I am running Linux under Mandriva 2011, 64 bit and was using Firefox (FF) 15 that comes with it. All previous upgrades of flash-plugin worked when installed. When I installed the latest upgrade and went to test it, I am told I need to upgrade flash plugin and it does not work. I reverted back to an old flash-plugin (291) and it works!
I then downloaded Firefox 22 (which is a 32 bit) and installed the latest plugin into /usr/lib/mozilla/plugins and it does not work. When I check my plugins, it is listed in the plugins, but when I test it I get a message that I need to install the plugin.
This seems to be a flash plugin problem, and while I know that Adobe will only be putting out security patches for Linux, it would be useful if they worked.
Thank you.
