudden Term:     Clean
Task size:       3444 pages
  Thread 0x13f      DispatchQueue 7          priority 31
  Thread 0x143      DispatchQueue 2          priority 33
  Thread 0x14b      DispatchQueue 6          priority 31
      24 _dispatch_worker_thread2 + 304 (libdispatch.dylib) [0x7fff9089a1fa]
            24 ??? (opendirectoryd + 110174) [0x107cf7e5e]
                24 __semwait_signal + 10 (libsystem_kernel.dylib) [0x7fff98c15386]
                 *24 semaphore_wait_continue + 0 (mach_kernel) [0xffffff8000234040]
  Thread 0x159      DispatchQueue 6          priority 31
            24 __systemcache_mig_initialize_block_invoke_0 + 39 (SystemCache) [0x10832361b]
              24 mach_msg_server + 289 (libsystem_kernel.dylib) [0x7fff98c13405]
  Thread 0x15b      DispatchQueue 6          priority 31
            24 __systemcache_mig_initialize_block_invoke_026 + 39 (SystemCache) [0x1083236f5]
  Thread 0x147      DispatchQueue 357        priority 31
          24 _dispatch_async_f_redirect_invoke + 117 (libdispatch.dylib) [0x7fff9089e317]
                24 __syscall + 10 (libsystem_kernel.dylib) [0x7fff98c155de]
  Thread 0x5c91c    priority 31
  Thread 0x5c995    priority 31
  Thread 0x5c997    priority 31
  Thread 0x5c9aa    priority 31
  Thread 0x5c9ab    priority 31
  Binary Images:
         0x107cdd000 -        0x107d3efff  opendirectoryd <34CCDB58-E926-36AD-8A3A-EA61FCF14446> /usr/libexec/opendirectoryd
         0x108304000 -        0x108334ff7  com.apple.opendirectoryd.module.SystemCache 10.8 (197.17.1)  /System/Library/OpenDirectory/Modules/SystemCache.bundle/Contents/MacOS/SystemCache
Process:         pboard [9294]
Path:            /usr/sbin/pboard
UID:             501
Sudden Term:     Clean
Task size:       249 pages
  Thread 0x5b48c    DispatchQueue 1          priority 31
    24 ??? (pboard + 2225) [0x108a168b1]
      24 mach_msg_server + 552 (libsystem_kernel.dylib) [0x7fff98c1350c]
  Binary Images:
         0x108a16000 -        0x108a16ff7  pboard <820FD61C-E0A7-389D-9B14-C0B17C66743D> /usr/sbin/pboard
Process:         pbs [9363]
Path:            /System/Library/CoreServices/pbs
UID:             501
Task size:       1450 pages
  Thread 0x5b6a1    DispatchQueue 2          priority 33
  Thread 0x5b6a4    DispatchQueue 7          priority 31
  Binary Images:
         0x103b7c000 -        0x103b90fff  pbs <943832C0-58FC-3DBD-BDB9-F6BC0D2128A0> /System/Library/CoreServices/pbs
      0x7fff90897000 -     0x7fff908acff7  libdispatch.dylib  /usr/lib/system/libdispatch.dylib
Process:         powerd [21]
Path:            /System/Library/CoreServices/powerd.bundle/powerd
Parent:          launchd [1]
UID:             0
Task size:       674 pages
  Thread 0x120      DispatchQueue 1          priority 31
    24 main + 2157 (powerd) [0x10bd31571]
  Thread 0x121      DispatchQueue 2          priority 33
  Thread 0x5c99c    priority 31
  Binary Images:
         0x10bd2b000 -        0x10bd49ff7  powerd  /System/Library/CoreServices/powerd.bundle/powerd
      0x7fff8fb68000 -     0x7fff8fc34ff7  libsystem_c.dylib <4C9EB006-FE1F-3F8F-8074-DFD94CF2CE7B> /usr/lib/system/libsystem_c.dylib
      0x7fff9228e000 -     0x7fff92478ff7  com.apple.CoreFoundation 6.8 (744.19) <0F7403CA-2CB8-3D0A-992B-679701DF27CA> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
      0x7fff98c03000 -     0x7fff98c1eff7  libsystem_kernel.dylib  /usr/lib/system/libsystem_kernel.dylib
 *0xffffff8000200000 - 0xffffff8000736dbc  mach_kernel <896CB1E3-AB79-3DF1-B595-549DFFDF3D36> /mach_kernel
Process:         printtool [9469]
Path:            /System/Library/Frameworks/ApplicationServices.framework/Frameworks/PrintCore.framework/Versions/A/printtool
UID:             501
Sudden Term:     Clean (allows idle exit)
Task size:       597 pages
  Thread 0x5c22f    DispatchQueue 7          priority 31
  Thread 0x5c230    DispatchQueue 2          priority 33
  Binary Images:
         0x10fd09000 -        0x10fd10ff7  printtool  /System/Library/Frameworks/ApplicationServices.framework/Frameworks/PrintCore.framework/Versions/A/printtool
Process:         PTPCamera [9376]
Path:            /System/Library/Image Capture/Devices/PTPCamera.app/Contents/MacOS/PTPCamera
UID:             501
Sudden Term:     Dirty
Task size:       4860 pages (-3)
  Thread 0x5b817    DispatchQueue 1          priority 47
  24 start + 1 (libdyld.dylib) [0x7fff975d97e1]
    24 ICD_main + 24 (ICADevices) [0x10cfe4c66]
      24 ICAApplicationMain + 470 (ICADevices) [0x10cfd959e]
  Thread 0x5b819    DispatchQueue 2          priority 49
  Thread 0x5b84a    priority 47
      24 -[PTPTransport callbackThreadFunction] + 304 (PTPCamera) [0x10cf7e729]
        24 CFRunLoopRun + 97 (CoreFoundation) [0x7fff922d1dd1]
  Thread 0x5b89f    priority 47
  Thread 0x5c98d    priority 47
  Binary Images:
         0x10cf7b000 -        0x10cfb2fff  com.apple.PTPCamera 8.0.5 (8.0.5) <40F62D32-7907-38E1-BE79-B0EF61D4C30E> /System/Library/Image Capture/Devices/PTPCamera.app/Contents/MacOS/PTPCamera
         0x10cfd8000 -        0x10d004fff  com.apple.ICADevices 8.0.2 (8.0.2)  /System/Library/Frameworks/ICADevices.framework/Versions/A/ICADevices
      0x7fff8dcea000 -     0x7fff8e917fff  com.apple.AppKit 6.8 (1187.39) <199962F0-B06B-3666-8FD5-5C90374BA16A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
      0x7fff975d7000 -     0x7fff975daff7  libdyld.dylib  /usr/lib/system/libdyld.dylib
Process:         revisiond [75]
Path:            /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisiond
Parent:          launchd [1]
UID:             0
Task size:       888 pages
  Thread 0x286      DispatchQueue 2          priority 33
  Thread 0x29c      DispatchQueue 7          priority 31
  24 _dispatch_sig_thread + 45 (libdispatch.dylib) [0x7fff90898d85]
    24 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib) [0x7fff98c15566]
  Thread 0x296      priority 31
       *24 hndl_unix_scall64 + 19 (mach_kernel) [0xffffff80002ce9c3]
         *24 unix_syscall64 + 522 (mach_kernel) [0xffffff80005e16aa]
               *24 ??? (mach_kernel + 1080233) [0xffffff8000307ba9]
                 *24 VNOP_READ + 77 (mach_kernel) [0xffffff8000311bcd]
                   *24 spec_read + 187 (mach_kernel) [0xffffff800031fe7b]
                     *24 cdev_read + 99 (AppleFSCompressionTypeDataless) [0xffffff7f81fcb9a4]
                       *24 msleep + 116 (mach_kernel) [0xffffff800056a1c4]
                         *24 ??? (mach_kernel + 3579350) [0xffffff8000569dd6]
                           *24 lck_mtx_sleep + 78 (mach_kernel) [0xffffff800022664e]
                             *24 thread_block_reason + 300 (mach_kernel) [0xffffff800022db8c]
                               *24 ??? (mach_kernel + 190657) [0xffffff800022e8c1]
                                 *24 machine_switch_context + 366 (mach_kernel) [0xffffff80002b47fe]
  Thread 0x297      priority 31
      24 fsctl + 10 (libsystem_kernel.dylib) [0x7fff98c15a5a]
           *24 fsctl + 342 (mach_kernel) [0xffffff8000303166]
             *24 ??? (mach_kernel + 1062110) [0xffffff80003034de]
               *24 ??? (mach_kernel + 1069266) [0xffffff80003050d2]
  Binary Images:
         0x102df8000 -        0x102e49fff  revisiond <6FF2058C-8B8C-3E35-A3A6-CE72DCCF5E70> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisiond
 *0xffffff7f81fca000 - 0xffffff7f81fcbff7  com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 49 (1.0.0d1)  /System/Library/Extensions/AppleFSCompressionTypeDataless.kext/Contents/MacOS/AppleFSCompressionTypeDataless
Process:         securityd [18]
Path:            /usr/sbin/securityd
Parent:          launchd [1]
UID:             0
Sudden Term:     Dirty
Task size:       2259 pages
  Thread 0x11b      DispatchQueue 1          priority 31
    24 ??? (securityd + 243976) [0x103889908]
      24 ??? (securityd + 568332) [0x1038d8c0c]
        24 ??? (securityd + 62883) [0x10385d5a3]
  Thread 0x176      DispatchQueue 2          priority 33
