2
After Effects error: (-1610153453)
Jul 13, 2013 Jul 13, 2013
I have recently made a intro for a user on youtube, I go to render the intro and I get this:
after effects: Rendering Error while writing to file (-1610153453)
Rendering Options:
1280 X 720
H.264
Audio output: 48.000 kHz
Video bitrate: 120
Level: 5.1
After effects version:
CS6
I've reinstalled Quicktime, and I've redone the settings, I am rendering it in my C:/ drive, the only one
I've only encountered this error about 5 times and It's starting to get VERY annoying.
Please reply as soon as you can, Thanks!
~ MUFFINSSS
54.7K
correct answers 2 Correct answers
Deleted User
Sep 04, 2013 Sep 04, 2013
Got the exact same error, solved it by replacing some special norwegian characters in folder name.
Community Beginner , Feb 06, 2016 Feb 06, 2016
This is an i/o performance Problem... dont write the file on the same drive your read. Well... your writing drive must be faster then your reading drive.
Try using the Adobe Media Encoder to render your AE comp using one of the YouTube presets. If that does not work then please tell us about your machine, what version of AE you are using, and what your comp is like. Just telling us it crashes does not give anyone enough to go on to even guess at the solution to your problem.
I've put down my version in the post, and this doesn't happen all the time.
Probably a performance issue, since you only render to a single drive. When it fails other processes probably cause heavy file I/O activity and AE can't append the frames to the file.... Also, since it's your system drive, it may be heavily fragmented and filled with lots of temporary data, which may also have sideeffects on writing large contiguous files such as video clips... Well, whatever, we can't know for sure. As Rick said, not enough info. You would have to monitor process activity in Resource Monitor and enable "Extra per Frame Info" in AE's render logging to even begin.
Mylenium
Jul 14, 2013 Jul 14, 2013
Could you please tell me were to click on to enable Extra per Frame info please?
I'm not so good navigating around on complicated programs even though I'm very good at making things with After effects.
~ MUFFINSSS
Check the relevant pop-up on teh render queue.
Mylenium
Jul 21, 2013 Jul 21, 2013
Relevant popup?
Screen shot this please, I'm having trouble searching through all my render settings to activate that checkbox I can't find. 😕
Oct 02, 2015 Oct 02, 2015
Hi. I encountered the same problem as "MUFFINS", and I will put here the characteristics of the source file and the composition. They´re are in text (source file) and jpg image (composition settings). My After Effects is CS 6 ver. 11.0.4.2.
The problem is an error message equal to MUFFINS reproted. (Rendering Error while writing to file (-1610153453)
Thanks in advance.
Source file:
Format  : MPEG-4
Format profile : Base Media / Version 2
Codec ID   : mp42
File size  : 64.9 MiB
Duration  :  2mn 1s
Overall bit rate mode   : Variable
Overall bit rate    : 4 477 Kbps
Format   : AVC
Format/Info    : Advanced Video Codec
Format profile : Main@L3.2
Format settings, ReFrames  : 3 frames
Format settings, GOP   : M=4, N=60
Width   : 1 280 pixels
Height   : 720 pixels
Display aspect ratio   : 16:9
Frame rate mode   : Constant
Frame rate : 29.970 fps
Standard  : NTSC
Color space  : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type  : Progressive
Guest
Dec 09, 2015 Dec 09, 2015
You should also check your time ruler... if its "after effects error rendering error while writing to file 1610153453"
Guest
Dec 18, 2013 Dec 18, 2013
@Ola_1974:
Yes you are right. Replacing some "ä" "ü" and "ö" in my renderpaths solved the problem.
I wonder why something like this happens in the year 2013?
Aug 02, 2019 Aug 02, 2019
what do you mean norwegian figures?
Mar 10, 2020 Mar 10, 2020
Thank you soooo much!! I was getting crazy
May 28, 2021 May 28, 2021
Same, looks like AE had a problem with special characters.
Mar 04, 2015 Mar 04, 2015
The same thing happend to me, but the problem was the size of the comp, it was wrong.
Aug 06, 2015 Aug 06, 2015
Rendering Options:
1280 X 720
H.264
Video bitrate: 120
Level: 5.1
CS6
Hi Forum i just have the some error today, and i solve, if u have that error is because u put your save in many folders for exemple:
C:\Users\UserName\Desktop\Folder_1/Folder_2/Folder_3/ etc...
Try just that:
Aug 11, 2015 Aug 11, 2015
Hi, this topic was posted 2 years ago, I'm quite suprised this is still being replied to..
Well, I should stop being lazy and start looking at my inbox.
Also, I don't have this problem, I don't even know of it anymore, thanks for your help though, and sorry for wasting your time
Aug 31, 2016 Aug 31, 2016
how did you solve this issue because i still have this error
Oct 10, 2016 Oct 10, 2016
Please start a new thread if you are still having these troubles. No one can help you here.
Oct 26, 2020 Oct 26, 2020
OMG I LOVE YOU. Thank you so much!
Jul 18, 2016 Jul 18, 2016
Hi there, now I had got a same problem. but I could not understand it.
I tried rendering as MP4 / H.264 format. as a result, I got a problem.
and I tried many solution following the posts. but it did not work.
anyway, I solved I just change the rendering option MP4 to MOV same H.264.
I don't understand it plz, tell me more clear if someone solved it. Thanx.
Dec 18, 2016 Dec 18, 2016
Solved by removing an apostrophe from the comp, file, and folder name.
Sep 26, 2016 Sep 26, 2016
Check the path of your output file that not contains latin characters.
I've got the same error code. The source file and the render out put file was in a folder with the name "diseño". Later I move the file to another path without a latin characters on it and it solve the issue.
Cheers.
