23 Replies Latest reply: Sep 23, 2013 8:51 AM by A.T. Romano RSS
    PE11: default project settings = last used project ?
    fredowww66 Community Member
      I've read here somewhere (I can't find the thread again) that PE11 always uses as default project setting (so before a single clip is added to the assetspanel or timeline) the project settings of your last project ?
      Is this above correct ?
      In my  case PE11 always chooses 1080i 25 for new empty projects while my projects (and footage) are in 1080p50. So I every time has to choose new project / settings etc
      I want to reinstall PE11 (uninstall, ccleaner, reinstall and reconfigurate) after finishing my current project but I have to be shure first that PE11 uses as default project settings for empty new projects the last one that was used .. ?
        • 1. Re: PE11: default project settings = last used project ?
          Steve Grisetti CommunityMVP
          Premiere Elements will always default to the last settings you selected when you set up a project.
          • 2. Re: PE11: default project settings = last used project ?
            A.T. Romano Community Member
            fredowww66
            Let us talk specific to Premiere Elements 11 Windows. Focus on the program getting first grabs on the project preset in the new project dialog.
            When you open a new project, you are always going to have the Premiere Elements 11 project preset default of
            If NTSC setup: NTSC AVCHD Full 1080i30
            or
            If PAL setup: PAL AVCHD Full 1080i30
            Before you import the source media, you can go to File Menu/New/Project and the new project dialog and prove that to yourself.
            That is the case, regardless of
            whatever the project preset setting was for the last saved/closed project
            or
            whatever the project preset setting was for any unsaved/closed prior project
            When you drag the first video clip to the Timeline, the program is supposed to set the project preset to a match for the properties of your specific source media. And, if it cannot recognize a matching project preset for you, it gives you the default Full 1080i as your project preset which may not be the best for your project setting. That is when you do the manual set of the project preset (File Menu/New/Project).
            Premiere Elements 11 does not remember what you set for your last project preset in the new project dialog from new project to new project. But for a given project that is saved/closed/reopened, the project preset will remain as set by you or the program when that project was started.
            I have found that the program will remember from new project to new project what you set last for the the mode, that is, Quick versus Expert.
            And, I have found that the program has serious problems in regard to saved/closed/reopening with regard to features of Window Menu/Dual Monitor Workspace.
            On the other hand, when you look at versions earlier than 11, where the user gets first grabs at the new project dialog, that new project dialog will show the project preset that was set last and not its default of NTSC DV Standard or PAL DV Standard.
            Consequently, I do not believe you have any say in the matter. It is what it is.
            Please let me know if I have misinterpreted your questions on this. Also, please do not hesitate to ask if you need clarifiation on anything that I have written.
            Thanks.
            ATR
            • 3. Re: PE11: default project settings = last used project ?
              Thanks for your clear and detailed answer.  I - only if necessary ofcourse - wanted to do a reinstall because I'm thinking that PE11 is not working well on my pc (described in other thread http://forums.adobe.com/message/5478427#5478427).
              But 1080i seems to be the default setting before you load something, so that's cleared out than and is NOT a proove of malfunctioning of my installed version.
              I've now tried also that automatic resetting of the preset (by dragging first clip 1080p50 to timeline). Well, on my pc, nothing happens, PE11 don't place the clip on the timeline and there are also no errormessages etc.
              Manually set the preset with new project/new name is thus the only option I've got for starting a project 1080p50
              So I'm still in doubt if my install is ok ... ?
              • 4. Re: PE11: default project settings = last used project ?
                fredowww66
                Thanks for the follow up. I just want to make sure you are OK on the following.
                In Premiere Elements 11 when you open a new project (before you import media), the project preset in the new project dialog is NTSC AVCHD Full 1080i30 or PAL AVCHD Full 1080i25 (depending on whether you installed as PAL or NTSC). When you import your video file using Add Media/Files and Folders, the file goes into Project Assets. The project preset is still the 1080i Adobe default. In this route there is no automatic placement of the file directly on the Timeline. It is when you drag the first video file to the Timeline (with nothing previously put there) that the program is supposed to do it work of analyzing the file and deciding on and setting the appropriate match between the file properties and one of its project presets.
                Important: it is you who put the file on the Timeline, from Project Assets to Timeline.
