10 Replies Latest reply on Jul 31, 2016 5:11 PM by Kukurykus
    Photoshop javascript: Open files in all subfolders
    David-PS-VBScript Level 1
      Hi guys
      I'm very new to javascript, and general Photoshop scripting. My script is coming on well, but I struggle working with files and folders. It's a lack of basic javascript knowledge, which I need to work on. Right now, I'm trying to expand the image open part of my script, so that it opens images regardless of whether they are in a subfolder or not.
      You can see my input folder (C:/Input). I want to be able to throw files in there, some in folders, some not. Out of interest, my outputs will be combined into one output folder... that bit is fine.
      var inFolder = new Folder("C:/Input")
      if(inFolder != null){
      var fileList = inFolder.getFiles(/\.(jpg|tif|psd|bmp|gif|png|)$/i);
      for(var a = 0 ;a < fileList.length; a++)
      var docRef = open(fileList[a]);
      //do things here
      Is there an easy way of expanding this to include files in subfolders? All advice greatly appreciated.
      David
        • 1. Re: Photoshop javascript: Open files in all subfolders
          Michael L Hale Level 5
          Folder.getFiles() only works with one folder at a time. To get all the files in the folder as well as in subfolders you need to scan each subfolder. One way to do that is with a recursive function. Something like this:
          var topFolder = new Folder('~/desktop/test');
          var fileandfolderAr = scanSubFolders(topFolder,/\.(jpg|tif|psd|bmp|gif|png|)$/i);
          alert('Scan of ' + topFolder.fullName + '\n' + fileandfolderAr[0].length + ' files\nLast File: ' + decodeURI(fileandfolderAr[0][fileandfolderAr[0].length-1]));
          alert('Scan of ' + topFolder.fullName + '\n' + fileandfolderAr[1].length + ' folders\nLast Folder: ' + decodeURI(fileandfolderAr[1][fileandfolderAr[1].length-1]));
          function scanSubFolders(tFolder, mask) { // folder object, RegExp or string
              var sFolders = new Array();
              var allFiles = new Array();
              sFolders[0] = tFolder;
              for (var j = 0; j < sFolders.length; j++){ // loop through folders
                  var procFiles = sFolders[j].getFiles();
                  for (var i=0;i<procFiles.length;i++){ // loop through this folder contents
                      if (procFiles[i] instanceof File ){
                          if(mask==undefined) allFiles.push(procFiles[i]);// if no search mask collect all files
                          if (procFiles[i].fullName.search(mask) != -1) allFiles.push(procFiles[i]); // otherwise only those that match mask
                  }else if (procFiles[i] instanceof Folder){
                      sFolders.push(procFiles[i]);// store the subfolder
                      scanSubFolders(procFiles[i], mask);// search the subfolder
             return [allFiles,sFolders];
          1 person found this helpful
          • 2. Re: Photoshop javascript: Open files in all subfolders
            Pascalculator Level 1
            var traverseFolder = function(path)
                 // Create new folder object based on path string
                 var folder = new Folder(path);
                 // Get all files in the current folder
                 var files = folder.getFiles();
                 // Loop over the files in the files object
                 for (var i = 0; i &lt; files.length; i++)
                      // Check if the file is an instance of a file
                      // else call the traverse folder recursively with the current folder as an argument
                      if (files[i] instanceof File)
                           // Convert the file object to a string for matching purposes (match only works on String objects)
                           var fileString = String(files[i]);
                           // Check if the file contains the right extension
                           if (fileString.match(/.(jpg|tif|psd|bmp|gif|png)$/))
                                // Do something if the file matches
                                alert(fileString + 'good file');
                           else
                                // Do something if the file doesn't match
                                alert(fileString + 'bad file');
                      else
                           alert('passing folder: ' + files[i]);
                           // Call method recursively with the current folder as an argument
                           traverseFolder(files[i]);
            traverseFolder('c:/path');
            You can use the traverseFolder() function and pass the path as a parameter. Make sure to delete the alerts, there just there to show you which folder/file is currently being loaded. Also make sure to delete the comments in the for statement, since they cause the program to slow down unneccesarily.
            2 people found this helpful
            • 3. Re: Photoshop javascript: Open files in all subfolders
              Pascalculator wrote:
              ... make sure to delete the comments in the for statement, since they cause the program to slow down unneccesarily.
              The comments will not effect the speed of the script as it runs. If the comments help you remember what the script does, how it does what it does, or how to use it I suggest leaving them in.
              • 4. Re: Photoshop javascript: Open files in all subfolders
                Thank you Michael and Pascalculator for your explanations, I'm very grateful. I've struggled a little to integrate either into my script - I will close myself in a dark room later and work on it. I'll get back when I've figured it!