  Thread 0x179      priority 31
      24 ??? (securityd + 61637) [0x10385d0c5]
        24 ??? (securityd + 372104) [0x1038a8d88]
          24 au_sdev_read_aia + 118 (libbsm.0.dylib) [0x7fff8dc12822]
            24 fgetc + 50 (libsystem_c.dylib) [0x7fff8fbe4b7f]
              24 __srget + 17 (libsystem_c.dylib) [0x7fff8fbe8e6f]
                24 __srefill1 + 27 (libsystem_c.dylib) [0x7fff8fbe8d2f]
                  24 __read_nocancel + 10 (libsystem_kernel.dylib) [0x7fff98c15282]
                                 *24 ??? (mach_kernel + 3364406) [0xffffff8000535636]
  Thread 0x5c7ca    priority 31
        24 ??? (securityd + 61813) [0x10385d175]
  Binary Images:
         0x10384e000 -        0x103958fff  securityd  /usr/sbin/securityd
      0x7fff8dc03000 -     0x7fff8dc16ff7  libbsm.0.dylib  /usr/lib/libbsm.0.dylib
Process:         SleepServicesD [73]
Path:            /System/Library/CoreServices/SleepServicesD
Parent:          launchd [1]
UID:             0
  Thread 0x24c      DispatchQueue 1          priority 31
    24 ??? (SleepServicesD + 3974) [0x10ba77f86]
      24 -[NSRunLoop(NSRunLoop) run] + 74 (Foundation) [0x7fff9613d1aa]
        24 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 268 (Foundation) [0x7fff961a47ee]
  Thread 0x26d      DispatchQueue 2          priority 33
  Binary Images:
         0x10ba77000 -        0x10ba7efff  SleepServicesD  /System/Library/CoreServices/SleepServicesD
      0x7fff96109000 -     0x7fff96468fff  com.apple.Foundation 6.8 (945.18) <1D7E58E6-FA3A-3CE8-AC85-B9D06B8C0AA0> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
Process:         spindump [9516]
Path:            /usr/sbin/spindump
Parent:          launchd [1]
UID:             0
Sudden Term:     Dirty
Task size:       799 pages (+270)
CPU Time:        0.136s
  Thread 0x5c9a1    DispatchQueue 1          priority 31
    24 ??? (spindump + 6841) [0x10953cab9]
  Thread 0x5c9a4    DispatchQueue 2          priority 33         cpu time   0.002s
     *20 hndl_unix_scall64 + 19 (mach_kernel) [0xffffff80002ce9c3]
       *20 unix_syscall64 + 522 (mach_kernel) [0xffffff80005e16aa]
         *20 kevent + 52 (mach_kernel) [0xffffff800054e414]
           *20 ??? (mach_kernel + 3467355) [0xffffff800054e85b]
             *20 kqueue_scan + 187 (mach_kernel) [0xffffff800054f22b]
               *20 thread_block_reason + 275 (mach_kernel) [0xffffff800022db73]
                 *20 ??? (mach_kernel + 187905) [0xffffff800022de01]
                   *20 processor_idle + 237 (mach_kernel) [0xffffff800022f34d]
                     *20 machine_idle + 443 (mach_kernel) [0xffffff80002b9c9b]
     *4  ??? (mach_kernel + 3471808) [0xffffff800054f9c0]
  Thread 0x5c9a6    DispatchQueue 15         priority 31         cpu time   0.128s
    24 _pthread_wqthread + 404 (libsystem_c.dylib) [0x7fff8fb7ed0b]
      24 _dispatch_worker_thread2 + 249 (libdispatch.dylib) [0x7fff9089a1c3]
        24 _dispatch_queue_invoke + 52 (libdispatch.dylib) [0x7fff9089a2f1]
          24 _dispatch_queue_drain + 180 (libdispatch.dylib) [0x7fff9089a448]
            24 _dispatch_queue_invoke + 72 (libdispatch.dylib) [0x7fff9089a305]
              24 _dispatch_source_invoke + 691 (libdispatch.dylib) [0x7fff9089b29b]
                24 _dispatch_client_callout + 8 (libdispatch.dylib) [0x7fff908990b6]
                       *24 stack_snapshot2 + 169 (mach_kernel) [0xffffff800053dbd9]
  Thread 0x5c9a5    priority 31         cpu time   0.002s
    24 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8fb7ed13]
      24 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff98c156d6]
       *24 ??? (mach_kernel + 3910896) [0xffffff80005bacf0]
  Thread 0x5c9a7    priority 31         cpu time   0.002s
       *23 ??? (mach_kernel + 3910896) [0xffffff80005bacf0]
  Thread 0x5c9b3    priority   23 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8fb691d1]
    23 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8fb7ed13]
      23 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff98c156d6]
  Thread 0x5c9b4    priority 31
  Thread 0x5c9b5    priority 31
  Thread 0x5c9b6    priority 31
  Thread 0x5c9b7    priority 31
  Thread 0x5c9b8    priority 31
  Thread 0x5c9ba    priority 31
  Thread 0x5c9bb    priority 31
  Thread 0x5c9bc    priority 31
  Thread 0x5c9bd    priority 31
  Thread 0x5c9be    priority 31
  Thread 0x5c9bf    priority 31
  Thread 0x5c9c0    priority 31
  Thread 0x5c9c1    priority 31
  Thread 0x5c9c2    priority 31
  Thread 0x5c9b3    DispatchQueue 30         priority 33
    1 _pthread_wqthread + 404 (libsystem_c.dylib) [0x7fff8fb7ed0b]
      1 _dispatch_worker_thread2 + 249 (libdispatch.dylib) [0x7fff9089a1c3]
        1 _dispatch_queue_invoke + 52 (libdispatch.dylib) [0x7fff9089a2f1]
          1 _dispatch_queue_drain + 235 (libdispatch.dylib) [0x7fff9089a47f]
            1 _dispatch_client_callout + 8 (libdispatch.dylib) [0x7fff908990b6]
              1 _dispatch_call_block_and_release + 15 (libdispatch.dylib) [0x7fff9089cf01]
                1 ??? (spindump + 55200) [0x1095487a0]
                  1 ??? (spindump + 21318) [0x109540346]
                    1 ??? (spindump + 16084) [0x10953eed4]
                      1 _dispatch_barrier_sync_f_invoke + 39 (libdispatch.dylib) [0x7fff9089a723]
                          1 ??? (spindump + 14871) [0x10953ea17]
                            1 dispatch_once_f + 50 (libdispatch.dylib) [0x7fff90899041]
                                1 ??? (spindump + 61819) [0x10954a17b]
                                  1 __system_launchdJobCopyDictionary + 143 (ServiceManagement) [0x7fff969d6c15]
                                    1 launchdadd_msg_launchd_request + 165 (ServiceManagement) [0x7fff969d196c]
  Binary Images:
         0x10953b000 -        0x109556fff  spindump  /usr/sbin/spindump
      0x7fff969d0000 -     0x7fff969dbff7  com.apple.bsd.ServiceManagement 2.0 (2.0)  /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
Process:         spindump_agent [9517]
Path:            /usr/libexec/spindump_agent
UID:             501
Sudden Term:     Clean
Task size:       505 pages (+18)
  Thread 0x5c9a9    priority 31
  11 start + 1 (libdyld.dylib) [0x7fff975d97e1]
    11 ??? (spindump_agent + 8236) [0x10542402c]
      11 dispatch_main + 45 (libdispatch.dylib) [0x7fff90898c26]
        11 pthread_exit + 30 (libsystem_c.dylib) [0x7fff8fb7dd61]
          11 _pthread_exit + 146 (libsystem_c.dylib) [0x7fff8fb7ca02]
            11 _pthread_tsd_cleanup + 240 (libsystem_c.dylib) [0x7fff8fb8355e]
              11 _dispatch_queue_cleanup2 + 85 (libdispatch.dylib) [0x7fff90898c9a]
                11 sleep$NOCANCEL + 61 (libsystem_c.dylib) [0x7fff8fbd1e52]
                  11 __semwait_signal_nocancel + 10 (libsystem_kernel.dylib) [0x7fff98c1539a]
                   *11 semaphore_wait_continue + 0 (mach_kernel) [0xffffff8000234040]
  Thread 0x5c9ad    DispatchQueue 2          priority 33
  Thread 0x5c9ac    DispatchQueue 7          priority 31
  Thread 0x5c9ae    priority 31
  Thread 0x5c9af    priority 31
  Thread 0x5c9b0    priority   24 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8fb691d1]
  Thread 0x5c9b1    priority 33
  Thread 0x5c9b2    priority 31
  Binary Images:
         0x105422000 -        0x105424ff7  spindump_agent  /usr/libexec/spindump_agent
Process:         spindump_symbolicator [9518]
Path:            /usr/libexec/spindump_symbolicator
Parent:          launchd [1]
UID:             0
Sudden Term:     Clean
Task size:       531 pages (+40)
CPU Time:        0.001s
  Thread 0x5c9b9    priority 31
  10 start + 1 (libdyld.dylib) [0x7fff975d97e1]
    10 ??? (spindump_symbolicator + 5078) [0x10b1a13d6]
      10 dispatch_main + 45 (libdispatch.dylib) [0x7fff90898c26]
        10 pthread_exit + 30 (libsystem_c.dylib) [0x7fff8fb7dd61]
          10 _pthread_exit + 146 (libsystem_c.dylib) [0x7fff8fb7ca02]
            10 _pthread_tsd_cleanup + 240 (libsystem_c.dylib) [0x7fff8fb8355e]