                If you have AVCHD "1080p50", then it should be setting PAL AVCHD1080p50 once you have dragged that AVCHD 1080p to the Timeline. At that time, you can check Edit Menu/Project Settings/General and the reading for Editing Mode, Timebase, Frame Size to see if that is the case. For some files, the program recognizes and fits the file into one of its project preset. When that does not happen, it gives the project its default 1080i project preset which may not be in the best for your file and the project. That is when you set the project preset yourself via the File Menu/New/Project route.
                When you use the File Menu/New/Project route, you select the more appropriate project preset, but remember to put a check mark next to "Force Selected Project Setting on this Project" before you exit the new project dialog. Important to remember is that you do the manual setting of the project preset before you go to Add Media for the import into Project Assets from where you drag the file to the Timeline.
                It would be one parameter in your file properties that is creating a problem for the program which is preventing it from giving you the PAL AVCHD AVCHD 1080p50. Would it be possible for you to post a MediaInfo properties readout for one of these files?
                http://mediaarea.net/en/MediaInfo
                Before you do any deactivation, uninstalling, and reinstalling, please take another look at what I wrote and what I have just wrote to see if any of it sheds more light on the matter. Not so long ago I wrote a blog post on the accuracy of the Premiere Elements 11 project preset situation.
                http://www.atr935.blogspot.com/2013/04/pe11-accuracy-of-automatic-project.html
                Please review the above and let us know if any of it helped your situation.
                We will be watching for your progress.
                Thanks.
                ATR
                • 5. Re: PE11: default project settings = last used project ?
                  Hello,
                  thanks for yr answer but I only read it today (and I reinstalled PE11 2 days ago ...).
                  The de- and reinstall made a difference: when I drag now first clip from assets panel to timeline expertview the clip IS placed on the timeline (that was not the case before reinstall, nothing happened than, the clip wasn't placed on the timeline ...).
                  BUT even now PE11 stays than in his default project setting (pal 1080i) instead of 1080p like the clip is.
                  Mediainfo, I installed it already, so hereunder is the info from a standard clip.
                  I must say that I detect also another project settings problem. My camera (Panasonic HC-X 900) has several modes for the sound. When I use a lower mode for the sound (fe just stereo instead of standard 5.1 sound I have also the problem that I can not drag the clip to the timeline (nothing happens). I had already other clips (1080p) on the timeline, project was set manually to 1080p.
                  So probably soundcodecs of my cam and PE11 are not matching well ... ?
                  Here is mediainfo from a standardclip:
                  Algemeen
                  Complete name                            : D:\Fredo\Video\Basisvideo\Le Crotoy\00004.MTS
                  Format                                   : BDAV
                  Format/Info                              : Blu-ray Video
                  File size                                : 118 MiB
                  Duration                                 : 39s 345ms
                  Overall bit rate mode                    : Variabel
                  Overall bit rate                         : 25,1 Mbps
                  Maximum Overall bit rate                 : 28,0 Mbps
                  Video
                  Menu ID                                  : 1 (0x1)
                  Format                                   : AVC
                  Format/Info                              : Advanced Video Codec
                  Format profile                           : High@L4.2
                  Format settings, CABAC                   : Ja
                  Format settings, ReFrames                : 2 frames
                  Format settings, GOP                     : M=3, N=24
                  Codec ID                                 : 27
                  Duration                                 : 39s 320ms
                  Bit rate mode                            : Variabel
                  Bit rate                                 : 23,7 Mbps
                  Maximum bit rate                         : 25,0 Mbps
                  Width                                    : 1 920 pixels
                  Height                                   : 1 080 pixels
                  Display aspect ratio                     : 16:9
                  Frame rate                               : 50,000 fps
                  Color space                              : YUV
                  Chroma subsampling                       : 4:2:0
                  Bit depth                                : 8 bits
                  Scan type                                : Progressief
                  Bits/(Pixel*Frame)                       : 0.228
                  Stream size                              : 111 MiB (94%)
                  Audio
                  Menu ID                                  : 1 (0x1)
                  Format                                   : AC-3
                  Format/Info                              : Audio Coding 3
                  Mode extension                           : CM (complete main)
                  Format settings, Endianness              : Big
                  Codec ID                                 : 129
                  Duration                                 : 39s 360ms
                  Bit rate mode                            : Constant
                  Bit rate                                 : 384 Kbps
                  Channel(s)                               : 6 kanalen
                  Channel positions                        : Front: L C R, Side: L R, LFE
                  Sampling rate                            : 48,0 KHz
                  Bit depth                                : 16 bits
                  Delay relative to video                  : -40ms
                  Stream size                              : 1,80 MiB (2%)
                  Tekst
                  Menu ID                                  : 1 (0x1)
                  Format                                   : PGS
                  Codec ID                                 : 144
                  Duration                                 : 38s 816ms
                  • 6. Re: PE11: default project settings = last used project ?