                David
                • 5. Re: Photoshop javascript: Open files in all subfolders
                  You could combine the code you posted with the code I posted like this:
                  var fileList = fileandfolderAr[0];
                  //do things here
                  • 6. Re: Photoshop javascript: Open files in all subfolders
                    Thanks so much, Micheal, for all your help. It's working fantastically, I really appreciate all your input, and to Pascalculator. Will try to pay back the community. : )
                    • 7. Re: Photoshop javascript: Open files in all subfolders
                      Raffter Level 1
                      Hello,
                      Inspired by the topic created a script that converts files .eps to .jpg. However, I have a problem. The script correctly reads the folders and subfolders and contained in their files and saves the converted files to the input folder.
                      I do not know how to save the converted file ".jpg" to the folder from which it was read source file.
                      Please suggestions on how to solve this problem.
                      My script looks like this:
                      function saveJPEG( doc, saveFile, qty ) {
                         var saveOptions = new JPEGSaveOptions( );
                         saveOptions.embedColorProfile = true;
                         saveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
                         saveOptions.matte = MatteType.NONE;
                         saveOptions.quality = qty;
                         doc.saveAs( saveFile, saveOptions, true );
                      function fitImage( xUnitValue, yUnitValue ){
                      var fitImage = stringIDToTypeID( "3caa3434-cb67-11d1-bc43-0060b0a13dc4" );
                          var size = new ActionDescriptor();
                          size.putUnitDouble( charIDToTypeID( "Wdth" ), charIDToTypeID( "#Pxl" ), xUnitValue.as( 'px' ) );
                          size.putUnitDouble( charIDToTypeID( "Hght" ), charIDToTypeID( "#Pxl" ), yUnitValue.as( 'px' ) );
                      executeAction( fitImage, size, DialogModes.NO );
                      var openOptions = new EPSOpenOptions();
                      openOptions.antiAlias = true;
                      openOptions.constrainProportions = true;
                      openOptions.mode = OpenDocumentMode.RGB;
                      openOptions.resolution = 600
                      var x = new UnitValue( 1280, 'px' );
                      var y = new UnitValue( 1024, 'px' );
                      var inputFolder = Folder.selectDialog (prompt);
                      var outputFolder = inputFolder;
                      var fileandfolderAr = scanSubFolders(inputFolder,/\.(eps|)$/i);
                      for(  var i =0; i < fileList.length; i++ ) {
                         var doc = open( fileList[ i ], openOptions );      var docName = decodeURI ( doc.name );
                         docName = docName.match( /(.*)(\.[^\.]+)/ ) ? docName = docName.match( /(.*)(\.[^\.]+)/ ) : docName = [ docName, docName, undefined ];
                         var saveName = docName[ 0 ]; // strip the extension
                         var saveFile =  new File ( outputFolder + '/' + saveName + '.jpg' );
                             doc.resizeImage( undefined, undefined, 72, ResampleMethod.NONE );
                         doc.flatten( );
                         doc.convertProfile( 'sRGB IEC61966-2.1', Intent.RELATIVECOLORIMETRIC, true, true );
                         fitImage( x, y );
                         saveJPEG( doc, saveFile, 8 );// or
                         //exportSFW( doc, saveFile, 65 );
                         doc.close( SaveOptions.DONOTSAVECHANGES );
                      • 8. Re: Photoshop javascript: Open files in all subfolders
                        Kukurykus Adobe Community Professional
                        In the last part of code in linecode:
                        replace outputFolder with activeDocument.path, so you'll get:
                        var saveFile =  new File ( activeDocument.path + '/' + saveName + '.jpg' );
                        I hope it will work, because I had to do two other little changes:
                        • I deleted EPS options from var doc = open( fileList[ i ], openOptions ); as I had no EPS files and were opening JPG's
                        • in fitImage function I had to change in 2 following lines xUnitValue.as('px') for xUnitValue and yUnitValue.as('px') for yxUnitValue (maybe because I tested it in CS2 that second change was necessary)
                        • 9. Re: Photoshop javascript: Open files in all subfolders
                          JJMack Most Valuable Participant
                          1. varsaveFile=newFile(activeDocument.path+'/'+saveName+'.jpg');
                          That will only work for old documents when the  Active document has been save in the past then there is a backing file and path.  It will not work for new Photoshop documents there is no activeDocument.path or backing file.
                          • 10. Re: Photoshop javascript: Open files in all subfolders
                            That's true, but there is backing file so the path as there are EpsOpenOptions and  Folder.selectDialog (prompt)  in the code. But that had to be a tip just in case I guess
