I have a form that allows users to add and delete rows om a table. This works fine while the user is viewing and editing the form, but when the form is saved and then reopened, previously deleted rows reappear. How can I make sure my deleted rows stay deleted?
The script for click for the delete button reads:
this.parent.instanceManager.removeInstance(this.parent.index);
Thank you for any insight into what is causing the deleted rows to reappear when the document is reopened.
Noam
Solved! Go to Solution.
Total Likes
This issue was resolved by associating a schema with the form which allowed the form to save state.
Total Likes
Is it a table? or just a repeating section? I am not sure if it makes a difference with tables, but on the repeating subforms there is a setting for the default number of instances - maybe this is causing the behavior? Otherwise, I don't know...back in previous versions I used xfa.form.remerge() after any instance manipulation - but I don't anymore.
Good luck.
Total Likes
Total Likes
Likes
Likes
Likes
