1. Re: Premiere Pro CC no audio with BlackMagic 9.7.5
Kevin-Monahan Jul 8, 2013 11:47 AM (in response to iodioz)Hello iodioz,
Did you install the latest drivers from Blackmagic?
Kevin
2. Re: Premiere Pro CC no audio with BlackMagic 9.7.5
iodioz Jul 8, 2013 1:14 PM (in response to Kevin-Monahan)Hi Kevin,
thanks for your reply. As you can read from the topic title I'm using Desktop Video 9.7.5
Reading around is a very common issue and not hardware related (i mean people with iMac and thunderbolt devices, for example, having the same problem).
In ten years of work with Adobe and Blackmagic I never had a problem, everything was just plug'n'play, with CC and 9.7.5. it's a mess.
To avoid you to waste time here you go with the list of experiments I did following Blackmagic suggestions:
- Roll back to 9.7.3 - Past setup works (at least I can use CS6)
- Clean install of OSX 10.7 on a brand new SSD, installed 9.7.5 and Premiere CC - same issues.
- All the possible combinations of System sound and Premiere sound settings.
- Upgrade the clean SSD to OSX 10.8 - same issues
In addition to what I reported before, for a while, during my test sessions, I has been able to hear the sound of Premiere CC but the performance was awful: random clippings. After the Nth restart-reboot-reset, no more audio from the card has been heard in Premiere CC.
Generally speaking about audio performance in Premiere CC, I noticed a slight unstability and a randomly changing setup.
Please have a chat with
Carys Hughes
Technical Support Consultant
Blackmagic Design EMEA
My ticket #: LCM-723-71038
Any suggestions?
Piero.
3. Re: Premiere Pro CC no audio with BlackMagic 9.7.5
petergaraway Jul 8, 2013 1:23 PM (in response to iodioz)Hi Piero,
Here's a few ideas you can try.
1. Place your Blackmagic card in slot 2
2. Set your OS system sound to Built-in or Line out audio
3. Set your buffer size to 1024
4. If those settings fail to help you can place the 9.7.3 plugins into the CC folder. Here's how:
Mac:
Copy from:
/Library/Application Support/Adobe/Common/Plug-ins/CS6/MediaCore
Paste to:
/Library/Application Support/Adobe/Common/Plug-ins/7.0/MediaCore
Hope that is helpful. Let us know how it goes.
Peter Garaway
Adobe
Premiere Pro
4. Re: Premiere Pro CC no audio with BlackMagic 9.7.5
iodioz Jul 8, 2013 1:30 PM (in response to petergaraway)Hi Peter,
tomorrow morning I will surely try. I can't use slot 2 because I have the second Quadro 4000 installed there. Could be a real problem?
P.
5. Re: Premiere Pro CC no audio with BlackMagic 9.7.5
Mark Mapes Jul 8, 2013 5:24 PM (in response to iodioz)The patch that is due out soon has fixes for several bugs that involve either audio or video going missing. As far as I'm aware, none of those bugs involve BlackMagic hardware.
In case you were going to ask when exactly to expect the patch, I'm not at liberty to talk about specific dates. About all I can say is that we're pushing hard and getting close.
6. Re: Premiere Pro CC no audio with BlackMagic 9.7.5
shooternz Jul 8, 2013 5:30 PM (in response to Mark Mapes)Hey Mark
Please, please, please dont let them break BM 9.7.5 Intensity Pro while fixing it.
It works fine on my PC (CS7 and CS6) and I also have it working in AEFX...at last.
7. Re: Premiere Pro CC no audio with BlackMagic 9.7.5
iodioz Jul 9, 2013 3:10 AM (in response to petergaraway)Hi Peter,
I try everything but not to change the card slot. I have two Quadro 4000 and they need 16x slot.
All the rest give me no results: CS6 works, CC don't.
P.