              10 _dispatch_queue_cleanup2 + 85 (libdispatch.dylib) [0x7fff90898c9a]
                10 sleep$NOCANCEL + 61 (libsystem_c.dylib) [0x7fff8fbd1e52]
                  10 __semwait_signal_nocancel + 10 (libsystem_kernel.dylib) [0x7fff98c1539a]
                   *10 semaphore_wait_continue + 0 (mach_kernel) [0xffffff8000234040]
  Thread 0x5c9c3    DispatchQueue 2          priority 33
  23 _dispatch_mgr_thread + 54 (libdispatch.dylib) [0x7fff9089b9ee]
    23 kevent + 10 (libsystem_kernel.dylib) [0x7fff98c15d16]
  Thread 0x5c9c5    DispatchQueue 7          priority 31
  23 _dispatch_sig_thread + 45 (libdispatch.dylib) [0x7fff90898d85]
    23 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib) [0x7fff98c15566]
  Thread 0x5c9c4    priority  cpu time   0.001s
  Thread 0x5c9cf    priority 31
  Thread 0x5c9d0    priority 31
  Thread 0x5c9c7    priority 31
  2 thread_start + 13 (libsystem_c.dylib) [0x7fff8fb691e1]
    2 _pthread_start + 327 (libsystem_c.dylib) [0x7fff8fb7c7a2]
      2 ??? (CoreSymbolication + 90968) [0x7fff978a2358]
        2 __semwait_signal + 10 (libsystem_kernel.dylib) [0x7fff98c15386]
         *2 semaphore_wait_continue + 0 (mach_kernel) [0xffffff8000234040]
  Binary Images:
         0x10b1a0000 -        0x10b1a1fff  spindump_symbolicator <11F50D3A-94EF-3D25-B98D-903F2592CFF5> /usr/libexec/spindump_symbolicator
      0x7fff9788c000 -     0x7fff97927fff  com.apple.CoreSymbolication 3.0 (117)  /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
Process:         stackshot [72]
Path:            /usr/libexec/stackshot
Parent:          launchd [1]
UID:             0
Sudden Term:     Clean
Task size:       388 pages
  Thread 0x24b      DispatchQueue 1          priority 31
    24 ??? (stackshot + 5915) [0x1013cf71b]
  Thread 0x287      DispatchQueue 2          priority 33
  Thread 0x2b0      priority 31
      24 ??? (stackshot + 10344) [0x1013d0868]
        24 __sigwait + 10 (libsystem_kernel.dylib) [0x7fff98c1557a]
             *24 __sigwait_nocancel + 362 (mach_kernel) [0xffffff8000566b0a]
  Binary Images:
         0x1013ce000 -        0x1013d1fff  stackshot <3934B7F8-4AE5-39ED-AE78-3B2D3A075247> /usr/libexec/stackshot
Process:         syslogd [24]
Path:            /usr/sbin/syslogd
Parent:          launchd [1]
UID:             0
Sudden Term:     Dirty
Task size:       453 pages
  Thread 0x139      DispatchQueue 2          priority 33
    24 __select_nocancel + 10 (libsystem_kernel.dylib) [0x7fff98c15336]
  Thread 0x13c      DispatchQueue 6          priority 31
          24 _dispatch_call_block_and_release + 15 (libdispatch.dylib) [0x7fff9089cf01]
            24 ??? (syslogd + 50962) [0x10c8e9712]
              24 _vprocmgr_log_drain + 70 (liblaunch.dylib) [0x7fff8eaff598]
                24 ??? (liblaunch.dylib + 18464) [0x7fff8eafd820]
  Thread 0x13d      DispatchQueue 6          priority 31
            24 ??? (syslogd + 34838) [0x10c8e5816]
  Thread 0x13e      DispatchQueue 7          priority 31
  Thread 0x5c9a0    priority 31
  Thread 0x5c9a2    priority 31
  Thread 0x5c9a3    priority 31
  Binary Images:
         0x10c8dd000 -        0x10c8f1ff7  syslogd <94DBAC39-B93D-3479-BAD5-A354E78B4EC5> /usr/sbin/syslogd
      0x7fff8eaf9000 -     0x7fff8eb01fff  liblaunch.dylib <2F71CAF8-6524-329E-AC56-C506658B4C0C> /usr/lib/system/liblaunch.dylib
Process:         syspolicyd [5160]
Path:            /usr/libexec/syspolicyd
Parent:          launchd [1]
UID:             0
Task size:       1153 pages
  Thread 0x330cc    DispatchQueue 7          priority 31
  Thread 0x330ce    DispatchQueue 2          priority 33
  Binary Images:
         0x10d792000 -        0x10d794ff7  syspolicyd  /usr/libexec/syspolicyd
Process:         SystemStarter [70]
Path:            /sbin/SystemStarter
Parent:          launchd [1]
UID:             0
Task size:       331 pages
  Thread 0x249      DispatchQueue 1          priority 31
  Thread 0x3f1      DispatchQueue 2          priority 33
  Binary Images:
         0x1010fc000 -        0x101100fff  SystemStarter <09E47B62-8243-3622-849D-9370F5AD0A56> /sbin/SystemStarter
Process:         SystemUIServer [9290]
Path:            /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
UID:             501
Sudden Term:     Clean
Task size:       7361 pages
  Thread 0x5b463    DispatchQueue 1          priority 47
    24 ??? (SystemUIServer + 83202) [0x1015d8502]
      24 -[NSApplication run] + 517 (AppKit) [0x7fff8de361a3]
        24 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128 (AppKit) [0x7fff8de3edf2]
          24 _DPSNextEvent + 685 (AppKit) [0x7fff8de3f533]
            24 BlockUntilNextEventMatchingListInMode + 62 (HIToolbox) [0x7fff95cd4ae3]
              24 ReceiveNextEventCommon + 356 (HIToolbox) [0x7fff95cd4c52]
                24 RunCurrentEventLoopInMode + 209 (HIToolbox) [0x7fff95cd4eb4]
  Thread 0x5b475    DispatchQueue 2          priority 49
  Thread 0x5b81b    priority 47
  Binary Images:
         0x1015c4000 -        0x10161eff7  com.apple.systemuiserver 1.7 (369.2) <29E36EAF-F4BB-361E-9872-88278B609075> /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
      0x7fff95c75000 -     0x7fff95fa5fff  com.apple.HIToolbox 2.0 <656D08C2-9068-3532-ABDD-32EC5057CCB2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
Process:         TabletDriver [9361]
Path:            /Library/Application Support/Tablet/WacomTabletDriver.app/Contents/Resources/TabletDriver.app/Contents/MacOS/TabletDriver
UID:             501
Task size:       1870 pages
Process:         talagent [9288]
Path:            /System/Library/CoreServices/talagent
UID:             501
Sudden Term:     Clean
Task size:       4544 pages
  Thread 0x5b45f    DispatchQueue 1          priority 47
    24 ??? (talagent + 8652) [0x101b781cc]
      24 ??? (talagent + 32130) [0x101b7dd82]
  Thread 0x5b46a    DispatchQueue 2          priority 49
  Binary Images:
         0x101b76000 -        0x101ba1ff7  talagent <43504756-26E6-3C6E-BCBD-D9130ABF7DAB> /System/Library/CoreServices/talagent
Process:         taskgated [8606]
Path:            /usr/libexec/taskgated
Parent:          launchd [1]
UID:             0
Task size:       1557 pages
  Thread 0x57886    DispatchQueue 1          priority 31
    24 ??? (taskgated + 7011) [0x106519b63]
      24 ??? (taskgated + 26722) [0x10651e862]
        24 ??? (taskgated + 27379) [0x10651eaf3]
  Thread 0x5788d    DispatchQueue 2          priority 33
  Thread 0x58b42    priority 31
      24 ??? (taskgated + 31885) [0x10651fc8d]
        24 ??? (taskgated + 28633) [0x10651efd9]
  Thread 0x59c73    priority 31
  Thread 0x5b55e    priority 31
  Binary Images:
         0x106518000 -        0x106527ff7  taskgated <52F68683-D580-3266-8EB0-FE12A1C547DD> /usr/libexec/taskgated
Process:         tccd [213]
Path:            /System/Library/PrivateFrameworks/TCC.framework/Resources/tccd
UID:             501
Task size:       1618 pages
  Thread 0x513      DispatchQueue 7          priority 31
  Thread 0x515      DispatchQueue 2          priority 33
  Binary Images:
         0x10c4b3000 -        0x10c4bafff  tccd <2CD13C97-6B64-3026-BFB7-03B28BDB503B> /System/Library/PrivateFrameworks/TCC.framework/Resources/tccd
Process:         tccd [8737]
Parent:          launchd [8671]
UID:             504
Task size:       1337 pages
  Thread 0x5858b    DispatchQueue 7          priority 31
  Thread 0x5858c    DispatchQueue 2          priority 33
  Binary Images:
         0x1024ca000 -        0x1024d1fff  tccd <2CD13C97-6B64-3026-BFB7-03B28BDB503B> /System/Library/PrivateFrameworks/TCC.framework/Resources/tccd
Process:         TotalFinder [9347]
Path:            /Applications/TotalFinder.app/Contents/MacOS/TotalFinder
UID:             501
Task size:       2008 pages
Process:         usbmuxd [68]
Path:            /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd
Parent:          launchd [1]
UID:             213
Sudden Term:     Clean
