Learn about Edge Delivery Services in upcoming GEM session
How do I make a process/service asyncronous.
Avatar
Level 4
When I invoke a long-lived process from another process, I get the following run-time error:
"The Long Lived Service x cannot be invoked synchronously."
How can I change the process/service so that is invoked asynchronously?
Thanks.
{NOTE:  It'd be really nice to be able to copy-n-paste into these forum windows.}
Avatar
Employee Advisor
You should also change the calling process to be long-lived, with this you'll be able to invoke it asynchronously. In workbench, right click the process, select configure, click on Advanced tab and change the "Type" to "long-lived".
Hope this helps.
Wasil
Avatar
Level 4
Thanks for the answer.  It appears to be *part* of the solution.
However, I am now getting a run-time error "Long lived operation and is not supported on transient branches".
Unfortunately, it doesn't "point' to a specific process or sub-process that I need to change.
Any ideas?
I am not allowed to post my code or files, at least not w/o special permission; however, one long-term process is invoking another long-term process ....
Avatar
Employee Advisor
I am not sure what's the version of LiveCycle you are using  . In case, it is 7.x, please refer to this : http://ncifrederick.cancer.gov/about/readingroom/css/COTS/LiveCycle/Adobe-LiveCycle-Workflow.pdf
If not, just try to find the branch which is transient/synchronous and change it to asynchronous(you can also refer to server log file to get some more info).
Wasil
Avatar
Level 4
I am using Live Cycle Workbench ES3, version 10.0.2.x
Avatar
Employee Advisor
Can you please share your lca through Acrobat.com ?
Avatar
Level 5
You can use a Script Object within your Short-Lived process to invoke a long-lived process, if that is the issue.
import javax.servlet.ServletException;
import java.util.*;
import com.adobe.idp.dsc.clientsdk.ServiceClientFactory;
import com.adobe.idp.dsc.clientsdk.ServiceClientFactoryProperties;
import com.adobe.idp.dsc.InvocationRequest;
import com.adobe.idp.dsc.InvocationResponse;
import com.adobe.idp.dsc.clientsdk.ServiceClient;
import com.adobe.idp.Document;
String strResultFlg = "FAIL";  //Assume failure status until completed successfully
Document inXML = patExecContext.getProcessDataDocumentValue("/process_data/formData");
System.out.println("formData =  " +  inXML);
      try
            // Create the service client factory
            ServiceClientFactory myFactory = ServiceClientFactory.createInstance();
            //Create a ServiceClient object
            ServiceClient myServiceClient = myFactory.getServiceClient();
            //Create a Map object to store the XML input parameter value
            Map params = new HashMap();
            params.put("formData", inXML);
            //Create an InvocationRequest object
            InvocationRequest lcRequest =  myFactory.createInvocationRequest(
                "<app_Name>/processes/<Process_Name>", //Specify the long-lived process name
                    "invoke",           //Specify the operation name
                    params,               //Specify input values
                   false);               //Create an asynchronous request
            //Send the invocation request to the long-lived process and
            //get back an invocation response object
            InvocationResponse lcResponse = myServiceClient.invoke(lcRequest);
            String invocationId = lcResponse.getInvocationId();
         // Print the verification message
          System.out.println(invocationId + " was successfully invoked." );
             strResultFlg = "DONE";
        }catch (Exception e) {
            System.out.println("Exception thrown while trying to invoke process " +      e.getMessage());
patExecContext.setProcessDataValue("/process_data/@strResultFlg", strResultFlg);
Hope this helps
Mark
Avatar
Level 7
@JosephDoggie
Did you get the solution of your posted problem?
Regards
Sunil
Avatar
Level 9
How about making a custom event of the short lived process of event Throw type and use the same event as an Event start point in the long lived process?
Lets say you have 1 Short Lived process which will accept a document variable as an input and you have one Longlived process which will use that document variable for creating a Task in workspace.
So what gonna you do is create a custom event in the short lived process and capture the document variable. Then in the long lived process use the same event as a Event start point use Xpath to map the event data value to a process variable.
One more thing you can try i.e invoking the long lived process through a webservice.
Does this help?
Bibhu.
Avatar
Level 3
I think it is a bug or a limitation in ES3.
I quickly tested this scenario (long-lived process calling another long-lived process) in ES2 SP2 and it is working.
On ES3, its not working and "Long lived operation and is not supported on transient branches" exception is thrown in server logs.
Request you to open a Support case for this issue by contacting Adobe LiveCycle Support and we can take it from there.
Varun Nohria