                    fredowww66
                    Thanks for the follow up with the additional information which is very helpful. Here is my take on your situation. Please review.
                    Based on the above you have
                    1920 x 1080p50 5.1 channel
                    There is no 1920 x 1080p50 5.1 channel project preset, so Premiere Elements 11 automatic project preset setting is doing what it  typically does under that situation, that is, giving you its default of 1920 x 1080i25 Stereo.
                    In this instance, I would encourage you to set the Premiere Elements 11 project preset yourself manually before you import this 1080p50 5.1 footage. As is, you are left with the choice of PAL AVCHD AVCHD1080p50.
                    However, if you want to enhance your workflow in many ways, I would suggest that you create your own 1920 x 1080p50 5.1 channel project preset. When that is done, Premiere Elements 11 should have it available to use it for the automatic set. But, it opens far more workflow possibilities than just in the project preset. It should open the door for you to export your 1080p50 5.1 channel as 1080p50 5.1 channel. But, the 5.1 channel will not be Dolby Digital, but it will be 5.1 channel. Your opportunities will be for a file exported with
                    AAC 5.1 channel
                    and
                    Windows Media Audio 10 5.1 channel
                    I have done a lot of work in this area. Lots of details which can be found in my blog posts:
                    http://atr935.blogspot.com/2013/04/pe11-exporting-1080p50-or-1080p60-file.html
                    http://atr935.blogspot.com/2013/07/pe11-exporting-1080p25-or-1080p30-file.html
                    Hope you can use the information for your advantage.
                    Thanks.
                    ATR
                    • 7. Re: PE11: default project settings = last used project ?
                      I've created a 1920x1080p50 5.1 channel project setting. So on the soundtrack 5.1 is mentioned now when I select this setting with new project.
                      But you say "When that is done (creating this new preset), Premiere Elements 11 should have it available to use it for the automatic set."
                      Automatic set still doesn't work, APE stays in the default 1080i when I have an empty project and add 1 clip to assetpanel (and to the timeline) ...
                      I've noticed also that when I add a lot of footage  (all 1080p 50fr specifications like above)  to the assetspanel (for example for a new project) APE is "conforming" every clip ... ? You see than an timeindicator (graph line) in the screen right below with the text "conforming xxxx" where xxx is the name of the footageclip. I have a dutch version, so I don't know what is the english word for "conforming" but I guess it's the same in English.
                      Is this normal behaviour of APE 11 even when the project settings are OK or is this again an indication that projectsettings are not ok ... ?
                      • 8. Re: PE11: default project settings = last used project ?
                        Bill Hunt CommunityMVP
                        The Conforming of the Audio in the files IS normal. That Audio Stream (per each file) is Conformed to 48KHz 32-bit floating point for extremely accurate editing. This process creates the CFA files, which are what PrE will access on the Timeline, and then the PEK files for the Waveform Display. Let the Conforming process complete 100% for all Imported files, before doing any editing. This article goes into more detail: http://forums.adobe.com/message/3892177#3892177
                        Good luck,
                        Hunt
                        • 9. Re: PE11: default project settings = last used project ?
                          fredowww66
                          The expectations were not ever for the automatic Premiere Elements 11 automatic project presets always working for this or any other case. Please read on for the fuller details. After you review them, we can discuss what needs to be done to achieve your workflow goals if they have not been met.
                          When the program cannot fit your video to one of its project presets, it gives you its default for your program set up (NTSC or PAL). In your case that default would be PAL AVCHD Full HD1080i25 rather than changing that to PAL AVCHD AVCHD 1080p50 5.1 channel based on the properties of the first drag to the Expert workspace Timeline.