Task size:       928 pages
  Thread 0x247      DispatchQueue 1          priority 31
  24 ??? (usbmuxd + 5928) [0x100001728]
    24 ??? (usbmuxd + 8907) [0x1000022cb]
  Thread 0x2d8      DispatchQueue 2          priority 33
  Thread 0x2e7      priority 31
  Binary Images:
         0x100000000 -        0x100014fff  usbmuxd <1EC5A7D9-80E9-39EF-B31E-FCD52F088DE0> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd
Process:         UserEventAgent [14]
Path:            /usr/libexec/UserEventAgent
Parent:          launchd [1]
UID:             0
Sudden Term:     Clean
Task size:       1243 pages (+3)
  Thread 0x113      DispatchQueue 1          priority 31
    24 ??? (UserEventAgent + 5198) [0x103f3344e]
  Thread 0x188      DispatchQueue 2          priority 33
  Thread 0x18a      priority 31
      24 captived_thread + 1061 (CaptiveSystemAgent) [0x10528847e]
  Thread 0x5c9cc    priority 31
  15 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8fb691d1]
    15 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8fb7ed13]
      15 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff98c156d6]
       *15 ??? (mach_kernel + 3910896) [0xffffff80005bacf0]
  Binary Images:
         0x103f32000 -        0x103f34ff7  UserEventAgent  /usr/libexec/UserEventAgent
         0x105285000 -        0x1052a3fff  com.apple.CaptiveSystemAgent 12.0 (1.11) <29FA455E-E356-3F22-8314-5384ABE7CC34> /System/Library/UserEventPlugins/CaptiveSystemAgent.plugin/Contents/MacOS/CaptiveSystemAgent
Process:         UserEventAgent [9282]
UID:             501
Sudden Term:     Clean
Task size:       2497 pages
  Thread 0x5b438    DispatchQueue 1          priority 46
    24 ??? (UserEventAgent + 5198) [0x10200a44e]
  Thread 0x5b455    DispatchQueue 2          priority 48
  Thread 0x5b96a    priority 46
      24 executeRunloopThread + 103 (com.apple.universalaccess.events) [0x1041f491e]
  Thread 0x5c904    priority   24 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8fb691d1]
  Thread 0x5c96e    priority 48
  Binary Images:
         0x102009000 -        0x10200bff7  UserEventAgent  /usr/libexec/UserEventAgent
         0x1041f3000 -        0x1041f5fff  com.apple.universalaccess.events 1.0 (143.7.2) <2D199F46-94B9-3447-8CF9-C006E46607F8> /System/Library/UserEventPlugins/com.apple.universalaccess.events.plugin/Contents/MacOS/com.apple.universalaccess.events
Process:         usernoted [9299]
Path:            /usr/sbin/usernoted
UID:             501
Task size:       1411 pages
  Thread 0x5b4c6    DispatchQueue 1          priority 4
  24 ??? (usernoted + 7284) [0x107af0c74]
    24 ??? (usernoted + 7573) [0x107af0d95]
  Thread 0x5b579    DispatchQueue 2          priority 4
  Binary Images:
         0x107aef000 -        0x107b1bff7  usernoted  /usr/sbin/usernoted
Process:         vpnagentd [103]
Path:            /opt/cisco/*/vpnagentd
Architecture:    i386
Parent:          launchd [1]
UID:             0
Task size:       1024 pages
Process:         WacomTabletDriver [9315]
Path:            /Library/Application Support/Tablet/WacomTabletDriver.app/Contents/MacOS/WacomTabletDriver
UID:             501
Task size:       9260 pages
Process:         WacomTouchDriver [9356]
Path:            /Library/Application Support/Tablet/WacomTabletDriver.app/Contents/Resources/WacomTouchDriver.app/Contents/MacOS/WacomTouchDriver
UID:             501
Task size:       3157 pages
Process:         warmd [67]
Path:            /usr/libexec/warmd
Parent:          launchd [1]
UID:             -2
Sudden Term:     Clean
Task size:       2617 pages
  Thread 0x2ed      DispatchQueue 2          priority 23
  Thread 0x303      DispatchQueue 7          priority 21
  Thread 0x304      priority 21
  Thread 0x5c999    priority 21
  Binary Images:
         0x10d597000 -        0x10d5aefff  warmd <572DD12B-86F1-39AA-9F72-2ED56AEC4450> /usr/libexec/warmd
Process:         wdhelper [66]
Path:            /usr/libexec/wdhelper
Parent:          launchd [1]
UID:             0
Task size:       1162 pages
  Thread 0x245      DispatchQueue 1          priority 31
    24 ??? (wdhelper + 5756) [0x10485b67c]
  Thread 0x295      DispatchQueue 2          priority 33
  Binary Images:
         0x10485a000 -        0x10489fff7  wdhelper  /usr/libexec/wdhelper
Process:         WindowServer [9260]
Path:            /System/Library/Frameworks/ApplicationServices.framework/Frameworks/CoreGraphics.framework/Resources/WindowServer
Parent:          launchd [1]
UID:             88
Task size:       22968 pages (+212)
CPU Time:        0.129s
  Thread 0x5b315    DispatchQueue 1          priority 63         cpu time   0.129s
    24 main + 9 (WindowServer) [0x105338f41]
      24 CGXServer + 1000 (CoreGraphics) [0x7fff96b85722]
        16 CGXRunOneServicesPass + 653 (CoreGraphics) [0x7fff96b85129]
          16 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff98c13686]
           *16 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
        5  CGXRunOneServicesPass + 609 (CoreGraphics) [0x7fff96b850fd]
          5  mach_msg_overwrite_trap + 10 (libsystem_kernel.dylib) [0x7fff98c13692]
           *3  hndl_mach_scall64 + 19 (mach_kernel) [0xffffff80002ce9e3]
             *3  ??? (mach_kernel + 681270) [0xffffff80002a6536]
               *3  mach_msg_overwrite_trap + 427 (mach_kernel) [0xffffff800021970b]
                 *3  ipc_mqueue_receive + 59 (mach_kernel) [0xffffff800021310b]
                   *3  thread_block_reason + 275 (mach_kernel) [0xffffff800022db73]
                     *3  ??? (mach_kernel + 187905) [0xffffff800022de01]
                       *3  processor_idle + 237 (mach_kernel) [0xffffff800022f34d]
                         *3  machine_idle + 443 (mach_kernel) [0xffffff80002b9c9b]
           *2  ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
        3  CGXRunOneServicesPass + 198 (CoreGraphics) [0x7fff96b84f62]
          3  run_timer_pass + 381 (CoreGraphics) [0x7fff96cb273f]
            3  CGXUpdateDisplay + 7189 (CoreGraphics) [0x7fff96b76e84]
              3  CGXReleaseDisplayDeviceSurface + 353 (CoreGraphics) [0x7fff96f6e20c]
                3  MPFinishSurfaceForDisplayDevice + 190 (CoreGraphics) [0x7fff96d3662a]
                  3  IOAccelFlushSurfaceOnFramebuffers + 95 (IOKit) [0x7fff958ecf4f]
                    3  IOConnectCallMethod + 174 (IOKit) [0x7fff958e3592]
                      3  io_connect_method + 380 (IOKit) [0x7fff9592ffcf]
                             *3  mach_msg_overwrite_trap + 187 (mach_kernel) [0xffffff800021961b]
                               *3  ipc_kmsg_send + 104 (mach_kernel) [0xffffff8000210448]
                                 *3  ipc_kobject_server + 317 (mach_kernel) [0xffffff8000220b3d]
                                   *3  ??? (mach_kernel + 625665) [0xffffff8000298c01]
                                     *3  is_io_connect_method + 415 (mach_kernel) [0xffffff8000665e2f]
                                       *3  IOUserClient::externalMethod(unsigned int, IOExternalMethodArguments*, IOExternalMethodDispatch*, OSObject*, void*) + 739 (mach_kernel) [0xffffff80006683f3]
                                         *3  shim_io_connect_method_scalarI_scalarO + 451 (mach_kernel) [0xffffff8000666363]
                                           *3  IONVSurfaceTesla::surface_flush(unsigned int, unsigned int) + 338 (GeForce) [0xffffff7f8168794a]
                                             *3  NVKernel::wait_for_time_stamp(unsigned int, bool, bool) + 53 (GeForce) [0xffffff7f81693037]
                                               *3  nvChannelTesla::WaitForTimeStamp(unsigned int, unsigned long long*) + 200 (GeForce) [0xffffff7f816a3f60]
  Thread 0x5b316    DispatchQueue 2          priority 33
  Thread 0x5b31b    priority 63
      24 eventThread + 379 (CoreGraphics) [0x7fff96cb9fe3]
  Thread 0x5b498    priority 55
      24 thread_fun + 25 (QuartzCore) [0x7fff930e9dc6]
        24 CA::Render::Server::server_thread(void*) + 403 (QuartzCore) [0x7fff9306517b]
