I have only seen one post on this forum where loading the MASTPlugin.swf is explained. The example goes something like this (I changed it a little bit as I have the MASTPlugin.swf running from my deploy location on localhost).
var parameters =
src: "rtmp://cp67126.edgefcs.net/ondemand/mediapm/stro be/content/test/SpaceAloneHD_sounas_640_500_short",
// Set asset level metadata. In this case it's the uri to the mast document which we need to set on the http://www.akamai.com/mast/1.0 namespace
// (mast string in src_mast_uri is simply an alias)
src_namespace_mast:"http://www.akamai.com/mast/1.0",
src_mast_uri:"http://mediapm.edgesuite.net/osmf/content/mast/mast_sample_onitemstart .xml",
// Load the mast plugin
plugin_mast:"http://osmf.org/dev/1.5gm/MASTPlugin.swf"
However is it possible to load VAST 2.0 using the MASTPlugin.swf at all ?
I have been successful setting up to some extent loading of VAST into Strobe by integrating Strobe with the code found in VASTSample.as; but would much prefer the plugin route.
Is there a different namespace and way to do the above?
Thank...Thomas
