I have TCS 4.0 (RoboHelp HTML and FM 11) and I want to create online help for a web server built into a product. The web server is used to set up the product using a web browser.
What I would like to have:
Could someone help me in the right direction? Is it possible at all with Robohelp to get all this, and if yes, which output format should I use?
Christiane
Multiscreen HTML5 is the only output designed to work with smartphones and tablets as well as PCs. It produces an output for each and the sniffer page directs the device to the appropriate format. Your third bullet point covers that.
If you go the Multiscreen HTML5 page on my site, there is a demo and the TOC is not seen when viewed on a smartphone or a tablet running iOS or Android.
Currently this way of working is the only option.
Does the product also work on all devices or just the web? I am wondering why you want the help to be multi-device if the product is not. Just curious.
Thanks a lot for your quick answer!
Yes, the product also works on PCs, smartphones and tablets. I don't know all the details, but the user interface is HTML with responsive design - you access the product's built-in web server from a smartphone, tablet or PC connected to the product by entering an IP address or url. The output is adjusted to the device where it is viewed. The help for the user interface should therefore be accessible from the same devices and also be adjusted to fit them.
Best regards,
Christiane
Then it is Multiscreen HTML5 you need. See Multiscreen HTML5 on my site. There is a link to a download and demo. Hope they help.
Please follow this link.
http://www.Adobe.com/cfusion/mmform/index.cfm?name=wishform&product=38
and submit a feature request for what you want.