  Binary Images:
         0x105338000 -        0x105338fff  WindowServer <784F82E2-48EC-3635-8CBE-DF3E76D774A0> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/CoreGraphics.framework/Resources/WindowServer
      0x7fff92fa8000 -     0x7fff93156fff  com.apple.QuartzCore 1.8 (304.3)  /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
 *0xffffff7f8166b000 - 0xffffff7f81701fff  com.apple.GeForce 8.12.47 (8.1.2) <7EC545A4-4B57-32F1-8DC3-C31023AFBDCB> /System/Library/Extensions/GeForce.kext/Contents/MacOS/GeForce
Process:         xpcd [8678]
Path:            /usr/libexec/xpcd
Parent:          launchd [1]
UID:             504
Task size:       1456 pages
  Thread 0x581ab    DispatchQueue 7          priority 31
  Thread 0x581ac    DispatchQueue 2          priority 33
  Binary Images:
         0x10123f000 -        0x101246ff7  xpcd  /usr/libexec/xpcd
Process:         xpcd [9018]
Parent:          launchd [1]
UID:             501
Task size:       1330 pages
  Thread 0x59d82    DispatchQueue 7          priority 31
  Thread 0x59d83    DispatchQueue 2          priority 33
  Binary Images:
         0x106ff4000 -        0x106ffbff7  xpcd  /usr/libexec/xpcd
Process:         kernel_task [0]
Path:            kernel_task
UID:             0
Version:         Darwin Kernel Version 12.4.0: Wed May  1 17:57:12 PDT 2013; root:xnu-2050.24.15~1/RELEASE_X86_64
Task size:       259401 pages (+17)
CPU Time:        17.682s
  Thread 0x1        priority 92
 *24 vm_pageout_continue + 0 (mach_kernel) [0xffffff800027f4a0]
  Thread 0x2        priority 0          cpu time   2.189s
 *24 idle_thread + 0 (mach_kernel) [0xffffff800022f5e0]
  Thread 0x3        priority 95
 *20 ??? (mach_kernel + 175152) [0xffffff800022ac30]
 *4  call_continuation + 23 (mach_kernel) [0xffffff80002b3137]
  Thread 0x4        priority 80
 *24 ??? (mach_kernel + 238800) [0xffffff800023a4d0]
  Thread 0x5        priority 93
 *24 ??? (mach_kernel + 239440) [0xffffff800023a750]
  Thread 0x6        priority 94
 *24 ??? (mach_kernel + 253904) [0xffffff800023dfd0]
  Thread 0x7        priority 95
 *24 call_continuation + 23 (mach_kernel) [0xffffff80002b3137]
   *24 mapping_replenish + 257 (mach_kernel) [0xffffff80002a50c1]
  Thread 0x8        priority 95
   *24 ??? (mach_kernel + 274194) [0xffffff8000242f12]
  Thread 0x9        priority 81
 *24 IOWorkLoop::threadMain() + 0 (mach_kernel) [0xffffff8000647150]
  Thread 0xb        priority 81
  Thread 0xd        priority 81
  Thread 0x1c       priority 81
  Thread 0x1e       priority 81
   *24 AppleIntelCPUPowerManagement::free() + 21173 (AppleIntelCPUPowerManagement) [0xffffff7f81da7391]
  Thread 0x21       priority 0          cpu time   2.236s
  Thread 0x24       priority 0          cpu time   2.134s
  Thread 0x27       priority 0          cpu time   2.195s
  Thread 0x2a       priority 0          cpu time   2.236s
  Thread 0x2d       priority 0          cpu time   2.237s
  Thread 0x30       priority 0          cpu time   2.227s
  Thread 0x33       priority 0          cpu time   2.207s
  Thread 0x38       priority 81
  Thread 0x7a       priority 81
 *24 ??? (mach_kernel + 974416) [0xffffff80002ede50]
  Thread 0x7e       priority 81
 *24 ??? (mach_kernel + 3737856) [0xffffff8000590900]
  Thread 0x80       priority 81
 *24 ??? (mach_kernel + 3375520) [0xffffff80005381a0]
  Thread 0x81       priority 81
 *24 ??? (mach_kernel + 3407168) [0xffffff800053fd40]
  Thread 0x82       priority 81
  Thread 0x83       priority 81
  Thread 0x84       priority 81
  Thread 0x85       priority 81
  Thread 0x86       priority 81
   *24 ??? (mach_kernel + 1308749) [0xffffff800033f84d]
  Thread 0x87       priority 81
  Thread 0x88       priority 81
  Thread 0x89       priority 81
 *24 ??? (mach_kernel + 3598944) [0xffffff800056ea60]
  Thread 0x90       priority 81         cpu time   0.001s
 *23 IOWorkLoop::threadMain() + 0 (mach_kernel) [0xffffff8000647150]
 *1  call_continuation + 23 (mach_kernel) [0xffffff80002b3137]
   *1  IOWorkLoop::threadMain() + 93 (mach_kernel) [0xffffff80006471ad]
     *1  thread_block_reason + 275 (mach_kernel) [0xffffff800022db73]
       *1  ??? (mach_kernel + 187905) [0xffffff800022de01]
         *1  processor_idle + 237 (mach_kernel) [0xffffff800022f34d]
           *1  machine_idle + 443 (mach_kernel) [0xffffff80002b9c9b]
  Thread 0x95       priority 81
 *24 sockwall_gc_thread + 0 (ALF) [0xffffff7f82098b71]
  Thread 0x99       priority 81
  Thread 0x9a       priority 81
  Thread 0x9b       priority 81
  Thread 0x9c       priority 81
  Thread 0xa1       priority 82
  Thread 0xa3       priority 82
  Thread 0xa4       priority 81
  Thread 0xa7       priority 81
  Thread 0xa9       priority 81
  Thread 0xaa       priority 81
  Thread 0xae       priority 81
  Thread 0xb1       priority 81
  Thread 0xb2       priority 97
  Thread 0xb3       priority 97
  Thread 0xd0       priority 81
   *24 ??? (mach_kernel + 3941996) [0xffffff80005c266c]
     *24 mach_msg_receive + 163 (mach_kernel) [0xffffff8000219503]
       *24 ipc_mqueue_receive + 66 (mach_kernel) [0xffffff8000213112]
  Thread 0xd1       priority 92
 *24 ??? (mach_kernel + 548864) [0xffffff8000286000]
  Thread 0xd2       priority 31
 *24 ??? (mach_kernel + 520960) [0xffffff800027f300]
  Thread 0xd3       priority 31
 *24 ??? (mach_kernel + 521120) [0xffffff800027f3a0]
  Thread 0xd4       priority 92
 *24 ??? (mach_kernel + 480672) [0xffffff80002755a0]
  Thread 0xfb       priority 81
   *24 ??? (mach_kernel + 3876970) [0xffffff80005b286a]
  Thread 0x10e      priority 81
  Thread 0x112      priority 81
  Thread 0x152      priority 81
   *24 ??? (mach_kernel + 1311581) [0xffffff800034035d]
  Thread 0x154      priority 81
  Thread 0x158      priority 81
  Thread 0x1a1      priority 81
  Thread 0x1a2      priority 81
  Thread 0x1a7      priority 81
  Thread 0x1aa      priority 81
  Thread 0x1ab      priority 81
  Thread 0x1ac      priority 81
  Thread 0x1af      priority 81
  Thread 0x1b0      priority 81
  Thread 0x1b2      priority 81         cpu time   0.002s
 *18 IOWorkLoop::threadMain() + 0 (mach_kernel) [0xffffff8000647150]
 *6  call_continuation + 23 (mach_kernel) [0xffffff80002b3137]
   *6  IOWorkLoop::threadMain() + 93 (mach_kernel) [0xffffff80006471ad]
     *6  thread_block_reason + 275 (mach_kernel) [0xffffff800022db73]
       *6  ??? (mach_kernel + 187905) [0xffffff800022de01]
         *6  processor_idle + 237 (mach_kernel) [0xffffff800022f34d]
           *6  machine_idle + 443 (mach_kernel) [0xffffff80002b9c9b]
  Thread 0x232      priority 81
  Thread 0x23e      priority 81
  Thread 0x27d      priority 92
  Thread 0x311      priority 81
  Thread 0x323      priority 81         cpu time   0.004s
  Thread 0x42c      priority 97
   *24 rtThreadNativeMain(void*, int) + 33 (VBoxDrv) [0xffffff7f820d0721]
     *24 rtThreadMain + 47 (VBoxDrv) [0xffffff7f820cc4df]
       *24 rtTimerThread(RTTHREADINT*, void*) + 62 (VBoxDrv) [0xffffff7f820cc90e]
         *24 rtR0SemEventDarwinWait(RTSEMEVENTINTERNAL*, unsigned int, unsigned long long, RTLOCKVALSRCPOS const*) + 516 (VBoxDrv) [0xffffff7f820cf394]
           *24 lck_spin_sleep + 78 (mach_kernel) [0xffffff800022653e]
  Thread 0x9ef      priority 81
  Thread 0x39654    priority 93         cpu time   0.002s
 *22 ??? (mach_kernel + 254368) [0xffffff800023e1a0]
 *2  call_continuation + 23 (mach_kernel) [0xffffff80002b3137]
   *2  ??? (mach_kernel + 255385) [0xffffff800023e599]
     *2  thread_block_reason + 275 (mach_kernel) [0xffffff800022db73]
       *2  ??? (mach_kernel + 187905) [0xffffff800022de01]
         *2  processor_idle + 237 (mach_kernel) [0xffffff800022f34d]
           *2  machine_idle + 443 (mach_kernel) [0xffffff80002b9c9b]
  Thread 0x3966f    priority 93         cpu time   0.002s
 *18 ??? (mach_kernel + 254368) [0xffffff800023e1a0]
   *6  ??? (mach_kernel + 255385) [0xffffff800023e599]
  Thread 0x3968f    priority 93         cpu time   0.002s