                          I believe that the program is defaulting because your video codec is "27" rather than avc1 which MediaInfo typically uses to designate the AVCHD (MPEG4 AVC/H.264) video codec. Often that Premiere Elements 11 automatic project selection will default if one or more of its parameters for choice is off. So, I suspect that Premiere Elements 11 is having difficulty identifying the video codec. So, I would set the project preset manually with File Menu/New/Project, setting for your PAL AVCHD AVCHD 1080p50 5.1 channel project preset. The important aspects of the project preset here are the frame size, frame rate, scan (field) type, and audio channels, that is 1920 x 1080, 50 frames per second, progressive, and audio 5.1 channel respectively.
                          So, manually set File Menu/New/Project
                          In the new project dialog, select PAL AVCHD AVCHD 1080p50 5.1 channel
                          Make sure to put a check mark next to "Force Selected Project Setting on this Project"
                          Exit the new project dialog.
                          Then use Add Media/Files and Folders/Project Assets
                          and then drag your 1080p50 5.1 channel to Expert workspace's Timeline
                          With any of these project presets with 5.1 channel in its description (whether created by you or Adobe), I would go with the manual setting of the project preset. The Premiere Elements 11 automatic setting of the project preset is not always correct, examples of this can be seen:
                          a. Importing AVCHD.mp4 5.1 channel that was exported from Premiere Elements.
                          Premiere Elements is labeling it "Mono" instead of 5.1 channel which it really is based on all independant video property readers. The automatic result would be project preset = PAL AVCHD AVCHD 1080p50 in your case. Not what you want.
                          b. Importing a 1080p50 Windows Media Video 9.wmv 5.1 channel that was exported from Premiere Elements. Here the automatic result would be project preset = PAL AVCHD Full HD1080i25. The program appears to be defaulting to its 1080i25 (in your case)  because it cannot class the Windows Media Video 9. Not wanted.
                          As I wrote in my blog post that I referenced earlier in this thread
                          4. It is highly recommended that you take control over setting up the Premiere Elements 11 project when you are using the sqpresets described. To do this, open to Premiere Elements 11 workspace, go to File Menu/New/Project and, in the New Project Dialog, select your 1080p50 5.1 channel or 1080p60 5.1 channel project preset. Make sure you put a check mark next to "Force selected Project Setting on this project" before you click OK. And, then move forward to Add Media and import of video with its 1080p50 5.1 channel properties. In the opened project, you should see a little "5.1" to the right of the name Audio 1 for that track.
                          Please review and then we can discuss this further.
                          As for the Premiere Elements 11 conforming, that is the program conforming the video and audio to its standards. For one thing, your video format and codec, BDAV and "27", may be factors versus the AVC format and avc1 typically seen to represent AVCHD (MPEG4 AVC/H.264) video compression. Please also refer to my blog post cited in an earlier post in this thread which mentions factors involved with the accuracy of the Premiere Elements 11 automatic project preset setting. There are all sorts of variations on what the Premiere Elements 11 automatic project preset set will and will not recognize correctly (or otherwise put...cannot put into a category based on its programmed criteria for the set).
                          ATR
                          • 10. Re: PE11: default project settings = last used project ?
                            pizzakid13 Community Member
                            interesting read. so there is a difference if you import you video through the "add media" vs. drag directly into the timeline. but it looks like that the program will adjust that dragged in video to fit as closely as possible to one of its presets and not to the manually set criteria?
                            • 11. Re: PE11: default project settings = last used project ?
                              pizzakid13
                              Please take another read related to your comment
                              If the Premiere Elements 11 feature of automatically setting the "right" project preset messes up, it does not do that in the name of giving you a "fit as closely as possible to one of its presets..."  It takes the easy way out and gives one result, namely, its default project preset of NTSC AVCHD Full HD1080i30 or PAL AVCHD Full HD1080i25 (depends on whether  your program was set up for NTSC or PAL).
                              I gave some examples in my blog post on the subject
                              The other side of the coin is that the user needs to know the properties of his/her source media so that he/she, unlike the program, makes the right choice to get off to a good start on the new project. With this information, then File Menu/New/Project for manual project preset followed by import of the source media via Add Media/
                              Hope that helps.
