1. Re: error creating swf movie file
Sidney Mitchell Jul 10, 2013 10:18 AM (in response to foxxy123) -
2. Re: error creating swf movie file
foxxy123 Jul 10, 2013 10:51 AM (in response to Sidney Mitchell)Hi,
I don't really understand that threat, so that's why I posted this question: to see if someone could give me a detailed answer.
3. Re: error creating swf movie file
Sidney Mitchell Jul 10, 2013 3:39 PM (in response to foxxy123)This could be a permission related issue regarding the folder where you are trying to publish.
One of the suggestions given in the thread is to create a test file and publish it at the same location to see if the issue continues.
If the same thing happens then we can pinpoint it being the folder permissions. Let us know how the test goes.
-Sidney
4. Re: error creating swf movie file
foxxy123 Jul 11, 2013 1:32 AM (in response to Sidney Mitchell)What do you mean test file...?
5. Re: error creating swf movie file
Sidney Mitchell Jul 12, 2013 9:02 AM (in response to foxxy123)Hi,
Apologies for the delay.
The error states an issue with the destination file being either read-only or already opened. So seeing if another file will open within the path that gives an error is the first thing you may want to test. Also, in the thread provided initially, clearing ASO cache or perhaps checking for some antivirus conflict.
I'm currently working with another colleague to investigate your video further to see what else could be causing this. I'll respond back shortly with any additional suggestion.
-Sidney
6. Re: error creating swf movie file
foxxy123 Jul 12, 2013 9:07 AM (in response to Sidney Mitchell)How do I clear my ASO cache?
7. Re: error creating swf movie file
Sidney Mitchell Jul 12, 2013 9:16 AM (in response to foxxy123)See if the following may help...
Control -> clear publish cache
Control -> clear publish cache and test movie
In the meanwhile I'm checking with the team to see if they is any other suggestions and will reply back as soon as I have more details.
Thanks for your patience.
8. Re: error creating swf movie file
Sidney Mitchell Jul 12, 2013 9:25 AM (in response to Sidney Mitchell)Also when trying to clear cache. If that doesn't work you might want to reference a similar query below.
"It means that the directory that you're publishing your SWF to isn't writeable, or doesn't exist. Check to see that the folder path indeed does exist and that it's able to be written to. Many times, if I move a project to a different location, but have the publish path hard-coded in my FLA, it'll throw this error. It's in File->Publish Settings->Formats."
I'll still continue to seek additional solution in the meanwhile.
-Sidney
9. Re: error creating swf movie file
foxxy123 Jul 12, 2013 9:35 AM (in response to Sidney Mitchell)Could you possibly give me a step by step guide of how to do that? I'm quite new to this.
10. Re: error creating swf movie file
foxxy123 Jul 12, 2013 9:53 AM (in response to Sidney Mitchell)After trying to clear the cache, it still says error creating swf movie file. And what where you saying about anti-virus? I've only got Microsoft Security.
11. Re: error creating swf movie file
Sidney Mitchell Jul 12, 2013 10:12 AM (in response to foxxy123)No worries about the cache/anti-virus suggestions.
See if you can change the destination path perhaps to desktop instead. Wherever the file is attempting to publish currently is causing this error to throw either because it no longer exist, permission is set to read-only or something else entirely.
To access this go to File -> Publish Settings -> change the output location to desktop. Then retry your steps...
Hope this helps!
-Sidney
12. Re: error creating swf movie file
foxxy123 Jul 12, 2013 10:47 AM (in response to Sidney Mitchell) -
13. Re: error creating swf movie file
Sidney Mitchell Jul 12, 2013 11:04 AM (in response to foxxy123)Thanks for the update.
We'll need to investigate this further and will get back to you with further instructions.
14. Re: error creating swf movie file
foxxy123 Jul 12, 2013 11:15 AM (in response to Sidney Mitchell)It doesn't seem to be saying error creating swf movie file, it just says something about the font not being right.
15. Re: error creating swf movie file
bgupta16 Jul 16, 2013 2:55 AM (in response to foxxy123)Hi foxxy123,
Two things that I noticed in the video:
1) You are not saving the file before publishing.
2) Flash warns you about the fonts missing from your system while opening the file.
"The document contains one or more fonts not available on your system. The text will display and publish with the font mapping below:"
So download and install the fonts on your computer "Blaster" and "Blaster Infinite" and save the file before publishing.
The message warn you that you have an anti-alias mode set on text and it requires you to have embedded fonts to use anti-aliasing. If you do not want to see that message anymore, then select your text blocks and set the anti-alias types to Use Device Fonts.
You can disable the warning message in the preferences dialog
Edit > Preferences > Warnings > uncheck "Warn on text needs embedded font".
Hope this helps,
Bhawna
16. Re: error creating swf movie file
foxxy123 Jul 16, 2013 2:58 AM (in response to bgupta16)Hi,
I've managed to fix all of the errors now, but I'm getting this now: http://www.youtube.com/watch?v=dFUi5O-OFXQ
17. Re: error creating swf movie file
bgupta16 Jul 16, 2013 3:15 AM (in response to foxxy123)Did you posted another video with the steps that I suggested? It seems the same as what you posted earlier.
18. Re: error creating swf movie file
foxxy123 Jul 16, 2013 3:16 AM (in response to bgupta16)Hello,
and thank you for your email! I should reply with in 2 days, or even quicker. Once again, thanks for your email!
Yours Weevily,
hf556
19. Re: error creating swf movie file
foxxy123 Jul 16, 2013 3:19 AM (in response to bgupta16)No, this time, it doesn't say the bit about font embedding it just doesn't load. It stays on connecting.
21. Re: error creating swf movie file
foxxy123 Jul 16, 2013 3:24 AM (in response to bgupta16)Hello,
Yours Weevily,
hf556
22. Re: error creating swf movie file
foxxy123 Jul 16, 2013 4:27 AM (in response to bgupta16)I didn't install any fonts.
23. Re: error creating swf movie file
foxxy123 Jul 16, 2013 4:49 AM (in response to bgupta16)It still says Connecting.
24. Re: error creating swf movie file
bgupta16 Jul 16, 2013 5:01 AM (in response to foxxy123)What is the workflow?
What will happen when you will click over that area?
Please share your files and related assets on a private FTP so that we can help further.
25. Re: error creating swf movie file
foxxy123 Jul 16, 2013 5:03 AM (in response to bgupta16)Hello,
Yours Weevily,
hf556
26. Re: error creating swf movie file
foxxy123 Jul 16, 2013 5:06 AM (in response to bgupta16)How do I view the workflow? And this is what's happening: http://prntscr.com/1fq67x
It just stays on connecting. I did find this http://www.smartfoxserver.com/docs/1x/docPages/running/troubleshooting.htm but I don't quite understand it.