 *23 ??? (mach_kernel + 254368) [0xffffff800023e1a0]
   *1  ??? (mach_kernel + 255385) [0xffffff800023e599]
  Thread 0x396af    priority 93         cpu time   0.003s
   *5  ??? (mach_kernel + 255385) [0xffffff800023e599]
     *5  thread_block_reason + 275 (mach_kernel) [0xffffff800022db73]
       *5  ??? (mach_kernel + 187905) [0xffffff800022de01]
         *5  processor_idle + 237 (mach_kernel) [0xffffff800022f34d]
           *5  machine_idle + 443 (mach_kernel) [0xffffff80002b9c9b]
   *1  ??? (mach_kernel + 254558) [0xffffff800023e25e]
     *1  IOTimerEventSource::timeoutAndRelease(void*, void*) + 219 (mach_kernel) [0xffffff800064b1ab]
       *1  IOCommandGate::runAction(int (*)(OSObject*, void*, void*, void*, void*), void*, void*, void*, void*) + 378 (mach_kernel) [0xffffff800064907a]
         *1  AppleHDADriver::runPeriodicTasks(OSObject*, void*, void*, void*, void*) + 92 (AppleHDA) [0xffffff7f81efb5d6]
           *1  AppleHDADriver::protectedRunPeriodicTasks() + 744 (AppleHDA) [0xffffff7f81efb8c2]
             *1  AppleHDADriver::runPolledTaskOnFunctionGroup() + 85 (AppleHDA) [0xffffff7f81efbc33]
               *1  AppleHDAWidgetALC885::pollPinSenseTransition(unsigned int*) + 244 (AppleHDA) [0xffffff7f81f3720c]
                 *1  AppleHDAWidget::pollPinSenseTransition(unsigned int*) + 564 (AppleHDA) [0xffffff7f81f2d306]
                   *1  AppleHDAWidget::pinSense(bool*, unsigned int*, bool) + 859 (AppleHDA) [0xffffff7f81f2a5b1]
                     *1  AppleHDAWidget::dispatchDetectAssistantComplete() + 46 (AppleHDA) [0xffffff7f81f2d0ca]
                       *1  AppleHDAWidget::detectAssistantComplete(unsigned int) + 251 (AppleHDA) [0xffffff7f81f2ce89]
                         *1  AppleHDAWidget::getFormatFromIEC60958(unsigned int*) + 79 (AppleHDA) [0xffffff7f81f29a55]
                           *1  IOHDACodecDevice::executeVerb(unsigned short, unsigned short, unsigned short, unsigned int*, bool) + 493 (IOHDAFamily) [0xffffff7f81e0c739]
                             *1  AppleHDAController::executeCodecCommand(IOHDACodecDevice*, unsigned int, unsigned int*) + 106 (AppleHDAController) [0xffffff7f81e24dde]
                               *1  IOWorkLoop::runAction(int (*)(OSObject*, void*, void*, void*, void*), OSObject*, void*, void*, void*, void*) + 65 (mach_kernel) [0xffffff8000647501]
                                 *1  AppleHDAController::handleCodecCommand(CodecCommand*) + 502 (AppleHDAController) [0xffffff7f81e24ffe]
                                   *1  IOEventSource::sleepGate(void*, unsigned long long, unsigned int) + 76 (mach_kernel) [0xffffff8000647c2c]
                                     *1  IOWorkLoop::sleepGate(void*, unsigned long long, unsigned int) + 73 (mach_kernel) [0xffffff8000647469]
                                       *1  IORecursiveLockSleepDeadline + 51 (mach_kernel) [0xffffff8000623f83]
                                         *1  lck_mtx_sleep_deadline + 87 (mach_kernel) [0xffffff80002266e7]
  Binary Images:
 *0xffffff7f81da1000 - 0xffffff7f81dbeff3  com.apple.driver.AppleIntelCPUPowerManagement 196.0.0 (196.0.0) <3EAB23E7-81DF-30FE-905C-7108BAF13F96> /System/Library/Extensions/AppleIntelCPUPowerManagement.kext/Contents/MacOS/AppleIntelCPUPowerManagement
 *0xffffff7f81e0b000 - 0xffffff7f81e0effd  com.apple.iokit.IOHDAFamily 2.3.7 (2.3.7fc4) <42731067-5154-3CA5-8741-8F33B2A3D6EB> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/IOHDAFamily.kext/Contents/MacOS/IOHDAFamily
 *0xffffff7f81e1e000 - 0xffffff7f81e2aff3  com.apple.driver.AppleHDAController 2.3.7 (2.3.7fc4) <1D9DA4E7-F36A-3FD1-B1CB-0342BC75120B> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAController.kext/Contents/MacOS/AppleHDAController
 *0xffffff7f81ef6000 - 0xffffff7f81f56fef  com.apple.driver.AppleHDA 2.3.7 (2.3.7fc4) <5E019BA3-4EC3-36FF-8A66-84961E3D117C> /System/Library/Extensions/AppleHDA.kext/Contents/MacOS/AppleHDA
 *0xffffff7f82093000 - 0xffffff7f82099fff  com.apple.nke.applicationfirewall 4.0.39 (4.0.39) <98AC313B-9E39-3526-B28C-27666C2E1E4A> /System/Library/Extensions/ALF.kext/Contents/MacOS/ALF
 *0xffffff7f820b2000 - 0xffffff7f820d7fff  org.virtualbox.kext.VBoxDrv 4.1.2 (4.1.2) <896E5E50-9B2C-CCA5-04D6-23053585415F> /Library/Extensions/VBoxDrv.kext/Contents/MacOS/VBoxDrv
  Kextstat:
Index Refs Address            Size       Wired      Name (Version)     1   73 0xffffff7f80743000 0x686c     0x686c     com.apple.kpi.bsd (12.4.0)
    2    6 0xffffff7f80737000 0x46c      0x46c      com.apple.kpi.dsep (12.4.0)
    3   91 0xffffff7f8074a000 0x1b7ec    0x1b7ec    com.apple.kpi.iokit (12.4.0)
    4   99 0xffffff7f80739000 0x99f8     0x99f8     com.apple.kpi.libkern (12.4.0)
    5   84 0xffffff7f80738000 0x88c      0x88c      com.apple.kpi.mach (12.4.0)
    6   36 0xffffff7f80769000 0x500c     0x500c     com.apple.kpi.private (12.4.0)
    7   53 0xffffff7f80766000 0x23cc     0x23cc     com.apple.kpi.unsupported (12.4.0)
    8    0 0xffffff7f81874000 0x41000    0x41000    com.apple.kec.corecrypto (1.0) <7 6 5 4 3 1>    9   17 0xffffff7f81347000 0x9000     0x9000     com.apple.iokit.IOACPIFamily (1.4) <7 6 4 3>   10   23 0xffffff7f808d4000 0x25000    0x25000    com.apple.iokit.IOPCIFamily (2.7.3) <7 6 5 4 3>   11    2 0xffffff7f82024000 0x58000    0x58000    com.apple.driver.AppleACPIPlatform (1.7) <10 9 7 6 5 4 3 1>   12    1 0xffffff7f8076f000 0xe000     0xe000     com.apple.driver.AppleKeyStore (28.21) <7 6 5 4 3 1>   13    8 0xffffff7f80800000 0x25000    0x25000    com.apple.iokit.IOStorageFamily (1.8) <7 6 5 4 3 1>   14    0 0xffffff7f813ac000 0x19000    0x19000    com.apple.driver.DiskImages (345) <13 7 6 5 4 3 1>   15    0 0xffffff7f81da1000 0x29000    0x29000    com.apple.driver.AppleIntelCPUPowerManagement (196.0.0) <7 6 5 4 3 1>   16    0 0xffffff7f807fd000 0x3000     0x3000     com.apple.security.TMSafetyNet (7) <7 6 5 4 2 1>   17    2 0xffffff7f80876000 0x4000     0x4000     com.apple.kext.AppleMatch (1.0.0d1) <4 1>   18    1 0xffffff7f8087a000 0x11000    0x11000    com.apple.security.sandbox (220.3) <17 7 6 5 4 3 2 1>   19    0 0xffffff7f8088b000 0x6000     0x6000     com.apple.security.quarantine (2.1) <18 17 7 6 5 4 2 1>   20    0 0xffffff7f82093000 0x8000     0x8000     com.apple.nke.applicationfirewall (4.0.39) <7 6 5 4 3 1>   21    0 0xffffff7f81d9c000 0x3000     0x3000     com.apple.driver.AppleIntelCPUPowerManagementClient (196.0.0) <7 6 5 4 3 1>   22    0 0xffffff7f81ff8000 0x3000     0x3000     com.apple.driver.AppleAPIC (1.6) <4 3>   23    2 0xffffff7f812d8000 0x4000     0x4000     com.apple.iokit.IOSMBusFamily (1.1) <5 4 3>   24    0 0xffffff7f82082000 0x7000     0x7000     com.apple.driver.AppleACPIEC (1.7) <23 11 9 5 4 3>   25    0 0xffffff7f81c9f000 0x4000     0x4000     com.apple.driver.AppleSMBIOS (1.9) <7 4 3>   26    0 0xffffff7f81dd6000 0x3000     0x3000     com.apple.driver.AppleHPET (1.8) <9 7 5 4 3>   27    0 0xffffff7f81ccb000 0x8000     0x8000     com.apple.driver.AppleRTC (1.5) <9 5 4 3 1>   28    1 0xffffff7f81fd3000 0x5000     0x5000     com.apple.driver.AppleEFIRuntime (1.7) <7 6 5 4 3>   29    4 0xffffff7f8077d000 0x6d000    0x6d000    com.apple.iokit.IOHIDFamily (1.8.1) <12 7 6 5 4 3 2 1>   30    0 0xffffff7f8208c000 0x4000     0x4000     com.apple.driver.AppleACPIButtons (1.7) <29 11 9 7 6 5 4 3 1>   31    0 0xffffff7f81fd8000 0x7000     0x7000     com.apple.driver.AppleEFINVRAM (1.7) <28 7 6 5 4 3>   32   11 0xffffff7f810bd000 0x5c000    0x5c000    com.apple.iokit.IOUSBFamily (5.6.0) <10 7 5 4 3 1>   33    0 0xffffff7f81175000 0x10000    0x10000    com.apple.driver.AppleUSBUHCI (5.2.5) <32 10 7 5 4 3 1>   34    0 0xffffff7f811c1000 0x18000    0x18000    com.apple.driver.AppleUSBEHCI (5.5.0) <32 10 7 5 4 3 1>   35    2 0xffffff7f80f70000 0x19000    0x19000    com.apple.iokit.IOATAFamily (2.5.1) <5 4 3 1>   36    0 0xffffff7f81578000 0xa000     0xa000     com.apple.driver.AppleIntelPIIXATA (2.5.1) <35 10 5 4 3>   37    