Hey All,
I'm using a COM object to retrieve formatted information from
a database and move it into another query - long story.... I'm able
to retrieve 90% of the variables from the object class, but 3 or 4
variables error out when I try to access them; they throw the
following exception:
"The cause of this exception was that:
java.lang.IllegalArgumentException: Argument is not a remote
object: 3"
The value "3" is the correct value for the parameter I'm
calling so it's getting the information back; I don't know what's
causing the error. I think it might be that the com "get" function
is not returning a variant datatype - maybe it's specifying a
datatype... Could that cause this error?
Code..
QuerySetCell(dataStore,"yrd_analyst","#dLA.Analyst#",currRow);
QuerySetCell(dataStore,"ysd_cpd_rdl","#dLA.IniMRL#",currRow);
QuerySetCell(dataStore,"ysd_RdlValue","#dLA.IniMRL#",currRow);
QuerySetCell(dataStore,"ysd_cpd_rdl","#dLA.MRL#",currRow);
QuerySetCell(dataStore,"ysd_RdlValue","#dLA.MRL#",currRow);
QuerySetCell(dataStore,"ysd_mdlValue","#dLA.nMDL#",currRow);
QuerySetCell(dataStore,"ysd_cpdParmWetValue","#dLA.WetResult#",currRow);
dLA is the com object and all lines that aren't commented out
work... The dla.IniMRL always throws.... A few others in the object
have the same problem...I'm including a cfdump (some lines removed
'....' indicates) of the dla object so you can see that variable
IniMRL is in the the object under "get" and "put" properties...
cfdump of dLA
object of coldfusion.runtime.com.ComProxy
{7e14dd06-47b9-4177-bbb6-f9b212f7e481}
Methods :
QueryInterface([in]USERDEFINED, [out]VOID, [out, retval]VOID)
AddRef([out, retval]UI4)
GetIDsOfNames([in]USERDEFINED, [in]I1, [in]UINT, [in]UI4,
[out]I4, [out, retval]VOID)
GetAnalyteQuals([out, retval]VARIANT)
GetTypeInfoCount([out]UINT, [out, retval]VOID)
Invoke([in]I4, [in]USERDEFINED, [in]UI4, [in]UI2,
[in]USERDEFINED, [out]VARIANT, [out]USERDEFINED, [out]UINT, [out,
retval]VOID)
GetTypeInfo([in]UINT, [in]UI4, [out]VOID, [out, retval]VOID)
Release([out, retval]UI4)
Put Properties:
SourceResult([in]VARIANT, [out, retval]VOID)
SurLL([in]VARIANT, [out, retval]VOID)
SurrType([in]VARIANT, [out, retval]VOID)
ResultSolids([in]VARIANT, [out, retval]VOID)
RT([in]VARIANT, [out, retval]VOID)
tResult([in]VARIANT, [out, retval]VOID)
SpikeID([in]VARIANT, [out, retval]VOID)
UNC([in]VARIANT, [out, retval]VOID)
Storet([in]VARIANT, [out, retval]VOID)
SurrAID([in]VARIANT, [out, retval]VOID)
SurrAType([in]VARIANT, [out, retval]VOID)
nResult([in]VARIANT, [out, retval]VOID)
SpikeAAmount([in]VARIANT, [out, retval]VOID)
PrepRatio([in]VARIANT, [out, retval]VOID)
SurrAmount([in]VARIANT, [out, retval]VOID)
isQC([in]VARIANT, [out, retval]VOID)
cfpf([in]VARIANT, [out, retval]VOID)
HazLevel([in]VARIANT, [out, retval]VOID)
cfpi([in]VARIANT, [out, retval]VOID)
Alias0([in]VARIANT, [out, retval]VOID)
SurrAAmount([in]VARIANT, [out, retval]VOID)
Instrument([in]VARIANT, [out, retval]VOID)
FlagLevel3([in]VARIANT, [out, retval]VOID)
RpToMDL([in]VARIANT, [out, retval]VOID)
SurrAUnit([in]VARIANT, [out, retval]VOID)
Wrk([in]VARIANT, [out, retval]VOID)
AnalyteQuals([in]USERDEFINED, [out, retval]VOID)
AnalyteInfo1([in]VARIANT, [out, retval]VOID)
FlagLevel([in]VARIANT, [out, retval]VOID)
