2 Replies Latest reply on Feb 27, 2007 12:02 AM by kennywu
    JRun suddenly no response with external web server Apache on Linux platform
    kennywu
      We have setup jrun and external web server apache on Linux platform successfully and running smoothly.
      But one day, jrun seems has no response, apache have 404 and 503 error. Restart jrun solves the problem and back to normal.
      Apache error log
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] 127.0.0.1:51002 jrConnect [19]
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] sent/avail/result 4/4/4
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] 127.0.0.1:51002 is reachable
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] 127.0.0.1:51002 added socket [19] to pool
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] 127.0.0.1:51002 returned socket [19] to pool
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] jrRecv [18] timeout but server reachable so recv again
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] read/len/total 0/4/0
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] readFully: [18] peer closed connection
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] JRun is busy. [18] dropped while sending command
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] 127.0.0.1:51002 destroying/closing socket [18] error 104
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] 127.0.0.1:51002 freeing pooled sockets
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] jrCloseSocket [19]
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] jrCloseSocket [18]
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] 127.0.0.1:51002 destroyed.
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] loadServersFromStore(/opt/jrun4/lib/wsconfig/1/jrunserver.store)
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] proxyservers =
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] Couldn't initialize from remote server, JRun server(s) probably down.
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] jrun_trans: can't get mappings from server
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] jrun_service: r is 0x82a3560, server is 0x820be60, virtual 1
      [Fri Feb 02 09:13:51 2007] [notice] jrApache[15698: 35850] jrun_service: no handler, return DECLINED
      [Fri Feb 02 09:13:51 2007] [error] [client 11.11.1.3] File does not exist: /opt/jrun4/servers/viadmin/viapp/viapp
      What is the problem and how to solve it?
      Thanks.
        • 1. Re: JRun suddenly no response with external web server Apache on Linux platform
          kennywu Level 1
          Similar problem is occurred in Feb 11.
          Restarting JRun solves the problem.
          Does anyone has idea on this problem?
          • 2. Re: JRun suddenly no response with external web server Apache on Linux platform
            kennywu Level 1
            Similar problem occurs in Feb 11, 18, 23 and 26.
            1. Is it related to loading?
            2. Any action can be done (e.g. turn on debug log, metrics) to help to find the root cause?
            3. Currently it is using Updater 5 (build 92909). Will upgrading to Updater 6 (Build 106363) help? Any other hot fixes are needed?
            Apache version using: 2.0.54
            Thanks.
            Apache error log
            Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] 127.0.0.1:51003 jrConnect [10]
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] sent/avail/result 4/4/4
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] 127.0.0.1:51003 is reachable
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] 127.0.0.1:51003 added socket [10] to pool
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] 127.0.0.1:51003 returned socket [10] to pool
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] jrRecv [9] timeout but server reachable so recv again
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] read/len/total 0/4/0
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] readFully: [9] peer closed connection
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] JRun is busy. [9] dropped while sending command
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] 127.0.0.1:51003 destroying/closing socket [9] error 104
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] 127.0.0.1:51003 freeing pooled sockets
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] jrCloseSocket [10]
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] jrCloseSocket [9]
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] 127.0.0.1:51003 destroyed.
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] loadServersFromStore(/opt/jrun4/lib/wsconfig/1/jrunserver.store)
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] proxyservers =
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] Couldn't initialize from remote server, JRun server(s) probably down.
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] jrun_trans: can't get mappings from server
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] jrun_service: r is 0xa145540, server is 0xa095800, virtual 0
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] jrun_service: found jrun-proxy-target index -1
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] HOST: <null>
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] filtering /jsp/stbinfo.jsp (/jsp/stbinfo.jsp) HOST=null
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] filterRequest: no match
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] request not for JRun.
            [Mon Feb 26 14:56:50 2007] [notice] jrApache[30478: 6556] JRun will not accept request. Check JRun web server configuration and JRun mappings on JRun server.