2 0xffffff7f8158a000 0x16000    0x16000    com.apple.iokit.IOAHCIFamily (2.3.1) <5 4 3 1>   38    0 0xffffff7f81ffd000 0x1a000    0x1a000    com.apple.driver.AppleAHCIPort (2.5.2) <37 10 5 4 3 1>   39    3 0xffffff7f8107e000 0x2b000    0x2b000    com.apple.iokit.IONetworkingFamily (3.0) <7 6 5 4 3 1>   40    0 0xffffff7f81394000 0x11000    0x11000    com.apple.driver.AppleIntel8254XEthernet (3.1.1b1) <39 10 5 4 3 1>   41    1 0xffffff7f81139000 0x3000     0x3000     com.apple.iokit.IOUSBUserClient (5.5.5) <32 7 5 4 3 1>   42    0 0xffffff7f818c4000 0x9000     0x9000     com.apple.BootCache (34) <7 6 5 4 3 1>   43    0 0xffffff7f81fc4000 0x4000     0x4000     com.apple.AppleFSCompression.AppleFSCompressionTypeZlib (1.0.0d1) <6 4 3 2 1>   44    2 0xffffff7f80fbf000 0x73000    0x73000    com.apple.iokit.IOFireWireFamily (4.5.5) <5 4 3 1>   45    0 0xffffff7f81407000 0x27000    0x27000    com.apple.driver.AppleFWOHCI (4.9.6) <44 10 7 6 5 4 3 1>   46    0 0xffffff7f81fca000 0x3000     0x3000     com.apple.AppleFSCompression.AppleFSCompressionTypeDataless (1.0.0d1) <7 6 4 3 2 1>   47    0 0xffffff7f811a6000 0x15000    0x15000    com.apple.driver.AppleUSBHub (5.5.5) <32 5 4 3 1>   49    0 0xffffff7f815b0000 0x17000    0x17000    com.apple.iokit.IOAHCIBlockStorage (2.3.1) <37 13 6 5 4 3 1>   50    3 0xffffff7f80892000 0x2b000    0x2b000    com.apple.iokit.IOSCSIArchitectureModelFamily (3.5.5) <5 4 3 1>   51    0 0xffffff7f81556000 0x7000     0x7000     com.apple.iokit.IOATAPIProtocolTransport (3.5.0) <50 35 5 4 3 1>   52    0 0xffffff7f81b6d000 0x3000     0x3000     com.apple.driver.XsanFilter (404) <13 5 4 3 1>   53    0 0xffffff7f812f2000 0x7000     0x7000     com.apple.iokit.SCSITaskUserClient (3.5.5) <50 13 5 4 3 1>   54    3 0xffffff7f812fd000 0xe000     0xe000     com.apple.iokit.IOCDStorageFamily (1.7.1) <13 5 4 3 1>   55    2 0xffffff7f8130e000 0xb000     0xb000     com.apple.iokit.IODVDStorageFamily (1.7.1) <54 13 5 4 3 1>   56    1 0xffffff7f8131c000 0xa000     0xa000     com.apple.iokit.IOBDStorageFamily (1.7) <55 54 13 5 4 3 1>   57    0 0xffffff7f81329000 0x1a000    0x1a000    com.apple.iokit.IOSCSIMultimediaCommandsDevice (3.5.5) <56 55 54 50 13 5 4 3 1>   59    1 0xffffff7f81145000 0x7000     0x7000     com.apple.driver.AppleUSBComposite (5.2.5) <32 4 3 1>   60    0 0xffffff7f8119f000 0x7000     0x7000     com.apple.driver.AppleUSBMergeNub (5.5.5) <59 32 4 3 1>   62    1 0xffffff7f8113c000 0x9000     0x9000     com.apple.iokit.IOUSBHIDDriver (5.2.5) <32 29 5 4 3 1>   63    1 0xffffff7f81dfd000 0x4000     0x4000     com.apple.driver.AppleHIDKeyboard (170.2) <29 4 3>   64    0 0xffffff7f81e01000 0x4000     0x4000     com.apple.driver.AppleUSBHIDKeyboard (170.2) <63 62 29 4 3>   65    0 0xffffff7f81d3e000 0x5000     0x5000     com.apple.driver.AppleMCEDriver (1.1.9) <9 5 4 3>   67   10 0xffffff7f80913000 0x38000    0x38000    com.apple.iokit.IOGraphicsFamily (2.3.7) <10 7 5 4 3>   68    5 0xffffff7f80956000 0x12000    0x12000    com.apple.iokit.IONDRVSupport (2.3.7) <67 10 7 5 4 3>   69    2 0xffffff7f8136e000 0xd000     0xd000     com.apple.driver.AppleSMC (3.1.4d2) <9 7 5 4 3>   70    3 0xffffff7f81350000 0xa000     0xa000     com.apple.driver.IOPlatformPluginFamily (5.3.0d51) <9 7 6 5 4 3>   71    1 0xffffff7f8135a000 0x12000    0x12000    com.apple.driver.IOPlatformPluginLegacy (1.0.0) <70 9 7 6 5 4 3>   72    0 0xffffff7f8137d000 0x10000    0x10000    com.apple.driver.ACPI_SMC_PlatformPlugin (1.0.0) <71 70 69 10 9 7 6 5 4 3>   73    2 0xffffff7f81e0b000 0xc000     0xc000     com.apple.iokit.IOHDAFamily (2.3.7fc4) <5 4 3 1>   74    1 0xffffff7f81e1e000 0x16000    0x16000    com.apple.driver.AppleHDAController (2.3.7fc4) <73 67 10 6 5 4 3 1>   76    1 0xffffff7f81476000 0x28000    0x28000    com.apple.iokit.AppleBluetoothHCIControllerUSBTransport (4.1.4f2) <32 10 9 7 5 4 3 1>   77    0 0xffffff7f8149e000 0x5000     0x5000     com.apple.iokit.CSRBluetoothHCIControllerUSBTransport (4.1.4f2) <76 32 7 5 4 3>   78    1 0xffffff7f81fb0000 0x3000     0x3000     com.apple.driver.AppleGraphicsControl (3.4.5) <68 67 10 9 7 5 4 3 1>   79    0 0xffffff7f81fb3000 0xc000     0xc000     com.apple.driver.ApplePolicyControl (3.4.5) <78 68 67 10 9 7 5 4 3 1>   80    0 0xffffff7f81789000 0x5000     0x5000     com.apple.Dont_Steal_Mac_OS_X (7.0.0) <69 7 4 3 1>   81    0 0xffffff7f81d8d000 0x3000     0x3000     com.apple.driver.AppleLPC (1.6.0) <70 10 5 4 3>   82    2 0xffffff7f8096a000 0x2a6000   0x2a6000   com.apple.NVDAResman (8.1.2) <68 67 10 5 4 3 1>   83    0 0xffffff7f814a6000 0xa4000    0xa4000    com.apple.iokit.IOBluetoothFamily (4.1.4f2) <32 7 5 4 3 1>   84    0 0xffffff7f812c4000 0x12000    0x12000    com.apple.iokit.IOSurface (86.0.4) <7 5 4 3 1>   85    1 0xffffff7f81d45000 0xe000     0xe000     com.apple.driver.AppleSMBusController (1.0.11d0) <23 10 9 5 4 3>   86    0 0xffffff7f81d56000 0xd000     0xd000     com.apple.driver.AppleMCCSControl (1.1.11) <85 67 10 9 7 5 4 3 1>   87    0 0xffffff7f80c1b000 0x2d5000   0x2d5000   com.apple.nvidia.nv50hal (8.1.2) <82 10 4 3>   88    0 0xffffff7f8166b000 0xce000    0xce000    com.apple.GeForce (8.1.2) <82 68 67 10 7 6 5 4 3 1>   89    0 0xffffff7f810b0000 0x7000     0x7000     com.apple.iokit.IOUserEthernet (1.0.0d1) <39 6 5 4 3 1>   90    0 0xffffff7f81bc2000 0x5000     0x5000     com.apple.driver.AppleUpstreamUserClient (3.5.10) <67 10 9 7 5 4 3 1>   91    0 0xffffff7f813f7000 0xe000     0xe000     com.apple.iokit.IOFireWireIP (2.2.5) <44 39 5 4 3 1>   92    2 0xffffff7f80f25000 0x7000     0x7000     com.apple.kext.OSvKernDSPLib (1.6) <5 4>   93    4 0xffffff7f80f2c000 0x32000    0x32000    com.apple.iokit.IOAudioFamily (1.8.9fc11) <92 5 4 3 1>   94    0 0xffffff7f80f66000 0x5000     0x5000     com.logmein.driver.LogMeInSoundDriver (1.0.2) <93 5 4 3>   95    0 0xffffff7f818df000 0x5000     0x5000     com.apple.driver.AudioAUUC (1.60) <93 67 10 9 7 5 4 3 1>   96    1 0xffffff7f81e34000 0xb9000    0xb9000    com.apple.driver.DspFuncLib (2.3.7fc4) <93 92 6 5 4 3 1>   97    0 0xffffff7f81ef6000 0x7d000    0x7d000    com.apple.driver.AppleHDA (2.3.7fc4) <96 93 74 73 68 67 6 5 4 3 1>  100    1 0xffffff7f812e1000 0xe000     0xe000     com.apple.iokit.IOSerialFamily (10.0.6) <7 6 5 4 3 1>  101    0 0xffffff7f81462000 0xa000     0xa000     com.apple.iokit.IOBluetoothSerialManager (4.1.4f2) <100 7 5 4 3 1>  102    0 0xffffff7f820b0000 0x2000     0x2000     com.radiosilenceapp.nke.PrivateEye (1) <4 1>  103    1 0xffffff7f818cf000 0x5000     0x5000     com.apple.kext.triggers (1.0) <7 6 5 4 3 1>  104    0 0xffffff7f818d4000 0x9000     0x9000     com.apple.filesystems.autofs (3.0) <103 7 6 5 4 3 1>  105    0 0xffffff7f81dcd000 0x5000     0x5000     com.apple.driver.AppleHWSensor (1.9.5d0) <5 4 3>  106    3 0xffffff7f820b2000 0x36000    0x36000    org.virtualbox.kext.VBoxDrv (4.1.2) <7 5 4 3 1>  108    0 0xffffff7f820e8000 0x8000     0x8000     org.virtualbox.kext.VBoxUSB (4.1.2) <106 41 32 7 5 4 3 1>  109    0 0xffffff7f820f0000 0x5000     0x5000     org.virtualbox.kext.VBoxNetFlt (4.1.2) <106 7 5 4 3 1>  110    0 0xffffff7f820f5000 0x3000     0x3000     org.virtualbox.kext.VBoxNetAdp (4.1.2) <106 5 4 1>  112    0 0xffffff7f820fa000 0x2000     0x2000     com.nvidia.CUDA (1.1.0) <4 1>  114    0 0xffffff7f820fc000 0xd000     0xd000     com.apple.nke.asp_tcp (7.1.0) <7 6 5 4 3 1>  115    1 0xffffff7f82109000 0x11000    0x11000    com.apple.security.SecureRemotePassword (1.0) <4 1>  116    0 0xffffff7f8211a000 0x4f000    0x4f000    com.apple.filesystems.afpfs (10.0) <115 7 6 5 4 3 1>
Model: MacPro3,1, BootROM MP31.006C.B05, 8 processors, Quad-Core Intel Xeon, 2.8 GHz, 14 GB, SMC 1.25f4
Graphics: NVIDIA GeForce 8800 GT, NVIDIA GeForce 8800 GT, PCIe, 512 MB
Memory Module: DIMM Riser B/DIMM 1, 1 GB, DDR2 FB-DIMM, 800 MHz, 0x80AD, 0x48594D5035313241373243503844332D5335
Memory Module: DIMM Riser B/DIMM 2, 1 GB, DDR2 FB-DIMM, 800 MHz, 0x80AD, 0x48594D5035313241373243503844332D5335
