9 Replies Latest reply: Aug 12, 2013 8:41 AM by Xoco RSS
    how do you create & use global variables in edge animate?
    maulshre Community Member
      to retain previous value while being used between parent & child symbol ?
        • 1. Re: how do you create & use global variables in edge animate?
          AMULI Community Member
          Hi maulshre,
          1) Preceding the name of a variable with var makes it local.
          2) « Global » (but local to a symbol)  variable:
          You can define in the Stage.compositionReady event handler a function callable from somewhere else in the Stage symbol :
          instanceNum = function( eRollover)
            console.log( eRollover.target.getAttribute("id"));
          Then each of the instances on stage of a given symbol yellowRect (with instance names yellowRect1, yellowRect2, yellowRect3 and yellowRect4) can have a mouseover event handler which is a call to the global function :
          instanceNum( e);
          3) Truly global variable (accessible from every symbol) :
          Definition in a symbol (usually inside the Stage.compositionReady event handler, a good place for global stuff) :
          sym.globalFunction = function()
            // statements
          To call this function from another symbol :
          sym.getComposition().getStage().globalFunction();
          Here the variable holds a function, but it could hold a number, string, etc.
          Gil
          • 2. Re: how do you create & use global variables in edge animate?
            thanks for the response and listing various options...
            i'm trying to use your option3 to target cumulative addition of numbers with previous retained value whenever that function is called.
            eg, the statement within my globalFunction() is total=total+x. Here i'm facing two problems:
            Q.1 how to initialize total to 0 without including that in my function else my cumulative total will again get reset whenever the function is called?
            Q.2 Is there any specific format for passing a numeral value (x) in this function?
            • 3. Re: how do you create & use global variables in edge animate?
              Endoplasmic Community Member
              this will get ya done:
              Symbol.bindSymbolAction(compId, symbolName, "creationComplete", function(sym, e) {
                   var total = 0; //this is private
                   sym.globalFunction = function(value){
                        //this is global you can call it by getting an instance of the symbol ie. sym.getSymbol('whatever').globalFunction(5);
                       total += value;
              //Edge binding end
              • 4. Re: how do you create & use global variables in edge animate?
                For example, if you increment the variable by the number of the clicked instance and display this cumulative count in a text field :
                You must initialize your variable outside of the function.
                Stage.compositionReady event handler :
                total = 0;
                incrementByInstanceNum = function( eClick)
                  // console.log( eClick.target.getAttribute("id"));
                  // => "Stage_yellowRect1_RoundRect", "Stage_yellowRect2_RoundRect", etc.
                  var num = eClick.target.getAttribute("id").substr(16,1);
                  total += parseInt( num);
                  sym.$("total").html( "total " +total);
                See that thread for explanations about the use of the event objet (eClick here) :
                http://forums.adobe.com/message/5513055#5513055
                Each of the yellowRect<i>.click event handler :
                incrementByInstanceNum( e);
                Downloadable example here : https://app.box.com/s/aiysjhmvx8eb9do60s5u
                Gil
                PS : it's option 2, because there is no need to communicate between symbols,
                as the instances are all in the symbol Stage.
                • 5. Re: how do you create & use global variables in edge animate?
                  For some reason, you may actually need to call the function from inside another symbol (and not from the instances as before). New version of the same exercise with the following structure where each rectangle and the associated text is wrapped in a symbol object<i> :
                  To make the function accessible from another symbol, you add sym. (the parameter of substr() is also adapted to the new id)
                  total = 0;
                  sym.incrementByInstanceNum = function( eClick)
                    // => "Stage_object2_yellowRect2_RoundRect" for example
                    var num = eClick.target.getAttribute("id").substr(12,1);
                  Each of the object<i>.yellowRect<i>.click event handler becomes :
                  sym.getComposition().getStage().incrementByInstanceNum( e);
                  The link given above has been updated and now includes this second version.
                  Gil
                  • 6. Re: how do you create & use global variables in edge animate?
                    Thanks a tonne S. Amuli. Really appreciate your time and effort.
                    • 7. Re: how do you create & use global variables in edge animate?
                      You're welcome, Maulshre
                      I remember some time ago when all this made me crazy
                      Gil
                      • 8. Re: how do you create & use global variables in edge animate?
                        hee..hee ... i agree... considering i started just one week back...
                        • 9. Re: how do you create & use global variables in edge animate?
                          Xoco Community Member
                          Also you can get/set the values from a textbox (or rectangle element too) hidden or out of Stage:
                          // set or initialise values
                          sym.$("globalVariables").data("globalVariable1",0);
                          sym.$("globalVariables").data("globalVariable2","No");
                          sym.$("globalVariables").data("globalVariable3","red");
                          // get values
                          color = sym.$("globalVariables").data("globalVariable3");
                          Maybe is not elegant but it's simple and works fine.
                          http://www.w3schools.com/jquery/misc_data.asp
