1. Re: <td class="productItemNotFound">This catalog has no products.</td>
thetrickster888 Jul 18, 2013 12:07 AM (in response to displaythis)Hey man--
You can do this with a simple Regular Expression and some jQuery that looks for all text within your site or a certain element and replaces it with your own text.
Here's the javascript you can add to the end of your page near the closing </body> tag or in another javascript file you're already referencing. It must be included after jQuery is loaded on the page. You can include it in the HEAD of your page template if you wish but it must follow the jQuery library reference.
I'm using a site that has US (English) as the culture/language so my "catalogue" is spelled "catalog".. Just update the code below to match your version of catalogue. Also, I'm searcing the whole "body" element but you can be more specific if you wish. You can change the references to "body" to something else like "#content" or ".shop-layout" or whatever container has your text somewhere as child text node.
(function($){ $(document).ready(function() { var noProductsMessage = "Your no products message"; // You can use HTML markup if you escape quotes with a backslash // or if you use single quotes in HTML markup var noSubCatalogMessage = "Your no subcatalogs message"; // Update "This catalog has no products." message $("body").html( $("body").html() // Update "This catalog has no products." message .replace(/this catalog has no products\./gi, noProductsMessage) // Update "This catalog has no sub-catalogs." message .replace(/this catalog has no sub-catalogs\./gi, noSubCatalogMessage) ); }); })(jQuery);You'll notice the .replace() function uses the Regular expression.. you can update what's in between the
/and\./gito match the text you want to replace. It doesn't matter about capital letters since this RegEx works with all cases. You'll also notice I'm escaping the period:\.Periods are special characters in RegEx that means "any character" so if you just use
/this catalog has no products./giit will still match the period but i'm telling this regex to specifically match a period not any character.You can replace the variables with your messages and I added one for the "no sub-catalogs" message too since you'll likely want that as well. If you don't want to use it-- comment out that line by throwing a
//in front of that line of js.Best of luck. Here's the fiddle of it in action so you can play around with it and update catalog to catalogue if you need to: http://jsfiddle.net/thetrickster/k35qV/
2. Re: <td class="productItemNotFound">This catalog has no products.</td>
displaythis Jul 18, 2013 3:07 PM (in response to thetrickster888)Is it a bord - is it a plane - No its Super Trickster888. I will read in detail tomorrow -eyes closing
Thanks again
3. Re: <td class="productItemNotFound">This catalog has no products.</td>
thetrickster888 Jul 18, 2013 3:38 PM (in response to displaythis)It's a bord.
4. Re: <td class="productItemNotFound">This catalog has no products.</td>
displaythis Jul 19, 2013 2:55 AM (in response to thetrickster888)Sorry its was late - its the superman say - is it a bird ! is it a plane !...
