Hello,
I adopted a CF 9 web-application and we're receiving the Internal 500 Error on a submit from a form that has line items for a RMA.
The server originally only had Cumulative Hot Fix 1 on it and I thought if I installed Cumulative Hot Fix 4, I would be able to adjust the postParametersLimit variable in the neo-runtime.xml. So, I tried doing this, and I've tried setting the number to an extremely large number (last try was 40000), and I'm still getting this error. I've tried putting a <cfabort> on the first line on the cfm file that is being called, but I'm still getting the 500 error.
As I mentioned, it's a RMA form and if the RMA has a few lines say up to 20 or 25 it will work.
I've tried increasing the following all at the same time:
postParameterSize to 1000 MB
Max size of post data 1000MB
Request throttle Memory 768MB
Maximum JVM Heap Size - 1024 MB
Enable HTTP Status Codes - unchecked
Here's some extra backgroun on this situation. This is all that happened before I got the server:
The CF Server is installed as a virtual machin and was originally part of a domain that was exposed to the internet and the internal network. The CF Admin was exposed to the internet.
AT THIS TIME THE RMA FORM WORKED PROPERLY, EVEN WITH LARGE NUMBER OF LINE ITEMS.
The CF Server was hacked, so they did the following:
They took a snapshot of the CF Server
Unjoined it from the domain and put it in the DMZ.
The server can no longer connect to the internet outbound, inbound connections are allowed through SSL
Installed cumulative hot fix 1 and hot fix APSB13-13
Changed the Default port for SQL on the SQL Server.
This is when the RMA form stopped working and I inherited the server. Yeah!
Any ideas on what i can try next or why this would have suddenly stopped working after making the above changes on the server.
Thank you
Should we know what RMA means? Request for Medical Attention, perhaps?
Really Meaningless Abbreviation?
Adam
Hello,
Thank you for your post. Did you check the error logs?
Anit Kumar
Hello,
I checked the error logs right after the 500 error was thrown and I don't see any reference to that page or error at all. Is there some setting I'm missing that will show this error? Should I clear out the log pages?
Please disregard the RMA acronym. It's extra detail that's irrelevant to the issue.
Does anyone have any suggestions please?
Start from the beginning. Return to the default values, and see what happens. To do so, proceed as follows.
Temporarily shut ColdFusion down. Create a back-up of the file neo-runtime.xml, just in case.
Now, open the file in a text editor and revert postParametersLimit and postSizeLimit to their respective default values, namely,
<var name='postParametersLimit'><number>100.0</number></var>
<var name='postSizeLimit'><number>100.0</number></var>
That is, 100 parameters and 100 MB, respectively. (Note that there is no postParameterSize! If you had included that element in the XML, remove it.)
Restart ColdFusion. Test and tell.
Issue was resolved. Followed BKBK's suggestion to reset everything back...still got the 500 error with nothing in the error logs. I then changed postParametersLimit to 5000 ( I have to set this to a large number because some forms will be in the 1000's...I know this is a bad practice). Changed postSizeLimit to 300.0 and the forms work now.
