I have a CFSELECT on the form and link to a query.
I would like to fill details information when user select thew option.
The option is at client side, since user select the option which I need pass my query to get information to fill on the details form on the same form.
I tried to use following JavaScripts which fill the details information, but browser goes to the page which I want to fill the details informaiton on the same form.
function FillInfo()
/*Fill Details Information*/
var url = 'ccdDetailsInfo.cfm?MyAccount=' + document.getElementById('frmEntry').lstNumber.value;
I tried to use iFrame, it works and fill on the same form, but everything under iFrame disappear like footer and all other controls in the table.
<iframe id="DetailsFrame" src="ccdDetailsInfo.cfm"</iframe>
I tried to use CFINCLUDE the file, but it does not take the paramter from client side.
The problem is the query paramter is server side query.
I am looking for a way can pass the client data to server parameter to run the query and to fill details form.
I did some reasearch for this on Google, but no luck,
If you can give me some link regarding pass parameters between client and CF server would be appreciated,
Iccsi,
jQuery("#product_id").val() -- is to get the value of selected option.
The value is concatenated to the "get_detail.cfm?product_id="
When get_detail.cfm is called, it will return a string as a "result" in the jQuery. Then, the result is inserted to the div tag which is "product_detail".
Go to jQuery documentation to learn more about ajax(), val(), and html(). The doc explains very clear and it has some examples how to use them.
Use HTML select instead of cfselect; and use AJAX instead of iFrame.
See this link: http://www.w3schools.com/jquery/ajax_ajax.asp
Replace url:"demo_test.txt" with e.g. url:"get_data.cfm"
Thanks for the message and help,
If I understand correctly, the sample read demo_test.txt and put the content on div1.
which I can read from external text file.
I want to pass my value on the select to my query parameter.
In this case, I need create an external file using my client page or I can read any variable on the demo_test.txt?
Please let me know if I am wrong,
Thanks again for helping,
Iccsi,
<!--- my_form.cfm --->
<script src="http://code.jquery.com/jquery-1.9.1.js"></script>
<script type="text/javascript">
jQuery(document).ready(function() {
jQuery("#product_id").change(function() {
jQuery.ajax({
url: "get_detail.cfm?product_id=" + jQuery("#product_id").val()
, type: "get"
, success: function(result) {
jQuery("#product_detail").html(result);
</script>
<form method="post" action="">
<select id="product_id">
<option value="1">Apple</option>
<option value="2">Banana</option>
<option value="3">Cherry</option>
</select>
<div id="product_detail"></div>
</form>
<!--- get_detail.cfm --->
<!--- You replace this with query --->
<cfswitch expression="#url.product_id#">
<cfcase value="1">My color is red.</cfcase>
<cfcase value="2">My color is yellow.</cfcase>
<cfcase value="3">My color is dark red.</cfcase>
<cfdefaultcase>Invalid product id</cfdefaultcase>
</cfswitch>
Thanks for the information and help,
If I understand correctly, jQuery create above link with parameter and
using CFINCLUDE to have get_detail.cfm in Product_Detail div that get_detail.cfm will accept #product_id parameter.
Iccsi,
Thanks a million for helping and information,
regards,
iccsi,
