I have several CFX tags written in Delphi. I want to port them over to CF 10 64 bit.
From what I can tell, it is not supported. CF 64-bit will not load the 32-bit dlls. Delphi CFX dlls require a file called cfxapid.pas. This file has assembly language stuff, which I do not fully understand, and would need to be converted to 64-bit assembly. There may be other hurdles.
Am I correct that this is just not supported? And never going to be supported?
George
George,
As far as I know it's not possible to mix 32bit code and 64bit code inside
a single process. You can create a 32bit wrapper around the CFX and use
inter-process communication or something of that sort (or a 32bit
ColdFusion in a virtual machine or maybe Railo 4).
On Tue, Jun 11, 2013 at 5:28 PM, George49085utrdf
I am interested in a clean, simple solution: compiling a 64 bit Delphi dll. I think I need a modified cfxapid.pas to do so.
If the only alternatives are more complicated than that, I'd rather go back to a 32 bit OS.
I don't think it's as easy as recompiling for 64bit. Pointer sizes are
different and the inline assembler might need updating also.
I think the 32bit ColdFusion is the quicker solution.
On Tue, Jun 11, 2013 at 6:03 PM, George49085utrdf
Quicker - surely.
Let me pose my questions again. Am I correct that this is just not supported? And never going to be supported?
It's not supported
Never say never but I think in this case it's never :).
Mack
Use the following updated cfxapid.pas file to create 64-bit CFX tags with Delphi.
{$R-,Q-,X+,W-,D-,L-,Y-}
{ Cold Fusion extensions classes for Delphi (CFX_D) }
{ originally by Leonid Fofanov lfofanov@hotmail.com }
{ modified for unicode by George Wynne george@nssco.com 11/23/2010 }
{ modified for 64-bit by Dima Bayer dima077@gmail.com 07/09/2013 }
ColdFusion calls the entry function of c++ CFX_tag with parameter - c++ object.
This object includes callback functions that can be called by CFX_tag and executed
by ColdFusion. When CFX_tag is written in c++ these function can be called directly.
If a CFX_tag is written in Delphi those function cannot be called directly. Their
address should be extracted before calling them. This is done by 4 assembly functions:
callMethod0, callMethod1, callMethod2, callMethod3.
Every c++ object that has at least one virtual function, includes
pointer to virtual table. This pointer value can be found at the
zero address of an object.
The structure of virtual table of c++ objects received from ColdFusion:
Cell Number * Function * Offset in bytes in x86 * Offset in bytes in x64
1 * virtual destructor * 0 * 0
2 * virtual function one * 4 * 8
3 * virtual function two * 8 * 16
4 * virtual function three * 12 * 24
The algorithm for extracting and calling those callback virtual functions is:
1)Access pointer of the virtual table.
2)Get the first address of virtual table
3)Get the address of an appropriate virtual function.
4)Call the virtual function
These manipulations are done by 4 assembler functions of class TCFXBaseClass:
unit cfxapid;
interface
const
CFX_STRING_NOT_FOUND = -1;
type
// Basic wrapper class, translates Pascal methods calls to C++ methods calls.
// All other classes in this file inherit from this class.
TCFXBaseClass = class
private
function callMethod0(index: int64): int64;
function callMethod1(parm1, index: int64): int64;
function callMethod2(parm1, parm2, index: int64): int64;
function callMethod3(parm1, parm2, parm3, index: int64): int64;
end;
TCFXStringSet = class(TCFXBaseClass)
function AddString(S: PAnsiChar):integer;
function GetCount: integer;
function GetString(Index: integer): PAnsiChar;
function GetIndexForString(S: PAnsiChar): integer;
end;
TCFXQuery = class(TCFXBaseClass)
function GetName: PAnsiChar;
function GetRowCount: integer;
function GetColumns: TCFXStringSet;
function GetData(Row, Column: integer): PAnsiChar;
function AddRow: integer;
procedure SetData(Row, Column: integer; Data: PAnsiChar);
end;
TCFXException = class(TCFXBaseClass)
function GetError: PAnsiChar;
function GetDiagnostics: PAnsiChar;
end;
TCFXRequest = class(TCFXBaseClass)
function AttributeExists(AttrName: PAnsiChar): boolean;
function GetAttribute(AttrName: PAnsiChar): PAnsiChar;
function GetAttributeList: TCFXStringSet;
function GetQuery: TCFXQuery;
function GetSetting(SettingName: PAnsiChar): PAnsiChar;
procedure Write(S: PAnsiChar);
procedure SetVariable(Name: PAnsiChar; Value: PAnsiChar);
function AddQuery(Name: PAnsiChar; Columns: TCFXStringSet): TCFXQuery;
function Debug: boolean;
procedure WriteDebug(Output: PAnsiChar);
function CreateStringSet: TCFXStringSet;
procedure ThrowException(Error, Diagnostics: PAnsiChar);
procedure ReThrowException(e: TCFXException);
procedure SetCustomData(Data: pointer);
function GetCustomData: pointer;
end;
implementation
// TCFXBaseClass class
//call c++ virtual function without parameters
//index - offset in bytes to the appropriate c++ function in c++ virtual table
function TCFXBaseClass.callMethod0(index: int64): int64;
asm
//Shadow space - at a minimum, each function must reserve
//32 bytes (four 64-bit values) on the stack.