8. Re: Premiere Pro CC no audio with BlackMagic 9.7.5
invisiblearts Jul 15, 2013 3:47 PM (in response to iodioz)All the rest give me no results: CS6 works, CC don't.
P.
This is a conclusion I'm drawing as well. CS6 works, CC does not. I've been having issues with playback, as read on this thread. Now I'm getting playback, but no audio. Just as your problem describes. I can pull the exact same project up in both CS6 and CC...it works in CS6, but not in CC. Good thing I've got some downtime at the office right now, this would kill my workflow schedule.
Seems like Blackmagic's and CC's relationship may be the culprit here, as everything works on my MacBook Pro station as does CS6 on my Mac Pro.
9. Re: Premiere Pro CC no audio with BlackMagic 9.7.5
Kevin-Monahan Jul 15, 2013 3:53 PM (in response to invisiblearts)Hi invisiblearts,
If you are getting playback, but no audio, have a look at the following article: http://helpx.adobe.com/premiere-pro/kb/no-sound-playback-premiere-pro.html
Kevin
10. Re: Premiere Pro CC no audio with BlackMagic 9.7.5
invisiblearts Jul 19, 2013 2:28 PM (in response to Kevin-Monahan)Also posted this in my original thread, but wanted to post it here as well...
Ok, everyone, I'm happy to report that today I was able to resolve the issue...knock on wood.
I had a very thorough discussion with Charles Van Wink at Adobe on Wednesday where he was able to screen share with me and walk me through the new layout of the preferences pane. He described the differences between the 'Audio Hardware' tab, and the 'Playback' tab, and when specifically to address the settings of each tab. While we weren't able to solve the issue during the phone call, Charles was able to educate me on how to troubleshoot more thoroughly in a systematic way.
According to the results I came to today, and how I came to a solution, my final determination on why I was having issues for MY particular case is as follows. I think it comes down to a difference in the CC preferences pertaining to the Decklink HD Extreme card compared to how CS6 dealt with those same preferences. What I mean is this.
In CS6, I was able to have audio playback through my Decklink card with no problems whatsoever, no matter what kind of sequence I made. I often would "make a sequence from clip" so that my sequence settings would match the clip, and playback worked fine. If I do that in CC, the Decklink card doesn't appear to like it, and won't play nice. Even if I selected the appropriate hardware and playback options, it still would not play back audio. But if I actually make a Blackmagic sequence in CC, playback suddenly works.
The crazy thing is that when I get it working, and then decide to create a non-blackmagic sequence as a control, playback would also work for that sequence...just not nearly as responsive.
So after all of this, and weeks of troubleshooting, I've decided that CC and Blackmagic really just play together best when Blackmagic sequence presets are used. I'm sure this isn't breaking news to Blackmagic or Adobe, but CS6 didn't seem to mind as much. CC, to me anyway, seems a bit more strict.
Thanks again for your help,
Beau Leland
Editor
OKC, OK
11. Re: Premiere Pro CC no audio with BlackMagic 9.7.5
petergaraway Jul 19, 2013 2:38 PM (in response to invisiblearts)Thanks for the update Beau.
I've never had problems using Premiere sequences with Blackmagic hardware but in case others do this is great info.
Best,
Peter Garaway
Adobe
Premiere Pro
12. Re: Premiere Pro CC no audio with BlackMagic 9.7.5
iodioz Oct 17, 2013 4:48 AM (in response to petergaraway)Hi Peter,
I still have problems with CC audio and my Decklink Extreme Pcie. Now I have installed the new release of BM Desktop Video (9.7.8) and something has improved but I still need to play some tricks in order to listen to the audio from my device.
Here's my workaround.
If I create a new project and import an AIFF or WAV or MOV (of course) file I can't ear any sound in viewer or from the timeline.
BUT... if I import a mp4 file and double click on it as first operation, magically the BM wake-up and let me listen to all the audio I need.
Crazy, don't you think?
Piero
