I am trying to use my Nook with digital editions to read a library book. I have done this in the past with no problems. Now I need a password to certify
the computer. I have tried many times resetting my password and always get the following message: Code:E-AUTH-NOT-READY.
HELP
Jo Anne Keyser
Moved to Adobe Digital Editions
Adobe Digital Editions (ADE) on the computer must have authorized itself already, probably with a kind of anonymous/implicit ID it invents to trap the unwary.
Remove then authorization using ctrl-shift-D (cmd-shift-D on Mac); restart ADE (maybe not necessary), and try to authorize again.
Thank you very much for your help. After spending two days trying to fix the problem, this instruction was easy
and digital editions is working for library books.
Thank you again.
Jo Anne Keyser
Great advice have done that but I need to put books onto sony e reader. It was working fine until I tried to by a book from Sainsburys online> (Never again 2 time had problems) could only get book on computer, still cant get on reader, do you have any ideas for helping, Thanks from a very old reader
There are problems with Sony readers and ADE2.0 working with Overdrive library books.
Maybe the same issue applies to Sainsbury books.
The only solution I found was to use the older but more reliable ADE v1.7.2.
No promises, but worth a try. Good luck.
There are lots of bugs in ADE2.0. Try replacing ADE2.0 with the older but more reliable v1.7.2.
(You can have them both installed at once if you like.)
Version 1.7.2, it is a little difficult to find, available on Adobe site for Windows and for Mac.
http://helpx.adobe.com/digital-editions/kb/cant-install-digital-editions.html
The forum software is sometimes corrupting the link above. There shouldn't be a blank in 'editio ns.html'. The following redirects to the same page: http://tinyurl.com/diged172
