2013-7-11+22-38-3.797 [info] 1614
2013-7-11+22-38-3.807 [info] 1615
2013-7-11+22-38-3.817 [info] 1618
2013-7-11+22-38-3.827 [info] 1608
2013-7-11+22-38-3.897 [warning] 1445
2013-7-11+22-38-3.907 [warning] 1442
2013-7-11+22-38-3.917 [info] 1600
2013-7-11+22-38-6.857 [info] 1602
2013-7-11+22-38-6.877 [info] 1609
2013-7-11+22-38-6.887 [info] 1612
2013-7-11+22-38-6.897 [info] 1620
=O====== M/11.8.800.94 2013-07-11+22-38-10.277 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe" -refreshIEElevationPolicies
=X====== M/11.8.800.94 2013-07-11+22-38-10.347 ========
2013-7-11+22-38-11.307 [error] 1226 1062
=O====== M/11.8.800.94 2013-07-11+22-38-06.887 ========
0000 00000010 FlashPlayerInstaller.exe -install -iv 9
0001 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_8_800_94.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.dll
0005 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0006 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0007
0008
0009 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0010
0011
0012
0013 00000012
=X====== M/11.8.800.94 2013-07-11+22-38-14.208 ========
I am getting this in my log file and am curious about the error: [error] 1226 1062, and the warning 1445, 1442.
Everything seems to work fine but am worried that something went wrong.
Any information on these specific error and warning codes would be appreciated.
Yes, something did go wrong: FlashPlayerUpdateService.exe was not replaced.
Perform a clean install: http://forums.adobe.com/thread/928315
=O====== M/11.8.800.94 2013-07-11+22-51-03.641 ========
0002
0003
0004
0005
0006
0007
0008
0009 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_8_800_94.dll
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_94_Plugin.exe
0011 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0012 00000017 C:\Windows\system32\Macromed\Flash
0013 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_8_800_94.exe
0014 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0015
0016
0017 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0018
0019
0020
0021 00000012
=X====== M/11.8.800.94 2013-07-11+22-51-08.665 ========
I had this after that, would this have fixed it? If not Is it a big concern? How often does FlashPlayerUpdateService.exe need to be updated? What could have caused this?
Thank you again for replying. Is there anyway to get a list of error code's explained so i can troubleshoot independently.
Actually I see now that 3 files got stuck: FlashPlayerCPLApp.cpl, FlashPlayerApp.exe, FlashPlayerUpdateService.exe - did you delete them during the clean install?
Sorry, these error codes are not documented anywhere (that I have access to), so I cannot provide you with this information. I only learned through experience that a 5 or 183 after a file name means that it could not be written.
