Hello Adobe-Community,
you're my last hope.
Since two days I'm trying to get a legal bought Adobe Product (Robohelp9) which suddenly refused to work, to work again.
One day Robohelp9 told me to 'Please activate me', but it isn't happy with our internet connection.
Adobe support told me that it must be a problem with our firewall (or the Windows hosts File) and so it's our own fault.
I'm very (VERY) angry at the moment because we can't work with the product anymore!
Okay, to the technical part.
Please see this picture:
http://files.cimdata-sw.de/packets.jpg
IP 172.30.2.55 is the IP of the host where Adobe Robohelp is intalled.
IP 172.30.1.240 is the IP of the Proxy Server (I've already disabled the proxy, changes nothing)
As far as I'm understanding the TCP Stuff, it seems that Adobe Robohelp is getting the Certificate from
http://svrintl-g3-aia.verisign.com/SVRIntlG3.cer .
After that it seems that 172.30.2.55 is sending an RST Packet.
To me it seems that Adobe Robohelp is resetting the connection.
Any ideas what is wrong here ?
Thomas
Here are the packets without a proxy:
http://files.cimdata-sw.de/adobe_robohelp9_activate_noproxy.jpg
I think Adobe Robohelp itself is resetting the Connection because of some error and doesn't tell us why.
It simply says 'check your internet connection'.
Adobe Support is really no help.
Thomas
You will not like this but it does seem more likely the problem is at your end as in many years of supporting these forums, I cannot recall anyone posting with this information.
The first thing I would try is installing Rh on a home PC to prove it does install OK there. Two concurrent activations are allowed and you can deactivate that one once you have tested.
I would ask if you are you working in an exceptionally secure environment, the equivalent of a US government or military department as that could be the cause and Adobe do have special arrangements for such environments. However, it appears you have previously had Rh9 installed and working. What has changed in your environment since then?
What is the operating system you are installing to?
Hello Peter,
thanks for your answer !
I myself work in the Customer Support and sure I don't have elmiated the possibility that the problem is on our side 🙂
But it's nearly impossible to get good help from the support.
They tell you to delete your hosts file or open your firewall ports.
If I say that I checked with Wireshark and that I don't think that it is such simply problem they don't believe me.
(I think most of them have no Idea what 'wireshark' or 'SSL' is...)
I will try to install Robohelp at home, but because it's a complete other environment I don't expect any problems there.
At least, it has been properly installed on this Server since more than a year.
The OS is Windows Server 2003, as always 'no one has changed anything'.
In fact, I don't know of any changes in our environment.
Do you know if Adobe has any Logfiles of the Activation Process ?
I would like to have a file in it with something like:
contacting adobe... contacted.
checking certificate... failed.
Activation aborted
I'm so angry that Customers who Pay a huge amount of money for legal products have more problems than
'so called' pirates who download the program somewehere.
Thomas
ohhh, no government, no ultra secure environment.
Can you install it on Windows 7 or 8? Officially Server is not supported and I'm surprised Support didn't point that out.
The screenshots and things like Wireshark are stuff outside the remit of most who support this forum, me included.
I will see if I can find out anything about logs.
Please contact me via my site if you still want details of the log files created.
