Unable to run ColdFusion after installing - produces terminal screen then exits
Jul 21, 2013 Jul 21, 2013
I have installed coldfusion to C:\ColdFusion10. When I run C:\ColdFusion10\cfusion\bin\coldfusion.exe, a terminal appears and immediately exits. Nothing else happens. What does this mean?
If it matters, I'm using the Windows 7 64 bit version.
822
Guide , Jul 21, 2013 Jul 21, 2013
Run services.msc is "ColdFusion 10 Application Server" running?
What happens browser http://127.0.0.1:8500/cfide/administrator/index.cfm ?
HTH, Carl.
Guide ,
Steven, try from cmd prompt as administrator cf10\cfusion\bin\cfstart
HTH, Carl.
I get similar results, with the message shown in http://puu.sh/3IlfP.png. I was expecting to see a graphical interface for the software to edit with ColdFusion. Was I running the wrong product?
Guide ,
HTH, Carl.
Adobe Employee ,
Hello Steven,
Just adding to Carl's point,
1. Launch Command prompt as Administrator
2.          Browse to cf_root\cfusion\bin and run the following command coldfusion.exe -start -console.
3.          Try to access the CF admin, once the services are started.
In case it gives an error message, please share the same.
Anit Kumar
Jul 22, 2013 Jul 22, 2013
Can you also check, is there any error in C:\Adobe\ColdFusion10\Adobe_ColdFusion_10_Install_....log? If so please share the error snippet..
Kaif Akbar
The product seems to work. Thank you.
Documentation