                              ATR
                              • 12. Re: PE11: default project settings = last used project ?
                                Is it normal, when you use 1920x1080p50 5.1 project settings that the audio effects do not work on 5.1 soundclips (if you drag an effect to the soundclip nothing happens) ?
                                My current project is in that preset and the audio effects doesn't work  on my original footage(sound).
                                I've added also other sound, like musicscore etc, and these are sometimes just normal stereo. On these soundclips audioeffects are working well.
                                • 13. Re: PE11: default project settings = last used project ?
                                  fredowww66
                                  My studies in my blog posts referenced have focused on the import and export for unedited 5.1 channel video as well as import of non 5.1 channel video and its export as 5.1 channel audio. I have not done a study on the editing opportunities for 5.1 channel video.
                                  What specific Premiere Elements audio effects are not working for your Timeline content of 1920 x 1080p50 5.1 channel?
                                  You bring up an interesting avenue to pursue. I will give this a look today for a variety of audio effects, the Adobe built in 5.1 channel project presets, and the special ones whose creation I suggested for export purposes.
                                  More later.
                                  ATR
                                  • 14. Re: PE11: default project settings = last used project ?
                                    They are ALL not working if I choose one and drag it to an audioclip 5.1. On the 'hover' moment the cursor is changing in forbidden sign.
                                    • 15. Re: PE11: default project settings = last used project ?
                                      fredowww66
                                      Took a quick look into the editing aspects of 5.1 channel in Premiere Elements.
                                      Let us start here.
                                      With a 1080p50 5.1 channel project preset and your 1080p50 5.1 channel file on the Premiere Elements 11 Timeline, can you keyframe the audio with the Audio Mix as well as with Adjust/Adjustment Palette/Volume?
                                      If you can, then we are together on that.
                                      If the issue resides with just the fx Effects/Audio Effects and you want to stay with Premiere Elements for an export (with 5.1 channel edit) to file saved to the computer hard drive, I may have a workaround.
                                      More later once I am sure that we are in sync on the Volume adjusts for 5.1 channel in this matter.
                                      ATR
                                      • 16. Re: PE11: default project settings = last used project ?
                                        I can change the volume with the rubberband on the timeline, I can also put keyframes on the timeline to change volume, direclty on timeline or with the volumesettings at the right screenbar. I think that last one is what you mean with palette/volume ?
                                        I've noticed another soundproblem; a wav fileclip that I already succesfull used in an other project (not 5.1 settings) and also plays well in windows media player doesn't play on my timeline. It also doesn't play in the asset panel (no sound, no error message).
                                        • 17. Re: PE11: default project settings = last used project ?
                                          fredowww66
                                          I am preparing the write up for a suggested workaround for editing 5.1 channel in Premiere Elements 11 Windows. I will have it ready for you to try out in a few hours.
                                          As the .wav (non 5.1 channel) sound problem, could you
                                          a. post the MediaInfo (tree view) properties readout
                                          for that or post a link to a small sample of the .wav for download here
                                          and
                                          b. indicate the project preset in use in Premiere Elements when this wav fails to play back.
                                          Thanks.
                                          ATR
                                          • 18. Re: PE11: default project settings = last used project ?
                                            fredowww66
                                            Here is the plan. Let us see if it works for you.
                                            Open Premiere Elements 11 and manually set the project preset to
                                            PAL
                                            AVCHD
                                            AVCHD 1080p50
                                            Import your 1080p50 5.1 channel
                                            Apply Audio Effects (as wanted) to the video from fx Effects. I used Audio Effect = PitchShifter with its Carton Mouse preset.
                                            Publish+Share
                                            Computer
                                            AVCHD
                                            with presets = MP4 - H.264 1920 x 1080p25
                                            under the Advanced Button/Video Tab and Audio Tab, set for a 1080p50 stereo export....
                                            Video Tab 1
                                            Audio Tab 1
                                            Now take the AVCHD.mp4 (1080p50 - Stereo) file and import that into a Premiere Elements 11 project with the
                                            manually set project preset = PAL AVCHD AVCHD 1080p50 5.1 channel.
