1 Reply Latest reply: Jul 8, 2013 11:38 AM by Muppet Mark RSS
    applescript, CS5 to CS6, files won't close
    Mattmcquiff Community Member
      This is the part of my script, that runs from with photoshop. on CS5 it opened and closed everything without a problem, however in CS6 it processes the images but does not close them.
      Can anyone see where it might be going wrong?
      Let me know if you need the whole thing and I'll condense it down.
      Many Thanks
      Matt
      tell current document
        --If the quick mask mode has been left on then delete the channel Quick Mask
        if (quick mask mode) then delete channel ¬
        "Quick Mask"
        --If the Layer is incorrectly labeled with Original Layer it needs renaming to original Image
        if (exists layer "Original Layer") then ¬
        tell layer "Original Layer" to set name to "Original Image"
        save in (localBrandFolder_PSD & origName) as Photoshop format with options myPSDOptions without copying
        (delete layer "Original Image") flatten
        resize image resolution 300 resample method none
        --sharpen image
        filter current layer using unsharp mask with options {amount:80, radius:3.2, threshold:0}
        save in (ftpBrandFolder_High_Res & name) as JPEG with options myOptions without copying
        --Prepare for Low RES by resetting image history
        set current history state to history state 3
        flatten
        resize image width 1348
        --add save to lowResFolder with same options
        save in (networkBrandFolder_Low_Res & name) as JPEG with options myOptions without copying
        set newFile to file path
        set newFile2 to newFile as string -- for testing end of name
        if newFile2 ends with "_2.jpg" or newFile2 ends with "_3.jpg" or newFile2 ends with "_4.jpg" or newFile2 ends with "_5.jpg" or newFile2 ends with "_6.jpg" or newFile2 ends with "_7.jpg" or newFile2 ends with "_8.jpg" or newFile2 ends with "_9.jpg" or newFile2 ends with "_10.jpg" or newFile2 ends with "11.jpg" then -- exclude website_images
        my duplicateFile(newFile, {ftpBrandFolder_Low_Res})
        else
        my duplicateFile(newFile, {ftpBrandFolder_Low_Res, website_images})
        end if
        close saving no
        display dialog "A"
        return
        end tell
        on error
        set noError to false
        my myLogs(thefile) -- write path to log file in Desktop
        try
        close saving no --if exists, close current document
        display dialog "B"
        return
        end try
