I've tried several times to install the new Flash player. For some reason the installer (and I've redownloaded it twice) doesn't think I've quite Safari, when I have. I've tried rebooting, quiting Safari before ever trying the installer, installing BEFORE I even open Safari on a fresh reboot.
The installer seems to have a bug in it's ear that I'm using Safari when I'm not.
Grrumbles.....
Any help appreciated ^^
Might be the process for safari is running in background, try this.
check in activity moniter can you see safari there, if yes than do quit process.
Ah! That was a great tip.
It turned out the Gmail Tab link was still open and that extension running was causing Safari to stay active.
Thanks so much!!!
Yers, a great tip and it worked ! Thanks to you both.
Oh, dear, still being called to be quit ! What might I do next ?
Check with the Activity Monitor.
press the apple icon in top left of your screen, select force quit, and then close safari.