                                            Publish+Share
                                            Computer
                                            AVCHD
                                            with Presets = MP4 - H.264 1920 x 1080p25
                                            under the Advanced Button/Video Tab and Audio Tab, set for a 1080p50 5.1 channel export...
                                            Video Tab 2
                                            Audio Tab 2
                                            This export's properties are confirmed by MediaInfo 1080p50 5.1 channel with the edit in of
                                            the PitchShifter audio effect.
                                            Please check it out and see if it works for you and is worth the workaround. There are a few variations on
                                            this basic idea. This is the unabridged version.
                                            Thanks.
                                            ATR
                                            • 19. Re: PE11: default project settings = last used project ?
                                              @AT Romano
                                              wav file answer
                                              a) Media info:
                                              Algemeen
                                              Complete name                            : D:\Fredo\geluiden\allerlei\boat_horn.wav
                                              Format                                   : Wave
                                              File size                                : 10,3 KiB
                                              Duration                                 : 2s 704ms
                                              Overall bit rate                         : 31,1 Kbps
                                              Audio
                                              Format                                   : MPEG Audio
                                              Format version                           : Version 2.5
                                              Format profile                           : Layer 3
                                              Codec ID                                 : 55
                                              Codec ID/Hint                            : MP3
                                              Duration                                 : 2s 704ms
                                              Bit rate                                 : 20,0 Kbps
                                              Channel(s)                               : 1 kanaal
                                              Sampling rate                            : 11,025 KHz
                                              Stream size                              : 6,60 KiB (64%)
                                              b) project preset
                                              AVCHD 1080P50 5.1 (pal)
                                              • 20. Re: PE11: default project settings = last used project ?
                                                A.T. Romano wrote:
                                                fredowww66
                                                PAL
                                                AVCHD
                                                AVCHD 1080p50
                                                Sorry, but I don't understand what you want to say with 'import yr 1080p50 5.1 channel' ?
                                                • 21. Re: PE11: default project settings = last used project ?
                                                  fredowww66
                                                  Thanks for looking into the suggestion.
                                                  What I wrote is what I want you to do. It will work.
                                                  To start...
                                                  1. You are going to set up the project preset manually. Open the program, immediately go to File Menu/New/Project and set the project preset = PAL AVCHD AVCHD 1080p50
                                                  (that is not a typing error....do not use the PAL AVCHD AVCHD 1080p50 5.1 channel)
                                                  Make sure that you have a check mark next to "Force Selected Project Setting on this Project" before exiting the new project dialog.
                                                  2. Then import your 1080p50 5.1 channel file. (that is not a typing error). You are taking your 1080p50 5.1 channel file into a Stereo based project where you will be able to edit the 5.1 channel audio on the Timeline. You cannot do this if the project preset were one with a 5.1 channel description.
                                                  Follow the rest of the instructions word by word. At the end of all of this, you should get an 1080p50 with edited 5.1 channel as verified by the MediaInfo readout.
                                                  Please do not hesitate to ask if you need further clarification on this.
                                                  It is really imagizing that you can get a 5.1 channel export from a stereo Timeline if you are using a project preset that includes 5.1 channel in its description. Please carry this through to completion to get the full impact of what I am suggesting.
                                                  Thanks.
                                                  ATR
                                                  • 22. Re: PE11: default project settings = last used project ?
                                                    A.T. Romano wrote:
                                                    fredowww66
                                                    .... Please do not hesitate to ask if you need further clarification on this.
                                                    I'm afraid I have too ...
                                                    "1080p50 5.1 channel file" is that my complete exported moviefile ... ?
                                                    In that case you will have to wait because my project isn't still finished yet, so I doesn't have an exported 5.1 file already ...
                                                    • 23. Re: PE11: default project settings = last used project ?
                                                      fredowww66
                                                      The validity of the rationale is proven in viewing the properties of the final export which should contain your original 1080p50 5.1 channel now with the edits to the 5.1 channel.
                                                      Workaround being, edit of 5.1 channel in stereo project...then edited file placed in a 5.1 channel project to get the 1080p50 5.1 channel. Details are as previously written and detailed.
                                                      You may want to test this out in a mini test run before the grand project.
                                                      Looking forward to your results.
                                                      Thanks for the follow ups.
                                                      ATR