Memory Module: DIMM Riser A/DIMM 1, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x0000, 0x000000463732353642363145363830304600
Memory Module: DIMM Riser A/DIMM 2, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x0000, 0x000000463732353642363145363830304600
Memory Module: DIMM Riser B/DIMM 3, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x0000, 0x000000463732353642363145353830304600
Memory Module: DIMM Riser B/DIMM 4, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x0000, 0x000000463732353642363145353830304600
Memory Module: DIMM Riser A/DIMM 3, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x0000, 0x000000463732353642363145353830304600
Memory Module: DIMM Riser A/DIMM 4, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x0000, 0x000000463732353642363145353830304600
Bluetooth: Version 4.1.4f2 12041, 2 service, 11 devices, 1 incoming serial ports
Network Service: Ethernet 1 (verizon), Ethernet, en0
PCI Card: NVIDIA GeForce 8800 GT, sppci_displaycontroller, Slot-1
Serial ATA Device: Hitachi HDS721050CLA362, 500.11 GB
Serial ATA Device: OWC Mercury Electra 6G SSD, 120.03 GB
Parallel ATA Device: PIONEER DVD-RW  DVR-112D
USB Device: iPhone, apple_vendor_id, 0x12a0, 0xfd100000 / 6
USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfd500000 / 2
USB Device: Intuos5 touch M, 0x056a  (WACOM Co., Ltd.), 0x0027, 0xfd510000 / 5
USB Device: USB/PS2 Wheel Mouse, 0x047d  (Kensington), 0x1029, 0xfd530000 / 4
USB Device: Apple Keyboard, apple_vendor_id, 0x0220, 0xfd520000 / 3
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8206, 0x5d200000 / 2
FireWire Device: built-in_hub, 800mbit_speed
Guest
Jul 02, 2013 Jul 02, 2013
Also, no wacexportfile.aip to be found anywhere, it seems.
Jul 03, 2013 Jul 03, 2013
I finally got a fix for this after months of having major problems with Illustrator.  Somewhere in my User Preferences or Application support folder there was some sort of preference file causing issues with Illustrator where it would give me the wheel of death for sometimes hours and then work correctly. It mostly happened during saving files, but also happened sometimes while creating new files and other common tasks. I remember seeing the files but unfortunately didn't take note of what it was because I wasn't sure if it was the cause of the issue at the time. But, just uninstalling Adobe products alone (even if remove preferences is checked) doesn't fix the issue.
Here is what I did.
  • Uninstalled all adobe products and ticked the "Remove Preferences" checkbox.
  • Manually removed all Adobe preferences, Application support, and cache files from my User Library. (I didn't mess with the primary library folder because when I created a new user and launched Illustrator, it worked fine).
  • Opened up Path Finder or another tool that reveals hidden files and folders and delete all hidden Adobe preferences, application support items, and caches (if any).
  • I did move all my user fonts to my primary library folder, but I don't think that it is neccessary to fix the problem.
  • Reinstalled Adobe products and IT WORKED!!!
Hope this works for others like it did for me, I know how aggrivating this issue is, I experienced it for roughly 6 months and I almost stopped using Illustrator completely because of it.
Jul 15, 2013 Jul 15, 2013
I won't necessarily call this a fix if one needs to uninstall & reinstall the application again,including setting up plug-ins and preferences when on a tight schedule and clients are waiting.
Doesn't Adobe have any other solution for an application hang after opening up a (Ai) file also created with CC?
it is more than likely a permissions problem in which a directory along the path is preventing the AI from access the file in question more than likely the somewhere along the path to the preference file or the Adobe Illustrator CC Settings folder.
That was the issue in previous versions. Also could be the com.adobe.illustrator.plist file or some such.
What happens is the when opening a file Illustrator has to access these folder or files and if the permissions are not correct it might not be able to do this it will either hang or quit. Same thing when creating a file.
Jul 16, 2013 Jul 16, 2013
Yep, thats what I thought ( and may well be the case ). But, simply running permission repairs doesn't fix the problem.
Not a classic "Fix", but definitely a fix for my aggrivation and time wasted.  You don't have to get rid of your plugins or brushes or anything like that... You can copy the presets out of User/Library/Preferences/Adobe Photoshop CC Settings folder and your Photoshop plugins folder into another directory before you uninstall, then replace them after reinstall. There is no quick fix for this issue that I have found; I delt with it for months with lots of banging my head against my desk, but am finally satisfied with the fix. Uninstalling and reinstalling took a fraction of the time I wasted force quitting and waiting on the wheel of death. It also fixed a issue where every time I opened Illustrator, 70-80 GB of my hard drive space would suddenly disappear (Im guessing for virtual mem even with 16GB ram installed).
Well worth the 20-30 minute uninstall/reinstall hassle, for me anyways...
Guest
Aug 27, 2013 Aug 27, 2013
I had this same issue just now. Took me about an hour but I made a new doc using a template, and then boom amazing fantastic I can make new docs again. Not a fix but hey it doesnt look like this is a high priority for them anyway.
Jul 30, 2014 Jul 30, 2014
Just to help future readers:
I have been Googling after Illustrator CC crashed on me suddenly with these specific symptoms (Opening app is fine, New file of Opening existing file makes it crash).
All other threads had no working solution for me and the symptoms of them seemed little different - Opening the program and keeping it open without opening or creating a file was no problem.
This was the well-appreciated solution that did the trick for me.
Re: Illustrator CC 17.1 Crashing on New File or Open File (Win 7) works under a different user?
(In my case I think my default printer had been changed in the background by using a VPN connection this morning which I hardly use ever. Never had been thinking in that direction of course.)
Good luck to you all.
May 24, 2015 May 24, 2015
YESSS Thank you !!!!! You took me on the right direction :
MY DEFAULT PRINTER (in that case, not powered and connected to a NAS device so was unreachable by illustrator)
I just had to CHANGE THE DEFAULT PRINTER to a 'non disapearing' device ... such as a network device can be...
whitch immediatly SOLVED my problem : Illustrator is running well...
++ XA
Jul 15, 2015 Jul 15, 2015
Changing deafault printer didn't help in my case, but turning off GPU did!!!!
Sep 01, 2015 Sep 01, 2015
Thank you, this fixed my issues too.
Aug 10, 2015 Aug 10, 2015
I just upgraded to Windows 10 and was getting the crash on new error. Swapping the default printer to another printer (and back) solved the issue for me. Thank you!
Jul 22, 2015 Jul 22, 2015
The Wacom driver was causing my problems (Illustrator crashing and InDesign running painfully slow). Once I removed the offening Wacom file everything corrected itself. This is a link to an older post but it solved my issues. Illustrator CC crashes at launch
Apr 27, 2016 Apr 27, 2016
Simple fix - change your default printer. If your default printer is unavailable, it locks up Illustrator. Similar to old PageMaker issues, the application is closely tied to the Default Printer.
Sep 25, 2017 Sep 25, 2017
Such a simple fix, I can't believe it! Adobe wasn't able to help me out before so I was really frustrated. Thanks so much!!
May 11, 2017 May 11, 2017
Disable GPU, under Menu - Edit - Preferences - GPU Performance solved the problem for me
Dec 28, 2017 Dec 28, 2017
@Flemming Jul that solved it for me, thank you so much!
