Unable to detect Microsoft PowerPoint. You must have PowerPoint installed on this machine prior to running this installation program
Unable to figure out how this is related to Flash Player! If it is, please eloborate with details of your OS and browser.
With regards,
Prabhu
The machine is a window xp using adobe presenter and will install because powerpoint is not install but is install. Some of the blog suggest updating flash player to 9.
It this is not case can you find some one who can address the problem
Marilyn LEvy
Moved your discussion to Presenter so that you get the correct solution.
With regards,
Prabhu
Hi
Try installing presenter 32bit for the office 32bit and presenter 64 bit for office 64bit.
Check this link : http://helpx.adobe.com/presenter/kb/presenter-install-issue.html
Sunil
Adobe Presenter Engg Team
Thanks I will try this
can you provide some help on this one
Running Adobe Presenter7.7 in power point 2010
Run-time error 2147467259(80004005) Slide Show Window (unknown member): invalid request. Automation right not granted
Hi
Try Following instruction provided here:
I hope this would help to resolve the issue.
Sunil
Adobe presenter Engg Team
I need help with error below
Hi
Please try the above posted steps.
The above provided link resolve the root cause for which "Automation right not granted issue".
Here is the link once again:
Sunil
Trying to do a report in Adobe when almost finish when almost finish it goes away and doesn't save the work
Hi
Please confirm if you are able to work on presenter now.
Was the provided link useful ??
Sunil
