Show 1 reply
1. Re: Saving a Populated Form
George_Johnson Jul 8, 2013 2:10 PM (in response to afierke)They need to use a PDF viewer that's capable of saving a filled in form. This means Acrobat, Reader 11, or previous version of Reader if the document has been Reader-enabled. You can Reader-enabled a form with Acrobat. For example, in Acrobat 11 that last thing you'd do before distributing the form to users is select: File > Save as Other > Reader Extended PDF > Enable More Tools
The menu item is different with every version of Acrobat, starting with 8 Pro.