AnalyteOrder([in]VARIANT, [out, retval]VOID)
Analysis([in]VARIANT, [out, retval]VOID)
Units([in]VARIANT, [out, retval]VOID)
Decimals([in]VARIANT, [out, retval]VOID)
Analyzed([in]VARIANT, [out, retval]VOID)
Analyte([in]VARIANT, [out, retval]VOID)
Batch([in]VARIANT, [out, retval]VOID)
FiniVV([in]VARIANT, [out, retval]VOID)
FlagLevel4([in]VARIANT, [out, retval]VOID)
FlagLow([in]VARIANT, [out, retval]VOID)
SpikeType([in]VARIANT, [out, retval]VOID)
InitialUnits([in]VARIANT, [out, retval]VOID)
SurrConc([in]VARIANT, [out, retval]VOID)
cfi([in]VARIANT, [out, retval]VOID)
UseAirFactor([in]VARIANT, [out, retval]VOID)
InitialResult([in]VARIANT, [out, retval]VOID)
FlagLevel2([in]VARIANT, [out, retval]VOID)
Detect([in]VARIANT, [out, retval]VOID)
CSVQuals([in]VARIANT, [out, retval]VOID)
nMRL([in]VARIANT, [out, retval]VOID)
Extraction([in]VARIANT, [out, retval]VOID)
IniMDL([in]VARIANT, [out, retval]VOID)
EXTRACT([in]VARIANT, [out, retval]VOID)
IniVV([in]VARIANT, [out, retval]VOID)
AnalyteInfo4([in]VARIANT, [out, retval]VOID)
NoDilMDL([in]VARIANT, [out, retval]VOID)
NoDilResult([in]VARIANT, [out, retval]VOID)
nMDL([in]VARIANT, [out, retval]VOID)
Alias4([in]VARIANT, [out, retval]VOID)
AnalyteInfo3([in]VARIANT, [out, retval]VOID)
CASNumber([in]VARIANT, [out, retval]VOID)
AnalyteInfo5([in]VARIANT, [out, retval]VOID)
AnalyteInfo2([in]VARIANT, [out, retval]VOID)
MDA([in]VARIANT, [out, retval]VOID)
Initial([in]VARIANT, [out, retval]VOID)
MRLSolids([in]VARIANT, [out, retval]VOID)
nWetResult([in]VARIANT, [out, retval]VOID)
Matrix([in]VARIANT, [out, retval]VOID)
MSolvent([in]VARIANT, [out, retval]VOID)
SpikeAUnit([in]VARIANT, [out, retval]VOID)
MolWt([in]VARIANT, [out, retval]VOID)
Analyst([in]VARIANT, [out, retval]VOID)
TInitial([in]VARIANT, [out, retval]VOID)
RESP([in]VARIANT, [out, retval]VOID)
TrueValue([in]VARIANT, [out, retval]VOID)
isSurr([in]VARIANT, [out, retval]VOID)
FlagLevel1([in]VARIANT, [out, retval]VOID)
QDecimals([in]VARIANT, [out, retval]VOID)
Sample([in]VARIANT, [out, retval]VOID)
isISTD([in]VARIANT, [out, retval]VOID)
IniMRL([in]VARIANT, [out, retval]VOID)
Extracted([in]VARIANT, [out, retval]VOID)
Get Properties
SourceResult([out, retval]VARIANT)
SurLL([out, retval]VARIANT)
SurrType([out, retval]VARIANT)
ResultSolids([out, retval]VARIANT)
RT([out, retval]VARIANT)
tResult([out, retval]VARIANT)
SurrUnit([out, retval]VARIANT)
Rpt([out, retval]VARIANT)
WetResult([out, retval]VARIANT)
UNC([out, retval]VARIANT)
Storet([out, retval]VARIANT)
SurrAID([out, retval]VARIANT)
SurrAType([out, retval]VARIANT)
nResult([out, retval]VARIANT)
RESP([out, retval]VARIANT)
TrueValue([out, retval]VARIANT)
Dilution([out, retval]VARIANT)
PrepRatio([out, retval]VARIANT)
SpikeUnit([out, retval]VARIANT)
SpikeConc([out, retval]VARIANT)
SurrAConc([out, retval]VARIANT)
SpikeAmount([out, retval]VARIANT)
SpikeAType([out, retval]VARIANT)
SpikeAID([out, retval]VARIANT)
tWetResult([out, retval]VARIANT)
Alias3([out, retval]VARIANT)
SigFigs([out, retval]VARIANT)
PrepIUnit([out, retval]VARIANT)
SpikeAConc([out, retval]VARIANT)
isSurr([out, retval]VARIANT)
FlagLevel1([out, retval]VARIANT)
QDecimals([out, retval]VARIANT)
MRL([out, retval]VARIANT)
Sample([out, retval]VARIANT)
isISTD([out, retval]VARIANT)
IniMRL([out, retval]VARIANT)
Extracted([out, retval]VARIANT)