push rbx
push rbx
push rbx
push rbx
mov rax, Self
mov rbx, [rax]
call qword ptr [rbx+rdx] //pointer to c++ virtual table + index
pop rbx
pop rbx
pop rbx
pop rbx
end;
//call c++ virtual function with one parameter
//parm1 - parameter to pass to c++ function
function TCFXBaseClass.callMethod1(parm1: int64; index: int64): int64;
asm
push rbx
push rbx
push rbx
push rbx
mov rax, Self
mov rbx, [rax]
//parm1 is passed in rcx as in Pascal
call qword ptr [rbx+r8] //pointer to c++ virtual table + index
pop rbx
pop rbx
pop rbx
pop rbx
end;
//call c++ virtual function with 2 parameters
//parm1, parm1 - parameters to pass to c++ function
// in c++ virtual table
function TCFXBaseClass.callMethod2(parm1, parm2, index: int64): int64;
asm
push rbx
push rbx
push rbx
push rbx
//Self assignment
mov rax, Self
mov rbx, [rax]
//parm1 and parm2 are passed to c++ exectly as in Pascal in x64
call qword ptr [rbx+r9] //pointer to c++ virtual table + index
pop rbx
pop rbx
pop rbx
pop rbx
end;
//call c++ virtual function with 3 parameters
//parm1, parm2, parm3 - parameters to pass to c++ function
function TCFXBaseClass.callMethod3(parm1, parm2, parm3, index: int64): int64;
asm
push rbx
push rbx
push rbx
push rbx
//Self assignment
mov rax, Self
mov rbx, [rax]
mov rax, index
//parm1, parm2 and parm3 are passed to c++ exectly as in Pascal in x64
call qword ptr [rbx+rax] //pointer to c++ virtual table + index
pop rbx
pop rbx
pop rbx
pop rbx
end;
// TCFXRequest class
function TCFXRequest.AttributeExists(AttrName: PAnsiChar): boolean;
begin
Result:=boolean(callMethod1(int64(AttrName), 8));
end;
function TCFXRequest.GetAttribute(AttrName: PAnsiChar): PAnsiChar;
var
returnedString : PAnsiChar;
begin
returnedString := PAnsiChar(callMethod1(int64(AttrName), 16));
Result:=returnedString;//PAnsiChar();
end;
function TCFXRequest.GetAttributeList: TCFXStringSet;
begin
Result:=TCFXStringSet(callMethod0(24));
end;
function TCFXRequest.GetQuery: TCFXQuery;
begin
Result:=TCFXQuery(callMethod0(32));
end;
function TCFXRequest.GetSetting(SettingName: PAnsiChar): PAnsiChar;
begin
Result:=PAnsiChar(TCFXQuery(callMethod1(int64(SettingName), 40)));
end;
procedure TCFXRequest.Write(S: PAnsiChar);
begin
callMethod1(int64(S), 48);
end;
procedure TCFXRequest.SetVariable(Name: PAnsiChar; Value: PAnsiChar);
begin
callMethod2(int64(Name), int64(Value), 56);
end;
function TCFXRequest.AddQuery(Name: PAnsiChar; Columns: TCFXStringSet): TCFXQuery;
begin
Result:=TCFXQuery(callMethod2(int64(Name), int64(Columns), 64));
end;
function TCFXRequest.Debug: boolean;
begin
Result:=boolean(callMethod0(72));
end;
procedure TCFXRequest.WriteDebug(Output: PAnsiChar);
begin
callMethod1(int64(Output), 80);
end;
function TCFXRequest.CreateStringSet: TCFXStringSet;
begin
Result:=TCFXStringSet(callMethod0(88));
end;
procedure TCFXRequest.ThrowException(Error, Diagnostics: PAnsiChar);
begin
callMethod2(int64(Error), int64(Diagnostics), 96);
end;
procedure TCFXRequest.ReThrowException(e: TCFXException);
begin
callMethod1(int64(e), 104);
end;
procedure TCFXRequest.SetCustomData(Data: pointer);
begin
callMethod1(int64(Data), 112);
end;
function TCFXRequest.GetCustomData: pointer;
begin
Result:=Pointer(callMethod0(120));
end;
// TCFXStringSet class
function TCFXStringSet.AddString(S: PAnsiChar):integer;
begin
Result:=callMethod1(int64(S), 8);
end;
function TCFXStringSet.GetCount: integer;
begin
Result:=callMethod0(16);
end;
function TCFXStringSet.GetString(Index: integer): PAnsiChar;
begin
Result:=PAnsiChar(callMethod1(Index, 24));
end;
function TCFXStringSet.GetIndexForString(S: PAnsiChar): integer;
begin
Result:=callMethod1(int64(S), 32);
end;
// TCFXQuery class
function TCFXQuery.GetName: PAnsiChar;
begin
Result:=PAnsiChar(callMethod0(8));
end;
function TCFXQuery.GetRowCount: integer;
begin
end;
function TCFXQuery.GetColumns: TCFXStringSet;
begin
end;
function TCFXQuery.GetData(Row, Column: integer): PAnsiChar;
begin
Result:=PAnsiChar(callMethod2(Row, Column, 32));
end;
function TCFXQuery.AddRow: integer;
begin
Result:=callMethod0(40);
end;
procedure TCFXQuery.SetData(Row, Column: integer; Data: PAnsiChar);
begin
callMethod3(Row, Column, int64(Data), 48);
end;
// TCFXException class
function TCFXException.GetError: PAnsiChar;
begin
end;
function TCFXException.GetDiagnostics: PAnsiChar;
begin
Result:=PAnsiChar(callMethod0(16));
end;
end.
Postscript: CF 10 64 bit on WS 2008 was never stable for me. It crashed about once a week. I'm pretty sure it is unrelated to these dlls. I had a problem that a lot of other people had as well: http://forums.adobe.com/thread/1016323?start=40&tstart=0
I installed the latest update (11).I tried this: http://blogs.coldfusion.com/post.cfm/tuning-coldfusion-10-iis-connector-configuration. I eventually gave up.
I'm back to 32 bit. I don't recommend 64 bit CF 10 for anyone.
Still, maybe the code will be useful to someone someday.
