I'm using PowerPoint 2007.pptx format and Adobe Presenter 8. I have inserted a hyperlink on the last slide. When I publish the presentation the hyperlink doesn't work and I get an error message that says: Adobe Flash Player has stopped a potentially unsafe operation. The following local applications on your computer or network: file path is trying to communicate with the Internet-enabled location: location name. To let this application communicate with the Internet, click Settings. You must restart the application after changing your settings.
When I click on Settings, they are set according to my company's requirements. Can anyone help?
You must be playing the presentation locally. This is a Flash security warning, and should show up. It is indicating that a Flash object on your local computer is attempting to access something off the Internet, and it has stopped it. You can change your Flash player settings to allow local object to access the Internet, or you can push the presentation to a server (Connect or any other web server), and access it over the web. You will not see that warning when clicking the link at the end of your presentation if it is delivered from a server.
In order to change your Flash player settings to allow local object to access the Internet, please do the followings :-
Go to this link -> http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager04.html
If this link doesn't work for your browser, then search in google "flash security settings" and follow the micromedia link.
Do the changes as depicted in below screenshot:-
VIkram
Adobe Presenter Engg. Team
Hi Vikram,
I’ve done this – it didn’t help.
Sharon
Sharon K. Tharas
Sr. Technical Writer, Consultant
Bristol Myers Squibb
Drug Development Learning & Collaboration
Wallingford, CT
203-677-5603
sharon.tharas@bms.com
Hi Sharon,
Which browser and OS(32/64) are you using?
If you are using chrome, please check whether you have installed external flash plugin along with the built in flash player.
Please follow these steps :-
Vikram
Hi Vikram,
I am using internet Explorer 8 and my OS is 32.
If you can help me that would be WONDERFUL!!!!!
Sharon
Sharon K. Tharas
Wallingford, CT
203-677-5603
Vikram,
Not using chrome…
Sharon
Sharon K. Tharas
Wallingford, CT
203-677-5603
Please specify your OS [XP/Vista/win7/win8] ?
Please just mention it. The image link is not working.
MS Windows XP Professional
Version 2002, SP3
Computer:
Intel(R) Core(TM)
I5-250M CPU @ 250GHz
773 MHZ, 2.93 GB of RAM
Sharon
Sharon K. Tharas
Wallingford, CT
203-677-5603
In normal scenario, the hyperlinks should work fine after setting the flash security settings. It may be setup related issue, where other programs like Anti-virus are interrupting the normal execution.
Please create an identical sample project where the issue is reproducible and send it to vikrakum@adobe.com along with the screenshot of the error message.
Vikram
Hi Vikram,
I found the problem – there was a JAVA update that I did not have on my system – it interacts with Adobe Flash – once I downloaded that the hyperlink worked.
Thank you so much for all your help. I really appreciate it!
Have a wonderful weekend!
Sharon
Sharon K. Tharas
Wallingford, CT
203-677-5603
You too!
Glad to hear that your issue is finally resolved.
Vikram
